2009 Passat ABS Coding for ACC Retrofit
   #21
golfi_vend
Tartu, Estonia
C?ID=195131
I tried 10533 but i got a fault for brake booster electrical problem. I only have an autoscan on swedish before abs swap but my old abs code was 0010538.
Can You show us the fault?
Your Swedish scan shows us coding 0002346, 0010538 would be same engine type with ACC enabled, but I believe that ABS 109T(SW0013) and AG(SW0015) may use different code part for same engine.
   #22
raziel90
Sweden
C?ID=172805
10538 and my old 2346 got rejected. 10533 is ok but i got a vacuum fault insted of control module not coded
   #23
raziel90
Sweden
C?ID=172805
So it should be in the 10000 range?
Dana
Western PA, USA
Hi guys,
I don't have much to contribute but I came up with the same 03-ABS coding values:
Original 8T2 = 092A | 0002346
PR-8T5 CCS = 292A | 0010538
PR-8T3 CCS = 692A | 0026922
We don't have a single scan coded to 0010538 -or- 0026922 so I agree with golfi_vend meaning this exact engine/trans coding may not support either of the known ACC coding values.
raziel90
Sweden
C?ID=172805
I think this came from a passat with a cbbb engine but i will look and se if i can find my order.
   #26
raziel90
Sweden
C?ID=172805
Today i ordera a abs that ends with the letter R with same sw 0013 as my old one. It came from a 2009 passat cc cbbb automatic so i hope it will work
   #27
Dana
Western PA, USA
Sounds good. When it arrives I would plug it in and see if 0010538, 0026922 or the original coding of 0002346 are accepted. If it accepts several of those coding values it should be worthwhile to install it so you can complete Basic Settings and bleed the brakes.
   #28
Dana
Western PA, USA
P.S. We have notes on an entirely different car type in our coding chart that may apply. For example:
78 = MY 2009: 2.0l TFSI CCTA [PR-TQ2] & 6-Speed Automatic [PR-G1A]
but
79 = MY 2009: 2.0l TFSI CCTA [PR-TQ2] & 6-Speed Automatic [PR-G1A] (with Replacement Control Module!)
That's a NAR 2.0T Gas so you don't want those actual values. Instead, I'm thinking the pattern may be applicable.
If so, the current module might accept a +1 version of the above. Try these bold options:
Original 8T2 092A +1 in Byte 1 = 092B | 0002347
PR-8T5 CCS = 292A +1 in Byte 1 = 292B | 0010539
PR-8T3 CCS = 692A +1 in Byte 1 = 692B | 0026923
raziel90
Sweden
C?ID=172805
but
I wrote those codes but 10533 gave me the least fault codes. I order the abs but the scrapyard saw that it isn't from factory so they shipoed another one so i will get the right one next week:banghead:
   #30
raziel90
Sweden
C?ID=172805
Meanwhile can some one tell me how to solve this fault
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - MIL ON
   #31
dnoermann
C?ID=358118
I assume it is from ECU.
Did you already enable ACC in ECU Coding, this could solve that.
If not, wait till the right coded ABS is in the car, than this could go away.
   #32
Dana
Western PA, USA
but
That sounds like it may be progress. Assuming it was the factory equivalent per my theory, the scan with it coded to 0002347 would be helpful so we can see if the conflicts were limited to basic settings and ACC conflicts. Likewise the scan with it coded to one of the ACC versions might help based on the fault codes.
Either way, dnoermann is correct about: Check Coding of ECUs on Powertrain Data Bus. That will not clear until you get the coding and PT module compatibility concerns resolved. For that reason I wouldn't worry about it until you get the 03-ABS module issues sorted.
raziel90
Sweden
C?ID=172805
THANKS EVERYONE FOR YOUR TIME AND EFFORT!!!!!
My original abs
artikelnr SW: 3C0 614 109 T HW: 3C0 614 109 T
Komponent: J104 C4 440 V2 0013
Revision: --025--- Serienummer: 00000786477401
Kodning: 0002346
Verkstad #: WSC 05311 000 00000
VCID: 2F552CC4BE7A8A3A6B-807A
My first new
Part No SW: 3C0 614 109 AG HW: 3C0 614 109 AG
Component: J104 C4 440 V3 0015
Revision: --025--- Serial number: 00000796066204
Coding: 0010000
Shop #: WSC 05311 000 00000
VCID: 63FD90F4A2327E57E4-8036
My second new
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 R HW: 3C0 614 109 R
Component: J104 C4 440 V3 0013
Revision: --025--- Serial number: 00000795061489
Coding: 0010538
VCID: 2D6936CCB476F82702-8078
now with the first abs(AG) that i tried it gave faults and as you know it didn`t accept the codes that i inputed and it had a differant HW and SW number compared to my original one, so i bought another on thet had the same HW and SW number and ended with the letter R. Because it`s shares the same partnumber with the AG and Q in etka and because to swap the abs on a passat you have to almost remove the DPF and the assembley carrier which is a lot of work and expensive i only swaped the abs module AND IT WORKED!!!!!
I cleard all the fault codes and i no longer have any fault codes except for the AC but thats because i have a auxiliary heater button but no OEM heater.
Tuesday,13,August,2019,00:28:09:26566
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 19.6.1.0
VIN: WVWZZZ3CZ9E551356   License Plate: DYM580
Mileage: 188940km-117401mi   Repair Order: FINISHED
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 13 14 15 16 17 19 20 25 2E 36 37 42 44 46 4F
          52 53 55 56 57 5C 62 69 6C 72 77
VIN: WVWZZZ3CZ9E551356   Mileage: 188940km-117401miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QF    HW: 03L 907 309
   Component: R4 2.0l TDI A000SG  9977
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 26214 051 00000
   VCID: 79C1D29C30BE9487DE-802C
   Coding: 0010538
   Part No SW: 3AA 907 044 E    HW: 3AA 907 044 E
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0014104808
   Shop #: WSC 80248 790 00003
   VCID: 325325B06548A7DF5F-8066
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 250
                    Mileage: 188943 km
                    Date: 2019.08.13
                    Time: 04:57:44
   Revision: 00H54000    Serial number: 00000009212812
   Coding: EFE28F8910041A0047978F0017000000000BFB4764401165170000000000
   Shop #: WSC 40970 222 55394
   VCID: 335D20B45252AED754-8066
   Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 251108 022  0602
   Coding: 00047029
   Shop #: WSC 40970
   Component: RLS     210109 054  0402
   Coding: 00471277
   Shop #: WSC 40970
                    Reset counter: 250
                    Mileage: 188943 km
                    Voltage: 12.35 V
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 L    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0021
   Revision: --------    Serial number: 06530901409498
   Coding: 310007
   Shop #: WSC 40970 222 98706
   VCID: 44BF7368C7FC196FFD-8010
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 J    HW: 3C0 907 567 G
   Component: AC201  RDW M    031 0232
   Revision: 00031000    Serial number: 00000000900473
   Coding: 0010100
   Shop #: WSC 05311 000 08193
   VCID: 325325B0AD48A7DF5F-8066
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 06010902520002
   Coding: 030180
   Shop #: WSC 05311 123 08193
   VCID: 66FB89E091000B7F03-8032
   Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
   Component: J234__304 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP0CG697
   Coding: 0012340
   VCID: 3B4D08947A0266978C-806E
   Subsystem 1 - Serial number: 6333FTS605571130
   Subsystem 2 - Serial number: 6343FTS657021130
   Subsystem 3 - Serial number: 6353ETS6GQPEV5KJ
   Subsystem 4 - Serial number: 6363ETS69QOFV5KR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AK    HW: 3C0 953 549 AK
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507CP
   Coding: 0200721
   VCID: 75D9DEAC1CA6F0E7BA-8020
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
   Part No SW: 3C8 920 880 GX    HW: 3C8 920 880 GX
   Component: KOMBI         H03 0132
   Coding: 140D00
   Shop #: WSC 80239 123 12345
   VCID: 0827A758B354FD0FD1-805C
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G108310221
   Coding: F9ADFF46C0465B004002
   Shop #: WSC 05314 123 12345
   VCID: 2C6F3BC88F6CF12F15-8078
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Revision: AA001002
   Coding: 0201006B74745D545420363E00
   Shop #: WSC 00066 123 12345
   VCID: 2D6936CC7476F82702-8078
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Shop #: WSC 54631 001 1048576
   VCID: 7AC3CD9035B89F9FD7-802E
   Revision: A1001003    Serial number: 7665373401
   Coding: 020100
   Shop #: WSC 00020 790 00000
   VCID: 2B6D38D44A62F6171C-807E
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
   Component: Sitzmemory    H02 1001
   Revision: 00H02000
   Coding: 000039
   VCID: 345F23A8975CA9EF4D-8060
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z7M4010128
   Coding: 0600040000000081200F
   VCID: 365B19A08120BBFF73-8062
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V12  8196
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1533
   Revision: 71009005    Serial number: 00000765589012
   Coding: 0004351
   VCID: 40B77F7813E4054FD9-8014
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.070 0502
   Revision: 1AH02240    Serial number: 00082740297802
   Coding: 0000258
   VCID: 3941129C703E54879E-806C
   Component:    KSG PQ46 ELV 043 0612
   Coding: 18910A0001864E7F3F029D1D70C8CFCE705F41
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Component: EZE_2         H14 0172
   Revision: --------    Serial number: 1021G108310221
   Coding: 01030100
   Shop #: WSC 05314 000 00000
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 847300039270
   Coding: 000006
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1533
   Revision: 71009005    Serial number: 00000521789114
   Coding: 0004590
   VCID: 41B17A7C18EE0C47D6-8014
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000232669
   Coding: 0000057
   Shop #: WSC 08876 000 104857
   VCID: 2867C7D89B94DD0FF1-807C
   Component: AFS-Steuergeraet    0136
   Coding: 3493064
   VCID: 345F23A8575CA9EF4D-8060
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0003
   Coding: 00000053
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0003
   Coding: 00000053
Address 57: TV Tuner        Labels: 7L6-919-148.clb
   Part No SW: 7L6 919 148 A    HW: 7L6 919 148
   Component: R0078 TVhybridDVB   0150
   Revision: R0H21000    Serial number: 93900501354101
   Coding: 0000801
   VCID: 3A430D9075385F9F97-806E
Address 5C: Lane Maintain.        Labels: 3C0-907-217.clb
   Part No SW: 3C0 907 217 A    HW: 4E0 907 217 C
   Component: J759  HCA           0150
   Revision: 00H07004    Serial number: 400209406000DA
   Coding: 0132002
   VCID: 2171DAFCF8AE2C47B6-8074
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000769112
   Coding: 0000200
   VCID: 31512ABCA84E9CC726-8064
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000129162821
   Coding: 0100000100000000
   VCID: 30572FB8634495CF29-8064
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H13000    Serial number: 525PA8-J480845
   Coding: 0030008
   Shop #: WSC 05311 000 00001
   VCID: 67E584E4560A127738-8032
Address 72: Door, Rear Right        Labels: None
   Part No SW: 3C8 959 704 D    HW: 3C8 959 794
   Component: J389   TUER-SG HR   0501
   Revision: 43004102    Serial number: 00000002825406
   Coding: 0065680
   Shop #: WSC 08224 016 263172
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669330704
   Coding: 0200000000010110
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 62F395F07528775FEF-8036
End-------------------------(Elapsed Time: 03:41)--------------------------
Now i have two probles which don`t give fault codes
1. i have mesured the wire the goes from the relay to the gateway pin 3 and i have 10v and it wont turn on so ecu can communicate with tha radar but when i connect CAN HI and LOW with wires directly everything works
2. the other problem is that it says ACC starting but it newer starts and when i push cruise control lever the cruise control symbol lights up green on the dash but then it turns off and i cant activate ACC
does anyone know what i need to do in order to get it to work?
THANKS in advance:D:thumbs:
raziel90
Sweden
C?ID=172805
Can the g85 sensor be faulty even if i get a 00778 fault code because it only reads 0.0° even when i turn the steering wheel?
   #35
raziel90
Sweden
C?ID=172805
The 00778 fault fixed it self!!:D
   #37
raziel90
Sweden
C?ID=172805
And now ACC is working ?
No. It just say starting and i cant activate acc only regular ccs but it doesn't work 100% and there isn't any acc under assistant systems. But all faults are gone
   #38
raziel90
Sweden
C?ID=172805
Update on my problem.
Today while driving i turned on my cruise control and it started braking by it self and then when i got som distance the car started to accelerating but my MFD still say STARTING and i cant se the ccs set speed. Any clue?
   #39
raziel90
Sweden
C?ID=172805
Hi again,
Does any one have the activation value for acc on the leavercentral? Maybe i wrote the wrong activation value or i messed up the deactivation of the regular ccs?
   #40
Dana
Western PA, USA
Please post the complete English Auto-Scan in the current condition.
