Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 59
Thread: 2009 Passat ABS Coding for ACC Retrofit
  1. #31
    Jan 2019
    Quote Originally Posted by raziel90 View Post
    005703 - Check Coding of ECUs on Powertrain Data Bus
    P1647 - 000 - - MIL ON
    I assume it is from ECU.
    Did you already enable ACC in ECU Coding, this could solve that.
    If not, wait till the right coded ABS is in the car, than this could go away.
  2. Likes Dana liked this post
  3. #32
    United States
    P.S. We have notes on an entirely different car type in our coding chart that may apply. For example:
    78 = MY 2009: 2.0l TFSI CCTA [PR-TQ2] & 6-Speed Automatic [PR-G1A]
    but
    79 = MY 2009: 2.0l TFSI CCTA [PR-TQ2] & 6-Speed Automatic [PR-G1A] (with Replacement Control Module!)
    That's a NAR 2.0T Gas so you don't want those actual values. Instead, I'm thinking the pattern may be applicable.
    If so, the current module might accept a +1 version of the above. Try these bold options:
    Original 8T2 092A +1 in Byte 1 = 092B | 0002347
    PR-8T5 CCS = 292A +1 in Byte 1 = 292B | 0010539
    PR-8T3 CCS = 692A +1 in Byte 1 = 692B | 0026923
    I wrote those codes but 10533 gave me the least fault codes. I order the abs but the scrapyard saw that it isn't from factory so they shipoed another one so i will get the right one next week
    That sounds like it may be progress. Assuming it was the factory equivalent per my theory, the scan with it coded to 0002347 would be helpful so we can see if the conflicts were limited to basic settings and ACC conflicts. Likewise the scan with it coded to one of the ACC versions might help based on the fault codes.
    Either way, dnoermann is correct about: Check Coding of ECUs on Powertrain Data Bus. That will not clear until you get the coding and PT module compatibility concerns resolved. For that reason I wouldn't worry about it until you get the 03-ABS module issues sorted.
  4. Likes Uwe liked this post
  5. #33
    Oct 2014
    Sweden
    THANKS EVERYONE FOR YOUR TIME AND EFFORT!!!!!
    My original abs
    artikelnr SW: 3C0 614 109 T HW: 3C0 614 109 T
    Komponent: J104 C4 440 V2 0013
    Revision: --025--- Serienummer: 00000786477401
    Kodning: 0002346
    Verkstad #: WSC 05311 000 00000
    VCID: 2F552CC4BE7A8A3A6B-807A
    My first new
    Part No SW: 3C0 614 109 AG HW: 3C0 614 109 AG
    Component: J104 C4 440 V3 0015
    Revision: --025--- Serial number: 00000796066204
    Coding: 0010000
    Shop #: WSC 05311 000 00000
    VCID: 63FD90F4A2327E57E4-8036
    My second new
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 R HW: 3C0 614 109 R
    Component: J104 C4 440 V3 0013
    Revision: --025--- Serial number: 00000795061489
    Coding: 0010538
    VCID: 2D6936CCB476F82702-8078
    now with the first abs(AG) that i tried it gave faults and as you know it didn`t accept the codes that i inputed and it had a differant HW and SW number compared to my original one, so i bought another on thet had the same HW and SW number and ended with the letter R. Because it`s shares the same partnumber with the AG and Q in etka and because to swap the abs on a passat you have to almost remove the DPF and the assembley carrier which is a lot of work and expensive i only swaped the abs module AND IT WORKED!!!!!
    I cleard all the fault codes and i no longer have any fault codes except for the AC but thats because i have a auxiliary heater button but no OEM heater.
    Tuesday,13,August,2019,00:28:09:26566
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 19.6.1.0
    VIN: WVWZZZ3CZ9E551356   License Plate: DYM580
    Mileage: 188940km-117401mi   Repair Order: FINISHED
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 10 13 14 15 16 17 19 20 25 2E 36 37 42 44 46 4F
              52 53 55 56 57 5C 62 69 6C 72 77
    VIN: WVWZZZ3CZ9E551356   Mileage: 188940km-117401miles
    Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 QF    HW: 03L 907 309
       Component: R4 2.0l TDI A000SG  9977
       Revision: 13H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 26214 051 00000
       VCID: 79C1D29C30BE9487DE-802C
       Coding: 0010538
       Part No SW: 3AA 907 044 E    HW: 3AA 907 044 E
       Component: Climatronic   H03 0101
       Revision: 00001K01
       Coding: 0014104808
       Shop #: WSC 80248 790 00003
       VCID: 325325B06548A7DF5F-8066
    13701424 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 250
                        Mileage: 188943 km
                        Date: 2019.08.13
                        Time: 04:57:44
       Revision: 00H54000    Serial number: 00000009212812
       Coding: EFE28F8910041A0047978F0017000000000BFB4764401165170000000000
       Shop #: WSC 40970 222 55394
       VCID: 335D20B45252AED754-8066
       Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 251108 022  0602
       Coding: 00047029
       Shop #: WSC 40970
       Component: RLS     210109 054  0402
       Coding: 00471277
       Shop #: WSC 40970
                        Fault Status: 01101100
                        Reset counter: 250
                        Mileage: 188943 km
                        Voltage: 12.35 V
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 L    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0021
       Revision: --------    Serial number: 06530901409498
       Coding: 310007
       Shop #: WSC 40970 222 98706
       VCID: 44BF7368C7FC196FFD-8010
    Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
       Part No SW: 3C0 907 567 J    HW: 3C0 907 567 G
       Component: AC201  RDW M    031 0232
       Revision: 00031000    Serial number: 00000000900473
       Coding: 0010100
       Shop #: WSC 05311 000 08193
       VCID: 325325B0AD48A7DF5F-8066
    Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
       Part No SW: 3C0 907 376     HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0069
       Revision: 00000000    Serial number: 06010902520002
       Coding: 030180
       Shop #: WSC 05311 123 08193
       VCID: 66FB89E091000B7F03-8032
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__304 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DP0CG697
       Coding: 0012340
       VCID: 3B4D08947A0266978C-806E
       Subsystem 1 - Serial number: 6333FTS605571130
       Subsystem 2 - Serial number: 6343FTS657021130
       Subsystem 3 - Serial number: 6353ETS6GQPEV5KJ
       Subsystem 4 - Serial number: 6363ETS69QOFV5KR
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AK    HW: 3C0 953 549 AK
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CP
       Coding: 0200721
       VCID: 75D9DEAC1CA6F0E7BA-8020
       Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H31 0037
       Coding: 00000130
       Part No SW: 3C8 920 880 GX    HW: 3C8 920 880 GX
       Component: KOMBI         H03 0132
       Coding: 140D00
       Shop #: WSC 80239 123 12345
       VCID: 0827A758B354FD0FD1-805C
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 N    HW: 3C0 907 951
       Component: J533  Gateway   H14 0172
       Revision:   H14       Serial number: 1021G108310221
       Coding: F9ADFF46C0465B004002
       Shop #: WSC 05314 123 12345
       VCID: 2C6F3BC88F6CF12F15-8078
       Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
       Revision: AA001002
       Coding: 0201006B74745D545420363E00
       Shop #: WSC 00066 123 12345
       VCID: 2D6936CC7476F82702-8078
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 54631 001 1048576
       VCID: 7AC3CD9035B89F9FD7-802E
       Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
       Revision: A1001003    Serial number: 7665373401
       Coding: 020100
       Shop #: WSC 00020 790 00000
       VCID: 2B6D38D44A62F6171C-807E
       Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
       Component: Sitzmemory    H02 1001
       Revision: 00H02000
       Coding: 000039
       VCID: 345F23A8975CA9EF4D-8060
       Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
       Component: RNS-MID       H27 6276
       Revision: AB001001    Serial number: VWZ6Z7M4010128
       Coding: 0600040000000081200F
       Shop #: WSC 12345 123 12345
       VCID: 365B19A08120BBFF73-8062
       Subsystem 1 - Part No: 1T0 919 859 C
       Component: EU East V12  8196
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1533
       Revision: 71009005    Serial number: 00000765589012
       Coding: 0004351
       VCID: 40B77F7813E4054FD9-8014
       Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.070 0502
       Revision: 1AH02240    Serial number: 00082740297802
       Coding: 0000258
       VCID: 3941129C703E54879E-806C
       Component:    KSG PQ46 ELV 043 0612
       Coding: 18910A0001864E7F3F029D1D70C8CFCE705F41
       Part No SW: 1K0 907 532     HW: 3C0 907 951
       Component: EZE_2         H14 0172
       Revision: --------    Serial number: 1021G108310221
       Coding: 01030100
       Shop #: WSC 05314 000 00000
       Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
       Component: J245/J878  H04 0054
       Serial number: 847300039270
       Coding: 000006
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1533
       Revision: 71009005    Serial number: 00000521789114
       Coding: 0004590
       VCID: 41B17A7C18EE0C47D6-8014
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000232669
       Coding: 0000057
       Shop #: WSC 08876 000 104857
       VCID: 2867C7D89B94DD0FF1-807C
       Component: AFS-Steuergeraet    0136
       Coding: 3493064
       VCID: 345F23A8575CA9EF4D-8060
       Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0003
       Coding: 00000053
       Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0003
       Coding: 00000053
    Address 57: TV Tuner        Labels: 7L6-919-148.clb
       Part No SW: 7L6 919 148 A    HW: 7L6 919 148
       Component: R0078 TVhybridDVB   0150
       Revision: R0H21000    Serial number: 93900501354101
       Coding: 0000801
       VCID: 3A430D9075385F9F97-806E
    Address 5C: Lane Maintain.        Labels: 3C0-907-217.clb
       Part No SW: 3C0 907 217 A    HW: 4E0 907 217 C
       Component: J759  HCA           0150
       Revision: 00H07004    Serial number: 400209406000DA
       Coding: 0132002
       VCID: 2171DAFCF8AE2C47B6-8074
       Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Component: J388   TUER-SG HL   0309
       Revision: 43004101    Serial number: 00000000769112
       Coding: 0000200
       VCID: 31512ABCA84E9CC726-8064
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Component: Anhaenger     H07 0070
       Revision: 3A001001    Serial number: 00000129162821
       Coding: 0100000100000000
       VCID: 30572FB8634495CF29-8064
       Part No SW: 3C8 907 441     HW: 3C8 907 441
       Revision: 00H13000    Serial number: 525PA8-J480845
       Coding: 0030008
       Shop #: WSC 05311 000 00001
       VCID: 67E584E4560A127738-8032
    Address 72: Door, Rear Right        Labels: None
       Part No SW: 3C8 959 704 D    HW: 3C8 959 794
       Component: J389   TUER-SG HR   0501
       Revision: 43004102    Serial number: 00000002825406
       Coding: 0065680
       Shop #: WSC 08224 016 263172
       Part No SW: 5K0 035 730     HW: 5K0 035 730
       Component: TELEFON       H09 1020
       Revision: 1B001001    Serial number: 00007669330704
       Coding: 0200000000010110
       ASAM Dataset: UHVNA A01009
       ROD: UHVNA.rod
       VCID: 62F395F07528775FEF-8036
    End-------------------------(Elapsed Time: 03:41)--------------------------
    Now i have two probles which don`t give fault codes
    1. i have mesured the wire the goes from the relay to the gateway pin 3 and i have 10v and it wont turn on so ecu can communicate with tha radar but when i connect CAN HI and LOW with wires directly everything works
    2. the other problem is that it says ACC starting but it newer starts and when i push cruise control lever the cruise control symbol lights up green on the dash but then it turns off and i cant activate ACC
    does anyone know what i need to do in order to get it to work?
    THANKS in advance
  6. Likes Dana liked this post
  7. #34
    Oct 2014
    Sweden
    Can the g85 sensor be faulty even if i get a 00778 fault code because it only reads 0.0 even when i turn the steering wheel?
  8. #35
    Oct 2014
    Sweden
    The 00778 fault fixed it self!!
  9. Likes Dana liked this post
  10. #36
    Jan 2019
    And now ACC is working ?
  11. Likes Dana liked this post
  12. #37
    Oct 2014
    Sweden
    Quote Originally Posted by dnoermann View Post
    No. It just say starting and i cant activate acc only regular ccs but it doesn't work 100% and there isn't any acc under assistant systems. But all faults are gone
  13. #38
    Oct 2014
    Sweden
    Update on my problem.
    Today while driving i turned on my cruise control and it started braking by it self and then when i got som distance the car started to accelerating but my MFD still say STARTING and i cant se the ccs set speed. Any clue?
  14. #39
    Oct 2014
    Sweden
    Hi again,
    Does any one have the activation value for acc on the leavercentral? Maybe i wrote the wrong activation value or i messed up the deactivation of the regular ccs?
  15. #40
    United States
    Please post the complete English Auto-Scan in the current condition.
  16. Likes Uwe liked this post
