2017 MK7R - Mirror Dip Issues
Mosquito
C?ID=14113
Hi.
I am trying to sort out an issue where mirror dip is no longer working.
Back in 2017 I modified my stock coding on module (52), Byte 4 to include bit 2 & 3. Since then mirror dip functioned as expected and always going back up with 90% accuracy.
It wasn't perfect, but it worked well.
This past week I decided to click and include bit 1 (mirror memory w/ memory seats) to the coding and see if I was lucky enough to have a perfect functioning mirror dip.
Not only was I not, but now mirror dip does not work at all. What could it be?
I have since tried everything I can imagine, but it will not dip no matter what.
I've since gone back to original stock programming (have new car backup scan) and proceeded to re-do the original 2017 programming for mirror dip of including bit 2 & 3 only. No luck.
This of course included enabling (09) in adaptation settings in the Infotainment, its mirror/wiper settings reset as well as assuring the side mirror knob is positioned on the "R" passenger side coupled with the known Park, Reverse, dip, Park, off procedure.
Is there anything I am missing?
I have compared my entire stock new car scan coding to my currently modified coding and found no other long coding differences. I do not have an Adaptation scan backup though so I can't help but wonder.
Is it possible that a long coding change can affect other modules, adaptation channels or even hidden programming within the same module?
I don't have any triggered or stored codes because of it. checked Bit 1 shows 99% X/Y and Active Voltage & Memory and will eventually create a mirror positioning implausible signal error while unchecked it shows 255% X/Y and Uninstalled Voltage & Memory, though the latter always worked without creating any errors.
Any help would be appreciated it. I've searched online everywhere for the last week and have not found one single person with the same issue. It's unlikely nobody has gone through this before.
I've changed long coding before, but never had an issue where I was not able to get it working again by going back to original code.
This is the original new car scan in stock form
Friday,04,November,2016,18:18:59:18648
VCDS Version: 16.8.3.1
VIN: WVWVF7AU4HW07xxxx   License Plate:
Mileage: 414km-257mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 75 A5 A9
VIN: WVWVF7AU4HW07xxxx   Mileage: 414km-257miles
Address 01: Engine (J623-CYFB)       Labels: None
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00122466000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
   ROD: N/A
   VCID: 48B1B1EEF3FB230234-801C
No ASAM data for: "EV_ECM20TFS0208V0906259K" (VW37)
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4937
   Revision: 06354004    Serial number: TFK01607080421
   ROD: EV_TCMDQ250021.rod
   VCID: 538B96823ABD90DA51-8006
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62216000000213
   Coding: 01FA6BA1542709734579030541C56980D62A90A2C0829637184050D8C2A803
   VCID: 7BDB1E22F2ADB89AE9-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0415694328
   Coding: 032C0C
   VCID: 3B5BDE22B22D789AA9-806E
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Revision: 00001K08
   Coding: 00020004200100000105000012111402
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 72C53306A5E7F9D2BA-8026
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061623000116
   Coding: 00011B46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 042965DE8F53C76298-8050
   Component: WWS    160813  043 0551
   Serial number:         160820061829
   Component: RLHS  042 0105
   Serial number: S6Y16M09D05H10M53S35
   Coding: 00A8DD
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39331624602444
   Coding: 0071155011
   VCID: 43ABA6C2CADD005AE1-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 350000C151FFC428949C8045000016
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: N/A
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
   Serial number: 11081641350344
   ROD: EV_DRCONTITEMIC.rod
   VCID: 3851C12E831B538244-806C
   Serial number: 003GCR05LJU4
   VCID: 47B3B2D2FEE52C7A3D-8012
   Occupant Detection:
   Serial number: IBH000000000005MSLB4
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 003 108 16
   Serial number: 357000000003A21D0D1F
   Subsystem 3 - Part No SW: -----------    HW: 480 002 608 16
   Serial number: 3580000000028C8C0E1U
   Subsystem 4 - Part No SW: -----------    HW: 480 402 008 16
   Serial number: 35100029F215E1E2301Z
   Subsystem 5 - Part No SW: -----------    HW: 480 400 606 16
   Serial number: 3520002B92076365F2F7
   Subsystem 6 - Part No SW: -----------    HW: 480 400 808 16
   Serial number: 3550002B521FBE83D3DS
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 708 16
   Serial number: 35600029D2095062039V
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 13081604220541
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_SK48.rod
   VCID: 093774EAA8719A0AEB-805C
   Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
   Component: KOMBI         304 8311
   Coding: 0BAD081A7F88CF0502886B0B5400000000000000
   VCID: 2F43FA727655943A15-807A
   Revision: --------    Serial number: 0005263671
   Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CD91D3EF7A3BFA2E0-8028
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S
   Serial number: 29160001259320106263
   Coding: 35FFFF
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00018.07.16
   Coding: 0001
   VCID: 4AB58BE6EDF7D11222-801E
   Revision: 00000000    Serial number: 16000131082008
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3449F51E9F73B7E268-8060
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H12 0071
   Serial number: 0414177386
   Coding: 02011103
   ROD: EV_HREntryHella.rod
   VCID: 3C59DD3EB7237FA2A0-8068
   Lane Change Assistant 2:
   Serial number: 010616EF106162
   Coding: 003E13208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000011414783
   Coding: 111000
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A55DB26BD174192B2-806E
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H30 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA0274L+
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6DFF207ABCD9262A67-8038
   Serial number: 290516EES08005
   Coding: 003E13208000040000800000
   VCID: 42A5A3C6D5C70952EA-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000011155584
   Coding: 091000
   Coding: 022202010B000400
   VCID: 40A1A9CEDBCB1B42FC-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0751
   Coding: 027300020000000051220002001808009F0207F401200105C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3245F3066567B9D27A-8066
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX00840
   Subsystem 2 - Part No SW: 3G0 919 866 AC    HW: -----------
   Component: NAR 2016/17  --- 0445
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 19081611P22253
   Coding: 0003070000000201002213548040490084000E100020
   ROD: EV_MFKBoschMQBB.rod
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 160622202345
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
End-------------------------(Elapsed Time: 05:18)--------------------------
This is the current 45K scan with mirror dip enabled. It replicates what I've used since 2K miles when back then mirror dip worked. Currently I sit at 45K miles with the same settings and a non-working mirror dip
Friday,02,August,2019,09:47:26:18648
VCDS Version: 19.6.1.0
Mileage: 72823km-45250mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
          55 5F 75 A5 A9
VIN: WVWVF7AU4HW07xxxx   Mileage: 72823km-45250miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 48B1B1EEF3FB230F11-801C
Readiness: 0000 0001
   VCID: 538B96823ABD90D774-8006
   VCID: 7BDB1E22F2ADB897CC-802E
   Coding: 032C0C
   VCID: 3B5BDE22B22D78978C-806E
   Revision: 00001K08
   Coding: 00020004100100000105004012111402
   VCID: 72C53306A5E7F9DF9F-8026
   ROD: EV_BCMBOSCH_015.rod
   VCID: 042965DE8F53C76FBD-8050
   Coding: 06A8DD
   Coding: 0071155011
   VCID: 43ABA6C2CADD0057C4-8016
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3851C12E831B538F61-806C
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47B3B2D2FEE52C7718-8012
   Occupant Detection:
   Coding: 30324E
   Coding: 0C10
   VCID: 093774EAA8719A07CE-805C
   Coding: 0BAD081A7F8CCF0502887B0B5400000000000000
   VCID: 2F43FA727655943730-807A
   VCID: 7CD91D3EF7A3BFAFC5-8028
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Coding: 35FFFF
   Component: Haldex4Motion H52 UM01
   Coding: 0001
   VCID: 4AB58BE6EDF7D11F07-801E
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449F51E9F73B7EF4D-8060
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C59DD3EB7237FAF85-8068
   Component: HRE_Slave  H12 0071
   Serial number: 0414481529
   Coding: 020111
   Coding: 111000
   Coding: 9102
   VCID: 3A55DB26BD17419F97-806E
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   VCID: 6DFF207ABCD9262742-8038
   Coding: 003E13208C00040000800000
   VCID: 42A5A3C6D5C7095FCF-8016
   Coding: 091000
   Coding: 022202000B000400
   VCID: 40A1A9CEDBCB1B4FD9-8014
   Coding: 2E0000
   Coding: 2E0000
   Component: MU-S-NS-US    840 0755
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3245F3066567B9DF5F-8066
          B11CF 53 [009] - Deactivated
                    Reset counter: 68
                    Mileage: 72423 km
                    Date: 2019.07.27
                    Time: 15:02:16
                    Voltage terminal 30: 12.4 V
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 143 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Coding: 0002070000000201002213548040490094000E100020
End-------------------------(Elapsed Time: 05:32)--------------------------
DV52
C?ID=194404
Mosquito: Hello again - good idea to post here as well because the forum expertise is penultimate (I'm tempted to say "superlative" but everything can be improved - I guess!!:D).
It's an interesting and (as you say) a not-common problem. Just to comply with normal forum protocol - please post an unedited auto-scan so forum folks can see what other equipment is fitted to the car. Clearly though from your explanation, the passenger side module doesn't have a memory module.
Have you attempted the factory reset in the MENU as an easy-try?
Mari
C?ID=150535
It probably lost settings of position of mirror
... try the following:
- activate mirror dip in infortainment-system
- set side mirror knob on the "R" passenger side...
- Turn ignition on
- Put car in reverse
- Set mirror to desired position with mirror knob joystick
- Put car in neutral
- Turn ignition off
Test it by turning on ignition and putting car in reverse!
Mosquito
C?ID=14113
Hi Don.
I've edited the original post with the information that allows further review.
In regards to the reset.
If you mean Infotainment reset as in wiper/mirror reset. I've tried that.
If you mean Default reset of all car settings from car menu. I've tried that.
If you mean, hold the power button for the Infotainment to reboot (perhaps reset) I have tried that as well.
Only one I haven't tried is the Default reset of all settings from within the settings menu. I might give that a try. May even try to go back to stock coding first, do full reset, set mirror dip coding, do full reset a 2nd time and on to setting up mirror dip and see if it fixed anything.
I continue to think it is a programming issue though which is why I keep thinking that a replacement J387 module (Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B) may fix that, but isn't necessarily THE fix and who knows if it would actually fix it. I have my doubts if even a Part: 5Q4 959 592 would fix it.
I am considering going by the dealership and seeing if it is possible to factory re-flash - Module 52 but I will most likely get TD1.
*Update - Went by the dealership and they said it would be $140 just to diagnose. I have no codes for a non-factory enabled feature so that plus the fact that the door modules (original 5Q0 or mirror memory enabled 5Q4) costs less means I probably won't go THAT route to get it fixed.
Kids. Lesson learned. If it ain't broke, don't fix it.
Mosquito
C?ID=14113
Thanks Mari.
I tried that but using park. I've also used it turn off the car which in the past always returned the mirror once power was off.
I will try that again using your exact method of using neutral instead.
Two things I'd add is that when I originally programmed mirror dip, it was quite easy to do and get working.
The other and more useful comment would be. Back when I clicked bit 1 and hit Do it!. Upon engaging reverse the mirror went down as expected and never went back up. with or without power, regardless of power off, regardless of going over 10 MPHs. I had to manually raise it so I could drive to work.
Mari
C?ID=150535
... don't forget to unthick bit 1 (and click do-it) to revert the changes for memoryseat you have made...
Mosquito
C?ID=14113
Thanks.
That is the first thing I did.
It didn't work with it clicked so I hoped going back to having it unclicked would make it work again. That didn't work.
The second scan posted is what my car currently sits at. There is no obvious reason as to why it isn't working, but it isn't.
DV52
C?ID=194404
What - $140 just to diagnose? I suspect that the number was padded somewhat because as I understand mirror-dip ain't a standard feature for mk7s in the land-of-the-free. So - giving the dealer the benefit of the doubt - perhaps the quote includes an "education allowance" for the master-tech to get him/her up to speed with the function.
So - back to the problem and I'm clutching at straws (I think that's the appropriate saying) - have you checked that the BCM channels are active for
  • IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt
  • IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkun
And in respect of the latter channel above (and forgive any inference that may be implied in my suggestion) - are you sure that the box for reverse dip is ticked in the MENU ?
Mosquito
C?ID=14113
Yeah. They quoted $140 which is insane and I know he didn't understand half of what I was talking about.
On the rest. Yeah, both BCM channels are active
The in car menu for mirror dip is checked.
I also tried a car settings reset from the main menu and nothing. I also tried Mari's suggestion and no change either.
In all honesty. My issue is not about the settings. The standard ones anyways. Those are correct.
My initial attempted change seems to have altered some other parameter. Something else is associated with the mirror dip function and I think I moved that setting away from it's "associated group" if you will when I clicked mirror memory but undoing it did not return it to its original place.
I've seen something like this happen before in computing software where uninstalls don't always revert things as prior to install form. In this case, if the same were to be true it would seem a module reflash might fix it but hard to know.
Mosquito
C?ID=14113
So I tried a complete back to stock coding and a reprogram of the mirror dip only coupled with a complete reset of the car Infotainment system. No dice, still not working.
The only thing I have not tried at this point is executing any of the adaptation options within module 52. There is a LOT of hex code there that is prefilled and I am not sure exactly what it is for and been hesitant to execute them afraid of breaking things even more.
If anyone has played with these I'd appreciate the input.
At this point I've tried all Long coding, output and basic setting options.
MasterTommy
Amsterdam
C?ID=295586
As stated by Mari, set the mirror position for reverse again.
By putting the mirror knob on 'R', starting the car and putting it in reverse (not Park). Then after you've set the mirror position, put it in Drive. Mirror should go back to previous position.
This is a very common mistake/oversight with this feature. If the conditions are not correct, you will not save a second mirror position and thus even though functionality is enabled and working, it will appear not to be.
Mirror dip will not function when the mirror knob is not in the R position, when the car is not in Reverse gear, or when the engine is not running.
Mosquito
C?ID=14113
MasterTommy.
Thank you but that doesn't seem to be it. The mirror is on the R position and I've gone through the programming motion 50 times in the last week and it doesn't work.
I can put it in R, lower it to desired position and go forward. The mirror will not go up in Drive as it won't dip in reverse.
Getting it to work back in 2017 was cake. Worked the first time. My issue is not of not being able to set it up. I clicked bit 1 for mirror memory and in my case since I don't have it, seems it messed something up where now it won't work.
DV52
C?ID=194404
Mosquito: Not sure if it helps, but I have an MQB door control module on my test bench that I'm happy to use as a crash-test-dummy.
Alas it's a driver side module and it has a different part-number to the unit in your auto-scan -see below. But it does have the "LOT of hex code" in it's admap.
Happy to modify the hex string on my test-bench to any value you want - to see if the modification generates any DTC's (it already has a litany of DTCs because of the artificial environment) and if the mod can be reverted-back to original setting.
PS: again a long shot (clutching at straws again, I suspect) - but have you made a blockmap of the hex42 module? It's an easy try - but it may be prudent to skim through the report. Perhaps it will highlight an oddity?
Note: this module is installed in a test-bench - so code-string values are NOT "normal"
;SW:5Q4-959-593-B   HW:5Q4-959-593-B ---  Door Elect, Driver
;Component:TSG FS        009 0014, Coding:001102000001040000000000
;EV_DCUDriveSideEWMAXCONT,006001,EV_DCUDriveSideEWMAXCONT.rod
;Monday,05,August,2019,09:53:05:16808
;VCDS Version: Release 19.6.0 (x64)  Data version: 20190529 DS308.0
;VCID: 44C48978CFDA776FF5-8010
IDE00001-Production mode,00000000 00000000 00000000  ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
Elapsed Time: 00:02
Mosquito
C?ID=14113
Thanks Don.
Please tell me more about this blockmap of the hex42 module you speak of.
Only thing I have is the original new car scan post#1. Nothing else.
I asked VCDS Jef by PM last week if he had a full adaptation backup of what seems to be his car, specially in stock form since I found an autoscan he posted back in 2017 of a MY17 MK7R w/DSG & DAP just like mine.
He didn't have a chance to get back to me and I honestly don't know if he even has it or if that was his car in the first place.
I noticed on your module, you have memory mirror 5Q4 part but regardless I think I will take a look at your coding tomorrow and compare it with what settings I have, as well as the adaptation channels I have vs yours and vs my passenger side.
It might offer some clues.
Specific to the Adaptation channels vs basic settings. Both apparently allow command execution.
Basic settings offer both reset and adaptations of mainly windows and locking mechanism. I played around with them all.
The Adaptation menu having all the Hex code seems to suggest a sort of "factory adaptation" or sorts (I can't double check proper description right now) but I have been too scared to execute it because aside from mirror dip not working, the car is error free.
One thing that has caught my attention recently and I don't have any codes to this either, but recently my cold start idle went from a normal 15 seconds +/- warm up cycle to easily 30+ seconds and consistently. It is happening at any time of the day and I am in sunny Miami, FL where right now temps are easily between 26C-38C range when the sun is out so there is no reason as to why the car should double the warm up cycle it has shown (15 seconds or so) for the last 3 years. I haven't even gotten 30+ seconds in 8C temps and now I get them every morning.
As a last resort, do you think I can pull off replacing the Passenger module for a Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B ?
If so, would I be forced to change the drivers module too?
DV52
C?ID=194404
Blockmaps as the name suggests takes a snapshot of all of the measurement block values for the module (at least this is my amateur understanding from reading the RT stuff). Actually, I think the name is somewhat of a misnomer and it might be a relic from older modules because the newer protocols in MQB platform vehicles don't seem to use more traditional "measurement blocks" with which we are all familiar.
In any event, with UDS modules, secret VCDS wizardry happens and there's apparently a decoding relationship with the module's .ROD file (I think). The end result (again, this is my understanding) is that the process interrogates the module for the factors in the Advanced Measuring Values facility.
To make a Blockmap - from the Main VCDS screen, select Applications, then select Controller Channel Map
On the sub-screen below, enter the module hex address and set the Measuring Values and the .CSV radio buttons (you can populate the SA 20103 - if you want)
here's the Blockmap from my mk7 passenger door module which has a memory module and mirror dip enabled:
;SW:5Q4-959-592   HW:5Q4-959-592 ---  Door Elect, Pass.
;Component:TSG BFS       007 0006, Coding:003A00208E01020000801000
;EV_DCUPasseSideEWMAXCONT,006001,EV_DCUPasseSideEWMAXCONT.rod
;Monday,05,August,2019,13:44:38:16808
;VCID: 014A406C9048A2479E-8054
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,11.8, V
IDE02266,Passenger side rear power window button,not activated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,11.8, V
IDE04216-MAS01458,Mirror heater-Operating condition,not_active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not activated,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,37, %
IDE04539-MAS02229,Mirror memory-Y coordinate,61, %
IDE04539-MAS02476,Mirror memory-install,installed,
IDE04540,Mirror adjustment (X/Y-direction),not installed,
IDE04580,Dimming of inside door handle lighting,0, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not installed,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,37, %
IDE05727-IDE02589,Front passenger side door status-Rotary latch status,Open,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not installed,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.0, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Idle condition,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.0, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Power window control standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,215, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,255, %
IDE06872,Front passenger power window button,not activated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,3202,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,1.5, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,70.0, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.5, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.5, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.5, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not recognized,
IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,2,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,22, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,35, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,5.5, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,11.0, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,11.0, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.5, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.5, %
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,5,
MAS00464-MAS00109,Standard - ambient data 1-Hours,13,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,44,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,38,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,197,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,46505, km
MAS02100,Switch for outside door handle,not installed,
MAS06010,Ambient light,100, %
ENG117314-ENG99000,control_event_memory_passenger_side_rear-Value,00 13 07 16 0B 24 0E 12 00 13 07 14 0F 2D 3A 12 00 13 07 16 0A 38 19 12 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117296-MAS00966,Passenger_Rear_VW_FAZIT_Identification_String-Manufacture location index,SVM-401,
ENG117296-MAS00968,Passenger_Rear_VW_FAZIT_Identification_String-Day of manufacture,20.12.12,
ENG117296-MAS00969,Passenger_Rear_VW_FAZIT_Identification_String-Manufacturer- test stand number,0023,
ENG117296-MAS00970,Passenger_Rear_VW_FAZIT_Identification_String-Running manufacturer number,0224,
ENG117310,Window_Regulator_Passenger_Side_Rear_Sleep_Indication,not active,
ENG117316-ENG99000,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-Value,J927 ,
Elapsed Time: 00:07
Please don't "look at [my] coding" - As I have noted in my post, the coding is an artifice and it's specifically set in an attempt to minimize DTCs in the test-bench environment.
I don't have access to ETKA so I'm not sure which modules are suitable for your car. However, I would caution against using a door module for a RH drive car on a LH drive car. I've read forum posts that tell how the up/down/left/right movement gets confused if this is done.
Mosquito
C?ID=14113
Thanks Don.
That is very helpful. I will look into the Blockmaps.
As far as your coding. I'm not looking to duplicate or even hitting Do It! but though they are different you can see the hex code change of each byte when you change an option so I am curious to see what yours would represent on mine.
On the mirror memory part.
Yeah, I think the safest bet for me would be to find the part number being used on a close USA MQB model that includes mirror memory and consider changing mine with that. I am not giving up on the coding just yet though.
Likewise, I have been trying to look into the folding mirror kit that seems to suggest it includes mirror memory, but some posts say it does others say you still have to change the door module for it. I am not particularly interested in the folding mirror kit, but whatever controller it includes is what I potentially may need.
Lastly. I came across a facebook post from the VW MK7 Golf - GTI - R - MQB group last night and there is a guy back in 2017 which had a working mirror dip that stopped working from one day to the next without reason and until his last post, he seemed unable to resolve it but I am reaching out to see if that was the case. It is the closest I've found to someone else having a similar issue to mine.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Try disconnecting the battery, if you haven't already. I've had a similar experience from being partway-thru retrofitting memory seats, and another person had a similar experience removing memory seats. Mk7 door controllers seem to be spectacularly persistent in remembering they were once set up for seat memory coordination. I had a memory seat controller in my car for like an hour, and the fault stuck around for months, until there was a battery disconnect.
Mosquito
C?ID=14113
Good advise. It is one of the few things I haven't tried and it crossed my mind, but I was like nah. Can't be.
Will try it tonight and report back.
Mosquito
C?ID=14113
It worked! and you were 100% right.
The setting stuck from the initial bit 1 click even though it would not show like so once I went back. Didn't matter if it was stock or something else.
I had a feeling there was something going on in the background, but couldn't put my finger on it. Didn't try disconnecting the battery and didn't think it would ultimately be that simple, but they say the simplest answer tends to be the right one and it was so.
After over a week of brain storming solutions and potential replacement parts I am glad it is solved, the efficient way.
Thank you very much, really. I think in this particular case, someone should make note of this for future use. I know I will.
I might as well share my process to tick all the boxes and get it working because I know someone will go through this as well and there is not a lot of information specifically on this, though I did see that some people could not get the mirror dip to function no matter what and I think there may be some 2nd hand cars around which may be carrying this with them as well. Anyhow.
My approach was as follows.
1. First reset the entire Infotainment and place side mirror knob in the middle.
2. Reverted coding back to stock (in my case, 52 long coding byte 4, bit 7 only. reboot ignition. Both 09 adaptations not active for MIB menu settings) reboot ignition 2nd time.
3. Reset entire Infotainment again
4. Wait 10 minutes for car to go into sleep mode
5. Disconnect the battery for 30+ minutes
6. Reconnect battery and go through the basic start up sequence of full left, full right steering wheel to clear most of the initial errors.
7. Long coding 52, byte 4 bit 2 & 3 were added. reboot ignition. Both 09 adaptations were set to active for the MIB menu settings yet again. reboot ignition 2nd time.
8. Reset entire Infotainment 3rd time.
9. Start car, assure reverse mirror is enabled in MIB, place in reverse and place mirror knob in R.
10. Boom, mirror went down.
From there on out I cleared all codes and setup the MIB system with the usual settings.
