New VW T-Cross, just broken in, no mods yet. Unsure about the exact engine code so I pasted both CHZD and CHZJ.
The cable has paid itself in half already - I saved $155 on skipping the Light Assist upcharge because it can be activated later in this particular car Just need to figure it out how
Thursday,11,July,2019,21:15:26:33127
VIN: WVGZZZC1ZKY0xxxxx   License Plate:
Mileage: 1366km-848mi   Repair Order:
Chassis Type: C1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 44 55 5F 75 A5 D6 D7
VIN: WVGZZZC1ZKY0xxxxx   Mileage: 1366km-848miles
Address 01: Engine (J623-DKRF)       Labels: None
   Part No SW: 04C 906 025 K    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6203
   Revision: D7H20000
   Coding: 0125003223641D081000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS01104C906025K 002002
   ROD: EV_ECM10TFS01104C906025B_002_VW27.rod
   VCID: 2809F948027B0D37A29-807C
   Part No SW: 0CW 300 043     HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1604
   Revision: 00005008    Serial number: CU501903216113
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 74B1DD388E3339D7DE1-8020
   Part No SW: 2Q0 614 517 AF    HW: 2Q0 614 517 M
   Component: ESC_high_vFGS H34 0342
   Serial number: 08506323190125
   Coding: 92054C3E3D4349B332FCBC1D12DD11A649264D46226A244844546254454888659264B26244562412222A462AA269D64FFD966BF2BF
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 72BDDB20F42737E7CCD-8026
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0510280409
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 43D34EE49B1DCE6F97B-8016
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 2G0 907 044 N    HW: 2G0 907 044 N
   Component: Climatronic   H03 0601
   Coding: 6120000008000100011008000244010D0100000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004022
   ROD: EV_ACClimaBHBMQBA0_VW27.rod
   VCID: 2F3B125427955A0F633-807A
   Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
   Component: BCM A0 Std+   H98 0926
   Serial number: 00001907901535
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 303911283AAB45F77A9-8064
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S6Y19M04D02H08M25S42
   Coding: 0018DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 2Q2 959 405     HW: 2Q2 959 163
   Component: FHSG_DRV  002 0005
   Serial number: 00000000000026164621
   Coding: 0300F0
   Subsystem 3 - Part No SW: 2Q2 959 406     HW: 2Q2 959 164
   Component: FHSG_PSG  002 0005
   Serial number: 00000000000026159405
   Coding: 1900F0
   Subsystem 4 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000029113756
   Coding: 030000
   Subsystem 5 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000029159000
   Coding: 1B0000
   Serial number: 000308418019086
   Coding: 0471155851
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4CC165D8B6430117661-8018
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 3204670248FF8748949C810580508700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 42DD4BE08407C7679CD-8016
   Part No SW: 2Q0 959 655 AK    HW: 2Q0 959 655 AK
   Component: VW22Airbag    010 0350
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000C40A80065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001014
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 065597F0E8AF3B47F05-8052
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 654 980 945     HW: 654 980 945
   Component: BeltPretRevFL  003 0050
   Serial number: 278A-001705041900148
   Coding: 303530
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 654 980 946     HW: 654 980 946
   Component: BeltPretRevFR  003 0050
   Serial number: 278A-000305041900644
   Coding: 303530
   Subsystem 3 - Part No SW: -----------    HW: 442 063 003 19
   Serial number: 3577Y21AD3040131210B
   Subsystem 4 - Part No SW: -----------    HW: 442 063 003 19
   Serial number: 3587Y21AD3040131031D
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 903 19
   Serial number: 3517780AB2FAE641A30V
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 903 19
   Serial number: 3527780AB2FAE646921-
   Subsystem 7 - Part No SW: -----------    HW: 442 131 803 19
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11BD2F9FE65867N
   Part No SW: 2G0 920 790 A    HW: 2G0 920 790 A
   Component: KOMBI         508 1701
   Coding: 04A4111C6D8800080188620B5001000800000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 2517F07C7569105F99F-8070
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009273026
   Coding: 030100046F085600FA00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E85CF50E01F1307285-803A
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036089190475
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 10105066
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000085831003
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313F142C31A14CFF757-8064
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 00000511954683
   Coding: 50014500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: EV_HREntryHellaGen3Kl15_001_VW48.rod
   VCID: 38292908D2DB9DB7329-806C
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6041
   Serial number: 01148079CP3K102
   Coding: 010000010100000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3C213518E6E3B197D61-8068
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 068A000001200003
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DF44EC8101DC7F857-8014
   Part No SW: 2GM 035 864     HW: 2GM 035 864
   Component: MU-S-N-ER     H41 0475
   Serial number: VWZAZ2W0805067
   Coding: 02120601BE0000004111000100080A001F0500F401200000CE
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 55F780BC658940DFC9F-8000
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJW0952028
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 022106016AB6140D0100040000354003804600
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: 3D27381CFDF9B89FE1F-8068
   Part No SW: 3Q0 980 654 R    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0460
   Serial number: 01041915P13961
   Coding: 0002070600000401002213548156440084000E20000000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002_VW27.rod
   VCID: 46D557F0A82FFB47B05-8012
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 571 AC    HW: 992 941 571 A
   Component: LED1L         H08 9201
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X.rod
   VCID: 6393AE643BDDAE6FB7B-8036
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9201
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:18, VBatt start/end: 12.2V/12.2V)-----------
