Results 1 to 10 of 16
Thread: 2018 Tiguan SE road legal in Germany - Radio and cluster questions
    Nov 2018
    Germany, Erfurt
    All,
    I am in the process of getting our 2018 Tiguan SE we took from the US to Germany road legal. The lights were the most work but actually quit simple (reused the rear position light cables and reconfigured them to become blinkers and reused the left reverse light cable to become the fog light).
    I also work on the cluster (language) and infotainment (language and radio frequencies). Here is were I am stuck:
    I coded 5F to use EU radio frequencies, which worked just fine. However, when I store a FM station its gone after a restart of the car. I was also not able to deactivate Sirius, anyone has an idea for these problems?
    When I try to change the language in the cluster it actually changes for a second (so the firmware supports it) but changes back. It only supports the languages which are configured in 5F, i confirmed that by putting a German cluster in there and it switched to English immediately. Is there a way to change it without changing 5F to German and if not, is there a way to change 5F to german with VCDS or ODIS? If not, I will see if I can get a german replacement unit and see if it works after removing CP.
    Thanks in advance, please see attached - full autoscan with adjustments of 17 and 5F
    	SW:3Q0-035-844-B   HW:3Q0-035-844-B ---  Informationselek. I
    	Bauteil:MU-S-S-US     722 0867, Codierung:02730600BE0000005100000100180A001F0500C40120050002
    	EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW26.rod
    	Freitag,02,August,2019,12:46:47:49457
    	VCDS Version: PCI 18.9.1  Datenstand: 20190520 DS296.1
    	VCID: 2E04FA5EB09B56673C1-807A
    IDE00001-Produktionsmodus,00 00 00 ,3
    IDE00346-Sommerzeit-Automatik,manuell ,1
    IDE00758-Grundlautstärke Telefon,50 %,1
    IDE00759-Grundlautstärke Sprachausgabe,50 %,1
    IDE00760-Mikrofonempfindlichkeit,0 dB,1
    IDE00769-Rufnummer 1 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Rufnummer 1 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00820-ENG117828-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-Infotainment_CAN_Messages,aus ,1
    IDE00820-ENG117829-Aktivieren und Deaktivieren aller Entwicklungsbotschaften-MIB_CAN_Messages,aus ,1
    IDE02121-Taster für CD-Rückgabe,freigegeben ,1
    IDE02122-Entwicklermodus,nicht aktiviert ,1
    IDE02330-Rufnummer 2 für Inforuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Rufnummer 2 für Pannenruf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02332-Produktionsmodus deaktivieren,0 ,3
    IDE02476-MAS03001-Elektrische Prüfung der Lautsprecher-Modus,automatisch ,49
    IDE02476-ENG117360-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
    IDE02476-ENG117361-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
    IDE02476-ENG117378-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
    IDE02476-ENG117379-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
    IDE02476-ENG117380-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
    IDE02476-ENG117381-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
    IDE02476-ENG117382-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
    IDE02476-ENG117383-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
    IDE02476-ENG117384-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
    IDE02476-ENG117385-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
    IDE02476-ENG117386-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
    IDE02476-ENG117387-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
    IDE02476-ENG117388-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
    IDE02476-ENG117389-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
    IDE02476-ENG117390-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
    IDE02476-ENG117391-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
    IDE02476-ENG117362-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
    IDE02476-ENG117363-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
    IDE02476-ENG117364-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
    IDE02476-ENG117365-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
    IDE02476-ENG117366-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
    IDE02476-ENG117367-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
    IDE02476-ENG117368-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
    IDE02476-ENG117369-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
    IDE02476-ENG117370-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
    IDE02476-ENG117371-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
    IDE02476-ENG117372-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
    IDE02476-ENG117373-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
    IDE02476-ENG117374-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
    IDE02476-ENG117375-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
    IDE02476-ENG117376-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
    IDE02476-ENG117377-Elektrische Prüfung der Lautsprecher-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
    IDE02502-Bestätigung der Verbauänderung,36 2D ,2
    IDE02699-Rufnummer 1 für Hilferuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Rufnummer 1 (roaming) für Hilferuf,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE03471-ENG117847-Fahrzeugkonfiguration-advanced_range_display,aus ,30
    IDE03471-ENG142146-Fahrzeugkonfiguration-allow_message_editing,aus ,30
    IDE03471-ENG130249-Fahrzeugkonfiguration-Apple_DIO,ein ,30
    IDE03471-ENG185764-Fahrzeugkonfiguration-Apple_DIO_Wireless,aus ,30
    IDE03471-ENG152525-Fahrzeugkonfiguration-Baidu_Car_Life,aus ,30
    IDE03471-ENG152559-Fahrzeugkonfiguration-Baidu_Car_Life_ios,aus ,30
    IDE03471-ENG185765-Fahrzeugkonfiguration-Baidu_Car_Life_ios_Wireless,aus ,30
    IDE03471-ENG185766-Fahrzeugkonfiguration-Baidu_Car_Life_Wireless,aus ,30
    IDE03471-ENG152560-Fahrzeugkonfiguration-block_hmi_function_p_epb,gesperrt ,30
    IDE03471-ENG142151-Fahrzeugkonfiguration-conditioning_variant,0 ,30
    IDE03471-ENG125043-Fahrzeugkonfiguration-Dtmf_without_active_call,ein ,30
    IDE03471-ENG142145-Fahrzeugkonfiguration-esim_data_only_sms_support,aus ,30
    IDE03471-ENG185778-Fahrzeugkonfiguration-FoD,SWaP ,30
    IDE03471-ENG130248-Fahrzeugkonfiguration-Google_GAL,ein ,30
    IDE03471-ENG185779-Fahrzeugkonfiguration-Google_GAL_Wireless,aus ,30
    IDE03471-ENG117850-Fahrzeugkonfiguration-gracenote_local_coverarts,aus ,30
    IDE03471-ENG117851-Fahrzeugkonfiguration-gracenote_local_other,aus ,30
    IDE03471-ENG117848-Fahrzeugkonfiguration-gracenote_online_coverarts,aus ,30
    IDE03471-ENG117849-Fahrzeugkonfiguration-gracenote_online_other,aus ,30
    IDE03471-ENG152533-Fahrzeugkonfiguration-Hybrid_Radio_additional_online_data,nicht aktiviert ,30
    IDE03471-ENG152534-Fahrzeugkonfiguration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG125049-Fahrzeugkonfiguration-Joker_button_1,nicht vorhanden ,30
    IDE03471-ENG125050-Fahrzeugkonfiguration-Joker_button_2,nicht vorhanden ,30
    IDE03471-ENG127492-Fahrzeugkonfiguration-LGI,aus ,30
    IDE03471-ENG130246-Fahrzeugkonfiguration-LTE_modul,aktiviert ,30
    IDE03471-ENG142142-Fahrzeugkonfiguration-map_email_support,aus ,30
    IDE03471-ENG142143-Fahrzeugkonfiguration-map_instant_messaging_support,aus ,30
    IDE03471-ENG142141-Fahrzeugkonfiguration-map_sms_support,aus ,30
    IDE03471-ENG142152-Fahrzeugkonfiguration-Map_Style,0 ,30
    IDE03471-ENG152537-Fahrzeugkonfiguration-media_control,nicht aktiviert ,30
    IDE03471-ENG138662-Fahrzeugkonfiguration-Mirror_link,ein ,30
    IDE03471-ENG142148-Fahrzeugkonfiguration-MirrorLink_Country_Code,MIB_NAR ,30
    IDE03471-ENG142150-Fahrzeugkonfiguration-MirrorLink_RGB_Preference,RGB565 ,30
    IDE03471-ENG117843-Fahrzeugkonfiguration-my_audi,aus ,30
    IDE03471-ENG117845-Fahrzeugkonfiguration-online_dictation,aus ,30
    IDE03471-ENG127495-Fahrzeugkonfiguration-online_media,aus ,30
    IDE03471-ENG117840-Fahrzeugkonfiguration-online_navigation,aus ,30
    IDE03471-ENG117837-Fahrzeugkonfiguration-online_POI,aus ,30
    IDE03471-ENG117838-Fahrzeugkonfiguration-online_POI_voice,aus ,30
    IDE03471-ENG117839-Fahrzeugkonfiguration-online_portal_browser_services,aus ,30
    IDE03471-ENG152553-Fahrzeugkonfiguration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Fahrzeugkonfiguration-online_street_view,aus ,30
    IDE03471-ENG125048-Fahrzeugkonfiguration-OPS_display_in_dash_board_display_unit,aus ,30
    IDE03471-ENG167521-Fahrzeugkonfiguration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Fahrzeugkonfiguration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Fahrzeugkonfiguration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Fahrzeugkonfiguration-Phone_module_operation_mode,Daten- und Sprachdienst aktiv ,30
    IDE03471-ENG117844-Fahrzeugkonfiguration-picture_navi,aus ,30
    IDE03471-ENG167523-Fahrzeugkonfiguration-Pilot_Parking,nicht aktiviert ,30
    IDE03471-ENG167525-Fahrzeugkonfiguration-Popup_if_GPS_services_in_use,nicht aktiviert ,30
    IDE03471-ENG152555-Fahrzeugkonfiguration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG127496-Fahrzeugkonfiguration-ProbeCar_lgi,aus ,30
    IDE03471-ENG137646-Fahrzeugkonfiguration-ProbeCar_vzo,aus ,30
    IDE03471-ENG125047-Fahrzeugkonfiguration-PSD_Protocol_Version,PSD_1.5 ,30
    IDE03471-ENG117846-Fahrzeugkonfiguration-remote_HMI,aus ,30
    IDE03471-ENG138661-Fahrzeugkonfiguration-RSE_software_component,aktiviert ,30
    IDE03471-ENG245031-Fahrzeugkonfiguration-rvc_low_black_screen_trunk_open,nicht aktiviert ,30
    IDE03471-ENG244966-Fahrzeugkonfiguration-rvc_low_black_screen_velocity_threshold,nicht aktiviert ,30
    IDE03471-ENG245015-Fahrzeugkonfiguration-rvc_low_failsafe,nicht aktiviert ,30
    IDE03471-ENG126143-Fahrzeugkonfiguration-RVC_video_input,FBAS ,30
    IDE03471-ENG152556-Fahrzeugkonfiguration-scon_telephony,nicht aktiviert ,30
    IDE03471-ENG142081-Fahrzeugkonfiguration-sd_slot_deactivation,keine Einschränkung ,30
    IDE03471-ENG138660-Fahrzeugkonfiguration-SDS_Region_Flag,no_region ,30
    IDE03471-ENG152557-Fahrzeugkonfiguration-show_volte_hmi_switch,nicht aktiviert ,30
    IDE03471-ENG125045-Fahrzeugkonfiguration-Sim_card_mode_switch,nicht vorhanden ,30
    IDE03471-ENG142144-Fahrzeugkonfiguration-sim_data_only_sms_support,aus ,30
    IDE03471-ENG138663-Fahrzeugkonfiguration-Smartphone_interface_for_rhmi,aktiviert ,30
    IDE03471-ENG126993-Fahrzeugkonfiguration-Station_Logo_DB_Mode,0 ,30
    IDE03471-ENG125044-Fahrzeugkonfiguration-Support_for_response_and_hold,aus ,30
    IDE03471-ENG125042-Fahrzeugkonfiguration-Support_of_threeway_calling,ein ,30
    IDE03471-ENG130247-Fahrzeugkonfiguration-Support_second_phone,ein ,30
    IDE03471-ENG167531-Fahrzeugkonfiguration-Tencent_myCar_canceling_share_location,aus ,30
    IDE03471-ENG126994-Fahrzeugkonfiguration-TPEG_availability,aus ,30
    IDE03471-ENG152571-Fahrzeugkonfiguration-unblock_functions_while_piloted_driving,gesperrt ,30
    IDE03471-ENG137647-Fahrzeugkonfiguration-UOTA,aus ,30
    IDE03471-ENG167532-Fahrzeugkonfiguration-UOTA_2,aus ,30
    IDE03471-ENG117852-Fahrzeugkonfiguration-UPnP,aus ,30
    IDE03471-ENG142149-Fahrzeugkonfiguration-vehicle_leaving_sound,nicht aktiviert ,30
    IDE03471-ENG142147-Fahrzeugkonfiguration-vehicle_readiness_sound,nicht aktiviert ,30
    IDE03471-ENG152558-Fahrzeugkonfiguration-voice_over_lte,nicht aktiviert ,30
    IDE03471-ENG117836-Fahrzeugkonfiguration-VZAPro,aus ,30
    IDE03471-ENG127494-Fahrzeugkonfiguration-VZO,aus ,30
    IDE03471-ENG137648-Fahrzeugkonfiguration-WiFi_Client_HMI,aus ,30
    IDE03471-ENG117842-Fahrzeugkonfiguration-WIFI_Hotspot,aus ,30
    IDE03471-ENG152572-Fahrzeugkonfiguration-wlan_5ghz_switch,nicht aktiviert ,30
    IDE03902-Automatische Ringbruchdiagnose,Kein automatischer Start ,1
    IDE04295-Bluetooth: bevorzugtes Verbindungsprofil für Telefonbuchdaten,PBAP ,1
    IDE04331-Auswahl der Freischaltcodes einer SWaP Funktion,FF FF FF FF ,4
    IDE04521-Sporadische Ringbruchdetektion,optisch ,1
    IDE04522-Weckfähigkeit am optischen Datenbus,aus ,1
    IDE04550-Bluetooth: Sniff-Mode,aus ,1
    IDE05113-Infotainment Recorder,aktiviert ,1
    IDE06425-Rollenprüfstandmodus: funktional,nicht aktiviert ,1
    IDE10221-MAS00839-Audio Management Eingangsverstärkung Generation 2-TV-Tuner,-128 ,40
    IDE10221-MAS00846-Audio Management Eingangsverstärkung Generation 2-Satellitenradio,5 ,40
    IDE10221-MAS01984-Audio Management Eingangsverstärkung Generation 2-Radio (FM),-128 ,40
    IDE10221-MAS01985-Audio Management Eingangsverstärkung Generation 2-Radio (AM),-128 ,40
    IDE10221-MAS01986-Audio Management Eingangsverstärkung Generation 2-Digitalradio (DAB),-128 ,40
    IDE10221-ENG125854-Audio Management Eingangsverstärkung Generation 2-Exbox_DMB,-128 ,40
    IDE10221-ENG117430-Audio Management Eingangsverstärkung Generation 2-HFP,-128 ,40
    IDE10221-ENG125846-Audio Management Eingangsverstärkung Generation 2-Media_Airplay,-128 ,40
    IDE10221-ENG125837-Audio Management Eingangsverstärkung Generation 2-Media_AUX_Adapter,-128 ,40
    IDE10221-ENG125836-Audio Management Eingangsverstärkung Generation 2-Media_AUXIN,-128 ,40
    IDE10221-ENG125843-Audio Management Eingangsverstärkung Generation 2-Media_Bluray,-128 ,40
    IDE10221-ENG125841-Audio Management Eingangsverstärkung Generation 2-Media_BTDevice,-128 ,40
    IDE10221-ENG125838-Audio Management Eingangsverstärkung Generation 2-Media_CDA,-128 ,40
    IDE10221-ENG125848-Audio Management Eingangsverstärkung Generation 2-Media_Cloud,-128 ,40
    IDE10221-ENG125839-Audio Management Eingangsverstärkung Generation 2-Media_DVD,-128 ,40
    IDE10221-ENG125844-Audio Management Eingangsverstärkung Generation 2-Media_HDMI,-128 ,40
    IDE10221-ENG125840-Audio Management Eingangsverstärkung Generation 2-Media_MFP,-128 ,40
    IDE10221-ENG125847-Audio Management Eingangsverstärkung Generation 2-Media_UPNP,-128 ,40
    IDE10221-ENG125855-Audio Management Eingangsverstärkung Generation 2-Mirrorlink,-128 ,40
    IDE10221-ENG125859-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_MFP,-128 ,40
    IDE10221-ENG125860-Audio Management Eingangsverstärkung Generation 2-Phone_Ringer_OB,-3 ,40
    IDE10221-ENG125858-Audio Management Eingangsverstärkung Generation 2-Phone_Voice,-128 ,40
    IDE10221-ENG125842-Audio Management Eingangsverstärkung Generation 2-TA_Tuner_FM,-128 ,40
    IDE10221-ENG125850-Audio Management Eingangsverstärkung Generation 2-Tone_Beep,-128 ,40
    IDE10221-ENG125853-Audio Management Eingangsverstärkung Generation 2-Tone_Messaging,-128 ,40
    IDE10221-ENG125852-Audio Management Eingangsverstärkung Generation 2-Tone_Touchscreen,6 ,40
    IDE10221-ENG125851-Audio Management Eingangsverstärkung Generation 2-Tone_Warning,-128 ,40
    IDE10221-ENG125856-Audio Management Eingangsverstärkung Generation 2-TTS_Nav,-128 ,40
    IDE10221-ENG125857-Audio Management Eingangsverstärkung Generation 2-TTS_SDS,-128 ,40
    IDE10221-ENG125845-Audio Management Eingangsverstärkung Generation 2-Tuner_Online,-128 ,40
    IDE10221-ENG125849-Audio Management Eingangsverstärkung Generation 2-Tuner_Personal,-128 ,40
    IDE10221-ENG125835-Audio Management Eingangsverstärkung Generation 2-Tuner_TI,-128 ,40
    IDE10221-ENG125861-Audio Management Eingangsverstärkung Generation 2-TV_AV_IN,-128 ,40
    IDE10480-MAS10741-Schnittstelle für externen Medien: Aktivierung-Anschluss 1,aktiviert ,4
    IDE10480-MAS10742-Schnittstelle für externen Medien: Aktivierung-Anschluss 2,aktiviert ,4
    IDE10480-MAS10743-Schnittstelle für externen Medien: Aktivierung-Anschluss 3,nicht aktiviert ,4
    IDE10480-MAS10744-Schnittstelle für externen Medien: Aktivierung-Anschluss 4,nicht aktiviert ,4
    IDE10604-Menü-Einträge für mobile Online-Dienste,nicht aktiviert ,1
    IDE11122-Länderkennung Verkaufsland HMI,US ,2
    IDE11502-ENG127601-Gesperrte Menüinhalte-FB_CAR_0,blocked ,21
    IDE11502-ENG127602-Gesperrte Menüinhalte-FB_CAR_1,non_blocked ,21
    IDE11502-ENG127611-Gesperrte Menüinhalte-FB_CAR_10,non_blocked ,21
    IDE11502-ENG127612-Gesperrte Menüinhalte-FB_CAR_11,blocked ,21
    IDE11502-ENG127613-Gesperrte Menüinhalte-FB_CAR_12,blocked ,21
    IDE11502-ENG127614-Gesperrte Menüinhalte-FB_CAR_13,non_blocked ,21
    IDE11502-ENG127615-Gesperrte Menüinhalte-FB_CAR_14,non_blocked ,21
    IDE11502-ENG127616-Gesperrte Menüinhalte-FB_CAR_15,non_blocked ,21
    IDE11502-ENG127617-Gesperrte Menüinhalte-FB_CAR_16,non_blocked ,21
    IDE11502-ENG127618-Gesperrte Menüinhalte-FB_CAR_17,non_blocked ,21
    IDE11502-ENG127619-Gesperrte Menüinhalte-FB_CAR_18,non_blocked ,21
    IDE11502-ENG127620-Gesperrte Menüinhalte-FB_CAR_19,non_blocked ,21
    IDE11502-ENG127603-Gesperrte Menüinhalte-FB_CAR_2,blocked ,21
    IDE11502-ENG127621-Gesperrte Menüinhalte-FB_CAR_20,non_blocked ,21
    IDE11502-ENG127622-Gesperrte Menüinhalte-FB_CAR_21,non_blocked ,21
    IDE11502-ENG127623-Gesperrte Menüinhalte-FB_CAR_22,non_blocked ,21
    IDE11502-ENG127624-Gesperrte Menüinhalte-FB_CAR_23,non_blocked ,21
    IDE11502-ENG127604-Gesperrte Menüinhalte-FB_CAR_3,blocked ,21
    IDE11502-ENG127605-Gesperrte Menüinhalte-FB_CAR_4,non_blocked ,21
    IDE11502-ENG127606-Gesperrte Menüinhalte-FB_CAR_5,non_blocked ,21
    IDE11502-ENG127607-Gesperrte Menüinhalte-FB_CAR_6,non_blocked ,21
    IDE11502-ENG127608-Gesperrte Menüinhalte-FB_CAR_7,blocked ,21
    IDE11502-ENG127609-Gesperrte Menüinhalte-FB_CAR_8,non_blocked ,21
    IDE11502-ENG127610-Gesperrte Menüinhalte-FB_CAR_9,non_blocked ,21
    IDE11502-ENG127521-Gesperrte Menüinhalte-FB_MEDIA_0,non_blocked ,21
    IDE11502-ENG127522-Gesperrte Menüinhalte-FB_MEDIA_1,blocked ,21
    IDE11502-ENG127531-Gesperrte Menüinhalte-FB_MEDIA_10,blocked ,21
    IDE11502-ENG127532-Gesperrte Menüinhalte-FB_MEDIA_11,blocked ,21
    IDE11502-ENG127533-Gesperrte Menüinhalte-FB_MEDIA_12,blocked ,21
    IDE11502-ENG127534-Gesperrte Menüinhalte-FB_MEDIA_13,blocked ,21
    IDE11502-ENG127535-Gesperrte Menüinhalte-FB_MEDIA_14,non_blocked ,21
    IDE11502-ENG127536-Gesperrte Menüinhalte-FB_MEDIA_15,blocked ,21
    IDE11502-ENG127537-Gesperrte Menüinhalte-FB_MEDIA_16,non_blocked ,21
    IDE11502-ENG127538-Gesperrte Menüinhalte-FB_MEDIA_17,non_blocked ,21
    IDE11502-ENG127539-Gesperrte Menüinhalte-FB_MEDIA_18,non_blocked ,21
    IDE11502-ENG127540-Gesperrte Menüinhalte-FB_MEDIA_19,non_blocked ,21
    IDE11502-ENG127523-Gesperrte Menüinhalte-FB_MEDIA_2,non_blocked ,21
    IDE11502-ENG127541-Gesperrte Menüinhalte-FB_MEDIA_20,non_blocked ,21
    IDE11502-ENG127542-Gesperrte Menüinhalte-FB_MEDIA_21,non_blocked ,21
    IDE11502-ENG127543-Gesperrte Menüinhalte-FB_MEDIA_22,non_blocked ,21
    IDE11502-ENG127544-Gesperrte Menüinhalte-FB_MEDIA_23,non_blocked ,21
    IDE11502-ENG127524-Gesperrte Menüinhalte-FB_MEDIA_3,blocked ,21
    IDE11502-ENG127525-Gesperrte Menüinhalte-FB_MEDIA_4,blocked ,21
    IDE11502-ENG127526-Gesperrte Menüinhalte-FB_MEDIA_5,blocked ,21
    IDE11502-ENG127527-Gesperrte Menüinhalte-FB_MEDIA_6,non_blocked ,21
    IDE11502-ENG127528-Gesperrte Menüinhalte-FB_MEDIA_7,non_blocked ,21
    IDE11502-ENG127529-Gesperrte Menüinhalte-FB_MEDIA_8,blocked ,21
    IDE11502-ENG127530-Gesperrte Menüinhalte-FB_MEDIA_9,blocked ,21
    IDE11502-ENG127625-Gesperrte Menüinhalte-FB_MISC_0,blocked ,21
    IDE11502-ENG127626-Gesperrte Menüinhalte-FB_MISC_1,non_blocked ,21
    IDE11502-ENG127635-Gesperrte Menüinhalte-FB_MISC_10,blocked ,21
    IDE11502-ENG127636-Gesperrte Menüinhalte-FB_MISC_11,blocked ,21
    IDE11502-ENG127637-Gesperrte Menüinhalte-FB_MISC_12,blocked ,21
    IDE11502-ENG127638-Gesperrte Menüinhalte-FB_MISC_13,blocked ,21
    IDE11502-ENG127639-Gesperrte Menüinhalte-FB_MISC_14,blocked ,21
    IDE11502-ENG127640-Gesperrte Menüinhalte-FB_MISC_15,non_blocked ,21
    IDE11502-ENG127641-Gesperrte Menüinhalte-FB_MISC_16,non_blocked ,21
    IDE11502-ENG127642-Gesperrte Menüinhalte-FB_MISC_17,non_blocked ,21
    IDE11502-ENG127643-Gesperrte Menüinhalte-FB_MISC_18,blocked ,21
    IDE11502-ENG127644-Gesperrte Menüinhalte-FB_MISC_19,blocked ,21
    IDE11502-ENG127627-Gesperrte Menüinhalte-FB_MISC_2,blocked ,21
    IDE11502-ENG127645-Gesperrte Menüinhalte-FB_MISC_20,blocked ,21
    IDE11502-ENG127646-Gesperrte Menüinhalte-FB_MISC_21,non_blocked ,21
    IDE11502-ENG127647-Gesperrte Menüinhalte-FB_MISC_22,blocked ,21
    IDE11502-ENG127648-Gesperrte Menüinhalte-FB_MISC_23,non_blocked ,21
    IDE11502-ENG127649-Gesperrte Menüinhalte-FB_MISC_24,non_blocked ,21
    IDE11502-ENG127650-Gesperrte Menüinhalte-FB_MISC_25,non_blocked ,21
    IDE11502-ENG127651-Gesperrte Menüinhalte-FB_MISC_26,non_blocked ,21
    IDE11502-ENG127652-Gesperrte Menüinhalte-FB_MISC_27,non_blocked ,21
    IDE11502-ENG127653-Gesperrte Menüinhalte-FB_MISC_28,non_blocked ,21
    IDE11502-ENG127654-Gesperrte Menüinhalte-FB_MISC_29,non_blocked ,21
    IDE11502-ENG127628-Gesperrte Menüinhalte-FB_MISC_3,non_blocked ,21
    IDE11502-ENG127655-Gesperrte Menüinhalte-FB_MISC_30,non_blocked ,21
    IDE11502-ENG127656-Gesperrte Menüinhalte-FB_MISC_31,non_blocked ,21
    IDE11502-ENG127657-Gesperrte Menüinhalte-FB_MISC_32,non_blocked ,21
    IDE11502-ENG127658-Gesperrte Menüinhalte-FB_MISC_33,non_blocked ,21
    IDE11502-ENG127659-Gesperrte Menüinhalte-FB_MISC_34,non_blocked ,21
    IDE11502-ENG127660-Gesperrte Menüinhalte-FB_MISC_35,non_blocked ,21
    IDE11502-ENG127661-Gesperrte Menüinhalte-FB_MISC_36,non_blocked ,21
    IDE11502-ENG127662-Gesperrte Menüinhalte-FB_MISC_37,non_blocked ,21
    IDE11502-ENG127663-Gesperrte Menüinhalte-FB_MISC_38,non_blocked ,21
    IDE11502-ENG127664-Gesperrte Menüinhalte-FB_MISC_39,non_blocked ,21
    IDE11502-ENG127629-Gesperrte Menüinhalte-FB_MISC_4,non_blocked ,21
    IDE11502-ENG127665-Gesperrte Menüinhalte-FB_MISC_40,non_blocked ,21
    IDE11502-ENG127666-Gesperrte Menüinhalte-FB_MISC_41,non_blocked ,21
    IDE11502-ENG127667-Gesperrte Menüinhalte-FB_MISC_42,non_blocked ,21
    IDE11502-ENG127668-Gesperrte Menüinhalte-FB_MISC_43,non_blocked ,21
    IDE11502-ENG127669-Gesperrte Menüinhalte-FB_MISC_44,blocked ,21
    IDE11502-ENG127670-Gesperrte Menüinhalte-FB_MISC_45,blocked ,21
    IDE11502-ENG127671-Gesperrte Menüinhalte-FB_MISC_46,blocked ,21
    IDE11502-ENG127672-Gesperrte Menüinhalte-FB_MISC_47,blocked ,21
    IDE11502-ENG127630-Gesperrte Menüinhalte-FB_MISC_5,blocked ,21
    IDE11502-ENG127631-Gesperrte Menüinhalte-FB_MISC_6,non_blocked ,21
    IDE11502-ENG127632-Gesperrte Menüinhalte-FB_MISC_7,non_blocked ,21
    IDE11502-ENG127633-Gesperrte Menüinhalte-FB_MISC_8,non_blocked ,21
    IDE11502-ENG127634-Gesperrte Menüinhalte-FB_MISC_9,blocked ,21
    IDE11502-ENG127561-Gesperrte Menüinhalte-FB_NAV_0,blocked ,21
    IDE11502-ENG127562-Gesperrte Menüinhalte-FB_NAV_1,non_blocked ,21
    IDE11502-ENG127571-Gesperrte Menüinhalte-FB_NAV_10,non_blocked ,21
    IDE11502-ENG127572-Gesperrte Menüinhalte-FB_NAV_11,non_blocked ,21
    IDE11502-ENG127573-Gesperrte Menüinhalte-FB_NAV_12,non_blocked ,21
    IDE11502-ENG127574-Gesperrte Menüinhalte-FB_NAV_13,non_blocked ,21
    IDE11502-ENG127575-Gesperrte Menüinhalte-FB_NAV_14,non_blocked ,21
    IDE11502-ENG127576-Gesperrte Menüinhalte-FB_NAV_15,non_blocked ,21
    IDE11502-ENG127577-Gesperrte Menüinhalte-FB_NAV_16,non_blocked ,21
    IDE11502-ENG127578-Gesperrte Menüinhalte-FB_NAV_17,non_blocked ,21
    IDE11502-ENG127579-Gesperrte Menüinhalte-FB_NAV_18,non_blocked ,21
    IDE11502-ENG127580-Gesperrte Menüinhalte-FB_NAV_19,non_blocked ,21
    IDE11502-ENG127563-Gesperrte Menüinhalte-FB_NAV_2,non_blocked ,21
    IDE11502-ENG127581-Gesperrte Menüinhalte-FB_NAV_20,non_blocked ,21
    IDE11502-ENG127582-Gesperrte Menüinhalte-FB_NAV_21,blocked ,21
    IDE11502-ENG127583-Gesperrte Menüinhalte-FB_NAV_22,non_blocked ,21
    IDE11502-ENG127584-Gesperrte Menüinhalte-FB_NAV_23,non_blocked ,21
    IDE11502-ENG127585-Gesperrte Menüinhalte-FB_NAV_24,non_blocked ,21
    IDE11502-ENG127586-Gesperrte Menüinhalte-FB_NAV_25,non_blocked ,21
    IDE11502-ENG127587-Gesperrte Menüinhalte-FB_NAV_26,non_blocked ,21
    IDE11502-ENG127588-Gesperrte Menüinhalte-FB_NAV_27,non_blocked ,21
    IDE11502-ENG127589-Gesperrte Menüinhalte-FB_NAV_28,non_blocked ,21
    IDE11502-ENG127590-Gesperrte Menüinhalte-FB_NAV_29,non_blocked ,21
    IDE11502-ENG127564-Gesperrte Menüinhalte-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127591-Gesperrte Menüinhalte-FB_NAV_30,non_blocked ,21
    IDE11502-ENG127592-Gesperrte Menüinhalte-FB_NAV_31,non_blocked ,21
    IDE11502-ENG127593-Gesperrte Menüinhalte-FB_NAV_32,non_blocked ,21
    IDE11502-ENG127594-Gesperrte Menüinhalte-FB_NAV_33,non_blocked ,21
    IDE11502-ENG127595-Gesperrte Menüinhalte-FB_NAV_34,non_blocked ,21
    IDE11502-ENG127596-Gesperrte Menüinhalte-FB_NAV_35,non_blocked ,21
    IDE11502-ENG127597-Gesperrte Menüinhalte-FB_NAV_36,non_blocked ,21
    IDE11502-ENG127598-Gesperrte Menüinhalte-FB_NAV_37,non_blocked ,21
    IDE11502-ENG127599-Gesperrte Menüinhalte-FB_NAV_38,non_blocked ,21
    IDE11502-ENG127600-Gesperrte Menüinhalte-FB_NAV_39,non_blocked ,21
    IDE11502-ENG127565-Gesperrte Menüinhalte-FB_NAV_4,blocked ,21
    IDE11502-ENG127566-Gesperrte Menüinhalte-FB_NAV_5,non_blocked ,21
    IDE11502-ENG127567-Gesperrte Menüinhalte-FB_NAV_6,blocked ,21
    IDE11502-ENG127568-Gesperrte Menüinhalte-FB_NAV_7,non_blocked ,21
    IDE11502-ENG127569-Gesperrte Menüinhalte-FB_NAV_8,non_blocked ,21
    IDE11502-ENG127570-Gesperrte Menüinhalte-FB_NAV_9,blocked ,21
    IDE11502-ENG127545-Gesperrte Menüinhalte-FB_PHONE_0,blocked ,21
    IDE11502-ENG127546-Gesperrte Menüinhalte-FB_PHONE_1,non_blocked ,21
    IDE11502-ENG127555-Gesperrte Menüinhalte-FB_PHONE_10,non_blocked ,21
    IDE11502-ENG127556-Gesperrte Menüinhalte-FB_PHONE_11,non_blocked ,21
    IDE11502-ENG127557-Gesperrte Menüinhalte-FB_PHONE_12,non_blocked ,21
    IDE11502-ENG127558-Gesperrte Menüinhalte-FB_PHONE_13,non_blocked ,21
    IDE11502-ENG127559-Gesperrte Menüinhalte-FB_PHONE_14,non_blocked ,21
    IDE11502-ENG127560-Gesperrte Menüinhalte-FB_PHONE_15,non_blocked ,21
    IDE11502-ENG127547-Gesperrte Menüinhalte-FB_PHONE_2,non_blocked ,21
    IDE11502-ENG127548-Gesperrte Menüinhalte-FB_PHONE_3,non_blocked ,21
    IDE11502-ENG127549-Gesperrte Menüinhalte-FB_PHONE_4,blocked ,21
    IDE11502-ENG127550-Gesperrte Menüinhalte-FB_PHONE_5,blocked ,21
    IDE11502-ENG127551-Gesperrte Menüinhalte-FB_PHONE_6,blocked ,21
    IDE11502-ENG127552-Gesperrte Menüinhalte-FB_PHONE_7,blocked ,21
    IDE11502-ENG127553-Gesperrte Menüinhalte-FB_PHONE_8,non_blocked ,21
    IDE11502-ENG127554-Gesperrte Menüinhalte-FB_PHONE_9,non_blocked ,21
    IDE11502-ENG127505-Gesperrte Menüinhalte-FB_TUNER_0,non_blocked ,21
    IDE11502-ENG127506-Gesperrte Menüinhalte-FB_TUNER_1,non_blocked ,21
    IDE11502-ENG127515-Gesperrte Menüinhalte-FB_TUNER_10,non_blocked ,21
    IDE11502-ENG127516-Gesperrte Menüinhalte-FB_TUNER_11,non_blocked ,21
    IDE11502-ENG127517-Gesperrte Menüinhalte-FB_TUNER_12,non_blocked ,21
    IDE11502-ENG127518-Gesperrte Menüinhalte-FB_TUNER_13,non_blocked ,21
    IDE11502-ENG127519-Gesperrte Menüinhalte-FB_TUNER_14,non_blocked ,21
    IDE11502-ENG127520-Gesperrte Menüinhalte-FB_TUNER_15,non_blocked ,21
    IDE11502-ENG127507-Gesperrte Menüinhalte-FB_TUNER_2,non_blocked ,21
    IDE11502-ENG127508-Gesperrte Menüinhalte-FB_TUNER_3,blocked ,21
    IDE11502-ENG127509-Gesperrte Menüinhalte-FB_TUNER_4,blocked ,21
    IDE11502-ENG127510-Gesperrte Menüinhalte-FB_TUNER_5,blocked ,21
    IDE11502-ENG127511-Gesperrte Menüinhalte-FB_TUNER_6,blocked ,21
    IDE11502-ENG127512-Gesperrte Menüinhalte-FB_TUNER_7,blocked ,21
    IDE11502-ENG127513-Gesperrte Menüinhalte-FB_TUNER_8,non_blocked ,21
    IDE11502-ENG127514-Gesperrte Menüinhalte-FB_TUNER_9,non_blocked ,21
    IDE11503-Tuner für Satellitenradio: voraktiviertes Abonnement,05 ,1
    IDE11524-ENG142156-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42,nicht aktiviert ,192
    IDE11524-ENG142157-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-climate_mastet_0x42_msg_bus,nicht aktiviert ,192
    IDE11524-ENG142158-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47,nicht aktiviert ,192
    IDE11524-ENG142159-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-connection_manager_0x47_msg_bus,nicht aktiviert ,192
    IDE11524-ENG152529-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51,nicht aktiviert ,192
    IDE11524-ENG152530-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-daf_profile_0x51_msg_bus,nicht aktiviert ,192
    IDE11524-ENG137043-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45,nicht aktiviert ,192
    IDE11524-ENG137044-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-display_configuration_0x45_msg_bus,nicht aktiviert ,192
    IDE11524-ENG185772-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D,nicht aktiviert ,192
    IDE11524-ENG185773-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-engine_functions_0x5D_msg_bus,nicht aktiviert ,192
    IDE11524-ENG142168-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D,nicht aktiviert ,192
    IDE11524-ENG142169-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-fas_profile_0x4D_msg_bus,nicht aktiviert ,192
    IDE11524-ENG142154-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41,nicht aktiviert ,192
    IDE11524-ENG142155-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-front_traffic_assist_0x41_msg_bus,nicht aktiviert ,192
    IDE11524-ENG152535-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50,nicht aktiviert ,192
    IDE11524-ENG152536-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-infotainmentsettings_profile_0x50_msg_bus,nicht aktiviert ,192
    IDE11524-ENG185787-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83,nicht aktiviert ,192
    IDE11524-ENG185788-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-mascot_0x83_msg_bus,nicht aktiviert ,192
    IDE11524-ENG152569-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E,nicht aktiviert ,192
    IDE11524-ENG152570-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-remote_services_profile_0x4E_msg_bus,nicht aktiviert ,192
    IDE11524-ENG139202-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44,nicht aktiviert ,192
    IDE11524-ENG139203-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-Soundcontrol_0x44_msg_bus,nicht aktiviert ,192
    IDE11524-ENG127678-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40,nicht aktiviert ,192
    IDE11524-ENG127679-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-spoiler_0x40_msg_bus,nicht aktiviert ,192
    IDE11524-ENG142162-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A,nicht aktiviert ,192
    IDE11524-ENG142163-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-statistic_0x4A_msg_bus,nicht aktiviert ,192
    IDE11524-ENG142164-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B,nicht aktiviert ,192
    IDE11524-ENG142165-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_front_0x4B_msg_bus,nicht aktiviert ,192
    IDE11524-ENG142166-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C,nicht aktiviert ,192
    IDE11524-ENG142167-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-sunroof_rear_0x4C_msg_bus,nicht aktiviert ,192
    IDE11524-ENG185817-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54,nicht aktiviert ,192
    IDE11524-ENG185818-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-vas_0x54_msg_bus,nicht aktiviert ,192
    IDE11524-ENG142160-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48,nicht aktiviert ,192
    IDE11524-ENG142161-Fahrzeug Funktionsliste BAP 2. Generation: Erweiterung-wireless_charging_0x48_msg_bus,nicht aktiviert ,192
    IDE13183-De-/Aktivierung der Popups für aktive Trackingdienste,00 00 00 00 ,4
    MAS00951-Bluetooth,ein ,1
    MAS01968-Lüfter,normal ,1
    MAS02809-MAS02870-Frequenz für Prüfton-Hochton Frequenzbereich,4000 Hz,6
    MAS02809-MAS02871-Frequenz für Prüfton-Mittelton Frequenzbereich,1000 Hz,6
    MAS02809-MAS02872-Frequenz für Prüfton-Tiefton Frequenzbereich,100 Hz,6
    MAS03782-WLAN,ein ,1
    ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,nicht aktiviert ,60
    ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,nicht aktiviert ,60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,nicht aktiviert ,60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,nicht aktiviert ,60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,nicht aktiviert ,60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,nicht aktiviert ,60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,nicht aktiviert ,60
    ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,nicht aktiviert ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,nicht aktiviert ,60
    ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,nicht aktiviert ,60
    ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,nicht aktiviert ,60
    ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,nicht aktiviert ,60
    ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,nicht aktiviert ,60
    ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,nicht aktiviert ,60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,aktiviert ,60
    ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,aktiviert ,60
    ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,nicht aktiviert ,60
    ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,nicht aktiviert ,60
    ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,nicht aktiviert ,60
    ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,nicht aktiviert ,60
    ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,nicht aktiviert ,60
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,nicht aktiviert ,60
    ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,nicht aktiviert ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,aktiviert ,60
    ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,aktiviert ,60
    ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,nicht aktiviert ,60
    ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,nicht aktiviert ,60
    ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,nicht aktiviert ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,aktiviert ,60
    ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,aktiviert ,60
    ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,nicht aktiviert ,60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,aktiviert ,60
    ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,aktiviert ,60
    ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,nicht aktiviert ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,aktiviert ,60
    ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,aktiviert ,60
    ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,nicht aktiviert ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,aktiviert ,60
    ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,aktiviert ,60
    ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,nicht aktiviert ,60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,aktiviert ,60
    ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,aktiviert ,60
    ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,nicht aktiviert ,60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,aktiviert ,60
    ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,aktiviert ,60
    ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,nicht aktiviert ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,aktiviert ,60
    ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,aktiviert ,60
    ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,nicht aktiviert ,60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,aktiviert ,60
    ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,aktiviert ,60
    ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,nicht aktiviert ,60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,aktiviert ,60
    ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,aktiviert ,60
    ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,nicht aktiviert ,60
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,nicht aktiviert ,60
    ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,nicht aktiviert ,60
    ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,nicht aktiviert ,60
    ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,nicht aktiviert ,60
    ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,nicht aktiviert ,60
    ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,nicht aktiviert ,60
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,nicht aktiviert ,60
    ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,nicht aktiviert ,60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,aktiviert ,60
    ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,aktiviert ,60
    ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,nicht aktiviert ,60
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,nicht aktiviert ,60
    ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,nicht aktiviert ,60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,aktiviert ,60
    ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,aktiviert ,60
    ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,nicht aktiviert ,60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,aktiviert ,60
    ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,aktiviert ,60
    ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,nicht aktiviert ,60
    ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,nicht aktiviert ,60
    ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,nicht aktiviert ,60
    ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,nicht aktiviert ,60
    ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,nicht aktiviert ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,aktiviert ,60
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,aktiviert ,60
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,nicht aktiviert ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,nicht aktiviert ,60
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,nicht aktiviert ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,nicht aktiviert ,60
    ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,nicht aktiviert ,60
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,nicht aktiviert ,60
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,nicht aktiviert ,60
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,nicht aktiviert ,60
    ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,nicht aktiviert ,60
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,aktiviert ,60
    ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,aktiviert ,60
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,nicht aktiviert ,60
    ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,nicht aktiviert ,60
    ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,nicht aktiviert ,60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,aktiviert ,60
    ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,aktiviert ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,nicht aktiviert ,60
    ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,nicht aktiviert ,60
    ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,nicht aktiviert ,60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,nicht aktiviert ,60
    ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,nicht aktiviert ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,nicht aktiviert ,60
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,nicht aktiviert ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,nicht aktiviert ,60
    ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,nicht aktiviert ,60
    ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,nicht aktiviert ,60
    ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,nicht aktiviert ,60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,aktiviert ,60
    ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,aktiviert ,60
    ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,nicht aktiviert ,60
    ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,nicht aktiviert ,60
    ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,nicht aktiviert ,60
    ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,nicht aktiviert ,60
    ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,nicht aktiviert ,60
    ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,nicht aktiviert ,60
    ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,nicht aktiviert ,60
    ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,nicht aktiviert ,60
    ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,nicht aktiviert ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,nicht aktiviert ,60
    ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,nicht aktiviert ,60
    ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,nicht aktiviert ,60
    ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,nicht aktiviert ,60
    ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,nicht aktiviert ,60
    ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,nicht aktiviert ,60
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,nicht aktiviert ,60
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,nicht aktiviert ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,aktiviert ,60
    ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,aktiviert ,60
    ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,nicht aktiviert ,60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,aktiviert ,60
    ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,aktiviert ,60
    ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,nicht aktiviert ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,nicht aktiviert ,60
    ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,nicht aktiviert ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,aktiviert ,60
    ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,aktiviert ,60
    ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,nicht aktiviert ,60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,aktiviert ,60
    ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,aktiviert ,60
    ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,nicht aktiviert ,60
    ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,nicht aktiviert ,60
    ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,nicht aktiviert ,60
    ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,nicht aktiviert ,60
    ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,nicht aktiviert ,60
    ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,nicht aktiviert ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,nicht aktiviert ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Datenbus Extended ,64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,nicht aktiviert ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Datenbus Fahrwerk ,64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,nicht aktiviert ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Datenbus Infotainment ,64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,nicht aktiviert ,64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,nicht aktiviert ,64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,nicht aktiviert ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,aktiviert ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Klemme 15 ,64
    ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,nicht aktiviert ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Datenbus Antrieb ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,aktiviert ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Datenbus Infotainment ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,aktiviert ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Datenbus Fahrwerk ,64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,aktiviert ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,aktiviert ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Datenbus Infotainment ,64
    ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,nicht aktiviert ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,aktiviert ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,nicht aktiviert ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,aktiviert ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,nicht aktiviert ,64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,nicht aktiviert ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,nicht aktiviert ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,aktiviert ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,nicht aktiviert ,64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,nicht aktiviert ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,aktiviert ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,nicht aktiviert ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,aktiviert ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,nicht aktiviert ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,nicht aktiviert ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Datenbus Antrieb ,64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,aktiviert ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,nicht aktiviert ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Datenbus Extended ,64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,aktiviert ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,nicht aktiviert ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Datenbus Infotainment ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,aktiviert ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,nicht aktiviert ,64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,nicht aktiviert ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,nicht aktiviert ,64
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Klemme 15 ,64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,nicht aktiviert ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,nicht aktiviert ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Datenbus Extended ,64
    ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,nicht aktiviert ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Datenbus Infotainment ,64
    ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,nicht aktiviert ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,nicht aktiviert ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Datenbus Antrieb ,64
    ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,nicht aktiviert ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Datenbus Komfort ,64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,nicht aktiviert ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Datenbus Komfort ,64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,nicht aktiviert ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Datenbus Komfort ,64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,aktiviert ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,nicht aktiviert ,64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,nicht aktiviert ,64
    ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,nicht aktiviert ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Datenbus Komfort ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,nicht aktiviert ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Datenbus Infotainment ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,aktiviert ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Datenbus Extended ,64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,aktiviert ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Datenbus Fahrwerk ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,nicht aktiviert ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Datenbus Extended ,64
    ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,nicht aktiviert ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Datenbus Komfort ,64
    ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,nicht aktiviert ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,nicht aktiviert ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Klemme 15 ,64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,aktiviert ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Datenbus Komfort ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,aktiviert ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Datenbus Infotainment ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,nicht aktiviert ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Datenbus Infotainment ,64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,aktiviert ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Datenbus Komfort ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,nicht verfügbar ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Datenbus Komfort ,8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,nicht verfügbar ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Datenbus Infotainment ,8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,verfügbar ,8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Datenbus Infotainment ,8
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,nicht verfügbar ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Datenbus Antrieb ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,nicht verfügbar ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Datenbus Fahrwerk ,8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,nicht verfügbar ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Datenbus Komfort ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Datenbus Komfort ,8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,nicht verfügbar ,8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,verfügbar ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Datenbus Komfort ,8
    ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,aus ,10
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,aus ,10
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,aus ,10
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,aus ,10
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,aus ,10
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
    ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
    ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,aktiviert ,5
    ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,aktiviert ,5
    ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,aktiviert ,5
    ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,aktiviert ,5
    ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,nicht aktiviert ,5
    ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,nicht aktiviert ,5
    ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,nicht aktiviert ,5
    ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,nicht aktiviert ,5
    ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,aktiviert ,5
    ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,nicht aktiviert ,5
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
    ENG117808-p_HMI_Display,13 %,1
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    	SW:5NA-920-850-B   HW:5NA-920-850-B ---  Schalttafeleinsatz
    	Bauteil:KOMBI         380 0310, Codierung:0BA40C1AA388CF0500882B0954000000A0000000
    	EV_DashBoardVDDMQBAB,009060,EV_DashBoardVDDMQBAB_009_VW37.rod
    	Freitag,02,August,2019,12:46:05:49457
    	VCDS Version: PCI 18.9.1  Datenstand: 20190520 DS296.1
    	VCID: 3E24CA1E60FBA6E7AC1-806A
    IDE00295-Öltemperaturanzeige,ein ,1
    IDE00301-Wegstrecke,8976 km,3
    IDE00342-WIV: Rücksetzen der WIV,Warnung aktiv ,1
    IDE00343-Sprachvariante,Englisch (US) ,1
    IDE00345-MAS00234-MFA3-Reset-MFA-Taste RESET / OK,manueller Reset: nicht möglich ,3
    IDE00345-MAS05463-MFA3-Reset-Nachtankerkennung Benzin / Diesel,MFA3-Reset ,3
    IDE00345-MAS05464-MFA3-Reset-Nachtankerkennung Gas,MFA3-Reset ,3
    IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset ,3
    IDE00499-Anzeigekorrektur Verbräuche und Reichweite,100 %,1
    IDE00500-Stunde,12 H,1
    IDE00501-Minute,46 min,1
    IDE00502-Jahr,2019 yr,2
    IDE00503-Monat,8 mon,1
    IDE00504-Tag,2 d,1
    IDE00510-WIV: Wegstrecke ab Inspektion,8977 km,3
    IDE00511-WIV: Zeit ab Inspektion,373 d,2
    IDE00512-WIV: Minwert Km-Fahrleistung/Inspektion,15000 km,2
    IDE00513-WIV: Maxwert Km-Fahrleistung/Inspektion,30000 km,2
    IDE00514-WIV: Maxwert der Zeit zwischen den Inspektionen,730 d,2
    IDE00515-WIV: Ölqualität,schlechte Ölqualität ,1
    IDE00517-WIV: Rußeintrag,0 km,2
    IDE00518-WIV: thermische Belastung,20100 km,2
    IDE00819-Tageszähler,371 d,2
    IDE00820-Aktivieren und Deaktivieren aller Entwicklungsbotschaften,nicht aktiv ,1
    IDE00827-WIV: Minwert der Zeit zwischen den Inspektionen,365 d,2
    IDE01153-SIA: Maxwert der Strecke bis Service,16100 km,2
    IDE01154-SIA: Maxwert der Zeit bis Service,365 d,2
    IDE02489-Displaydarstellung,Variante 1 ,1
    IDE02818-IDE02689-Offset für Werte der Tankkalibrierung (-eichung)-Tank Vollkalibrierung (-eichung),-12.8 l,5
    IDE02818-MAS02376-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 1,-12.8 l,5
    IDE02818-MAS02377-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 2,-12.8 l,5
    IDE02818-MAS02378-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 3,12.7 l,5
    IDE02818-MAS02379-Offset für Werte der Tankkalibrierung (-eichung)-Offset Geber 4,12.7 l,5
    IDE03329-Fahrprofil für Restreichweite,8.3 l/100km,2
    IDE03346-IDE00301-Eingestellte Einheiten-Wegstrecke,Kilometer ,3
    IDE03346-MAS01230-Eingestellte Einheiten-Datum,mm_dd_jj ,3
    IDE03346-MAS01456-Eingestellte Einheiten-Geschwindigkeit,Kilometer pro Stunde ,3
    IDE03346-MAS02201-Eingestellte Einheiten-Temperatur,Grad Celsius ,3
    IDE03346-MAS02957-Eingestellte Einheiten-Uhrzeit,24h ,3
    IDE03346-MAS03032-Eingestellte Einheiten-Volumen,Liter ,3
    IDE03346-MAS03034-Eingestellte Einheiten-Druck,bar ,3
    IDE03346-MAS05637-Eingestellte Einheiten-Verbrauch CNG (komprimiertes Erdgas),kg pro 100 km ,3
    IDE03346-MAS05638-Eingestellte Einheiten-Verbrauch Benzin / Diesel / LPG (Flüssig-/Autogas),Liter pro 100 km ,3
    IDE03346-MAS05875-Eingestellte Einheiten-Durchschnittsverbrauch Elektroantrieb,kWh pro 100 km ,3
    IDE03346-MAS13665-Eingestellte Einheiten-Anhänge-/Stützlast Masse,Kilogramm (kg) ,3
    IDE03348-MAS01456-Geschwindigkeitswarnung-Geschwindigkeit,0 ,2
    IDE03348-MAS01561-Geschwindigkeitswarnung-Einheit,Kilometer pro Stunde ,2
    IDE03348-Geschwindigkeitswarnung-,nicht aktiv ,2
    IDE03349-Fix:Max. Fahrstrecke bis nächste laufleistungsabhängige Inspekt,32200 km,2
    IDE03350-FIX: Maximale Zeit bis zur nächsten zeitabhängigen Inspektion,730 d,2
    IDE03351-FIX:Fahrstrecke seit letzter laufleistungsabhängiger Inspektion,8900 km,2
    IDE03352-FIX: Zeit seit letzter zeitabhängiger Inspektion,373 d,2
    IDE03372-Quelle für Synchronisation der Uhrzeit,GPS ,1
    IDE03568-ENG119828-Service-Key Einstellungen-p_deactivate_SK_Function,ein ,5
    IDE03568-ENG99943-Service-Key Einstellungen-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG119827-Service-Key Einstellungen-p_main_switch_Basic,ein ,5
    IDE03568-ENG102414-Service-Key Einstellungen-p_main_switch_keyless,ein ,5
    IDE03568-ENG102611-Service-Key Einstellungen-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-Key Einstellungen-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-Key Einstellungen-p_write_distance,20 km,5
    IDE03867-Gurtwarnung deaktivieren,nein ,1
    IDE05930-Servicevorwarnung in Tage,30 d,1
    IDE05931-FIX: Rücksetzwert für die nächsten laufleistungsabh. Inspekt.,32200 km,2
    IDE05932-FIX: Rücksetzwert für die nächsten zeitabhängigen Inspektionen,730 d,2
    IDE05971-Schnittstellensteuergerät für Fahrzeugortungssystem,nicht verbaut ,1
    IDE06425-Rollenprüfstandmodus: funktional,nicht aktiviert ,1
    IDE06588-Zündung aktiv Meldung: Auslöser,Fahrertür ,1
    IDE06922-Anzeige Spannungsfreiheit,Unbekannt (2),1
    IDE07221-Zylinderabschaltung,Anzeige ,1
    IDE11086-Servicevorwarnung,30 d,1
    IDE11932-MAS01877-Display Farbabgleich-Rot,0 ,3
    IDE11932-MAS01878-Display Farbabgleich-Grün,0 ,3
    IDE11932-MAS01879-Display Farbabgleich-Blau,0 ,3
    IDE12226-MAS03686-Anzeigen Längsregelkoordinator-Automatische Distanzregelung,nicht aktiv ,1
    IDE12226-MAS05203-Anzeigen Längsregelkoordinator-GRA,nicht aktiv ,1
    IDE12226-MAS10720-Anzeigen Längsregelkoordinator-Geschwindigkeitsbegrenzer,nicht aktiv ,1
    MAS03685-Digitaltachometer,Anzeige ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
    ENG119875-defuel_threshold,9 l,1
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,10 ,12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0E ,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
    ENG119874-Gas_functionality,nicht aktiv ,1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
    ENG119882-init_fuel_algorithm,nein ,1
    ENG130585-Leaving_warning_delay,1.6 s,1
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
    ENG119825-Picture_Upload_Download,nicht aktiv ,1
    ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
    ENG119876-Service_Key_Clear_All_Counter,ja ,1
    ENG130584-Statistic_phev_mileage,5 km,1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,nicht aktiv ,4
    2017 Ford Mustang Shelby GT350 (FUN), 2019 VW Passat 2.0 TDI 4Motion (Daily-Company-Car), 2018 VW Tiguan SE (Wife)
    VCDS, ETKA, Erwin, ODIS with FAZIT Online Access
    Prior cars:
    Fiat Bravo 1.6, Fiat Marea 1.6, Audi 80 2.6, Audi A4 2.6, Audi A4 2.4, Audi A6 2.8, Audi V8 3.6 & 4.2, Fiat Marea 1.6, Passat 2.0TDI, Mustang 3.7, Ford Taurus SHO, Mustang 5.0, Lincoln MKS
    Feb 2018
    SLC
    I believe the 5F Languages are set using parameterization. When I put a Discover Media in my GTI I had to upload the parameter files with VCP, one of which was the Language packs.
    Although, I could very well be wrong, I'm still pretty new to all this.
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
  3. Likes Dana liked this post
    May 2017
    ^ you are correct. That is the way to add languages to the MIB unit.
  5. Likes Dana liked this post
  6. #4
    Nov 2018
    Germany, Erfurt
    Thank you guys! Do I assume right that this only changes the ability to install EU updates? Meaning after I have changed the language parameter, I would need the EU update to install on the system?
    May 2017
    Not an update, new dataset. Different thing. Datasets contain parameters with what you can modify the characteristics how the system performs. Like change the language packs, change the audio profile etc.
    Vcds is not able to update datasets they need to be flashed to the units eeprom
    Nov 2018
    Germany, Erfurt
    Got it.
    As I want to get DAB instead of the dead Sirius anyway, I went ahead and bought a 5F from a german Tiguan. Will see if ODIS automatically changes the dataset back to NAR when I remove CP.
    If it does, I can still go ahead and order VCP...
    I found a thread for MIB2 in 2017+ Audi models saying that the language parameters cannot be overwritten via VCP (OBD) anymore but that you have to gain physical Telnet access to the unit. Any knowledge if this is the same for the VW 5Fs?
    Anyhow, lets hope it stays german after removing CP, I will update this thread anyway with the result.
    May 2017
    If you only remove CP, it should not change anything in ODIS. If you run the online coding and parameterization of the unit, then bye bye languages. Is the speaker configuration the same on both yours and the german Tiguan? If not, that will probably pose a problem.
    Remember to restore feature enable codes to the new unit. Otherwise you don't have navi or bluetooth.
  10. #8
    Nov 2018
    Germany, Erfurt
    @Downtime
    Its possible that the speakers are different as I believe the one I bought is a HIGH model, not standard but not 100% certain by the part number (has the MOST connector though).
    I will see if it has audio problems after CP removal and coding, was really cheap for test purposes so not to concerned about this.
    Will restore features but the US SE model has nothing fancy besides APP LINK and BT but no NAVI
    @All
    I found some answers to my other questions myself, maybe they help someone:
    Sirius deactivation:
    - It looks like Sirius CANT be deactivated according to all the research I did on this. Makes sense I guess, as Sirius wants to stay present in case a (new) customer decides to reactive his subscription
    Radio preset store problem:
    - Are resolved and were caused by incorrect coding. The 5F through an "incorrect coding" DTC and therefor didn't store ANY settings of the radio anymore, this also affected other settings like audio balance ect. and not only the radio presets
    - I went ahead and re-coded the unit with ODIS/FAZIT to factory specs and than went ahead and just changed the FM frequencies from NAR to EU. Now works like a charm and I will change the other codings step by step and see which one it didn't like.
  11. Likes Uwe, downtime, jyoung8607, Dana liked this post
  12. #9
    Nov 2018
    Germany, Erfurt
    Hi Folks,
    making progress here and want to give an update. New unit came, plugged in and changed language to German. As assumed, cluster changed instantly to German as well
    It had Appconnect and BT activated but Voice was missing. Removed CP which worked fine but than App Connect ect. was gone as expected.
    Problem was, that SVM process detects a wrong module for the car and does not allow any adaptions. LUCKILY ODIS allows restore of FEC codes by VIN and strangely didn't care about the non matching module during this process.
    All functions restored including Appconnect, BT and Voice. It also checked SW version during this process but did not change back to NAR image, so still German available. Also DAB is still active
    So now its homework to code with VCDS and than I believe we will be fine beside the wrong software DTC which I dont really care about as long as it works....
    Will keep you posted.
    Prior cars:
  13. Likes downtime, Uwe, jyoung8607 liked this post
  14. #10
    May 2017
    Good work.
    Check software version management error is the easiest to get rid of. Instructions here : https://forums.ross-tech.com/showthr...l=1#post126709
  15. Likes apial, Uwe, Dana liked this post
