Thursday,01,August,2019,06:38:22:50436
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWCA71K58W052753 License Plate: FNG
Mileage: 132570km-82375mi Repair Order:
Chassis Type: 1K-VW35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWCA71K58W052753 Mileage: 132570km-82375miles
16-Steering wheel -- Status: Not registered 0011
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BK HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1568
Revision: 1NH01--- Serial number: VWX7Z0G53NC9G8
Shop #: WSC 66565 257 00032
VCID: 73B0D7A8D7B978DFC7B-8027
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 004 - Implausible Signal - Intermittent
Fault Frequency: 14
Mileage: 129308 km
Time: 16:53:01
RPM: 718 /min
Load: 19.6 %
Temperature: 95.0°C
Temperature: 39.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.573 V
006481 - Radiator Fan 2 (V177)
P1951 - 002 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 36
Mileage: 130928 km
Time: 09:53:31
RPM: 2505 /min
Load: 12.2 %
Speed: 78.0 km/h
Temperature: 56.0°C
Temperature: 25.0°C
Voltage: 14.224 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Fault Frequency: 14
Mileage: 130985 km
Time: 20:00:26
RPM: 2026 /min
Load: 13.3 %
Speed: 78.0 km/h
Temperature: 82.0°C
Temperature: 33.0°C
Voltage: 13.843 V
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 01279 785 00200
VCID: 3FD84B98AB71ECBFF33-806B
Part No SW: 1K0 820 047 HC HW: 1K0 820 047 HC
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
VCID: 6C82CCD48A87A727061-8039
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 00000007951380
Coding: 008D0F214004150047140000001400000009730B5C000100000000000000
Shop #: WSC 12345 785 00200
VCID: 6FB8DBD8BB915C3F233-803B
Component: Wischer 180208 021 0501
Coding: 00038805
Shop #: WSC 12345
01505 - Bulb for Blinkers; Rear Right (M8)
Fault Status: 00101100
Reset counter: 53
Mileage: 129286 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.45 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6L AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0ALB5.
Coding: 0013900
Shop #: WSC 01269 785 00200
Subsystem 1 - Serial number: 6332MSME2A606A08D
Subsystem 2 - Serial number: 6342MSME2B724C2EQ
Subsystem 3 - Serial number: 6352QSME56504177C
Subsystem 4 - Serial number: 6362QSME56043A63F
Subsystem 5 - Serial number: 63727SME13354603S
Subsystem 6 - Serial number: 63827SME12370320M
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000022
VCID: 7F580B98EBF12CBFB33-802B
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 854 T HW: 1K0 920 854 T
Component: KOMBIINSTRUMENT VDD 1222
Revision: V0002000 Serial number: VWX7Z0H13NM89T
Coding: 0007303
Shop #: WSC 94759 999 54046
VCID: 3C223C94BA67F7A7D61-8069
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K082150180
Coding: E9807F044002020002
VCID: 303A18A4662F03C77A9-8065
Fault Frequency: 18
Reset counter: 17
Mileage: 122896 km
Time: 00:29:21
Component: IMMO VDD 1222
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4253450
Coding: 0000040104000B000000100A
Shop #: WSC 09003 957 00200
ROD: EV_RNS315NARV2UDS.rod
VCID: 2514F9F0256D566F99F-8071
Component: NAR_V9N 0070
1048632 - Antenna 1 for Radio
B1119 13 [008] - Open Circuit
Reset counter: 33
Mileage: 130163 km
Time: 07:16:34
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1219
Coding: 0001205
VCID: 382A20848E5FDB87329-806D
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 353429B0994D26EF29F-8061
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 9B9006885103283F0904058FB0080F0488FC80
VCID: 71BCDDA0ADA54ACF357-8025
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001204
VCID: 392C2580B555C28FCD7-806D
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1305
Coding: 0001168
Shop #: WSC 01279 785 1012552
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0001168
End----------(Elapsed Time: 01:04, VBatt start/end: 12.3V/12.2V)-----------
