Hello everyone,
I know it happens quite often as i have looked over the forums and seen plenty of noob questions on here but im pretty stuck. I have done alot of work to my 2010 Gti and could use some help with diagnosing where i went wrong here.
First off i purchased my Gti from a man who worked at a dealership but sold the car to me privately. (should have known there was something fishy there). i knew there was an issue but i never suspected all of this trouble to come about. After researching the best VW mechanic in the entire area of Seattle, I immediatley brought the car to a nearby "Volkswagen Specialist" shop. This mechanic had outstanding reviews and was also recommended by a few friends of mine. He was quick to diagnose the problems i had with my engine and vehicle and i ended up needing new Timing Chains, highpressure fuel pump and a rear main seal. My subframe was also cracked so after charging me $3500 dollars to do all of this i had to wait about 3 weeks before i could afford to get my car back from the shop. I finally got the money together and figured my baby would be ready to rock!!... But unfortunately not even 24hrs later my Gti's engine "seized" while i was driving completely normal doing about 35 mph down a hill on Roxbury. I was at the top of the hill when all of a sudden i went to go to 4th gear from 3rd and the car just shut off. NO power, NO nothin. Since i was on a hill, i tried quickly compression starting in 3rd once and then 2nd gear one time and failed to get it started so i pulled over and called triple A. I popped the hood thinking maybe a battery issue and i could smell what smelt like burning wires maybe. TRiple A checked the battery and tried jumping but car wouldnt do anything. I hadnt even drove the car very much at all for that 20 hour period nor did i drive aggressivley or "slam gears" like some people like to refer to it. So i did what any normal person would and had the car towed back to the "Volkswagen Specialist" to see what had happened. When i came in the next day, he told me that i needed to start looking for a new engine because the current motor "seized" When i asked him how exactly had the engine seized he said that he didnt know but he would help me replace it after i bought another and also informed it wouldnt be very cheap Irritated i decided to tow my car to my newly rented home w/garage and diagnose this engine failure myself as i could not afford anymore crazy shop fees. The motor wouldnt turn by hand so i decided to pull it and i found that the inspection window for the timing chains was never replaced and there was oil all around this area.
https://photos.google.com/photo/AF1QipPOAM2xobha-YVJ5KHvMANKoKr1x3rcl704CLkf
https://photos.google.com/photo/AF1QipNjxsNrUJmGDWuyUeFNDmfSgEp75t3GSKOy7CYB
https://photos.google.com/photo/AF1QipN1hG7B4t_treY7Mdk0iUqVEHsduZFDW-DXK3G8
So after This discovery i proceeded to look for a used engine online. I found the perfect engine and decided to go hear it run as this was possible because the engine was still in the 2013 jetta. Everything sounded great engine started right up and purred so nicely but also found out the car was a lil newer so it was a cbfa instead of my ccta. looking further into it i seen the only significant difference was SAI (right?) and decided to pull the engine and pay the man selling it $1k.
When i did the swap, i used the new high pressure fuel pump that was replaced in my ccta. i also used a SAI blockoff plate where it bolts to the engine and also used the old ecm from my ccta cause i figured it does not have the SAI in the firmware so no worries there and wiring should match up to these nearly identical engines, correct?. the turbo also had to be switched out so it would fit the downpipe and i decided to use the ccta tranny as well because the cbfa had junkyard markings on the case. i figured if purchased at the junkyard and replaced it had already been in two total cars so why not just use the one thats only been in one other car and never swapped. i also replaced clutch assembly, pressure plate oil, oil filter, coolant, and lost my transponder key in the process so i tried having a locksmith come and make a new one and im almost positive he messed up my instrument cluster whilst doing so. so i have only a key to turn engine and from what i know i should be able to get the car to run for 1 second until immobilizer shuts off. my goal was to get that accomplished before i shelled out another $260 for a key from VW. Do i have to replace cluster as well? I know this is a lot to take in but imagine how i feel i have been studying this since March lol. Any help is appreciated. Here is my Auto - Scan:
I know i might need to answer some questions so please lemme know how i can make this easier i just want to get this thing started & going after all this trouble and getting screwed literally over and over. The car turns over but wont start.
Sunday,04,August,2019,12:41:57:58658
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4505.4
VIN: WVWEV7AJ0AW064514 License Plate: BNW5405
Mileage: 185990km-115568mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 65 77
VIN: WVWEV7AJ0AW064514 Mileage: 185990km-115568miles
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH06--- Serial number:
Coding: 0403010A18070160
VCID: 71BFD4EA5DA748AF357-8024
12 Faults Found:
005445 - Throttle Valve Controller
P1545 - 000 - Malfunction - MIL ON
Fault Status: 11100000
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:18
Temperature: 26.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
005464 - Throttle Actuator (G186)
P1558 - 000 - Electrical Malfunction
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:18
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 11.938 V
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:18
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 11.938 V
004501 - Fuel Pressure Regulator Valve (N276)
P1195 - 000 - Open or Short to Ground - Intermittent
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:18
Temperature: 26.0°C
Temperature: 20.0°C
Voltage: 11.938 V
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 000 - Open Circuit - MIL ON
Date: 2047.15.31
Time: 31:63:63
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 11.811 V
001092 - EVAP Purge Control Valve (N80)
P0444 - 000 - Circuit Open
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:32
RPM: 137 /min
Load: 97.2 %
Speed: 255.0 km/h
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 10.160 V
008200 - Intake Manifold Flap; Bank 1
P2008 - 000 - Electrical Malfunction
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:32
RPM: 137 /min
Load: 97.2 %
Speed: 255.0 km/h
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 10.160 V
000579 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 000 - Malfunction
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:32
RPM: 137 /min
Load: 97.2 %
Speed: 255.0 km/h
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 10.160 V
000051 - Turbocharger Bypass Valve Control Circuit
P0033 - 000 - Malfunction / Open Circuit
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:32
RPM: 137 /min
Load: 97.2 %
Speed: 255.0 km/h
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 10.160 V
000016 - Bank 1: Camshaft A (Intake)
P0010 - 000 - Position Actuator Malfunction
Mileage: 185999 km
Date: 2019.08.01
Time: 01:21:32
RPM: 137 /min
Load: 97.2 %
Speed: 255.0 km/h
Temperature: 26.0°C
Temperature: 21.0°C
Voltage: 10.160 V
001378 - System Voltage
P0562 - 000 - Too Low
Mileage: 185999 km
Date: 2019.08.01
Time: 02:52:58
Temperature: 30.0°C
Temperature: 21.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 9.652 V
000112 - Sensor for Ambient Air Temperature (G17)
P0070 - 000 - Malfunction
Mileage: 185999 km
Date: 2019.08.04
Time: 00:28:18
Temperature: 25.0°C
Temperature: 19.0°C
Voltage: 12.573 V
Readiness: 1110 0101
Part No SW: 1K0 907 379 AM HW: 1K0 907 379 AM
Component: ESP MK60EC1 H45 0108
Revision: 00H45001
Coding: 114B600CC92800FE881006E5931D00413008
VCID: 7DA7F8DA1DFF3CCFA1F-8028
Reset counter: 231
Count: 3
Count: 28672
Count: 8208
Count: 43008
Count: 1
03391 - Coding Not Possible
Reset counter: 231
Count: 2
Count: 28672
Count: 8254
Count: 42752
Count: 1
Reset counter: 231
Count: 2
Count: 28672
Count: 8211
Count: 42752
Count: 1
Reset counter: 231
Count: 7
Count: 1
Count: 28672
Count: 128
Count: 29184
Count: 1
Part No SW: 3C8 907 336 N HW: 3C8 907 336 N
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 382929CE72DDD9E7329-806C
8 Faults Found:
9477489 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Fault Frequency: 23
Reset counter: 7
Mileage: 185875 km
Date: 2019.05.23
Time: 00:42:05
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Motorsteuergerät - bitte Fehlerspeicher auslesen]
Reset counter: 16
Time: 00:00:00
U1111 00 [008] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Reset counter: 16
Time: 00:00:00
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
Reset counter: 231
Mileage: 185999 km
Date: 2019.08.04
Time: 00:28:22
B10AB F0 [009] - Too Low
Reset counter: 231
Mileage: 185999 km
Date: 2019.06.25
Time: 05:11:48
9480465 - Control Circuit for A/C Compressor
B10A9 11 [008] - Short to Ground
Reset counter: 16
Mileage: 185999 km
Date: 2019.06.25
Time: 02:40:13
9480469 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Reset counter: 231
Mileage: 185999 km
Date: 2019.06.25
Time: 00:00:09
13635840 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 16
Mileage: 185999 km
Date: 2019.08.01
Time: 02:10:37
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AD
Coding: 6D180A3F90272A04808800815000090440050086434D8D60648020200000
Shop #: WSC 22600 444 99999
VCID: 353720FA654F248F29F-8060
Component: Wischer 03070 21 0501
Coding: 009795
10 Faults Found:
Reset counter: 16
Voltage: 12.05 V
Term 50 Off
Reset counter: 231
Mileage: 185999 km
Date: 2019.08.04
Time: 01:53:47
Voltage: 12.30 V
Term 50 Off
Fault Status: 00101010
Reset counter: 16
Mileage: 185999 km
Voltage: 12.85 V
Term 50 Off
Reset counter: 16
Voltage: 11.95 V
Term 50 Off
Fault Status: 01101010
Fault Frequency: 9
Reset counter: 231
Voltage: 11.95 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 16
Voltage: 8.40 V
Term 50 Off
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 16
Voltage: 8.40 V
Term 50 Off
Reset counter: 16
Voltage: 8.00 V
Term 50 Off
00532 - Supply Voltage B+
Reset counter: 16
Voltage: 7.90 V
Term 50 Off
Reset counter: 16
Mileage: 185999 km
Date: 2019.08.01
Time: 00:00:00
Term 15 Off
Voltage: 13.65 V
Term 50 Off
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 019 0706
Serial number: 003C4D071WG2
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F2CCA49D7C0EFCD7-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 001 0002
Serial number: ---0000R--00046P3H00
Component: S.Sens.Fahr.V U01 ----
Serial number: 3572MSME0F4E0049ZZZ$
Component: S.Sens.Beif.V U01 ----
Serial number: 3582MSME5D2F6648ZZZA
Serial number: 3512QSME0C3D2F5AZZZ8
Serial number: 3522QSME14433017ZZZF
Component: F.Sens.Beif --- ----
Serial number: 35627SME5F741200ZZZB
6 Faults Found:
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 185999 km
Date: 2019.06.25
Time: 00:00:02
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [136] - Open or Short to Plus
Mileage: 185999 km
Date: 2019.06.26
Time: 00:00:03
U0155 00 [008] - -
Reset counter: 16
Time: 00:00:00
[Powersupply lower threshold fall short of]
Reset counter: 16
Mileage: 185967 km
Date: 2019.05.25
Time: 01:04:48
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Fault Frequency: 9
Reset counter: 16
Mileage: 185967 km
Date: 2019.05.25
Time: 01:04:04
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Reset counter: 16
Mileage: 185999 km
Date: 2019.06.25
Time: 12:42:35
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 055 0111
Coding: 0000532
VCID: 78A9E9CE3EDD19E7F29-802C
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5K6 920 970 G HW: 5K6 920 970 G
Component: KOMBI H05 0206
Coding: 270D00
Shop #: WSC 22606 444 105560
8 Faults Found:
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Fault Frequency: 23
Reset counter: 231
9453330 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
Reset counter: 231
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
[Steuergerät defekt (SiWaLa)]
12604672 - Combination / Chassis CAN Bus (SAE Bus D)
U0055 00 [008] - Malfunction
[Datenbus Kombi/Fahrwerk defekt]
Fault Frequency: 20
Reset counter: 16
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [008] - Performance
[Datenbus Kombi/Fahrwerk: keine Kommunikation]
Reset counter: 16
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Reset counter: 16
Mileage: 185999 km
Date: 2019.06.25
Time: 11:47:57
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Reset counter: 16
Mileage: 185999 km
Date: 2019.07.23
Time: 21:29:48
12666368 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Diagnose Interface: keine Kommunikation]
Reset counter: 16
Mileage: 185999 km
Date: 2019.07.23
Time: 21:29:48
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 0222
Revision: H16 Serial number: 4020K097071245
Coding: E9811F07101612000000
VCID: 6695B7B664699F17505-8032
Fault Frequency: 15
Reset counter: 15
Fault Frequency: 13
Reset counter: 15
Fault Status: 00101110
Fault Frequency: 28
Reset counter: 15
01304 - Radio
Reset counter: 15
Reset counter: 15
Mileage: 185999 km
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T5Q9T04
VCID: 7EA5FFD61CF927D7B85-802A
Reset counter: 16
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0206
9456433 - Key
B104B 31 [009] - No Signal
9456681 - Key
B104C 29 [009] - Implausible Signal
Fault Frequency: 20
Reset counter: 16
Part No SW: 5N0 035 342 D HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0140
Revision: A1001003 Serial number: 7667482343
Shop #: WSC 22600 444 999999
VCID: 2809F98EA2FD4967A29-807C
Reset counter: 16
Reset counter: 16
01304 - Radio
Reset counter: 16
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2107
Coding: 0001076
VCID: 313F14EA9D2708AF757-8064
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 74 2901
Revision: 00H17000
VCID: 2F3B12928B131E5F633-807A
Reset counter: 16
Voltage: 12.13 V
DD
Temperature: 23.0°C
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198608229
VCID: 678BBAB26FE3861F6B3-8032
U1400 00 [008] - -
Fault Frequency: 7
Reset counter: 16
Mileage: 185967 km
Date: 2019.05.25
Time: 01:04:22
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 323D1BE6982133B70CD-8066
Component: AFS-Steuergeraet 0142
Coding: 1446940
VCID: 34311DFE62353D871E1-8060
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
7 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
Fault Status: 11100100
Fault Frequency: 11
Reset counter: 231
Voltage: 11.93 V
ABS 1
Reset counter: 16
Voltage: 11.93 V
ABS 1
Reset counter: 16
Voltage: 11.93 V
ABS 1
000 - - - MIL ON
Reset counter: 231
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Reset counter: 231
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Reset counter: 231
Invalid
Invalid
Invalid
Fault Status: 11100101
Reset counter: 231
Invalid
Invalid
Invalid
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0043
Revision: -----19S Serial number: VWZ4Z7J1106900
Coding: 0101000001
VCID: 619FA4AA8147F82FA57-8034
Reset counter: 16
Reset counter: 231
Reset counter: 16
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018705
00667 - Ambient Temperature Signal
Mileage: 185999 km
Date: 2019.08.04
Time: 00:28:22
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520161748
Coding: 412100
VCID: 290FFC8AB9F7706FBD7-807C
Reset counter: 16
Reset counter: 16
01304 - Radio
Reset counter: 16
End----------(Elapsed Time: 01:17, VBatt start/end: 12.3V/12.3V)-----------
