Just did the PCV, removed the supercharger, etc.. Did something not get plugged back in, do I need to run an adaptation or did I break something?
9779 - Boost Pressure
P0235 00 [175] - Regulation Range not Reached
6307 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [175] - -
AutoScan
P0068 00 [175] - -
AutoScan
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4411.4
Dealer/Shop Name: Andy 2012 S4
VIN: WAUKGAFL4CA License Plate:
Mileage: 166350km-103365mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 36 3C 42 46 47 52 53 55
56 5F 62 6C 72
VIN: WAUKGAFL4CA112050 Mileage: 166350km-103365miles
6C-Back-up Cam. -- Status: Status: OK 0000
Address 01: Engine (J623-CCBA) Labels:| 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H08 0003
Revision: --H08---
Coding: 0104000A240F0128
Shop #: WSC 06324 123 12345
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 323E12A8A4A385679C5-8066
Mileage: 167379 km
Date: 2019.08.04
Time: 10:08:56
Engine speed: 3056.00 /min
Normed load value: 69.4 %
Vehicle speed: 103 km/h
Coolant temperature: 93 °C
Intake air temperature: 49 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 13.609 V
Engine speed: actual: 4128 /min
MAF_ENVD: 925.99998 mg/stroke
Coolant temperature (unfiltered): 93.8 °C
RFP_AV_ENVD: 0.0000
TIA_AM_SCHA: 57.00 °C
AMP_ENVD: 960.5020 hPa
P0068 00 [175] - -
Mileage: 167379 km
Date: 2019.08.04
Time: 10:08:56
Normed load value: 69.8 %
Vehicle speed: 104 km/h
MAP_1_ENVD: 1353.19336 hPa
MAP_2_ENVD: 0.00000 hPa
PDT_ENVD: 928.66211 hPa
RFP_AV_ENVD: 0.0000
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K2 927 156 S HW: 0B5 927 156 F
Component: 0B5 30TFSINAR H10 0001
Revision: --H10--- Serial number: 0000000168
Coding: 000001
Shop #: WSC 06325 000 00000
ROD: EV_TCMDL501.rod
VCID: 46D65E78382B09C720D-8012
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 290D1A
Shop #: WSC 06324 000 00000
VCID: 025E82685403F5E74C5-8056
Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
Component: BCM2 2.0 H05 0435
Coding: 0D0100
VCID: 77A8E3BC0FC1A04F6BB-8022
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000262430004
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01181220110352
Coding: 66106000
VCID: 005A88605A0FE7F75A1-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001168356
Coding: 26001091003CAF212700080300003D0D0F9CD24802010161000000
Shop #: WSC 06325 123 12345
VCID: 3C223C9076674317469-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 141211 H07 0070
Serial number: SWF11120146264
Coding: 00F511
Component: RLS H04 0003
Serial number: 20010916
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000812110065
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
1 Faults Found:
014 - Defective
Fault Status: 01101110
Fault Frequency: 24
Reset counter: 105
Mileage: 165975 km
Date: 2019.07.11
Time: 19:35:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0081
Revision: 11001001 Serial number: 36861134900422
Coding: 20010D
VCID: 4ACE6A482CB3EDA7C45-801E
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Serial number: 003GLD90477.
Coding: 303837354230303030304A55304C384B3053
VCID: 45D45974052D02DF297-8010
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100006MMP
Serial number: 6334MSME6620396FK
Serial number: 6344MSME49750670C
Serial number: 6352QSME45684C6E-
Serial number: 6362QSME0E65104CK
Serial number: 63732SME7166187A2
Serial number: 63832SME2766137A%
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KLC001DO
Coding: 000036
VCID: 3E263698607B510768D-806A
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q
Component: KOMBIINSTR. H12 0261
Revision: 00000000 Serial number: ND420FDDC
Coding: 831709008B00D705020000
VCID: 41DC4D6411852EFF15F-8014
Part No SW: 8T0 907 468 AJ HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0120
Revision: FC201059 Serial number: 5900F11C028020
Coding: 00C303
VCID: 094C95446935A6BF0DF-805C
Component: J367-BDMHella H03 8040
Serial number: 8540856001
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
Component: 4 Wheel Drive H13 0025
Serial number: 000812110001015
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
VCID: 2E0606D8B09BA187F8D-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000020176063
Coding: 00581B00000000000000
VCID: 3B203F8C7369442F4F3-806E
Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0030
Revision: 00H02000 Serial number: 6PZ 009 014-82
VCID: 3C223C907A674317469-8068
Subsystem 1 - Part No: 8K0 907 568 H
Component: J0770_SWA_Slave_H01 0030
Subsystem 2 - Serial number: 6PZ 009 014-92
Subsystem 3 - Serial number: 5F01.12.1100H010003C322137ÿ
Subsystem 4 - Serial number: 322137ÿ
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C13204E00410001
VCID: 53F0772CFBF9AC6FB73-8006
Revision: 00002001 Serial number: 0165771988
Coding: 0106063A00FA44058330013200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000463946
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34804012392403
VCID: 7AAEFA883CD3BD27145-802E
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: 52FE7228C4E3A567BC5-8006
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000001074202
VCID: 343214B05E378B578E9-8060
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 C HW: 8H0 907 357 C
Component: AFS 1 H01 0040
Revision: 00H01001 Serial number:
Coding: 0000019
VCID: 323E12A8A82385679C5-8066
Subsystem 1 - Part No: 8K0 941 329
Component: AFS-Modul links H01 S001
Subsystem 2 - Part No: 8K0 941 329
Component: AFS-Modul rechtsH01 S001
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 156L/0B7584005
Coding: 020007010000000001
VCID: 1F18EB1CC7B1380F43B-804A
Part No SW: 8T1 035 664 D HW: 8T1 035 664 B
Component: H-BN-NA H52 0165
Revision: -------- Serial number: 490L90B7656953
Coding: 010200000206E9FF77091F0E040000030000
VCID: 392C25847955763F5DF-806C
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130LA0BS077026
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000001020292
Component: CD-Database 2712
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1501
Coding: 010C13204000210001
VCID: 56F68E38E80BB94750D-8002
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H05--- Serial number: 525PA8-J1892IK
Coding: 1000006
VCID: 382A20804E5F6F37A21-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H06 1501
End----------(Elapsed Time: 01:59, VBatt start/end: 12.9V/13.4V)-----------
