Results 1 to 5 of 5
Thread: Only connecting to some modules...
    Exclamation Only connecting to some modules...
    Hello... help...
    for some reason VCDS is connecting to some but not all modules...2008 Touareg
    I did use my other scan tool Autel, and it did connect to all installed modules.
    VCDS is my go to tool... (I have to have the other one for BMW, etc)...
    what else is needed from me to resolve this, hopefully asap...
    Saturday,03,August,2019,11:36:10:11965
    VCDS Version: 19.6.1.0 HEX-NET CB: 0.4508.4
    VIN: WVGBE77L28D049297 License Plate:
    Chassis Type: 7L (6N0)
    Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 46 56 65 68 6D 6E 76
    VIN: WVGBE77L28D049297 Mileage: 125070km-77714miles
    68-Wiper Electr. -- Status: OK 0000
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
    Part No SW: 7L0 907 379 L HW: 7L0 907 379 L
    Component: ESP ALLRAD MK25E1 0303
    Revision: 00H53001
    Coding: 0004354
    Shop #: WSC 31414 790 00001
    VCID: C2C8C94099A1EC5F4F-8096
    Address 05: Acc/Start Auth. Labels: None
    Part No SW: 7L0 909 135 B HW: 5WK 485 16
    Component: Kessy 6840
    Revision: 68406620 Serial number: VWX3Z0G2689301
    Coding: 0000232
    VCID: B02C9388270D6ECFA9-80E4
    Component: ELV XXXX
    00171 - Key 1 not learned
    008 - Implausible Signal
    Address 08: Auto HVAC Labels: 7L6-907-040.clb
    Part No: 7L6 907 040 AF
    Component: CLIMAtronic R/L 4331
    Coding: 0020030
    VCID: F4A45F98939512EF0D-80A0
    00003 - Control Module
    014 - Defective
    (no units): 2.0
    Temperature: 38.0C
    Temperature: 34.0C
    Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
    Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
    Component: J519 2000
    Revision: -0004--- Serial number: --------------
    Coding: 220002002F043C000000000000000000
    VCID: 804C0348D72D3E4F19-80D4
    02254 - Interface to Generator
    Revision: 00000000 Serial number: AUZ4Z7G0215051
    Coding: 0000100
    VCID: B3269C84D21B55D7D4-80E6
    Reset counter: 116
    Mileage: 122430 km
    Date: 2018.08.23
    Time: 09:27:13
    Address 15: Airbags Labels: 7L0-959-655.lbl
    Part No SW: 7L0 959 655 HW: 7L0 959 655
    Component: J234 3A VW8T 0250
    Revision: 92011025 Serial number: 0039P003L7AZ
    Coding: 0013121
    VCID: FAB871A0B1F1649F57-80AE
    Subsystem 1 - Part No: 7L0 959 339 E
    Component: BF-Gewichtsens. 007 0009
    Subsystem 2 - Serial number: 3PK06
    Subsystem 3 - Serial number: 0001.01.000000700000000000
    Subsystem 4 - Serial number: 000000
    Address 16: Steering wheel Labels: 7L6-953-549.lbl
    Part No: 7L6 953 549 F
    Component: J527 3601
    Coding: 0010011
    Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
    Part No SW: 7L6 920 975 L HW: 7L6 920 975 L
    Component: J285 KOMBI-INST. 7320
    Revision: KHH05V03
    Coding: 0007201
    VCID: C5C2D25C8C8FDB676A-8090
    Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
    Part No SW: 6N0 909 901 HW: 7L6 920 975 L
    Component: J533 GW-K-CAN TP20 7320
    Coding: 57E2F79961066002
    VCID: F0AC5388E38D2ECFE9-80A4
    Address 1C: Position Sensing Labels: 7L6-919-879.lbl
    Part No SW: 7L6 919 879 B HW: 7L6 919 879 B
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1439802T0LQE02
    VCID: C6C0D550B189D07F63-8092
    Address 22: AWD
    Address 46: Central Conv.
    Address 56: Radio Labels: 7L6-035-180-56.lbl
    Part No SW: 7L6 035 180 C HW: 7L6 035 180 C
    Component: Radio DE2 0008
    Revision: 00005000 Serial number: VWZ4Z4GN014731
    Coding: 0001400
    VCID: AD128AFC343F032782-80F8
    Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
    Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
    Component: J0502 RDK 0006
    Revision: 00004006 Serial number: 00000900009783
    Coding: 0040008D8D0000000000000000
    VCID: BA38B1A0F171A49F17-80EE
    Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
    Part No: 7L6 955 119 B
    Component: J400__ Front Wiper 5301
    Coding: 0001397
    VCID: B93AAEACF077AF871E-80EC
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 111207 046 0204
    Coding: 00208933
    Shop #: WSC 31414
    Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
    Part No SW: 7L6 959 107 A HW: 7L6 959 107 A
    Component: J605 HECKKLAPPE 1210
    Revision: --H05--- Serial number: --------025542
    Coding: 0122110
    VCID: B93AAEACF477AF871E-80EC
    Address 6E: Ctrl Head Roof Labels: None
    Part No SW: 7L6 919 044 Q HW: 7L6 919 044 Q
    Component: J702 Dachdisplay 0400
    Revision: --30004S Serial number: 00000000050898
    Address 76: Park Assist Labels: Redir Fail!
    Part No: 7L0 919 283 F
    Component: 0E Einparkhilfe 1107
    End----------(Elapsed Time: 02:38, VBatt start/end: 12.2V/12.1V)-----------
    Oct 2014
    Arandjelovac, Serbia
    Lightbulb
    You try to enter "direct" for ex. [01-Engine]? VBatt: 12.2V - 12,1V, please connect a charger.
    Looks like VCDS is picking up all the modules that talk on CAN, but none of the modules on K-Line.
    Check the condition of pin 7 in the diagnostic socket. Sometimes cheap Chinese scan tools have crappy, over-sized pins that open up the receptacle pins in the socket enough not to make contact with pins that are made to the SAE J1962 specs like ours are.
    Check the corresponding pin 7 in your HEX-NET. Is it possible it's bent or broken?
    If no obvious problem found, test your HEX-NET in another older car that you know uses a K-Line diagnostic connection. Pretty much anything 2005 or earlier will/does (except 2004+ Audi A8 and 2005+ A6).
    Quote Originally Posted by Boki Ar View Post
    Yes, I tried selecting 01-Engine by itself, no luck...
    Check the corresponding pin 7 in your HEX-NET. Is it possible it's bent or broken?.
    HEX-NET cant be bent... I treat this thing better than my wife!
    I will check the connector on the car tomorrow... if still no go, I will plug it into my 2000 Golf tdi, to verify k-line functioning...
  6. Likes Boki Ar, Uwe, jyoung8607 liked this post
