Results 1 to 5 of 5
Thread: 2009 Audi A4 B8, Steering wheel (talk button) issue
    Aug 2014
    IL, United States
    I have a 2009 A4 B8 non-NAVI. It has worked for several years until now. I am trying to troubleshoot a problem with my steering wheel (talk button). The other multifunction controls on the steering wheel work just fine. The problem is intermittent meaning I can be parked on a fresh start in the morning and hit the talk button and it works normal meaning I can provide a command per the Audi manual. But once I start driving the talk button does not respond once it is pressed and if I would drive to a location put the car in park (still running) and press the talk button it still refuses to work. So here are the general problems;
    When I press the steering wheel button (while I am driving) it will not go into voice command mode for dialing etc. It does absolutely nothing.
    Incoming calls into my mobile phone (while I am driving) do not always trigger the telephone mode screen to turn on, and/or the call does not go through to the speakers every time. This is an intermittent problem as well.
    My phone device is an android running (Android version 9). Bluetooth connection to the car works fine. Attached is a fresh autoscan with no errors, which I have done several times. Is there a way to use VCDS to troubleshoot these issues?
    Friday,02,August,2019,11:30:27:24553
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAUSF78K39N0xxxxx   License Plate: 080219
    Mileage: 122400km-76055mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
              65 72 77
    VIN: WAUSF78K39N0xxxxx   Mileage: 122400km-76055miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Revision: E1H14---
       Coding: 0104010A190F0160
       Shop #: WSC 26142 001 1048576
       VCID: F9BAA47978863B875E-80AC
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0030
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: B6206F45091814FFF3-80E2
       Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
       Component: ESP8 quattro  H04 0060
       Coding: 150500
       Shop #: WSC 02399 823 56573
       VCID: F9BAA47970863B875E-80AC
       Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
       Component: BCM2 1.1      H80 0141
       Coding: 090100
       VCID: B3265651126A01D7D4-80E6
       Serial number: 0508000043807010
       Serial number: 0208000046520008
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0140
       Revision: C1000000    Serial number: 0125.08.080763
       Coding: 64002000
       VCID: F2A893552DF048DF1F-80A6
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Revision: 05022001    Serial number: 00000000208444
       Coding: 26005295063CAF010000080300003D0D0F1C520800010161000000
       VCID: B02C595DE37C3ACFA9-80E4
       Component: WWS 150808  H06 0070
       Serial number: SWFBIE 0000194
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10232262
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000000209081197
       Component: UGDO HL US  H04 0060
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Serial number: 0039KD1426P/
       VCID: C0CC099D5BDCAA4F59-8094
       Serial number: 5810000R0800001U8G
       Serial number: 6334MSME3F560157F
       Serial number: 6344MSME3E735127G
       Serial number: 6352QSME7808312CI
       Serial number: 6362QSME47030500/
       Serial number: 63732SME1608503CY
       Serial number: 63832SME7E071B0EB
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90315HHN000BG
       Coding: 000016
       VCID: BD327069242EC7A732-80E8
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H17 0224
       Revision: 00000000    Serial number: 9DR11UX88
       Coding: 831709000300D705020000
       VCID: AD124029F44E572782-80F8
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0094
       Revision: 4GB20042    Serial number: 4200G088038040
       Coding: 000303
       VCID: C6C01F8571F8847F63-8092
       Component: J367-BDM  H04 0150
       Serial number: 1803C283130808
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Revision: 00000000
       Coding: 020302
       VCID: F8BCA17D4B8C228F21-80AC
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001136122
       Coding: 00581300000000000000
       VCID: F7BEA24146922DF728-80A2
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000007618410
       Coding: 011C03204E00410001
       VCID: C1CA0C9958D6A34756-8094
       Revision: 00002001    Serial number: 0113865630
       Coding: 0106063A007A440402B001
       Component: GTO BF  H06 0040
       Serial number: 00000000000000065345
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S2100000
       Coding: 0203010102
       VCID: EE90872539C86C3FFB-80BA
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007593984
       VCID: C0CC099D53DCAA4F59-8094
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 00000000199850
       VCID: B12A5C59E87633C7A6-80E4
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000004
       VCID: B424554DD76406EFCD-80E0
       Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
       Component: Symph3 Sirius H02 0211
       Revision: 00000004    Serial number: AUZ5Z4H1038695
       Coding: 040200020101850043D9070800
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000100223112
       Coding: 010C03204000210001
       VCID: C4C4058D47C4B66F7D-8090
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140786081891
       Coding: 0CD154
       Revision:             Serial number: 0000100223109
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005017358
       Coding: 0010370
       VCID: BB367E71FA3AC9970C-80EE
    End----------(Elapsed Time: 01:51, VBatt start/end: 12.5V/12.4V)-----------
    __________________________________________________ _____
    Remember, Today is the Tomorrow you worried about Yesterday!
    Otto
    The status of the controls on the steering wheel should be visible at Address 16: Steering wheel, Measuring Blocks, likely Group 007 or 008. Look there when it's working, confirm you can see it change, and check it again when it's not working.
    Aug 2014
    IL, United States
    I ran the measured blocks (006) twice and have inserted the log for a test while the car was parked (ignition running). When the car is parked and ignition off it states that same information because controls cant be used. I then started the car and moved all 4 tested points on the steering wheel. They registered activated until I stopped moving them and that is why the log states not operational.
    Monday,05,August,2019,15:14:36:24553
    Dealer/Shop Name:
    VIN: WAUSF78K39N0XXXXX License Plate:
    Address 16: Steering wheel (8K0 953 568 F)
    15:14:17 Group 007: Multifunction Steering Wheel III
    Not Oper. Multi-Function Button (Left)
    Not Oper. Multi-Function Button (Right)
    Not Oper. Thumb Button (Left)
    Not Oper. Thumb Button (Right)
    I still have 3 issues;
    While driving incoming calls are not routed to the speakers.
    While driving talk button on steering does not engage the voice commands.
    While driving outgoing calls from the car unit should engage my phone to dial out. It does not.
    I basically have to pick up the phone handset if I wanted to answer a call. BTW, the phone is connected to the car via BlueTooth verified on the radio screen and on the phone. I am just not sure which module controls the function of an incoming call. I guess it could be the radio itself which is a Generation III - Symphony III with no navigation.
    I also have considered the clock spring being the issue just because it controls the controls on the steering wheel.
    Otto
    Aug 2014
    IL, United States
    Has anybody in the forum given my situation any thought? I am stumped at this point. Can the HEX-NET device even help me at this point?
    Otto
    Aug 2014
    IL, United States
    Had to go to the dealership for this problem. They were surprised that there were no error codes. They were told by Audi HQ that the issues with the Bluetooth side are rare and that the 5F module that controls the BT will need replacement. That part is (8T0862336F). I will replace the module myself with a new or used and hopefully, the current codes in the module will transfer over if there are problems. Will post more once I get there. If there are any pointers from the forum, please reply. Thx
    3 issues;
    Otto
