Results 1 to 10 of 12
Thread: ACC is not working
    Feb 2016
    ACC is not working
    I had some problems with my previous Passat B8 so I got another one.
    The person i bought it from has made some changes with a VCDS? cable and could not change it anymore.
    So when i got the car I made a log with my genuine Ross Tech cable.
    The first fault in 5F is because the navi screen was changed to a later model, I think this has smething to do with a hash code?
    But i dont mind this one so much. The second one there is no camera installed.
    the one were i have problems with is that the ACC is not working. And all the faults it is giving in 1 engine and 13 ACC.
    The guy told me he has being playing around with some adaptations but did not remember were.
    I have went true a lot of adaptations and other settings but I don't know were the problem is.
    Is there someone who could help me with this problem??
    Regars Jaap
    Friday,02,August,2019,14:10:51:23330
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ3CZGE163400   License Plate: 2-8-19
    Mileage: 58944km-36626mi   Repair Order:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
              6D BB BC
    VIN: WVWZZZ3CZGE163400   Mileage: 58944km-36626miles
    Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 3G0 906 264     HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 0925001A2474050B3000
       Shop #: WSC 05311 115 00322
       ASAM Dataset: EV_ECM18TFS0203G0906264 001007
       ROD: EV_ECM18TFS0203G0906264_VW48.rod
       VCID: 6596451A85E4740F59F-8030
    17176 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:05:51
                        Coolant temperature: 68 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 12.343 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    Readiness: 1110 0001
       Part No SW: 0CW 300 048 R    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0610
       Revision: 00005005    Serial number: CU501512306528
       Shop #: WSC 05311 115 00068
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4BC293A20340A27F6FB-801E
       Revision: 00000000    Serial number: 60116000000586
       Coding: 0FEC6A8F34262B6F077B060041C349F0562CD4E0608292F51842F078C209
       Shop #: WSC 00015 115 00001
       VCID: 7AAC06661C5AEBF784D-802E
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0710
       Revision: 00026000    Serial number: 0392280444
       Coding: 000F0F0F03
       ASAM Dataset: EV_KessyHellaMQBAB 004032
       VCID: 392ED96A59DC20EFCD7-806C
       Part No SW: 5G1 907 044 J    HW: 5G1 907 044 J
       Component: Climatronic   H04 1202
       Revision: 00001K10
       Coding: 12020004204101011015504C00101802
       ASAM Dataset: EV_ACClimaBHBVW37X 005137
       ROD: EV_ACClimaBHBVW37X_005_VW37.rod
       VCID: 2F3AE7329798FE5F633-807A
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86582912151648
       Coding: 00031A46C2C102FF53C44004001457081C80000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 03527B826B90AA3FD7B-8056
       Component: WWS    151215  042 0607
       Serial number:         160112021047
       Component: RLHS  037 0059
       Serial number: S5Y16M01D25H00M31S50
       Coding: 90A8DD
       Light switch:
       Serial number: 31 10 2015  10001183
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391601402578
       Coding: 0071051911
       VCID: 44D0B89E2E1E6D07AE1-8010
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200670A51FFC428949C804D
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3430E85E7EBEDD871E1-8060
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_ALIGNMENT_NOT_OK]
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:04:40
                        Control Module temperature: 42 °C
                        Voltage terminal 15: 12.2 V
                        Status_ACC_System: ACC_irreversible error
    2141 - Databus
              [FAULT_DIS_FAIL]
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:04:40
       Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003STP188F4Z
       Coding: 88CCC000008000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F5AF7720778CEDFB33-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 001 101 16
       Serial number: 3576U000000C55610914
       Subsystem 2 - Part No SW: -----------    HW: 454 001 401 16
       Serial number: 3586U000000D53CCF81Z
       Subsystem 3 - Part No SW: -----------    HW: 454 801 212 15
       Serial number: 3516R3DB22A090000006
       Subsystem 4 - Part No SW: -----------    HW: 454 801 212 15
       Serial number: 3526RBD6F7709000000P
       Subsystem 5 - Part No SW: -----------    HW: 454 802 112 15
       Serial number: 3556V4C1960090000005
       Part No SW: 3Q0 953 521 AM    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0205
       Revision: FF034034    Serial number: 20160110500840
       Coding: 0410
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7BA203621360D2FF9FB-802E
       Part No SW: 3G0 920 750 A    HW: 3G0 920 750 A
       Component: KOMBI         301 6421
       Coding: 07A509182B8000080188FF021000000000000000
       VCID: 221C1E06D44A4337FCD-8076
    1048578 - No Basic Setting
              B2010 00 [009] - -
              [Steuergerät keine oder falsche Grundeinstellung]
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:04:39
    16777010 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_LDW_0x19 keine Kommunikation]
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:04:42
       Part No SW: 5Q0 963 272 F    HW: 5Q0 963 272 F
       Component: STH-MQB       007 0072
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001306207
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 09011610520335
       Coding: 0B0300347F015900FB0002581C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 79AE196A195CE0EF8D7-802C
       Serial number: 29150002538530055517
       Coding: 2FFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 8842448603
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Component: WECHSELRICHTE  H55 0033
       Serial number: 0187580
       Analog clock:
       Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Component: Analoguhr  111 1004
       Serial number: 1011201500010136
       Serial number: 16000008193012
       Coding: 0800000000000000
       Shop #: WSC 00015 115 08193
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BE214A412CA8AF357-8024
       Serial number: 221015BJL11935
       Coding: 00350B208000020000001000
       VCID: 43D2BB822B106A3F97B-8016
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 0103
       Shop #: WSC 00015 115 00322
       Serial number: 291015BJN02962
       Coding: 003501208000020000001000
       VCID: 42DCBE86340A63379CD-8016
       Coding: 03DA010009000000
       Shop #: WSC 05311 000 00001
       VCID: 75B6155A3544848FE9F-8020
       Part No SW: 3Q0 035 846     HW: 3Q0 035 846
       Component: MU-S-N-ER     820 0624
       Coding: 02840201FF00000051110001000808031F0100C401200100CF
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 6E843A365012B757285-803A
       Component: ABT_Std-2_Nav  H34 8074
       Serial number: VWZ6ZDS2240005
       Subsystem 2 - Part No SW: 5NA 919 866 AG    HW: -----------
       Component: ECE AS 2020  --- 1310
              B201A 00 [009] - -
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:04:40
                        Voltage terminal 30: 12.2 V
                        Status_Software_Version_Management-module_name: C
    7179 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:04:44
                        BAP-BAP_Function_ID: 02
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0203
       Revision: 8A001003    Serial number: 0392347641
       Coding: 0100000202000000
       VCID: 3B22C36253E012FFDFB-806E
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30421177000000
       Coding: 0280
       ASAM Dataset: EV_DeckLidCONTIAU736 001012
       VCID: 3FDAB77247F80EDFF33-806A
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 251115BKP04299
       Coding: 000001200100020000001000
       Shop #: WSC 53469 001 1048576
       Serial number: 251115BKP0429C
    End----------(Elapsed Time: 02:23, VBatt start/end: 12.2V/12.2V)-----------
    May 2017
    What happened to the car? Software update done to components?
              B2010 00 [009] - -
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
    And did you bump the radar into something?
              C1103 00 [009] - -
                        Reset counter: 253
                        Mileage: 58944 km
                        Date: 2019.08.02
                        Time: 14:04:40
    Feb 2016
    No there was no updates done or bumps.
    May 2017
    If you're absolutely sure that the ACC radar has not moved, you can zero the error by going into the ACC module and running the basic setting for the ACC adjustment. Can't remember the exact name of the basic setting item but it just sets the current position of the radar as the set values for it.
    Now, if it has really moved this won't probably fix the issue as at some point it will flag the same error again as the degree of deviation from the set value will grow too high.
    The instrument cluster basic setting is a new one. I've never seen that instruments need a basic setting as well
    And here's the instructions how to remove the first error in 5F :
    https://forums.ross-tech.com/showthr...ll=1#post96873
    And here's the calculator you can use :
    http://audienthusiasts.com/Application_SVMError.html
    Just scroll down to the almost bottom of the page.
    Feb 2016
    I looked in the basic settings off the ACC module but there nothing for the adjustment.
    Maybe somebody can post a Admap of the ACC module.
    May 2017
    Go to module 13 -> Security settings. Use code 20103. Then open Basic settings and choose reset alignment position or zero alignment position (or something like that), press GO. That should remove the incorrect position error if the module has not moved.
  7. Likes Uwe liked this post
    Feb 2016
    I tried it again with the security code but there is nothing to choose like reseting the alignment.
    In the picture you can see the options I get.
  9. #8
    Jun 2019
    Leicester, UK
    With regards to the SVM error, I got rid of the issue on mine by following the guide here:
    https://www.audienthusiasts.com/Appl..._SVMError.html
    Steve
  10. #9
    May 2017
    Quote Originally Posted by jaap View Post
    Picture is not showing up. The dropbox is not a good pic sharing service. Try something like flickr.
  11. Likes Uwe, PetrolDave liked this post
  12. #10
    Feb 2016
    Can you see it now?
