Hi.
I am trying to sort out an issue where mirror dip is no longer working.
Back in 2017 I modified my stock coding on module (52), Byte 4 to include bit 2 & 3. Since then mirror dip functioned as expected and always going back up with 90% accuracy.
It wasn't perfect, but it worked well.
This past week I decided to click and include bit 1 (mirror memory w/ memory seats) to the coding and see if I was lucky enough to have a perfect functioning mirror dip.
Not only was I not, but now mirror dip does not work at all. What could it be?
I have since tried everything I can imagine, but it will not dip no matter what.
I've since gone back to original stock programming (have new car backup scan) and proceeded to re-do the original 2017 programming for mirror dip of including bit 2 & 3 only. No luck.
This of course included enabling (09) in adaptation settings in the Infotainment, its mirror/wiper settings reset as well as assuring the side mirror knob is positioned on the "R" passenger side coupled with the known Park, Reverse, dip, Park, off procedure.
Is there anything I am missing?
I have compared my entire stock new car scan coding to my currently modified coding and found no other long coding differences. I do not have an Adaptation scan backup though so I can't help but wonder.
Is it possible that a long coding change can affect other modules, adaptation channels or even hidden programming within the same module?
I don't have any triggered or stored codes because of it. checked Bit 1 shows 99% X/Y and Active Voltage & Memory and will eventually create a mirror positioning implausible signal error while unchecked it shows 255% X/Y and Uninstalled Voltage & Memory, though the latter always worked without creating any errors.
Any help would be appreciated it. I've searched online everywhere for the last week and have not found one single person with the same issue. It's unlikely nobody has gone through this before.
I've changed long coding before, but never had an issue where I was not able to get it working again by going back to original code.
This is the original new car scan in stock form
This is the current 45K scan with mirror dip enabled. It replicates what I've used since 2K miles when back then mirror dip worked. Currently I sit at 45K miles with the same settings and a non-working mirror dip
Friday,04,November,2016,18:18:59:18648
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
VIN: WVWVF7AU4HW07xxxx License Plate:
Mileage: 414km-257mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F 75 A5 A9
VIN: WVWVF7AU4HW07xxxx Mileage: 414km-257miles
Address 01: Engine (J623-CYFB) Labels: None
Part No SW: 8V0 906 259 K HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00122466000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
ROD: N/A
VCID: 48B1B1EEF3FB230234-801C
No ASAM data for: "EV_ECM20TFS0208V0906259K" (VW37)
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H54 4937
Revision: 06354004 Serial number: TFK01607080421
ROD: EV_TCMDQ250021.rod
VCID: 538B96823ABD90DA51-8006
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62216000000213
Coding: 01FA6BA1542709734579030541C56980D62A90A2C0829637184050D8C2A803
VCID: 7BDB1E22F2ADB89AE9-802E
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0415694328
Coding: 032C0C
VCID: 3B5BDE22B22D789AA9-806E
Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 00020004200100000105000012111402
VCID: 72C53306A5E7F9D2BA-8026
Air quality sensor:
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061623000116
Coding: 00011B46C041A2E169E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 042965DE8F53C76298-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160813 043 0551
Serial number: 160820061829
Component: RLHS 042 0105
Serial number: S6Y16M09D05H10M53S35
Coding: 00A8DD
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Revision: -------- Serial number: 39331624602444
Coding: 0071155011
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 43ABA6C2CADD005AE1-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 350000C151FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: N/A
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 11081641350344
ROD: EV_DRCONTITEMIC.rod
VCID: 3851C12E831B538244-806C
Serial number: 003GCR05LJU4
VCID: 47B3B2D2FEE52C7A3D-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005MSLB4
Coding: 30324E
Subsystem 2 - Part No SW: ----------- HW: 480 003 108 16
Serial number: 357000000003A21D0D1F
Subsystem 3 - Part No SW: ----------- HW: 480 002 608 16
Serial number: 3580000000028C8C0E1U
Subsystem 4 - Part No SW: ----------- HW: 480 402 008 16
Serial number: 35100029F215E1E2301Z
Subsystem 5 - Part No SW: ----------- HW: 480 400 606 16
Serial number: 3520002B92076365F2F7
Subsystem 6 - Part No SW: ----------- HW: 480 400 808 16
Serial number: 3550002B521FBE83D3DS
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 708 16
Serial number: 35600029D2095062039V
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 13081604220541
Coding: 0C10
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 093774EAA8719A0AEB-805C
Part No SW: 5G1 920 858 B HW: 5G1 920 858 B
Component: KOMBI 304 8311
Coding: 0BAD081A7F88CF0502886B0B5400000000000000
VCID: 2F43FA727655943A15-807A
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005263671
Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CD91D3EF7A3BFA2E0-8028
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H11 0040
Serial number: 29160001259320106263
Coding: 35FFFF
Serial number: HA1-00018.07.16
Coding: 0001
VCID: 4AB58BE6EDF7D11222-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000131082008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 3449F51E9F73B7E268-8060
Address 3C: Lane Change (J1086) Labels: None
Component: HRE_Master H12 0071
Serial number: 0414177386
Coding: 02011103
ROD: EV_HREntryHella.rod
VCID: 3C59DD3EB7237FA2A0-8068
Component: TSG FS 020 0041
Serial number: 010616EF106162
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000011414783
Coding: 111000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9102
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A55DB26BD174192B2-806E
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA0274L+
VCID: 6DFF207ABCD9262A67-8038
Component: TSG BFS 020 0041
Serial number: 290516EES08005
Coding: 003E13208000040000800000
VCID: 42A5A3C6D5C70952EA-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000011155584
Coding: 091000
Component: AFS-ECU H07 0090
Coding: 022202010B000400
VCID: 40A1A9CEDBCB1B42FC-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0751
Coding: 027300020000000051220002001808009F0207F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3245F3066567B9D27A-8066
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX00840
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Component: OCULowMQBUS 007 0568
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 19081611P22253
Coding: 0003070000000201002213548040490084000E100020
ROD: EV_MFKBoschMQBB.rod
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160622202345
End-------------------------(Elapsed Time: 05:18)--------------------------
Friday,02,August,2019,09:47:26:18648
VCDS Version: 19.6.1.0
Mileage: 72823km-45250mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
55 5F 75 A5 A9
VIN: WVWVF7AU4HW07xxxx Mileage: 72823km-45250miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Revision: --H13---
ROD: EV_ECM20TFS0208V0906259K.rod
VCID: 48B1B1EEF3FB230F11-801C
Readiness: 0000 0001
VCID: 538B96823ABD90D774-8006
VCID: 7BDB1E22F2ADB897CC-802E
Coding: 032C0C
VCID: 3B5BDE22B22D78978C-806E
Revision: 00001K08
Coding: 00020004100100000105004012111402
VCID: 72C53306A5E7F9DF9F-8026
Air quality sensor:
ROD: EV_BCMBOSCH_015.rod
VCID: 042965DE8F53C76FBD-8050
Coding: 06A8DD
Coding: 0071155011
VCID: 43ABA6C2CADD0057C4-8016
ROD: EV_ACCBOSCHVW416_001_VW37.rod
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3851C12E831B538F61-806C
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47B3B2D2FEE52C7718-8012
Occupant Detection:
Coding: 30324E
Coding: 0C10
VCID: 093774EAA8719A07CE-805C
Coding: 0BAD081A7F8CCF0502887B0B5400000000000000
VCID: 2F43FA727655943730-807A
VCID: 7CD91D3EF7A3BFAFC5-8028
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Coding: 35FFFF
Component: Haldex4Motion H52 UM01
Coding: 0001
VCID: 4AB58BE6EDF7D11F07-801E
ROD: EV_ELVMarquMQB.rod
VCID: 3449F51E9F73B7EF4D-8060
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C59DD3EB7237FAF85-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0414481529
Coding: 020111
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Coding: 111000
Coding: 9102
VCID: 3A55DB26BD17419F97-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
VCID: 6DFF207ABCD9262742-8038
Coding: 003E13208C00040000800000
VCID: 42A5A3C6D5C7095FCF-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Coding: 091000
Coding: 022202000B000400
VCID: 40A1A9CEDBCB1B4FD9-8014
Coding: 2E0000
Coding: 2E0000
Component: MU-S-NS-US 840 0755
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 3245F3066567B9DF5F-8066
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 68
Mileage: 72423 km
Date: 2019.07.27
Time: 15:02:16
Voltage terminal 30: 12.4 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 143 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
Coding: 0002070000000201002213548040490094000E100020
End-------------------------(Elapsed Time: 05:32)--------------------------
