Results 1 to 8 of 8
Thread: Amarok 2H Back-up cam retrofit trouble
    Feb 2016
    Norway
    Hello.
    I did retrofit Back-Up cam and a Pioneer head-unit to my Amarok. To do this I ordered a retrofit-kit for the camera similar to the one Kufatec sells (intended for the RCD-510). Then I ordered a conversion cable kit for the Pioneer head-unit. And another conversion-kit to connect "original" back-up camera to the Pioneer.
    I then activated module 6C in CAN gateway list. Did the coding for the module, and I the camera works somehow as expected. My problem is that I can't get the calibration to register.
    I go in to module 6C. Choose Security-Access and enter the pin as stated in the pop-up. It is accepted, so I go in to Adaptation, and follow the steps ending in changing value from 0 to 1 in the last step. All steps are accepted. I clear the fault-code, and go back in to fault-codes. The same error comes back.
    Anyone able to help me? Any steps I missed?
    Autoscan:
    Tuesday,14,January,2020,17:12:58:39202
    VIN: WV1ZZZ2HZCA064485   License Plate: RK77259
    Mileage: 23120km-14366mi   Repair Order: 03
    Chassis Type: 2H-VN81 (6N0)
    Scan: 01 03 08 09 15 17 18 19 22 25 32 56 69 6C 77
    VIN: WV1ZZZ2HZCA064485   Mileage: 23120km-14366miles
    56-Radio -- Status: Not registered 0011
    77-Telephone -- Status: Not registered 0011
    Address 01: Engine (J623-CDCA)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 FA    HW: 03L 907 309 K
       Component: R4 2.0l BTD   X43 9978
       Revision: 26X43---    Serial number: 00000000000000
       Coding: 01194012232600080000
       Shop #: WSC 26214 051 00000
       ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
       ROD: EV_ECM20BTD01103L906019FA_004.rod
       VCID: 6FBBD41B57149E5F20D-803A
    Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
       Part No SW: 2H0 907 379 G    HW: 2H0 907 379 D
       Component: ESP MK25A XT  H44 0106
       Revision: 00H44001
       Coding: B07324B6919A0D9924A689AB6F5510
       Shop #: WSC 07456 790 49164
       VCID: 34311B777E32FD871DF-8060
       Part No SW: 2H0 907 047 C    HW: 2H0 907 047 C
       Component: Climatic-T5   H19 0404
       Revision: 00001007
       Coding: 0000000002
       Shop #: WSC 07456 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 2809FF07B27A8967A17-807C
       Part No SW: 6R7 937 087 K    HW: 6R7 937 087 K
       Component: PQ25 BCM      H27 0532
       Revision: -1------    Serial number: 1009009900
       Coding: 2C0000380C01000000280C103C4B94D50080410E60020000300000000000
       VCID: 4CC1639706C2854765F-8018
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3321
       Coding: 100000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3321
       Coding: 100000
       Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H09 0013
       Serial number: 0061349
       Coding: 020000
       Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
       Component: VW10Airbag00B H07 0013
       Revision: --------    Serial number: 003HN007CSEI
       Coding: 000000000000000000000000000000003042
       Shop #: WSC 07446 790 50316
       VCID: 3333186B7BBCFABF045-8066
       Serial number: 3495RRB40670VC0KO8TC
       Serial number: 3505RRB404V0VC0KK9A4
       Serial number: 3555YRB405B134DQHGDV
       Serial number: 3565YRB40650V8BO7PA7
       Part No SW: 2H0 920 861 B    HW: 2H0 920 861 B
       Component: KOMBI         H02 0505
       Coding: 150A00
       VCID: 2615F13FB86E9F1793B-8072
       Part No: 7E0 815 071 B
       Component: J737__Standheizung  0605
       Revision: 00085000    Serial number: 09019275F00000
       Coding: 0010031
       Shop #: WSC 07456 000 09999
       VCID: 2411EB37C2D26D078DF-8070
       Part No SW: 6N0 909 901     HW: 6R7 937 087 K
       Component: GW-K-CAN TP20 H27 0532
       Revision: -1------
       Coding: 742000
       Shop #: WSC 07462 790 50316
       VCID: 70B9D7674AAA81A7397-8024
       Part No SW: 2H0 927 755 B    HW: 2H0 927 755 B
       Component: SG offroad VTG      0153
       Revision: 00H06000    Serial number: T1IYC34413PZH3
       Coding: 0000013
       VCID: 2F3B141B9B14DE5F60D-807A
       Component: IMMO          H02 0505
       VCID: 6A8DC50F6CF67B77773-803E
    Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
       Part No SW: 2H0 927 771 A    HW: 2H0 927 771
       Component: Quersperre    H04 0017
       Revision: 11001001    Serial number: 4DG 10.03.12 00
       ASAM Dataset: EV_QuersUDSAAMVN817 A01606
       ROD: EV_QuersUDSAAMVN817.rod
       VCID: 2C010317A682A54745F-8078
    Address 56: Radio
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Revision: 3A001001    Serial number: 00008030021836
       Coding: 0100000100000000
       VCID: 303917678A2AC1A7797-8064
       Part No SW: 2H0 907 441     HW: 2H0 907 441
       Component: J772__Rearview      0020
       Revision: 00H11000    Serial number: 525 PA8J2Z0169
       Coding: 0010717
       Shop #: WSC 98765 666 38384
       VCID: 6393A82B875C2A3FB45-8036
                        Reset counter: 25
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661841667
       Coding: 0F00010000010101
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 270BFC3BBF64861FA8D-8072
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 25
                        Mileage: 23120 km
                        Date: 2020.01.14
                        Time: 17:07:44
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 25
                        Mileage: 23120 km
                        Date: 2020.01.14
                        Time: 17:07:44
    End----------(Elapsed Time: 01:06, VBatt start/end: 14.3V/14.3V)-----------
    Admin note: Please don't use FONT tags in your scan.
    Feb 2016
    Norway
    I'm sorry. What is FONT tags? I just copy-pasted my Autoscan from notepad.
    Edit: I can see what they are. But I have no idea how they got there, or how to remove them. When I edit the post, I only see the plain text in my autoscan.
    Well, it's full of stuff like this:
    [FONT=Verdana]
    [/FONT]
    I'm scratching my head wondering how you managed to do that. Notepad normally just leaves text alone.
    Feb 2016
    Norway
    I did misunderstand what FONT tags are. I tought they were the green words you can hover over to see their explanations.
    Like i wrote earlier. There are no FONT tags in the autoscan part of the post when I click "Edit Post" to look for them. Should be easy enough to find after you showed me exactly where to look..
    I will post the autoscan again here. Just to see if it happens again. This is again direct copy paste from my autoscan.txt named "Log-RK77259-WV1ZZZ2HZCA064485-23120km-14366mi-03.txt" (opened in Notepad. Ctrl+A. Ctrl+C, Then Ctrl+V between CODE and /Code brackets)..
       Revision: 00H44001
       Revision: 00001007
       Coding: 0000000002
       Coding: 100000
       Coding: 100000
       Coding: 020000
       Coding: 150A00
       Coding: 0010031
       Revision: -1------
       Coding: 742000
       Coding: 0000013
    Address 56: Radio
       Coding: 0010717
                        Reset counter: 25
       ROD: UHVNA.rod
                        Reset counter: 25
                        Mileage: 23120 km
                        Date: 2020.01.14
                        Time: 17:07:44
                        Reset counter: 25
                        Mileage: 23120 km
                        Date: 2020.01.14
                        Time: 17:07:44
  6. #6
    Well there is certainly something strange going on there, that doesn't seem to happen for anyone else, because the FONT tags are still there, even in your new post. I'm at a loss to explain it.
  7. #7
    Sep 2018
    Guatemala
    I understand that you have a Pioneer aftermarket radio and an OEM style camera with the black 21-pin connector.
    I think you also bought the RCA camera conversion kit, since the camera is RGB type and the radio has RCA video input.
    1. Activate 6C on the can gateway is only for the camera with module (high version camera)
    2. The error in the telephone module is because the bluetooth module will not work with the radio aftermarket.
    3. When you use an aftermarket radio there is nothing that can be done with coding.
    the error about the camera calibration, I think is not important, since it is assumed that the camera is directly connected to the pioneer radio, the camera is no longer part of the car system.
    That is what I understand with what you say.
  8. #8
    Feb 2016
    Norway
    Sorry for late reply.
    This is the OEM camera with module (RVC High), and the calibration is to get the helping lines (both static, and moving) to line up correctly.
    Address 6C: Back-up Cam. Labels: 5N0-907-441.clb Part No SW: 2H0 907 441 HW: 2H0 907 441
    Coding: 0010717
    Reset counter: 25
