Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 123
Thread: Dynamic Chassis Control Retrofit
  1. #91
    May 2017
    Thanks. I’ll check that out.
  2. #92
    May 2017
    Ok, flashed the unit with Golf Clubsport dataset just to finish the project. Ran the basic setting for the system and now everything is working as should.
    BUT, I don't have DCC option in the drive select..... So bad news for darkchina.
    So some more investigation is needed. I'm 100% sure it's a coding issue, not FeC issue. The damping changes when I change between normal and sport mode, that is very clearly felt, but there's no comfort option and there's no DCC option in individual.
    Hmmm... I think I need to check one thing, maybe this is a dataset issue to gateway and not coding one...
    Anyway's here's the current autoscan. Nice and almost error free The fuel tank flap is due to freezing temps here.
    Tuesday,28,January,2020,20:24:45:18875
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
    VIN: WVGZZZ5NZHW310427   License Plate: ---
    Mileage: 86041km-53463mi   Repair Order:
    Chassis Type: 5N-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 22 29 39 3C 42 44 47
              52 55 5F 69 6C 6D A5 BB BC CF D6 D7
    VIN: WVGZZZ5NZHW310427   Mileage: 86041km-53463miles
    Address 01: Engine (J623-DFHA)       Labels:. User\04L-907-309-V1.lbl
       Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
       Component: R4 2.0l TDI   X24 3015
       Revision: B4X24---
       Coding: 0125003A04761D082000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01104L906026EJ 004002
       ROD: EV_ECM20TDI01104L906026EJ_004.rod
       VCID: 76B5E6CBA843A607E3B-8022
       Part No SW: 0DL 300 011 A    HW: 0DE 927 711
       Component: GSG DQ500     H12 1449
       Revision: 00H12V32
       VCID: 2615F68B3863968793B-8072
       Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
       Component: ESC           H25 0507
       Revision: 00000000    Serial number: 61576000000096
       Coding: 0AEE6B9A54210B6C477B670262CA4950D62AD0E2E646927D386250F8C2AA02
       VCID: 78A9E8F3A257D077F17-802C
       Part No SW: 5NA 907 044 L    HW: 5NA 907 044 L
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000B00147934
       Coding: 0002010420411101110510400010102A
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 48C95833923760F7417-801C
       Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
       Serial number: 02001616700623
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA5FEEB8073EE47BBB-802A
       Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 160523  033 0372
       Serial number: 00000001605180309405
       Component: RLHS  037 0059
       Serial number: S5Y16M06D13H18M41S51
       Coding: 03A8DD
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                        Reset counter: 123
                        Time: 00:00:00
       Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0029
       Serial number: 002605167478042
       Coding: 0231567A51
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3C2134E3D6EF3C57D5F-8068
    Address 13: Auto Dist. Reg (J428)       Labels:| User\2Q0-907-572.lbl
       Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0155
       Coding: 320C47DB1CFF8728749C8065304085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001010
       ROD: EV_ACCMRRCONTIVW376_001.rod
       VCID: 392F2DF7D9DD097FCE9-806C
       Serial number: 17011741350132
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 382928F3E2D71077317-806C
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR1V63SC
       Coding: 98CCC0C00C0000005C5400CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B053AAE7E837597-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5NB857705C0161Q00678
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5NB857706C0166Q00679
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 357000000000741C4C1D
       Subsystem 4 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 358000000006741C4C1K
       Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 3510001BD20FC483F79N
       Subsystem 6 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 3520001BD20FC483D309
       Subsystem 7 - Part No SW: -----------    HW: 480 401 206 16
       Serial number: 3550001BD20FC482B3CL
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001AF20FC483447B
       Subsystem 9 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001AF20FC484462A
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001C120FC48557F6
       Subsystem 11 - Part No SW: -----------    HW: 480 000 906 16
       Serial number: I0M00000000F9A6DEB1X
       Subsystem 12 - Part No SW: -----------    HW: 480 000 906 16
       Serial number: I0N00000000689188B17
       Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160617400541
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 41DF4517B10D51BF869-8014
    Address 17: Instruments (J285)       Labels:| User\5G0-920-XXX-17.lbl-SRI3
       Part No SW: 5NA 920 790 A    HW: 5NA 920 790 A
       Component: KOMBI         405 2153
       Coding: 07A500087F88000801883B0B1401000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 40D94013BA0758B7897-8014
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 123
                        Mileage: 86018 km
                        Date: 2020.01.27
                        Time: 19:16:08
    Address 18: Aux. Heat (J364)       Labels:| User\5Q0-963-272.lbl
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3A2D32FBDCDB0267C73-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000050175
       Revision: --------    Serial number: 0005002497
       Coding: 030500341F087300FB87225E1E0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F4E3966FFC5795F-8028
       Serial number: 29160001037370086211
       Coding: 2DFFFF
       Serial number: 8958780404
       Serial number: HA1-00002.04.16
       Coding: 0101
       VCID: 4ACD623B8C3B92E7573-801E
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH05 0012
       VCID: 45D75107A5257D9FBA1-8010
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
       Component: MRR1Rear      H21 0510
       Revision: --------
       Coding: 16C002
       Shop #: WSC 00046 000 00000
       Serial number: 300516EEU15285
       Coding: 003F0B20D000048000001000
       VCID: 43D34F1FAB1143AF945-8016
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000860713
       Coding: 01010011004001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
       VCID: 3D2739E7CDF5355FE21-8068
    Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
       Part No SW: 3Q0 035 466 C    HW: 3Q0 035 466 C
       Component: MIB2_amp_P_VW H45 0210
       Revision: 00000001    Serial number: VWZ8Z1GAT00N6GR
       Coding: 1284010001A00A2AAA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       VCID: 2F3B13AF1799D7CF60D-807A
       Serial number: 220516EEL28614
       Coding: 003F0120DE00048000001000
       VCID: 42DD4A1BB40B4AA79F3-8016
    Address 55: Headlight Range (J745)       Labels:| User\7P6-907-357.lbl
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0051
       Coding: 08A200104B200201
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
       Part No SW: 3Q0 035 840 B    HW: 3Q0 035 840 B
       Component: MU-S--ER      710 0757
       Coding: 02730600000000005111000200080A001F0106E40120000003
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2A0D02BB2C7BB2E7B73-807E
       Subsystem 1 - Part No SW: 7C0 919 606     HW: 7C0 919 606
       Component: ABT_HIGH  H54 1031
       Serial number: VWZ8Z9SGY005RH
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0407247491
       Coding: 0100000202000000
       VCID: 3B2337FFD3E13B6FDC5-806E
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 01230601A3002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       VCID: 77ABEBCFAF49DF0FF8D-8022
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30718393900000
       Coding: 0A80
       ASAM Dataset: EV_DeckLidCONTIAU736 001012
       VCID: 3FDB43EFC7F9274FF0D-806A
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| User\3Q0-980-65X-A5.lbl
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H06 0272
       Serial number: 07061611K13443
       Coding: 000307060000040101220047C056890088000E200040
       Shop #: WSC 25768 001 104857
       Serial number: 030616EF218555
       Coding: 002E01200101048000001000
       Serial number: 190516EEI19186
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
       Revision: --------
       Coding: 16C002
       VCID: 372B2BCFEFC91F0F38D-8062
       VCID: 1675C64B8803060703B-8042
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 02:03, VBatt start/end: 12.1V/12.1V)-----------
    EDIT :
    Got confirmation from a reliable source that DCC is not a separate FeC along with drive modes. DCC will appear when everything is correctly coded and adapted.
    Could be that as I now have Golf dataset in the DCC module, it's not compatible with the Tiguan drive profiles and thus is the reason it's not showing there.
    I bought another DCC module from breakers in Germany for a whopping 25€ which is from an identical car as mine. Let's see if that works any better. Of course I need to do a new basic setting but that was piece of cake. I used a DIY garage which has a pillar lift. Took less than 20 minutes to do.
  3. Likes jyoung8607, Uwe liked this post
  4. #93
    Feb 2018
    SLC
    I'm not sure if this has been mentioned yet, but is there a driving profile bit in the CAN gateway coding for DCC?
    I had to enable one for AFS to get it to show up on my drive mode settings when I retrofitted my headlights, so I wonder if that applies here as well.
    EDIT:
    glad you are making progress. if you use experimental coding you will find a bit in the gateway that has DCC in the description, it's in german so no clue on what it does. I enabled it and the gateway did not complain, and we happen to have the very same gateway.
    that would be the one^^^ its labelled FPA_FUNKTION_DCC
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
  5. #94
    Apr 2018
    ITALY
    I enabled that very bit but didn't get the menu, but my shocks were still disconnected so no basic settings yet.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  6. #95
    Feb 2018
    SLC
    ^^ I wonder if it will show up after Basic Settings have been completed.
  7. #96
    Apr 2018
    ITALY
    @downtime
    can you also describe how to perform basic settings? I know the car has to be lifted from ground with all 4 wheels hanging. then? what entry you selected in what menu? was VCDS enough or ODIS was needed?
  8. #97
    May 2017
    Yes, exactly like that. I used pillar lift to lift the car up so that all four wheels were hanging. I used ODIS to do the basic settings. Easiest is to click on the basic setting on the test list it proposes on start. Then follow on screen instructions.
    Basic settings take 20 seconds
    @Somnus. Thank you. I’ll check that. I could not see that exact bit in experimental coding. There was something like FPA_stxxxDCC.
    @darchina811, you wrote on one of the earlier posts "DCC and I enabled BYTE 9 BIT 7 in gateway experimental coding." So is that the same one Somnus is writing about?
    I need to check this again.
  9. #98
    Apr 2018
    ITALY
    yeah I assume so. it is kind of obvious, it's the only one that says "something DCC".
  10. #99
    May 2017
    Yep, but seems that it's not that. I got advice from another location as well that DCC bit needs to be enabled in gateway and let the gateway go to rest state to actually take the change into use. But, what is the actual DCC bit?
    I compared the coding to a coding of a car with DCC, and that car did not have that something something DCC bit enabled either.
    So I'm puzzled, but not worried. Eventually this will sort out.
    Edit:
    The bit is labeled FPA_function_StufenDCC. What does Stufen mean this context?
  11. #100
    Have you maybe tried Byte 12 Bit 7 in CAN Gateway coding ?
    Stufen, is steps, I would guess.
  12. Likes downtime, jyoung8607, Uwe liked this post
