Ok here's a 2010 Jetta TDI 2.0L. Towed into us wouldn't hardly run. Found a completely restricted DPF. Replaced DPF and performed DPF adaptations and reset so the ECM knows it's new. However, now it won't hardly accelerate. So continued with adaptations and found IF the EGR adaptation works (like maybe 1 out 4 tries) the vehicle revs up great and power is restored and you can drive it and all is well. Up until you cycle the key off. Then it does it again. While doing the procedure, came up with a P0403 for N18 EGR circuit. Verified my 5 volt ref, ground and signal and motor control circuits all checked ok. Replaced N18 EGR. Same exact problem. Looking for some guidance if possible. Thanks.
Monday,22,July,2019,16:14:22:35939
VCDS Version: 19.6.0.4 (x64) HEX-NET CB: 0.4505.4
VIN: 3VWRL7AJ9AM028566 License Plate:
Mileage: 154420km-95952mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRL7AJ9AM028566 Mileage: 154420km-95952miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 9971
Revision: 12H02--- Serial number:
Coding: 0050078
Shop #: WSC 05152 444 82797
VCID: F8BCA6F68B5FA88F2F-80AC
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1920
Revision: 04844002 Serial number: 00000906300560
VCID: D1EA3B524865D9C7C8-8084
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Fault Frequency: 255
Reset counter: 37
Mileage: 154422 km
Date: 2013.09.18
Time: 00:54:41
01196 - Engine-Transmission Data Bus
Reset counter: 37
Mileage: 154422 km
Date: 2013.09.18
Time: 00:54:43
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 114B400C49240002881002EA921F0042B100
Shop #: WSC 13248 002 1048576
VCID: 804CCE16138FE04F17-80D4
Reset counter: 250
Mileage: 154422 km
Date: 2013.09.18
Time: 00:54:41
Count: 12
Count: 12800
Count: 8194
Count: 41216
Count: 65280
Reset counter: 252
Mileage: 154422 km
Date: 2013.12.12
Time: 00:24:01
Count: 7
Count: 13
Count: 4096
Count: 128
Count: 30976
Part No SW: 3C8 907 336 N HW: 3C8 907 336 N
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: B83C66F603DF688FEF-80EC
U1111 00 [008] - -
[Motorsteuergerät - kein Signal/Kommunikation]
Reset counter: 35
Mileage: 154422 km
Date: 2019.04.28
Time: 00:54:40
Part No SW: 5K0 937 085 C HW: 5K0 937 085 C
Component: BCM PQ35 B++ 008 0019
Revision: BI008001
Coding: 6D200B1E902F3EE4800800054000000001000086510085605C8020000000
VCID: B32651DA12B98BD7DA-80E6
Component: Wischer 29080 21 0501
Coding: 009795
Reset counter: 37
Voltage: 8.35 V
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Reset counter: 37
Mileage: 154422 km
Term 15 Off
Voltage: 16.85 V
Reset counter: 38
Mileage: 154422 km
Date: 2013.12.12
Time: 02:28:34
Voltage: 11.20 V
01117 - Generator Terminal DF Load Signal
Reset counter: 37
Mileage: 154422 km
Date: 2013.10.22
Time: 21:31:20
Voltage: 12.80 V
Reset counter: 35
Mileage: 154422 km
Date: 2013.09.18
Time: 00:54:42
Voltage: 11.55 V
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM01149%
Coding: 0012340
VCID: EE9080AEF91BE63FF5-80BA
Subsystem 2 - Serial number: 6332MSME48202F035
Subsystem 3 - Serial number: 6342MSME490562378
Subsystem 4 - Serial number: 6351HSME1D16583AE
Subsystem 5 - Serial number: 6361HSME1D145E039
Subsystem 6 - Serial number: 63727SME000F1C16
Subsystem 7 - Serial number: 63827SME000E546C2
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001731
VCID: F6A0A8CE814BDEFF3D-80A2
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5M0 920 970 C HW: 5M0 920 970 C
Component: KOMBI H08 0021
Revision: V0008011 Serial number:
Coding: 271F00
ASAM Dataset: EV_KombiUDSMM9RM10 A04010
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: B02C5ED6EBAFB0CFA7-80E4
13701120 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP: Funktionseinschränkung wegen Kommunikationsstörung]
Fault Frequency: 143
Reset counter: 253
Mileage: 154422 km
Date: 2019.04.28
Time: 00:09:25
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Reset counter: 35
Mileage: 154422 km
Date: 2019.04.28
Time: 00:54:40
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 200709F2000842
Coding: ED807F07001602001002
VCID: E680F88ED1EB2E7F8D-80B2
Fault Status: 00110100
Reset counter: 34
Mileage: 154422 km
Date: 2013.09.18
Time: 00:54:42
01304 - Radio
Reset counter: 249
Mileage: 154422 km
Date: 2013.09.18
Time: 00:09:36
Part No SW: 1K5 919 965 D HW: 1K5 919 965 D
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1293324T4A5105
Coding: 0000004
VCID: BC347AE6FFE744AF0B-80E8
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H08 0021
ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
ROD: EV_ImmoUDSMM9RM10_VW12.rod
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1525
Revision: 72009005 Serial number: 00000759698806
Coding: 0001205
VCID: EFAE9DAAFE11EF37FE-80BA
Fault Status: 01100101
Reset counter: 253
Mileage: 154422 km
Date: 2013.09.18
Time: 00:09:35
Fault Status: 00101100
Reset counter: 37
Mileage: 154422 km
Date: 2013.09.18
Time: 01:16:12
Fault Status: 00111000
Reset counter: 37
Mileage: 154422 km
Date: 2013.10.22
Time: 00:50:04
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H17000
VCID: AF2E5DAA3E91AF37BE-80FA
Reset counter: 35
Mileage: 154422 km
Date: 2013.09.18
Time: 00:54:41
Voltage: 11.63 V
DU
Temperature: 34.0°C
RPM: 1498 /min
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1525
Revision: 72009005 Serial number: 09051215554103
Coding: 0001204
VCID: F0AC9ED6E32FF0CFE7-80A4
Fault Status: 00100101
Reset counter: 37
Mileage: 154422 km
Date: 2013.09.18
Time: 00:09:43
Address 56: Radio
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000004193636
Coding: 0001168
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 008 0817
Coding: 018705
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000004206848
Coding: 0001168
VCID: F7BEA5CA8641A7F726-80A2
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
Component: FSE_2P8x H35 0170
Revision: 00000000 Serial number: 00000005060561
Coding: 0011070
VCID: B83C66F6CBDF688FEF-80EC
01304 - Radio
Reset counter: 206
Mileage: 153656 km
Date: 2013.02.08
Time: 02:11:39
End----(Elapsed Time: 01:40, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Address 01: DTCs cleared
Readiness Status: 00000000 00011111 11101011 11101011
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 0
MIL Status: MIL OFF
Fuel System: Passed
Coding: 0050078
Reset counter: 36
Mileage: 154422 km
Date: 2013.09.19
Time: 00:54:41
Reset counter: 36
Mileage: 154422 km
Date: 2013.09.19
Time: 00:54:43
Revision: 00H45001
Reset counter: 250
Mileage: 154422 km
Date: 2013.09.19
Time: 00:54:41
Count: 12
Count: 12800
Count: 8194
Count: 41216
Count: 65280
Reset counter: 252
Mileage: 154422 km
Date: 2013.12.13
Time: 00:24:01
Count: 7
Count: 13
Count: 4096
Count: 128
Count: 30976
Revision: 00006001
Coding: 0000000000
U1111 00 [008] - -
Reset counter: 35
Mileage: 154422 km
Date: 2019.04.29
Time: 00:54:40
Revision: BI008001
Coding: 009795
Reset counter: 37
Voltage: 8.35 V
Reset counter: 37
Mileage: 154422 km
Term 15 Off
Voltage: 16.85 V
Reset counter: 39
Mileage: 154422 km
Date: 2013.12.13
Time: 06:35:09
Voltage: 11.70 V
Reset counter: 37
Mileage: 154422 km
Date: 2013.10.23
Time: 21:31:20
Voltage: 12.80 V
Reset counter: 35
Mileage: 154422 km
Date: 2013.09.19
Time: 00:54:42
Voltage: 11.55 V
Coding: 0012340
Coding: 0001731
Coding: 00000130
Coding: 271F00
U1110 00 [009] - -
Fault Frequency: 173
Reset counter: 254
Mileage: 154422 km
Date: 2019.04.29
Time: 00:09:25
U1400 00 [008] - -
Reset counter: 39
Mileage: 154422 km
Date: 2019.07.23
Time: 00:46:38
U1111 00 [008] - -
Reset counter: 35
Mileage: 154422 km
Date: 2019.04.29
Time: 00:54:40
Reset counter: 34
Mileage: 154422 km
Date: 2013.09.19
Time: 00:54:42
01304 - Radio
Reset counter: 249
Mileage: 154422 km
Date: 2013.09.19
Time: 00:09:36
Coding: 0000004
Coding: 0001205
Reset counter: 254
Mileage: 154422 km
Date: 2013.09.19
Time: 00:09:35
Reset counter: 37
Mileage: 154422 km
Date: 2013.09.19
Time: 01:16:12
Reset counter: 37
Mileage: 154422 km
Date: 2013.10.23
Time: 00:50:04
Revision: 00H17000
Reset counter: 35
Mileage: 154422 km
Date: 2013.09.19
Time: 00:54:41
Voltage: 11.63 V
DU
Temperature: 34.0°C
RPM: 1498 /min
Coding: 0001204
Reset counter: 37
Mileage: 154422 km
Date: 2013.09.19
Time: 00:09:43
Address 56: Radio
Coding: 0001168
Coding: 018705
02214 - Tire Pressure Warning
Mileage: 154422 km
Date: 2013.12.13
Time: 00:02:16
Text: 3391139675
Pressure: 1.80 bar
Pressure: 2.40 bar
Temperature: 32.0°C
Text: 80
Coding: 0001168
Coding: 0011070
01304 - Radio
Reset counter: 206
Mileage: 153656 km
Date: 2013.02.09
Time: 02:11:39
End----------(Elapsed Time: 01:37, VBatt start/end: 12.9V/13.0V)-----------
Thursday,01,August,2019,09:09:17:35939
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
Coding: 0050078
VCID: F8BCA6F68B5FA88F21-80AC
VCID: D1EA3B524865D9C7C6-8084
Revision: 00H45001
VCID: 804CCE16138FE04F19-80D4
Reset counter: 254
Mileage: 154424 km
Date: 2013.12.16
Time: 08:08:40
Count: 2
Count: 13
Count: 4096
Count: 128
Count: 26112
Count: 256
Revision: 00006001
Coding: 0000000000
VCID: B83C66F603DF688FE1-80EC
U1111 00 [008] - -
Reset counter: 35
Mileage: 154422 km
Date: 2019.04.29
Time: 00:54:40
Revision: BI008001
VCID: B32651DA12B98BD7D4-80E6
Coding: 009795
Reset counter: 37
Voltage: 8.35 V
Reset counter: 40
Mileage: 154422 km
Term 15 Off
Voltage: 16.85 V
Reset counter: 40
Mileage: 154424 km
Date: 2013.12.22
Time: 02:23:06
Voltage: 11.70 V
Reset counter: 39
Mileage: 154422 km
Date: 2013.10.23
Time: 21:31:20
Voltage: 12.80 V
Reset counter: 35
Mileage: 154422 km
Date: 2013.09.19
Time: 00:54:42
Voltage: 11.55 V
Coding: 0012340
VCID: EE9080AEF91BE63FFB-80BA
Coding: 0001731
VCID: F6A0A8CE814BDEFF33-80A2
Coding: 00000130
Coding: 271F00
VCID: B02C5ED6EBAFB0CFA9-80E4
U1110 00 [009] - -
Reset counter: 0
Mileage: 154422 km
Date: 2019.04.29
Time: 00:09:25
U1400 00 [008] - -
Reset counter: 39
Mileage: 154422 km
Date: 2019.07.23
Time: 00:46:38
U1111 00 [008] - -
Reset counter: 35
Mileage: 154422 km
Date: 2019.04.29
Time: 00:54:40
VCID: E680F88ED1EB2E7F83-80B2
01304 - Radio
Reset counter: 254
Mileage: 154422 km
Date: 2013.12.13
Time: 06:46:27
Coding: 0000004
VCID: BC347AE6FFE744AF05-80E8
Coding: 0001205
VCID: EFAE9DAAFE11EF37F0-80BA
Reset counter: 0
Mileage: 154422 km
Date: 2013.12.13
Time: 06:46:21
Revision: 00H17000
VCID: AF2E5DAA3E91AF37B0-80FA
Coding: 0001204
VCID: F0AC9ED6E32FF0CFE9-80A4
Address 56: Radio
Coding: 0001168
Coding: 018705
Mileage: 154422 km
Date: 2013.12.13
Time: 06:46:21
Text: 3391139675
Pressure: 0.00 bar
Pressure: 2.40 bar
Temperature: 52.4°C
Text: 00
Coding: 0001168
VCID: F7BEA5CA8641A7F728-80A2
Coding: 0011070
VCID: B83C66F6CBDF688FE1-80EC
00532 - Supply Voltage B+
Reset counter: 40
Mileage: 154424 km
Date: 2013.12.20
Time: 02:50:37
01304 - Radio
Reset counter: 254
Mileage: 154422 km
Date: 2013.12.13
Time: 06:46:21
End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.2V)-----------
Thursday,01,August,2019,09:18:38:35939
Coding: 0050078
Revision: 00H45001
Revision: 00006001
Coding: 0000000000
Revision: BI008001
Coding: 009795
Coding: 0012340
Coding: 0001731
Coding: 00000130
Coding: 271F00
U1110 00 [009] - -
Reset counter: 0
Mileage: 154424 km
Date: 2019.08.01
Time: 02:48:59
01304 - Radio
Reset counter: 0
Mileage: 154424 km
Date: 2013.12.22
Time: 02:49:26
Coding: 0000004
Coding: 0001205
Reset counter: 0
Mileage: 154424 km
Date: 2013.12.22
Time: 02:49:33
Revision: 00H17000
Coding: 0001204
Address 56: Radio
Coding: 0001168
Coding: 018705
Mileage: 154424 km
Date: 2013.12.22
Time: 02:50:07
Text: 3391139675
Pressure: 1.80 bar
Pressure: 2.40 bar
Temperature: 32.0°C
Text: 80
Coding: 0001168
Coding: 0011070
01304 - Radio
Reset counter: 0
Mileage: 154424 km
Date: 2013.12.22
Time: 02:50:24
End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.2V)-----------
