Results 1 to 8 of 8
Thread: Anyone help with fault code (P2002 CNHA engine)
    Nov 2016
    replaced dpf sensor...............but getting this fault
    64 plate audi a6 tdi
    Wednesday,31,July,2019,14:53:18:07086
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUZZZ4G0EN185537   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
              62 72 AC
    VIN: WAUZZZ4G0EN185537   Mileage: 88499km-54990miles
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 BD    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 8244
       Revision: 85H23---
       Coding: 0A254012242401080000
       Shop #: WSC 45974 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021BD 002005
       ROD: EV_ECM20TDI01104L906021BD_002.rod
       VCID: 68D5ABEE9368750F31-803C
    19226 - Particulate Trap Bank 1
              P2002 00 [237] - Efficiency Below Threshold
                        Mileage: 88327 km
                        Date: 2019.07.30
                        Time: 14:38:31
                        Engine speed: 1290.00 /min
                        Normed load value: 48.6 %
                        Vehicle speed: 35 km/h
                        Coolant temperature: 89 °C
                        Intake air temperature: 71 °C
                        Voltage terminal 30: 14.400 V
                        Exhaust mass flow of low-pressure EGR: calculated: 3.019
                        Differential pressure ratio: low-pressure EGR: 21.8 kg/h
                        Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 27.7 hPa
                        Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 23.4 hPa
                        Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 89.55 %
                        Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 38.96 %
                        Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 27.0 hPa
    Readiness: 1 1 0 0 0
       Part No SW: 4G0 927 153     HW: 0CK 927 156 P
       Component: 0CK 20TDI RdW H02 0003
       Revision: --H02---    Serial number: 0000000120
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002011
       ROD: EV_TCMDL382021_AU57.rod
       VCID: 66C9A5D6997C637F03-8032
       Coding: 06A29F016045F980DB00
       VCID: 3A7121A6BD44379F97-806E
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0551
       Coding: 01B83046000000000000
       VCID: 7AF1E1A6F5C4F79FD7-802E
       Serial number: 0214000130974005
       Part No SW: 4G0 820 043 BB    HW: 4G0 820 043 BB
       Component: KLIMA 2 ZONEN H14 0096
       Serial number: 11071400111495
       Coding: 3421090821
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS_004.rod
       VCID: 60C5B3CE7B580D4FF9-8034
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Revision: 20012002    Serial number: 00000001774733
       Coding: 2600201040349FE00181008300001D0C0F9DC30827090201000004606100
       VCID: 6ED9DDF6B98CAB3F7B-803A
       Component: WWS57X 140625  H37 0080
       Serial number:         140707083408
       Coding: 0045F7
       Serial number: 22882302
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 14 07 2014  00001156
       Serial number: 8FA80437000000000001
       Revision: 11001001    Serial number: 61061419602064
       Coding: 08C306
       VCID: 71E3C68AA0B2B4C766-8024
    1079316 - Center Rear Right Parking Aid Sensor
              B1078 14 [008] - Open or Short to Ground
                        Reset counter: 152
                        Mileage: 88321 km
                        Date: 2019.07.30
                        Time: 13:01:09
       Revision: --------    Serial number: 003JG00JP6WY
       Coding: 3032343631324E303235554A305234473053
       VCID: 36693596895CD3FF73-8062
       Serial number: 3575HRB400Q50RHSCPQU
       Serial number: 3585HRB405F2MKOU7H6D
       Serial number: 3515JRB405P2SLKAJH3A
       Serial number: 3525JRB405P2SLKA40S4
       Serial number: 3554VRB400652MR4N1IQ
       Serial number: 3564VRB400452MR4JA4G
       Revision: 00000000    Serial number: 20140714000091
       Coding: 000034
       VCID: 3065038E6338FDCF29-8064
       Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
       Component: MDieGb        H43 0411
       Revision: 27450259    Serial number: 658120714592041
       Coding: 33A60A000B412600010000
       ASAM Dataset: EV_RBC7KMID 004048
       ROD: EV_RBC7KMID.rod
       VCID: 3F8750B2A66612B7A0-806A
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001476965
       Coding: 00CD074400
       VCID: 72E1C986A5B48FDF9F-8026
       Serial number: 0874093903
       Voltage stabilizer:
       Serial number: 14043000000000000089
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA720B77M7
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336F0C829A2EC6D754-8066
       Coding: 011C16004001620002080002
       VCID: 47974852F6B65A7718-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0009754873
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0341755770
       Coding: 011B062280B900008320080400010E470000000000000000000000000000
    02616 - Fuel Tank Cap; Unlock
                        Fault Status: 00101001
                        Reset counter: 194
                        Mileage: 88490 km
                        Date: 2019.07.31
                        Time: 10:01:29
       Revision: CJ007001    Serial number: 00000000123512
       VCID: 1D3BCA3A04AA60A792-8048
       VCID: 46894556F1BC437FE3-8012
       Revision: --------    Serial number: 00000001136892
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D5B1AFA7C0A902702-8078
       Serial number: 140712-0002-060
       Coding: 112196101000A300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
       Component: RMC Nav Plus  H55 0801
       Coding: 0101000101415B47082B060301020100000000
       VCID: 2757E8D256F6BA77F8-8072
       Subsystem 1 - Part No: 8X0 919 884 F
       Component: P23-50-13.06  0001
       Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464F/0E2669161
       Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
       Serial number: 90349NGB000VS
       VCID: 49934E6AE0A2AC070E-801C
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0010
       Revision: 00000000    Serial number: 141841460
       ROD: EV_RDCMA00100_008.rod
       VCID: 2B5F14E2421E9E171C-807E
    End-------------------------(Elapsed Time: 05:10)--------------------------
    Did you do the Basic Setting?
    IDE01772 -- Adaptation of diff. pressure sensor particulate filter
    Nov 2016
    Yes, I did that, finished correctly and all seemed good for 2 days.
    Verify the pipe is not plugged from DPF to PSI sensors, very common now!
    Nov 2016
    Thanks, il check it, is it one of the pipes from dpf to the pressure sensor, one of 2 rubber hoses?
    All conduit from the DPF including barb on DPF must be cleaned and verified for obstruction.
    Did you think to install traps or filters with inspection glass or clear plastic & to collect the debris & so it doesn't smoke another PSI sensor?
    Cheap insurance............
  7. #7
    Nov 2016
    Cheers..... Not my car, just one I fitted a sensor to.
  8. #8
    I often wonder why this was not a thought for a service, for so many miles accumulated and to shift liability to consumer for failing to do it but hey here it's under useful life warranty for 15 years 150K?
