Hello
Praveen here, bought a VCDS scan tool recently and posting for the first time.
I have received a Audi Q5 2010 model year car with the following fault code i.e. P17D8 00 (040)
would like to know if there is any other further details that I can get from the VCDS about the excessive clutch temperature or should it possibly be one of the clutches that has failed and causing the high temperature.
Also is it possible to drill down into further details as to which of the clutches is causing the problem.
Copied below is the scan report.
Saturday,27,July,2019,19:03:02:48250
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: License Plate: KA20P2323
Mileage: 87140km-54146mi Repair Order: 003
VIN: WAUZFA8R4AY700022 Mileage: 87140km-54146miles
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8R0 927 156 H HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H03 0003
Revision: --H03--- Serial number: 0000000430
Coding: 000001
Shop #: WSC 90001 000 00000
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: C0CCC5445B3F394F59-8094
8040 - Torque Restriction due to Clutch Temperature
P17D8 00 [040] - -
Serial number: 00000000002602100868
Regards,
Praveen.
Coding: 000001
P17D8 00 [040] - -
Regards,
Praveen.
