Lower the air suspension on 2019 Audi Etron?
AJ82
New Member
Norway
Have anyone tried this or know how to? I want to lower the car an extra inch :) Cant find anything on this car, just other models....
A.J.
I'm confident VCDS can talk to the systems in the car.
But I'm not terribly confident that anyone has worked out how to adjust the suspension height.
PetrolDave
Westbury, UK
C?ID=1423
An Auto-Scan will give extra information, which might give some hints whether it is possible or not?
Dana
Western PA, USA
A.J. Congratulations on the Etron purchase.
As Dave mentioned, we would need to see a complete VCDS scan from this vehicle but if you don't already own VCDS we do not want to see you purchase VCDS for this one thing.
If things go well, a completely experimental procedure that our distributor in Denmark has may work properly. However, if things end poorly you may end up at the Audi dealer for a non-warranty suspension repair.​
Please let us know if you already own VCDS. If not, and you want our product for other reasons, it may be worth purchasing it as long as you are willing to run a potentially risky suspension calibration and have access to a vehicle hoist (car lift) available.
AJ82
New Member
Norway
Thank you:)
I do have vcds and can try to run a complete scan. Not sure if I want to risk doing something wrong. It will probably be expensive if I have to let Audi fix my mess :p I know that one car here in Norway has been lowered with vcds, but don’t know who did it. I have access to a hoist, but why do I need this?
A.J.
Dana
Western PA, USA
Please do run a complete scan and post it here. That will help us verify the part numbers of the installed modules and determine what's necessary to get you registered/verified.
Honestly, I don't know if a hoist is actually necessary but ODIS (the dealer scan tool) calls it out as a requirement so we never pushed buttons on a brand new Audi in a dealer parking lot to test that requirement.
Dana
Western PA, USA
I'm not aware of any feedback in this forum to date. If you are a VCDS user that happens to own a 2019 Audi e-tron please post the scan.
Pierson8706
C?ID=375292
2019 E-Tron scan, want to lower air suspension ride height
Tuesday,16,June,2020,16:57:17:13548
VIN: WA1LAAGE7KB022712   License Plate: JAMES
Mileage: 697km-433mi   Repair Order:
Chassis Type: GE-AU58 (4KL)
Scan: 01 03 09 15 16 17 19 2B 36 3C 42 44 46 47 51 52 5F 6D 74 75
          81 8C A5 BB BC C0 C5 C6 CA CE CF D6 D7 DE 8104
VIN: WA1LAAGE7KB022712   Mileage: 697km-433miles
51-Electric Drive -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CE-Drive Motor 2 -- Status: Malfunction 0010
DE-Charger 1 for mobile dev -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 E    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0001
   Coding: 2A0A0012002E000034280000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
   ROD: EV_VCU00XXX0204KE907558E.rod
   VCID: 4BC3676353465E93F69-801E
   Part No SW: 4KE 909 059 AC    HW: 4KE 909 059 G
   Component: ESC           H09 0078
   Revision: 00000000    Serial number: 62709000006127
   Coding: 008800BA3D960B9B93570872187952D0253EA80000BCD0C910184A0BA47C15
   Shop #: WSC 00007 444 00000
   ASAM Dataset: EV_BRSContiMKC1AU516 009376
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 0849986F02B0758B1BB-805C
16416 - TPMS Warning; Front Left Tire
          C1055 00 [044] - Flat
          [PUNC_FRNT_LE]
                    Mileage: 646 km
                    Date: 2020.06.13
                    Time: 19:50:52
                    Unlearning counter according OBD-OBD unlearning counter: 255
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 0: 00
16418 - TPMS Warning; Rear Left Tire
          C1059 00 [044] - Flat
          [PUNC_RE_LE]
                    Mileage: 646 km
                    Date: 2020.06.13
                    Time: 19:50:52
16419 - TPMS Warning; Rear Right Tire
          C105B 00 [044] - Flat
          [PUNC_RE_RI]
                    Mileage: 646 km
                    Date: 2020.06.13
                    Time: 19:50:52
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07000363C0291CDD074287089CEF9C28130B37510C06009709010A0019231601086309024010200000000100004B181A0802800044010000000000000000000000
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7DA7F9BB5D72202338D-8028
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001908280402281
   Coding: 7DC727
   Serial number: 23552312X81A955555A0
   Coding: 02005E
   Light switch:
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S04.07.1900691620
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00Q102
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 A    HW: 4KE 857 511
H05 0001
   Serial number: GX1NR104091923311020
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0415
   Serial number: C00363496
   Coding: 0D0104
   Electrically Adjustable Steering Column:
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA139372000075231492
   Coding: 0A0700
   Subsystem 8 - Part No: 4N0 963 575 A
   Component: V512 LLR1SLvL  0012
   Serial number: Q98BJ24888414
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BJ24888417
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BJ24888418
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BJ24888415
67735 - Databus
          [MxB not available]
                    Reset counter: 71
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 12:58:23
                    average_Voltage_terminals: 14.30 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 22.00 °C
                    interior_temperature: 22.50 °C
                    Vehicle speed: 0.00 km/h
   Part No SW: 4KE 959 655 A    HW: 4KE 959 655 A
   Component: AirbagVW32    H43 3122
   Serial number: 003XQM00GZLR
   Coding: BFCCFCC000200000A200003FFA0D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4CC1647F564859ABFF3-8018
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2019246157200000
   Coding: 03F002
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2019246501700000
   Coding: 03F002
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000C3RIH0H
   Coding: 303232
   Subsystem 4 - Part No SW: -----------    HW: 480 002 609 19
   Serial number: 35700000000F2219814E
   Subsystem 5 - Part No SW: -----------    HW: 480 002 609 19
   Serial number: 3580000000042AD8604K
   Subsystem 6 - Part No SW: -----------    HW: 480 031 809 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C245E9E9008B6I
   Subsystem 7 - Part No SW: -----------    HW: 480 031 809 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C245E1629098C9
   Subsystem 8 - Part No SW: -----------    HW: 480 020 410 19
   Component: FrontSensor_D  000 0149
   Serial number: 35500010662F2C62F712
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 020 410 19
   Component: FrontSensor_P  000 0149
   Serial number: 35600010662F2C6303B
   Sensor High Voltage System 1:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 309 19
   Component: HVSensor_gSat  000 0149
   Serial number: 3510001242CA196325AX
   Side Sensor B-Pillar Driver Front:
   Subsystem 11 - Part No SW: -----------    HW: 480 022 309 19
   Component: SideSens_B_Df  000 0149
   Serial number: 35200013062E22E4635T
   Side Sensor B-Pillar Passenger Front:
   Subsystem 12 - Part No SW: -----------    HW: 480 022 809 19
   Component: SideSens_B_Pf  000 0149
   Serial number: 35500011E62E2326036U
1065478 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_FGE]
                    Reset counter: 71
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 12:58:40
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Fault Frequency: 14
                    Reset counter: 82
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 12:58:40
1065479 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_SPE]
                    Reset counter: 71
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 12:58:40
   Part No SW: 4N0 907 129 F    HW: 4N0 907 129 F
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 34311C9F2EB8216B873-8060
   Part No SW: 4KE 920 795 A    HW: 4KE 920 795 A
   Component: FHybRDWACC--- H13 0105
   Coding: 8B6600C97888D7050206E170BB840B0008000000
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 45D7515B7522A8E320D-8010
   Part No SW: 4KL 907 468     HW: 4KL 907 468
   Component: Gateway       H04 0362
   Serial number: 14F05082881001
   Coding: 02010005000100C000810000005B01328C8A0007180000000900009F00000000
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x.rod
   VCID: 0D47A97B6DD210A328D-8058
   Subsystem 1 - Part No SW: 4N0 951 523 J    HW: 4N0 951 523 J
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Component: J367-BDMConti  H03 1051
   Serial number: 76749602001909120714
131826 - Unknown Error Code
          U1645 00 [008] - -
          [Timeout_Node_0xF2_zr2_DiagAdress_005F]
                    Reset counter: 75
                    Mileage: 558 km
                    Date: 2020.06.11
                    Time: 10:09:02
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_BatteryControl]
                    Fault Frequency: 53
                    Reset counter: 82
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 13:43:16
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000253140012
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0044
   Serial number: 00000389518452
   Coding: 005C1A400000B4010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   VCID: 79AFEDAB495A1C03145-802C
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 4KE 907 566     HW: 4N0 907 566 A
   Component: MRR_HR H12 0426
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 0557915B35A268E360D-8050
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        010 0387
   Serial number: 0000389220436
   Coding: 001FDB0052001480A001A032
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 48C9586F4230B58BDBB-801C
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: 94000101010000
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1A87D4AC2F5B95F-8066
   Part No SW: 8W1 907 064 AH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0542
   Coding: 017400004FB100C1650FA0006C01888200004000810026582F0400000F04823F001E0101000F13
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 03538F433B9656D34E9-8056
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1924506DG
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047673823
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4KE 945 423 A    HW: 4KE 945 423 A
   Component: T1 LH SAE HD  H10 0403
   Serial number: A1WM0000960
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11996851
   Rear Light Left 2:
   Subsystem 5 - Part No SW: 4KE 945 429 A    HW: 4KE 945 429 A
   Component: T2 LH SAE HD  H11 0403
   Serial number: A1WP00009G4
   Rear Light Right 1:
   Subsystem 6 - Part No SW: 4KE 945 424 A    HW: 4KE 945 424 A
   Component: T1 RH SAE HD  H10 0403
   Serial number: A1WS0000904
   Rear Light Right 2:
   Subsystem 7 - Part No SW: 4KE 945 430 A    HW: 4KE 945 430 A
   Component: T2 RH SAE HD  H11 0403
   Serial number: A1WQ00009G5
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D02FUTT
   Coding: 0115160000AAAA2FAA0000010002
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411ECDF9E58B1EB173-8070
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 0EF 907 080 G    HW: 0EF 907 080 C
   Component: CUFZD683Q0AD2 H03 0010
   Revision: --------    Serial number: -00131.05.19000
   Coding: 01000000000000000000
   Shop #: WSC 06856 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003007
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3A2D32A70CDCD71B5DF-806E
13828096 - Component protection
          U1115 00 [047] - No basic setting for SHE key
          [CmpntPrtctn_SHEKeyNoCnfg]
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 12:59:05
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       010 0387
   Serial number: 0000389230331
   Coding: 001FDB005E001480A001A030
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 47CB5B534F2EBAF3D21-8012
   Part No SW: 4K0 035 084 D    HW: 4KE 035 084
   Component: MU-H-LNS-US   054 2711
   Coding: 0115760200000000C3220002061C02302F0001E403F00804CE
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 270BFBD3EF6E5AF3321-8072
   Subsystem 1 - Part No: V03 959 804 CD
   Component: MIB2P_NA_Q119  0366
   Subsystem 2 - Part No SW: 4KE 919 605 B    HW: 4KE 919 605
   Component: DU AU516 High  H71 0147
   Serial number: INX00109011900130880
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0110
   Serial number: 00004419000105628021
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00119071900140206
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900508090002
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2
   Coding: 3330
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 4ACD62675C3C479BCDF-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AD    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2311
   Serial number: 1309190649
   Coding: 18D86083DA4020
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 0E45AE7760D42BBBD17-805A
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130702399
   Coding: 303030
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120689
   Coding: 01C020FEC040800000
   ASAM Dataset: EV_ConBoxAU651 002004
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809F8EFE270558B3BB-807C
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SJ200118
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C2134BF06E8E92B4F3-8068
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 4KE 915 233 F    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0231
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU58.rod
   VCID: 41DF454B610A84C31C5-8014
   Battery Junction Box:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H13 0369
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module: control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Coding: 02218400000000000033D60000F4450C139C5600000000000000000000969401019BA80000000000000000800000000000000000000000000000800000000000000078D80000009000000000000000000080400000F0
   ASAM Dataset: EV_ZFASAU516 001006
   ROD: EV_ZFASAU516_001.rod
   VCID: 0F7BB37367DE22B3DA1-805A
233479 - Parking Sensor(s); Rear
          B107B F0 [008] - Function Limitation due to External Factors
                    Reset counter: 71
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 13:53:28
233523 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
                    Reset counter: 71
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 13:53:14
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       010 0387
   Serial number: 0000389786616
   Coding: 000FDB0000001480E000A020
   ROD: EV_DCU2RearDriveMAXHCONT_AU58.rod
   Component: TSG HBFS      010 0387
   Serial number: 0000389786860
   ROD: EV_DCU2RearPasseMAXHCONT_AU58.rod
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4KE 035 335     HW: 3F0 035 335
   Component: E_SOUND_SGH05 0121
   Serial number: EN193837410000
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
   ROD: EV_ESoundMLBEvoS1NN.rod
   VCID: 77ABEB937F4E0A73621-8022
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0076281
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Component: J848 HV-PTC  200 0204
   Serial number: -00104.0W.3B20370631
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019090500099
   Geber für Kältemitteldruck/Kältemitteltemperatur 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Refrigerant Expansion Valve 2:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151049381
   Refrigerant Shut Off Valve 2:
   Subsystem 6 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130934878
   Refrigerant Shut Off Valve 3:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130934836
   Refrigerant Shut Off Valve 4:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130934868
   Refrigerant Shut Off Valve 5:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130934850
   Radiator shutter:
   Subsystem 10 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1  H13 0110
   Serial number: 20190820060103053570
   Radiator Shutter 2:
   Subsystem 11 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V550KJS2  H13 0110
   Serial number: 20190821060103050788
   Coolant valve 1:
   Subsystem 12 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000395312
   Coolant valve 2:
   Subsystem 13 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000137103
   Coolant valve 3:
   Subsystem 14 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000390003
   Coolant valve 4:
   Subsystem 15 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000152971
Address C6: Batt. Chrg. (J1050)       Labels:* None
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: ---------------
   Coding: 2A49A44542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F586179884137B597-8002
3280899 - Unknown Error Code
          U15AC 00 [040] - -
          [ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
                    Reset counter: 26
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 14:08:26
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 228040051602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
   VCID: 75B7E19B6542786370D-8020
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 J    HW: 0EF 907 180 C
   Component: CUBZE683Q0AD2 H03 0010
   Revision: --------    Serial number: -00125.03.19000
   ASAM Dataset: EV_DMCM2HITACAU516 003007
   VCID: 3E253EB710F4FB3B617-806A
                    Mileage: 486 km
                    Date: 2020.06.09
                    Time: 12:59:05
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0426
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 71BFD58B112A5443AC5-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   ASAM Dataset: EV_Charg1MobilDevicAU651 004001
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 2313EFC39B56B6D36E9-8076
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
   VCID: 3FDB43B317FEF2336A1-806A
End----------(Elapsed Time: 02:48, VBatt start/end: 13.1V/13.2V)-----------
Curious to see if you can figure out how to lower the ride height, I see a bunch of options but am unable to change any, wonder if security access is needed? I'm newer to the VCDS.
Pierson8706
C?ID=375292
Hmm, I was about to make some SA code suggestions however after reading this
https://forums.ross-tech.com/showth...pension-Question&p=73398&viewfull=1#post73398
.. I'm rather reluctant! It would be terrible if you got 20103 to accept and wipe out the settings resulting in a trip (or tow) to the dealer.
I have access to the ODIS system at the dealer, but as far as I know coding changes can't be done with it. Once it connects to the server to load the vehicle coding it automatically wipes out any changed coding, as it compares the current coding to the build coding by VIN, as a security measure/way to return to original if a module gets messed up.
I might try to get in using that code and see what all I can make happen, worst case use ODIS and reload the original, unless you have any other ideas?
Dana
Western PA, USA
That sounds like a plan. If you are unable to finish the process with VCDS you should be able to use ODIS to firstly get it back to a factory-like ride height and perhaps perform the intended tweak like the 4M chassis Q7 guy with that Fahrwerk-SG system.
Pierson8706
C?ID=375292
We managed to lower the E-tron, using ODIS. In the chassis control module, perform a full basic setting of the suspension. On the part that asks to measure the ride height, we added the value we wanted to lower by (this vehicle allowed a max input of 480mm for all four wheels), and after finishing the basic setting found that the car was lower by about an inch to an inch and a half maybe.
If you are able to look into doing it with the VCDS and maybe eliminating the input limit it should be able to go lower.
bluetomato
C?ID=407511
Were these the adaptations you changed?
IDE02001-Body height left front wheel house edge,443.50 mm,2
IDE02002-Body height right front wheel house edge,442.50 mm,2
IDE02003-Body height left rear wheel house edge,454.80 mm,2
IDE02004-Body height right rear wheel house edge,456.70 mm,2
Pierson8706
C?ID=375292
Yes, that should be it. The test plan only asks for the measurement and to input the result, we used the maximums the test plan would allow which was 480mm on all four wheels.
srcovert
Thornton, CO, USA
C?ID=231280
THIS WORKED for me:
I added 25mm to each wheel which lowered the car 2 inches YET that was too much and the ride was flat and bumpy (I also got my OUT OF RANGE message when I tried 28mm - I was greedy).
I went with +20mm all around and it lowered the car 1 1/2 inches and drove fine/smooth in Dynamic, smoother in Comfort. PLEASE beware that E-TRONS are complicated vehicles and all kinds of sensors communicate with each other so if one is out of adjustment then the others might bitch about it - play with coding at your own risk.
Test requirements:
-Start with Ignition ON > OFF 10 sec. > ON
-Vehicle standing on flat level surface
-Wheels must face straight ahead
-Select "Comfort" in Drive Select in MMI
-No persons or extra items in the vehicle
-Doors and Rear lid closed.
(security code if needed 24085)
[Basic Settings - 04]
hit GO with each of these, let run for a minute (no compressor sounds) then hit STOP, then on to the next
IDE0 3751 - Activate level control system
IDE0 9292 - Start up prelim. stage for calibrate customer service
IDE0 3802 - Set reference level
IDE0 3763 - Deactivating level control system
- Measure the height difference between the center of the wheel and up to fender edge on all four wheels, for your own reference.
** then:
[Adaptation - 10]
(for my 2019 E-Tron e55) all at 16.75” with 470 / 467 / 479 / 477 (no bumpy ride)
TOO MUCH - at 15.75” 16.25” with 472 / 475 / 484 / 482 (very bumpy ride)
** then:
IDE0 9283 - Switch to normal level control function
Please wait until the compressor can no longer be heard.
Ignition OFF 1 min.
** then:
  1. IDE09282-MAS00675-Start up normal level with tight ctrl tolerance
  2. IDE09279-MAS00675-Calibration of level control for axle load determination
  3. IDE09283-MAS00675-Switch to normal level control function
  4. IDE03751-MAS00675-Activate level control system
Erase DTC in [74-Chassis Control]
Car OFF
I did not have a DTC when I followed the entire process above.
Dana
Western PA, USA
Adding one tiny detail here. The e-tron (both the e-tron 55 and the GT) are fussy animals with their diagnostic VIN since they do not support Generic OBD2 so anyone doing this as of October, 2023 should use our current Beta. Using VCDS Release 23.3 will result in VIN/ROD file errors after the initial key cycle.
The same can occur on MLBevo based ICE Q7 or Q8 models, in which case Beta is the answer as well.
