- Joined
- May 27, 2017
- Messages
- 3,335
- Reaction score
- 2,086
- Location
- Finland
- VCDS Serial number
- C?ID=280813
Bracket change is a must. Completely different bracket MK70 vs. MK60 vs. MK60EC1.
But that is really really easy. Lift the front end of the car up. Remove passenger side wheel and remove the inner wheel arch. Now you have a very good access to remove the ABS bracket nuts from below.
And like langers2k wrote, the wires need to be correct way around. If you want to be completely sure, you can login to erwin, buy one hour and print all the ABS wiring diagrams for your car. Also at the same time you can print out abs pump remove and installation, bracket removal and installation and brake pipe replacement guides from workshop manual section.
What comes to coding, again what langers wrote. Just google for autoscans from mk6 Golfs. The biggest gripe is that part of the cars VIN is embedded into the ABS coding, so you cannot just copy and paste the codes. Google for eng-mk60ec1.xpl label file. It's an unofficial label file but it has the VIN positions correct so you can paste an existing long code to lcode.exe, open this label file and then change the VIN parts to match your cars VIN numbers. Then copy and paste that lcode to the ABS pump.
It is quite easy to make a working EC1 lcode nowadays. The bytes are quite well documented.
