Results 1 to 10 of 16
Thread: 2001 Jetta 1.8T 032 DL - NO VCDS communication in car
    Mar 2014
    Brighton, MI
    Trying to help a friend with his 2001 Jetta.
    Car cranks, starts, dies after 2 sec.
    First though immo kicks in (and could well be).
    Plugging VAGcom in, does not connect to ANY module.
    Plugged another ECU I had on hand, same behavior.
    Took the ECU out and plugged into my bench setup. Connects/reads fine (scan below).
    Radio removed (read aftermarket radio can mess with K band).
    What can I try next to get the car running?
    What might cause the issue?
    What should I unplug (in order of priority/likeliness of causing the issue)?
    ECU BENCH scan (not in-car scan since NO communication when in car):
    Monday,22,July,2019,15:22:40:03761
    VCDS Version: Release 19.6.1 (x64) Running on Windows 7 x64
    Address 01: Engine Labels: 06A-906-032-AWW.lbl
    Control Module Part Number: 06A 906 032 DL
    Component and/or Version: 1.8L R4/5VT G 0004
    Software Coding: 07500
    Work Shop Code: WSC 14130
    VCID: 6BD44A4B198B41175C-5140
    17 Faults Found:
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1116 - 35-10 - Open Circuit - Intermittent
    17526 - Oxygen (Lambda) Sensor Heating; B1 S2
    P1118 - 35-10 - Open Circuit - Intermittent
    17522 - Oxygen (Lambda) Sensor; B1 S2
    P1114 - 35-10 - Internal Resistance too High - Intermittent
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 35-00 - Signal too High
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 35-10 - Performance too Low - Intermittent
    17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
    P1340 - 35-10 - Incor. Correlation - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1
    P0130 - 35-10 - Malfunction in Circuit - Intermittent
    17633 - Fuel Injector for Cylinder 1 (N30)
    P1225 - 35-10 - Short to Ground - Intermittent
    17635 - Fuel Injector for Cylinder 3 (N32)
    P1227 - 35-10 - Short to Ground - Intermittent
    17636 - Fuel Injector for Cylinder 4 (N33)
    P1228 - 35-10 - Short to Ground - Intermittent
    P1602 - 35-10 - Voltage too Low - Intermittent
    16622 - Manifold Pressure / Boost Sensor (G31)
    P0238 - 35-00 - Signal too High
    17071 - ECM Power Relay Control Circuit
    P0687 - 35-00 - Short to Plus
    18057 - Powertrain Data Bus
    P1649 - 35-00 - Missing Message from ABS Controller
    18058 - Powertrain Data Bus
    P1650 - 35-00 - Missing Message from Instrument Cluster
    16497 - Intake Air Temp. Sensor (G42)
    P0113 - 35-00 - Signal too High
    17931 - Crash Signal from Airbag Controller
    P1523 - 35-00 - Implausible Signal
    Readiness: 0010 1101
    Check fuses as per JPPSG
    Unplug each module on K line until you establish communication and check the ground daisy chain to the airbag control module.
    Start with ABS and radio first.
    Don't crash the K line Kraft.........
    HQ
    Plug up to the car, go to [Options], then [Test]. What are ALL of the results?
    Jef
  4. Likes Uwe liked this post
    Mar 2014
    Brighton, MI
    Jef, will do at next opportunity (car is 1/2 hour drive from me) and post up.
    Mar 2014
    Brighton, MI
    Will do again (since it has been a while), but I did unplug ABS (and radio is out). ABS was on the list of k band murderers I read elsewhere so that was done. Also disconnected O2 sensor.
    Checked for fuel (aftermarket (walbro) pump running, fuel coming out rail).
    Not sure easy the instrument cluster can be removed from Jetta, but should that be next?
    Can door module (I think locks not working) cause it?
    Suggestions for next module to unplug.
    That string of faults screams FP relay too or a problem with OXS heaters in car better have a look at that too!
    See if by plugging in you can get the gateway 0x19 in the cluster too and look at advanced block or 125 area values for communications on internal W CAN high/low network.
    HQ
    I will hazard a guess the LED on the HEX+CAN (HUC) goes solid red when plugged up and your port test will be K-Line short to ground or B+. Unplug the HUC and then decide what control module is easiest to unplug, then retest... repeat as needed until you get communication.
    Jef
  9. #8
    Mar 2014
    Brighton, MI
    OXS are unplugged (if OXS is some sort of ghetto for 02 sensors?). Can they (or the wiring to the connector) still cause problems? If so, how to verify?
    Will check the FP relay (need to locate it first). How would the FP relay prevent VAGcom from connecting to all modules?
    Don't know how to access 0x19. Only know enough VCDS to go to modules, blocks; measurement and advance measurements.
  10. #9
    Mar 2014
    Brighton, MI
    I agree. When I last tried to troubleshoot, we unplugged radio, ABS and O2 for that reason. But never went further. Need to get a list of potential modules that might be in a 2001 Jetta Wolfsburg 1.8T. Then determine order of 'unplug and test'.
  11. #10
    Sure could by corrosion bridge .....use RTFB and WD and trace, test with load light & DVOM for cross!
    It wouldn't just reporting on the limited data you provided as a heads up.
    0x19 is the gateway in the cluster.
    https://forums.ross-tech.com/showthr...ut-0x01-08-000
