Results 1 to 10 of 10
Thread: New here - Retrofitting MY18 MFSW with DSG paddles to an MY13 Octavia questions
    New User
    Aug 2019
    The Netherlands
    Hello forum!
    I have looked through different topics, but I cannot get it right. That is why I open this new topic.
    I have a Skoda Octavia from '10 2013. It is a DSG-7 gear.I have since carried out many updates on the Octavia. Now I am working on a steering wheel project. Unfortunately, I have a number of questions that I cannot solve myself and try to solve with your knowledge. I have been able to buy an MFSW with flattened bottom and DSG paddles (5E0419091 BT CXA) from a 2018 Octavia. This handlebar has the VIEW button, so I would have to transfer the multifunction buttons of my current handlebar.
    Unfortunately, my current steering wheel controls have no inputs for the plugs coming from the DSG paddles.
    That's why I have to look for the same steering wheel controls as my current MFSW.
    Now my question is whether I will also need another gateway to get the new MFSW working.
    From a VCDS log of my car I can extract from line 19 that my Octavia is equipped with a can-mid (CW MQB Mid).
    Gateway SW: 5Q0907530L
    Gateway HW: 5Q0907530E
    Do I have to install a new gateway to get the DSG paddles working?
    Or should it be possible with my Octavia's current gateway?
    According to the link below it is said that these components are needed to realize an MFSW, but I already have an MFSW. The only thing that comes with it is the DSG paddles.
    https://www.cars-equipment.com/en/sh...wheel-buttons/
    1x buttons 5E0919719B
    1X gateway 5Q0907530AC
    1X multifunctional wiring 5E0971584A
    The steering wheel control from the link is the one I need for the new MFSW. This is with the DSG paddle plugs.
    Who can help me with this big issue. Any help is welcome! If needed, I can post my VCDS log into this topic.
    Thanks alot, HarrieSkoda from the Netherlands
    Nov 2015
    Go ahead and post that VCDS log please.
    Cheers.
  3. Likes Uwe liked this post
    New User
    Aug 2019
    The Netherlands
    Hope with this log you can give me some information.
    If you need more of the log I can expand the log.
    Part No SW: 5E0 920 861 A HW: 5E0 920 861 A
    Component: KOMBI 204 3390
    Coding: 07AD0A082180000801087A00040000
    ASAM Dataset: EV_DashBoardJCIMQBAB 008011
    ROD: EV_DashBoardJCIMQBAB_008.rod
    VCID: 251600BF0563012FCD3-8070
    Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
    Component: GW MQB Mid 124 1144
    Revision: -------- Serial number: 0001021580
    Coding: 030100042B086400EF00064C1C0F00010001000000000000000000000000
    Shop #: WSC 43281 001 1048576
    ASAM Dataset: EV_GatewLear 009013
    ROD: EV_GatewLear_009.rod
    VCID: 3A2CC3C39CDD9ED7901-806E
    Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
    Component: E221__MFL-PR6 H04 0120
    Serial number: 000000000B0883110913
    Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
    Component: J367-BDMHella H03 8042
    Serial number: 2228871303
    Nov 2015
    Need a complete autoscan please. Odd snippets of a couple of controllers isn't much help.
  6. Likes Uwe, PetrolDave, Dana liked this post
    New User
    Aug 2019
    The Netherlands
    No problem, I'm a newbie in this kind of project I'm busy with... I'm sorry.
    I think I've got a full scan over here, correct me if I'm wrong, thanks!
    Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 A    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   X08 7697
       Revision: WAX08---
       Coding: 01250032232401080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM12TFS01104E906016A 001008
       ROD: EV_ECM12TFS01104E906016A.rod
       VCID: 201811AB1A41E407BE5-8074
    Readiness: 0010 0000
       Part No SW: 0CW 300 044 T    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5299
       Revision: 00043014    Serial number: CU501309156168
       Shop #: WSC 73430 031 12345
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 49CEAC0FC93B054F09B-801C
       Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
       Component: EMB8 EHCB     H31 0356
       Revision: 00000000    Serial number: 625830000008E2
       Coding: 1C076A912427116F007D060541CA243856248800608224F000210070C009
       VCID: 4BC29607C347175F3B7-801E
    0213 - Vacuum sensor
              C10A3 29 [008] - Signal Implausible
              [Single Vacuum Pressure Sensor sends no valid data]
                        Reset counter: 56
                        Mileage: 118429 km
                        Date: 2018.10.13
                        Time: 16:15:50
       Part No SW: 5E0 907 044     HW: 5E0 907 044
       Component: Climatronic   H02 0604
       Revision: 00001K06
       Coding: 02010004000100011005004000100000
       ROD: EV_ACClimaBHBVW37X_002_SK37.rod
       VCID: 629C5BA354CDB617E81-8036
    328196 - Motor for Right Temperature Flap
              B108D 71 [008] - Actuator stuck
                        Reset counter: 60
                        Mileage: 118661 km
                        Date: 2018.10.18
                        Time: 22:46:28
       Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
       Component: BCM MQBAB M   H14 0112
       Serial number: 00011325502178
       Coding: 0C021842424702FB47E04000011407080000000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: 48C8A90BD231FC47165-801C
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 130903  041 0570
       Serial number:         130916055511
       Coding: 065DDD
       Component: RLFS  024 0042
       Serial number: Y13M09D18H14M50S11S1
       Coding: 02805D
    8202 - Bulb for Left DRL
              B121D 15 [008] - Open or Short to Plus
                        Reset counter: 77
                        Mileage: 118819 km
                        Date: 2018.10.25
                        Time: 16:20:58
    10762 - Bulb for Right Tail Light
              B12BF 15 [008] - Open or Short to Plus
                        Reset counter: 73
                        Mileage: 118918 km
                        Date: 2018.11.11
                        Time: 13:53:12
    12810 - Bulb for Right Back-up Light
              B12CC 15 [008] - Open or Short to Plus
                        Reset counter: 73
                        Mileage: 118918 km
                        Date: 2018.11.11
                        Time: 13:54:41
    14858 - Bulb for Right Brake Lamp / Tail Lamp
              B133C 15 [008] - Open or Short to Plus
                        Reset counter: 73
                        Mileage: 118918 km
                        Date: 2018.11.11
                        Time: 13:54:40
       Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H09 0033
       Revision: --------    Serial number: 60831326101133
       Coding: 0001150111
       ASAM Dataset: EV_EPHVA14AU3700000 002018
       VCID: 3828D9CBA2D18CC7665-806C
       Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
       Component: Airbag VW20   011 0188
       Revision: --------    Serial number: 003NYPJQUASQ
       Coding: 98FCC000000000005C5400CC000800000065
       Shop #: WSC 73430 790 00209
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7DA608DFCD7369EFF53-8028
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169593B24091370684
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169592B24091370531
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 454 000 909 13
       Serial number: 3576U00000061798DD0M
       Subsystem 4 - Part No SW: -----------    HW: 454 001 009 13
       Serial number: 3586U000000D3051DD0E
       Subsystem 5 - Part No SW: -----------    HW: 454 800 409 13
       Serial number: 3516RBC8EE201000000I
       Subsystem 6 - Part No SW: -----------    HW: 454 800 109 13
       Serial number: 3526R420DF001000000Z
       Subsystem 7 - Part No SW: -----------    HW: 454 800 508 13
       Serial number: 3556V7325AF010000007
       Part No SW: 5Q0 953 507 AJ    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 23091304400511
       Coding: 1400
       Shop #: WSC 73430 031 00063
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 7EA40FD3C07572F7EC9-802A
    66052 - Infotainment CAN Bus (SAE Bus E)
              U0065 00 [008] - Performance
              [Globaler Timeout CAN-Infotainment]
                        Reset counter: 77
                        Mileage: 118944 km
                        Date: 2018.11.14
                        Time: 16:33:11
                        Supply voltage: Terminal 30: 12.4 V
                        Terminal 15: OFF
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Component: TSG FS        007 0006
       Serial number: 0000076270347
       Coding: 00110120D000028000001100
       VCID: 025C7B23B48D1617881-8056
       Component: FOND_FHSG_DRV  005 0004
       Serial number: 00000000000000716496
       Coding: 010200
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
       Component: EPS_MQB_ZFLS  127 1021
       Coding: 01
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D26C8DF8DF3A9EFB53-8068
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Component: TSG BFS       007 0006
       Serial number: 0000075766091
       Coding: 00110120DC00028000001100
       VCID: 015E742FB18B0D0F91B-8054
       Component: FOND_FHSG_PSG  005 0004
       Serial number: 00000000000000744460
       Coding: 190200
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
       Part No SW: 5E0 035 864 A    HW: 5E0 035 864 A
       Component: MU-S-N-ER     040 0421
       Serial number: S3F02009132071
       Coding: 03730201FF00000011110001000000002F0000940100010046
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
       Component: ABT_Std_Nav  H50 0022
       Serial number: SKZ8Z9NK800C3X
       Subsystem 2 - Part No SW: 5E0 051 236     HW: -----------
       Component:  ECE 2017/18  --- 0067
       Part No SW: 5Q0 907 383     HW: 5Q0 907 383
       Component: Anheanger     H10 0030
       Serial number: 00006789000000
       Coding: 0100000200000000
       ASAM Dataset: EV_TrailFunctDemouHella 001001
       ROD: EV_TrailFunctDemouHella.rod
       VCID: 74B02DFBFE3928A78AD-8020
    End----(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
  8. Likes Uwe, Dana liked this post
  9. #6
    New User
    Aug 2019
    The Netherlands
    Posted full scan, but nobody is replying....? Nobody knows??
  10. #7
    United States
    We're still limping by after the incident so I don't have access to much info however my relatively low-spec Golf Alltrack has a factory fitted flappy paddle MK7 wheel with a GW MQB Mid 19 module. For that reason I would like to believe that yours would support the wheel as well.
  11. Likes Uwe liked this post
  12. #8
    May 2017
    Quote Originally Posted by HarrieSkoda View Post
    Why did you leave the header part out. Usually FULL, UNEDITED autoscan. You can hide the registration but otherwise don't add or remove anything from the autoscan.
  13. #9
    Mar 2019
    Australia
    Going to end up in hall of shame ��
  14. Likes PetrolDave liked this post
  15. #10
    Quote Originally Posted by Jeromeo View Post
    Nope. You can see I edited the tags on the scan and clicked LIKE on the post several days ago. You can take that to mean I looked at it and determined it's not pirated.
  16. Likes PetrolDave liked this post
