Results 1 to 10 of 11
Thread: Coding ABS Module
    Jun 2019
    Chicago, USA
    Question Coding ABS Module
    I hope everyone is doing well!
    New user of the VCDS software here. I've got a 2009 GTI that had a bad abs module. The original ABS model was thrown out without retrieving the original coding. Out of desperation of needing a functioning vehicle (before the ABS recall happened), I replaced the original abs module with a module out of a 2011 Jetta. It "seems" to function, but I am really uncertain as to whether this module can be coded or not to my vehicle. Any help on this matter would be greatly appreciated. Below I attached the scan of the abs module first & then the auto scan with the fault codes.
    Thanks!
    Sunday,28,July,2019,13:01:01:14274
    VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
                    Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
      Component and/or Version: ESP MK60EC1   H31 0121
               Software Coding: 00000000000000000000000000000000000000
                Work Shop Code: WSC 00066 000 00000
                          VCID: 7BA3F60F93E61CFF9FB-802E
                        Reset counter: 234
                        Count: 3
                        Count: 20992
                        Count: 195
                        Count: 42240
                        Fault Status: 01100101
                        Reset counter: 29
                        Mileage: 253708 km
                        Count: 3
                        Count: 2
                        Count: 28672
                        Count: 279
                        Count: 42240
                        Count: 65280
                        Reset counter: 29
                        Mileage: 253708 km
                        Count: 3
                        Count: 2
                        Count: 28672
                        Count: 295
                        Count: 42240
                        Count: 65280
                        Reset counter: 29
                        Mileage: 253708 km
                        Count: 3
                        Count: 2
                        Count: 28672
                        Count: 270
                        Count: 42240
                        Count: 65280
    ________________________________________________________________________________
    Sunday,28,July,2019,13:11:08:14274
    VIN: WVWEV71K19W133621   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    VIN: WVWEV71K19W133621   Mileage: 265580km-165023miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0030
       Revision: AAH03---    Serial number: VWX7Z0H93N77VW
       Coding: 0403010A18070160
       Shop #: WSC 85573 554 600234
       VCID: 698FBC47E57A9E6F7D7-803C
    006481 - Radiator Fan 2 (V177)
                   P1951 - 000 - Movement Restricted / Jammed - Intermittent
                        Mileage: 265414 km
                        Time: 10:09:12
                        RPM: 2775 /min
                        Load: 23.5 %
                        Speed: 113.0 km/h
                        Temperature: 90.0°C
                        Temperature: 33.0°C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.843 V
       Revision: 00H31001
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 16391
                        Count: 8192
                        Count: 195
                        Count: 46848
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 279
                        Count: 43008
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 295
                        Count: 43008
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 270
                        Count: 43008
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78A9E903AED037E7F29-802C
       Revision: 00H54000    Serial number: 00000008574964
       Coding: A78D8F214004150047140000001400000038770B5C000100000000000000
       VCID: 33331E2FF73614BF07B-8066
       Component: Wischer 250908 021  0501
       Coding: 00038805
       Shop #: WSC 01357
                        Fault Status: 00101010
                        Reset counter: 200
                        Mileage: 264938 km
                        Voltage: 13.90 V
       Revision: 00000000    Serial number: AUZ4Z7H0426202
       Coding: 0000100
       Component: 6K AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0C1NC
       Coding: 0013899
       VCID: 6C81C553EA888B47061-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME3D0141362
       Subsystem 3 - Serial number: 6342MSME4005290F7
       Subsystem 4 - Serial number: 6352QSME1B0E303AJ
       Subsystem 5 - Serial number: 6362QSME60081F36H
       Subsystem 6 - Serial number: 63727SME186C044FA
       Subsystem 7 - Serial number: 63827SME186C121E6
       Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
       Coding: 0002022
       VCID: 015F84E7FD0A762FC57-8054
       Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
       Component: KOMBIINSTRUMENT VDD 2416
       Revision: V0003000    Serial number: VWX7Z0H93N77VW
       Coding: 0007203
       Shop #: WSC 02120 444 84272
       VCID: 392F2C07D55AEEEFCD7-806C
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 240908F2001478
       Coding: E9811F070013020000
       VCID: 35372037F9420A8F29F-8060
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T46WV03
       VCID: 7DA7F81781F212CFA1F-8028
       Component: IMMO            VDD 2416
       Component: Tuer-SG         006 1207
       Coding: 0001077
       VCID: 38292903EE50F7E7329-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.074 H08 1901
       Shop #: WSC 00000 028 00001
       Coding: 139006885103081B09040585B0080A04889C00
       VCID: 04518DF3E2186307EE1-8050
       Coding: 0001076
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74B1DD33B2B85387DE1-8020
       Component: Radio PM6       125 0037
       Revision: 00125000    Serial number: VWZ5Z7H2265781
       Coding: 0040402
       VCID: 290FFC4725FA5E6FBD7-807C
       Coding: 0100101
    End----------(Elapsed Time: 01:13, VBatt start/end: 12.1V/12.0V)-----------
    A complete Auto-Scan (to see how the vehicle is equipped) that also shows the complete VIN is absolutely essential here. Portions of the VIN mus be embedded in the coding.
    Jun 2019
    Chicago, USA
    Is this the correct scan that you need to see? I used auto scan>>Auto- Detect (CAN only)>>start
    I apologize if it's not, I looked at the videos and it seemed like the only option.
    Sunday,04,August,2019,12:59:29:14274
    VIN: WVWEV71K19W133621   Mileage: 266310km-165477miles
       Revision: 00H31001
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 16391
                        Count: 8192
                        Count: 195
                        Count: 46848
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 279
                        Count: 43008
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 295
                        Count: 43008
                        Reset counter: 162
                        Mileage: 265580 km
                        Count: 3
                        Count: 2
                        Count: 12288
                        Count: 270
                        Count: 43008
       Coding: 00038805
       Shop #: WSC 01357
       Coding: 0000100
       Coding: 0013899
       Coding: 0002022
       Coding: 0007203
       Coding: 0001077
       Coding: 1390068851034E3F2D040585B0080A04889C00
       Coding: 0001076
       Coding: 0000003
       Coding: 0040402
                        Reset counter: 187
                        Mileage: 266312 km
                        Time: 00:55:12
                        Reset counter: 187
                        Mileage: 266312 km
                        Time: 00:55:12
                        Reset counter: 187
                        Mileage: 266312 km
                        Time: 00:55:12
                        Reset counter: 187
                        Mileage: 266312 km
                        Time: 00:55:12
       Coding: 0100101
    End----(Elapsed Time: 01:07, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
  5. Likes Uwe liked this post
  6. #4
    Quote Originally Posted by ThatDude View Post
    Yes, that's fine. Assuming the ABS control module is correct for the car, I'm confident someone will be able to get you a usable coding based on that.
  7. Likes ThatDude, Jack@European_Parts liked this post
  8. #5
    Jun 2019
    Chicago, USA
    Sounds good. Thanks for your help Uwe. I'm looking forward to trying a code provided by someone in these forums.
    To reiterate, my abs module is from a 2011 Jetta and my cars is a 2009 GTI, But I heard of people having success coding it and it accepting the coding in this scenario.
    Any help in generating the code is very much appreciated on my part!
    Thanks in advance.
  9. #6
    Vehicle Identification No. WVWEV71K19W133621
    Model Golf 2,0
    GO
    Date of production 14.10.2008
    Model year 2009
    Sales type 1K19W2
    Engine Code CCTA
    Transmission Code KNU
    Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA <<<<<<<<<<<<<<<<<<<<<<<< FOD check PASS!
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ <<<<<<<<<<<<<<<<<<<<<<<<<<< FOD Check FAIL!
    Revision: 00H31001
    LEGACY POSSIBILITY
    PART NUMBER DESCRIPTION REMARK
    1K0 907 375 AN Control unit for ABS
    1K0 614 517 BD
    1K0 907 379 AD
    1K0 907 379 CD
    1K0 907 375 AP Control unit for ABS
    1K0 614 517 BE
    1K0 907 379 AE
    1K0 907 375 AE
    1K0 614 517 BK
    1K0 907 379 AP
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HA Vehicle class differentiation -1K0-
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 7GB Emission standard ULEV 2
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E4 Activated carbon canister (ORVR) and siphoning device for fueling
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8H Top sports equipment
    Brake type in rear 1KV Disc brakes in rear (Geomet D)
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1LV Silver caliper
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A9 CD changer preparation (front)
    "Charism" 2H0 Without "drive select"
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C24 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JE Rear sports shock absorption
    Suspension system in front G05 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0EN Installation differentiation for transmission MQ 350 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MD Decorative aluminum inserts
    Scuff plates 7M6 Protective film for scuff plate
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF1 Electric interface for external use
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF1 pedal cluster
    Headlight activation 8K4 Separate daytime running lights NAR
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
    Weight category front axle L95 Suspension range 95 installation control only, no requirement forecast
    Base engine TQ2 4-cyl. petrol engine 2.0 l assembly 06J.B
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G0K 6-speed manual transmission
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J4 Body-colored rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear seats 3NU Rear bench seat, not split, split backrest, folding centre armrest
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8JF Twin headlamps for driving on the right (gas discharge) w/ integrated high beam (US design)
    Customized installation FC1 Customized installation
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    Cassette and CD storage unit 4W0 without cassette / CD tray
    coolbox 1W2 Glove compartment cooling system
    child safety 4H3 Manual child lock
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y3 Cold zones
    Compass/road sign display QR1 With compass
    headrest for seat, rear 3T2 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel tank treatment 2LC Fuel tank with special material treatment (coextrusion)
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A5 Petrol injector fuel system (FSI)
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H9 Backrest release for front seats with Easy Entry feature
    Air duct, front area VK1 Air duct, type 1
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2FN Leather-wrapped multi-function steering wheel with decorative aluminum inserts
    Speaker installation 8RW 10 speakers (passive)
    Headlight range control 8Q3 Dynamic headlight range control (self-adjusting while driving)
    Center armrest 6E3 Center armrest in front
    Marten repeller UM0 Without marten repeller
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z6 Hot country
    Engine specifications D2L 4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TH Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WD Integrated front fog light
    Upgrading measures GP0 Vehicles w/o special upgrade measures
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CQ4 Alloy wheels 7.5J x 18
    Radios 8US Radio "Premium" (double-size standard radio)
    Smoker's/non-smoker's package 9JF Non-smoking package (NAR)
    Tire pressure monitoring system 7K4 Tire pressure monitoring system 315 MHz High
    tire HX9 All-season tires 225/40 R18 92H xl (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G1 Space-saving spare wheel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    PIT IPod and CD changer preparation
    PRW Wheels package Detroit with HX9
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q6 Gearshift knob/handle in aluminum
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TG Sports comfort seat in front, left
    Front seat, right 3SG Sports comfort seat, front, right
    Nameplates for sales name QD0 Without lettering for sales name
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N2K Seat trim covers in fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A3 seat heating for front seats separat controlable
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Control number (no PR family) S3S Control (in-plant)
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B2 Body-colored protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JG bumper in color of vehicle
    Rear stabilizer 0BF Rear stabilizer
    Front stabilizer bar 0AE Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UC Sports version
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 0NH Nameplate set "GTI"
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B34 Legal requirements USA
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A1 2 doors
    TV reception/digital radio reception QV8 Satellite radio reception NAR
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  10. Likes ThatDude liked this post
  11. #7
    Jun 2019
    Chicago, USA
    Hi Jack, I see that you provided the coding "0403010A18070160". I tried this and it does not work. Are you suggesting that my module is not able to be coded to my car? Are the legacy possibility "remarks" the correct controller that I need to buy in order to be coded? I am quite a novice when it comes to this stuff. I am trying my best to understand so I apologize. If you could give a little more insight I would really appreciate it!
  12. #8
    That was not a coding to ABS and from your scan provided to verify the config and which is in possible FOD error!
  13. #9
    If the ABS can be used on that car, try this coding:
    113B600D492500FD881106E6921A0041300000
    Further info here.
  14. Likes Uwe, Jack@European_Parts liked this post
  15. #10
    Coding: 114B000C092500FD881100E6901A0000000000 FULL STRIP LHD
    Coding: 113B600D492500FD881106E6921A0041300000 NETech LHD 312/253 stripped
    I don't see any scans on net with a match to this part number.
    Scans of the net "base hardware abstract" NOT YOUR CODING OP!
    Coding: 113B600D49280003880F06E8921A00413000
    Coding: 113B600D492600FC881206E4921E0041B100
    Coding: 113B600D49240000880D06E7921900413800
    Coding: 113B600D49280000881306ED921D0041B100
  16. Likes Uwe liked this post
