- Joined
- Jun 24, 2019
- Messages
- 14
- Reaction score
- 2
- Location
- Chicago, USA
- VCDS Serial number
- C?ID=370464
I hope everyone is doing well!
New user of the VCDS software here. I've got a 2009 GTI that had a bad abs module. The original ABS model was thrown out without retrieving the original coding. Out of desperation of needing a functioning vehicle (before the ABS recall happened), I replaced the original abs module with a module out of a 2011 Jetta. It "seems" to function, but I am really uncertain as to whether this module can be coded or not to my vehicle. Any help on this matter would be greatly appreciated. Below I attached the scan of the abs module first & then the auto scan with the fault codes.
Thanks!
Thanks!
Sunday,28,July,2019,13:01:01:14274
VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component and/or Version: ESP MK60EC1 H31 0121
Software Coding: 00000000000000000000000000000000000000
Work Shop Code: WSC 00066 000 00000
VCID: 7BA3F60F93E61CFF9FB-802E
Reset counter: 234
Count: 3
Count: 20992
Count: 195
Count: 42240
Fault Status: 01100101
Reset counter: 29
Mileage: 253708 km
Count: 3
Count: 2
Count: 28672
Count: 279
Count: 42240
Count: 65280
Reset counter: 29
Mileage: 253708 km
Count: 3
Count: 2
Count: 28672
Count: 295
Count: 42240
Count: 65280
Reset counter: 29
Mileage: 253708 km
Count: 3
Count: 2
Count: 28672
Count: 270
Count: 42240
Count: 65280
________________________________________________________________________________
Sunday,28,July,2019,13:11:08:14274
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWEV71K19W133621 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K19W133621 Mileage: 265580km-165023miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H93N77VW
Coding: 0403010A18070160
Shop #: WSC 85573 554 600234
VCID: 698FBC47E57A9E6F7D7-803C
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 265414 km
Time: 10:09:12
RPM: 2775 /min
Load: 23.5 %
Speed: 113.0 km/h
Temperature: 90.0°C
Temperature: 33.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.843 V
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Reset counter: 162
Mileage: 265580 km
Count: 16391
Count: 8192
Count: 195
Count: 46848
Reset counter: 162
Mileage: 265580 km
Count: 3
Count: 2
Count: 12288
Count: 279
Count: 43008
Reset counter: 162
Mileage: 265580 km
Count: 3
Count: 2
Count: 12288
Count: 295
Count: 43008
Reset counter: 162
Mileage: 265580 km
Count: 3
Count: 2
Count: 12288
Count: 270
Count: 43008
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78A9E903AED037E7F29-802C
Revision: 00H54000 Serial number: 00000008574964
Coding: A78D8F214004150047140000001400000038770B5C000100000000000000
VCID: 33331E2FF73614BF07B-8066
Component: Wischer 250908 021 0501
Coding: 00038805
Shop #: WSC 01357
Fault Status: 00101010
Reset counter: 200
Mileage: 264938 km
Voltage: 13.90 V
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0426202
Coding: 0000100
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0C1NC
Coding: 0013899
VCID: 6C81C553EA888B47061-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME3D0141362
Subsystem 3 - Serial number: 6342MSME4005290F7
Subsystem 4 - Serial number: 6352QSME1B0E303AJ
Subsystem 5 - Serial number: 6362QSME60081F36H
Subsystem 6 - Serial number: 63727SME186C044FA
Subsystem 7 - Serial number: 63827SME186C121E6
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 051 0101
Coding: 0002022
VCID: 015F84E7FD0A762FC57-8054
Component: E0221 002 0010
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H93N77VW
Coding: 0007203
Shop #: WSC 02120 444 84272
VCID: 392F2C07D55AEEEFCD7-806C
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 240908F2001478
Coding: E9811F070013020000
VCID: 35372037F9420A8F29F-8060
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T46WV03
VCID: 7DA7F81781F212CFA1F-8028
Component: IMMO VDD 2416
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 38292903EE50F7E7329-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103081B09040585B0080A04889C00
VCID: 04518DF3E2186307EE1-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1DD33B2B85387DE1-8020
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 125 0037
Revision: 00125000 Serial number: VWZ5Z7H2265781
Coding: 0040402
VCID: 290FFC4725FA5E6FBD7-807C
Component: RDK 0450
Coding: 0100101
End----------(Elapsed Time: 01:13, VBatt start/end: 12.1V/12.0V)-----------
