Cannot update
skoukiadakis
Greece
C?ID=262443
My HEX-NET interface cannot update ASAM!
Also stucks when I try to access Engine!
I post an auto scan here!
#hndoc:?docid=000051E7&xt=hnh:17A2E2902D933650D85838A5C18FFA16EF1E95AF3EEEF915335A82B0209B0168
VCDS Mobile 0.4508.0.4
Scan: 01 02 03 08 09 10 15 17 19 25 44 55
08-Auto HVAC -- Status: OK 16000
09-Cent. Elect. -- Status: OK 16000
19-CAN Gateway -- Status: OK 16000
Address 01: Engine  (CAVE J623)	Labels: 03C-907-309-V1.clb
	Part No SW: 03C 906 027 AR	HW: 03C 906 027 AR
	Component: 1.4l R4 TSI   H15 9971
	Revision: L2H15---
	Coding: 00250012002400000000
	Shop #: WSC 00017 666 02801
	ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
	ROD: N/A
	VCID: 71A546C70477922CD57C42-8024
	No ASAM data for: "EV_ECM14TSI01103C906027AR"
No fault codes found.
Address 02: Auto Trans	Labels: 0AM-927-769.clb
	Part No SW: 0AM 300 050 K	HW: 0AM927769D
	Component: GSG DSG AG7     403  9032
	Revision: 00040034	Serial Number: TFK01012130269
	Shop #: WSC 22643 000 1048576
	VCID: 312586C7C4F74B2C95FC82-513C
Address 03: ABS Brakes  (J104)	Labels: 6R0-907-37x-ESP82.clb
	Part No SW: 6R0 907 379 AK	HW: 6R0 907 379 AF
	Component: ESP8.2i front H05 0001
	Revision: --------
	Coding: 210248E3417602BB842512E682D640411700
	Shop #: WSC 00788 648 00255
	VCID: 8751881F9AF3209CEB584C-80D2
Address 08: Auto HVAC  (J255)	Labels: 6R0-907-044.clb
	Part No SW: 6R0 907 044 N	HW: 6R0 907 044 N
	Component: Climatronic   H12 0812
	Revision: V0000000
	Shop #: WSC 00000 000
	VCID: 3E3FADFB05A92554187E31-806B
Address 09: Cent. Elect.  (J519)	Labels: 7H0-937-08x-09.clb
	Part No SW: 7H0 937 089 D	HW: 7H0 937 089
	Component: BCM T5GP Li4  H47 0230
	Revision: BS047001
	Coding: 3DB029BF48F324009B280EB17CEB0FD05AC0670F60053041200000000000
	Shop #: WSC 124697 483 00190
	VCID: 3731B8DF2A93141CDB38FC-8062
	Subsystem 1 - 	Part No SW: 1K0-955-559-AH	Labels: 1K0-955-559-AG.clb
	Component: RLS 140111 0554  0403
	Coding: 06302D
	Subsystem 2 - 	Part No SW: 6R0-959-801-AB	Labels: 6R0-959-801.clb
	Component: J386__TSG_FT 007 1621
	Coding: 08BC30
	Subsystem 3 - 	Part No SW: 6R0-959-802-AD	Labels: 6R0-959-802.clb
	Component: J387__TSG_BT 007 1621
	Coding: 08BC30
	Subsystem 4 - 	Part No SW: 1K8-951-171-A
	Component: DWA-Sensor 00001 0103
	Subsystem 5 - 	Part No SW: 1K8-951-605-B
	Component: LIN BACKUP HOH11 9005
	Subsystem 6 - 	Part No SW: 6R0-959-591-A
	Component: J245 PS72.015H05 0006
	Coding: 081001
	Subsystem 7 - 	Part No SW: 1K8-951-171-A
	Subsystem 8 - 	Part No SW: 5K0-959-542
	Component: E221__MFL-TASH06 0010
	Coding: 830000
Address 10: Park/Steer Assist  (J446)	Labels: 6R0-919-475.clb
	Part No SW: 6R0 919 475 B	HW: 7E0 919 475
	Component: PARKHILFE 4K  H10 0012
	Revision: --------
	Coding: 108104
	ASAM Dataset: EV_VW250ParkiAssis2 S01008
	ROD: N/A
	VCID: 3D3DAAF708AF264C01743E-8068
	No ASAM data for: "EV_VW250ParkiAssis2"
Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
	Part No SW: 6R0 959 655 M	HW: 6R0 959 655 M
	Component: VW10Airbag012 H09 0020
	Revision: --------
	Coding: 003132
	ROD: N/A
	VCID: 4CDBF73343159FC486EADB-8019
	No ASAM data for: "EV_AirbaVW10BPAVW250"
	Subsystem 1 - 	Serial Number: 3575HRB406509RECAH8F
	Subsystem 2 - 	Serial Number: 3585HRB406109REC297
	Subsystem 3 - 	Serial Number: 3515RRB405709GGUGHB
Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
	Part No SW: 6R0 920 870	HW: 6R0 920 870
	Component: KOMBI         H20 0320
	Coding: 140E00
	ROD: N/A
	VCID: F2A7C9CB81712934AC66F5-80A7
	No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway  (J533)	Labels: 6N0-909-901-19.lbl
	Part No SW: 6N0 909 901	HW: 7H0 937 089
	Component: GW-K-CAN TP20 0230
	Coding: 002000
	VCID: F0A3C3C38F7D03245A72CF-80A5
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Part No SW: 5K0 953 234	HW: 5K0 953 234
	Component: IMMO          H20 0320
	ROD: N/A
	VCID: EA97D1ABA9A1E1F414368D-80BF
	No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 44: Steering Assist	Labels: 6Q0-423-156.clb
	Part No SW: 6R0 423 156 B
	Component: LenkhilfeTRW        V277
	Coding: 11241
	Shop #: WSC 00788 000
	VCID: 2F2180BFD2C348DC83C894-807A
Address 55: Xenon Range  (J431)	Labels: 6R0-907-357.clb
	Part No SW: 6R0 907 357	HW: 6R0 907 357
	Component: LWR-ECU       H02 0070
	Revision: --------
	Coding: 0110000001000000
	ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
	ROD: N/A
	VCID: F7B1F8DFEA134C1C9BB83C-80A2
	No ASAM data for: "EV_HeadlRegulVWLWRPt"
End--(Elapsed Time: 02:03, VBatt start/end: 13.3/13.3 Vign: 0.0)-
Moving to HEX-NET support.
Shaun
I've switched your interface to the alpha channel, where there is a new update. Please download this update and then try again and see if that helps.
skoukiadakis
Greece
C?ID=262443
Did the update!
Although I see a message getvin timeout!
skoukiadakis
Greece
C?ID=262443
Do I have to switch my interface to beta channel or not?
No. Alpha is an update channel you can't switch to yourself. When someone from Ross-Tech tells you they've put you on Alpha, switching back down to Beta or Release just is counter-productive! I see you've done exactly that, but without updating your interface.
I've just put you back on Alpha again. Please check for updates. You should get CB version 4513. Once you have that, please try updating your ROD/ASAM data again.
skoukiadakis
Greece
C?ID=262443
Thanks for helping!
Did the update.Now i have CB version 4513.
Now when I will plug it to the car,if any updates,i must install them with VCDS mobile or with VCDS configurator?
Zenerdiode
Newcastle, England
C?ID=24330
Use either. But remember, don’t touch the Beta or Release channel switcher in VCI-Config.
