Results 1 to 2 of 2
Thread: Audi A6-Level sensor broken
    May 2018
    India
    Below is my car's scan result. It is a RHD, and issue is front-right level sensor (threading is broken) i.e. threading end that connects to wheel side.
    Can someone help with the front-right level sensor part number please? Since the sensor is working fine I would like to see if I could get one in open market here.
    Thursday,25,July,2019,23:09:46:11426
    VIN: WAUZED4G3DY002451
    Mileage: 56024km-34811mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 34 36 3B 42 44 46 52
              53 55 5F 62 72 8F 90
    VIN: WAUZED4G3DY002451   Mileage: 56024km-34811miles
    Address 01: Engine (J623-CMGB)       Labels: None
       Part No SW: 03L 906 018 LC    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9979
       Revision: 45H25---
       Coding: 0A034012242400080000
       Shop #: WSC 64639 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018LC 003013
       ROD: EV_ECM20TDI01103L906018LC.rod
       VCID: F6A091D049EB1FFF33-80A2
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G2 927 155 D    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000000169
       Coding: 000001
       Shop #: WSC 90001 790 00000
       ASAM Dataset: EV_TCMVL381 A02432
       ROD: EV_TCMVL381.rod
       VCID: AE1079B0F13B673FBB-80FA
       Coding: 06A147016085E280DB00
       Shop #: WSC 90001 000 00000
       VCID: B62051D0096B5FFFF3-80E2
    0706 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SCL_FA_Niveau_Druck_VL_Error]
                        Reset counter: 3
                        Mileage: 55921 km
                        Date: 2019.07.24
                        Time: 21:31:24
                        VzRef: 27
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 16
                        Uz: B1
    0708 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SCL_FA_Niveau_Druck_VR_Error]
                        Reset counter: 3
                        Mileage: 55921 km
                        Date: 2019.07.24
                        Time: 21:31:20
                        VzRef: 23
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 18
                        Uz: B1
       Part No SW: 4H0 907 064 CT    HW: 4H0 907 064 CT
       Component: BCM2 2.0      H33 0433
       Coding: 01983046000000000000
       VCID: FDB28EFC64DD4CA772-80A8
       Part No SW: 4G0 820 043 AD    HW: 4G0 820 043 AD
       Component: KLIMA 4 ZONEN H13 0086
       Serial number: 06031300041557
       Coding: 3421607889
       ASAM Dataset: EV_AirCondiComfoUDS 002040
       VCID: E18AD28CF065884776-80B4
       Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
       Revision: 19012002    Serial number: 00000001521633
       Coding: 2600201040349FE08981008080001D0CCF9DC30823090201000008606101
       VCID: ED92BEBC34BDDC27C2-80B8
       Component: WWS57X 130303  H36 0080
       Serial number:         130309102841
       Coding: 0045F7
       Serial number: 21024995
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 24 02 2013  00000034
       Serial number: B8080996000000000001
    Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
       Part No SW: 8X0 035 110 C    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0490
       Revision: 00000008
       VCID: AD127EBCF43D1C2782-80F8
       Revision: 11001001    Serial number: 61061306001500
       Coding: 08C105
       VCID: F1AAA2CC208538C7E6-80A4
       Revision: --------    Serial number: 003JG00CBJ71
       Coding: 30323436313230303232554A305234473053
       Serial number: 3575HRB400K50EV4GPE-
       Serial number: 3585HRB40531S1NK68AD
       Serial number: 3515JRB400E50CTSPGMB
       Serial number: 3525JRB400E50CTSC8HT
       Serial number: 3554VRB40084UON8CP3C
       Serial number: 3564VRB40084UON8H9GF
       Revision: 00000000    Serial number: 20130208000697
       Coding: 000034
       VCID: B02C67C8E30F71CFA9-80E4
       Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
       Component: E221 - MFL  H09 0010
       Part No SW: 4G8 920 932 D    HW: 4G8 920 932 D
       Component: TDieRdw       H79 0515
       Revision: 28460208    Serial number: 658040313596006
       Coding: 33A609001B410008010000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU57.rod
       VCID: B02C67C8EB0F71CFA9-80E4
       Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000000844933
       Coding: 00C1034400
       ASAM Dataset: EV_GatewPkoUDS 001018
       Serial number: 3864680103
       Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
       Component: KLIMA FOND    H07 0086
       Serial number: 22021300041481
       Coding: 22
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
    0027 - Motor for Rear Left Upper Body Vent
              B10D3 07 [008] - Mechanical Failure
                        Reset counter: 246
                        Mileage: 55068 km
                        Date: 2019.06.29
                        Time: 16:37:01
                        Voltage terminal 30: 13.29 V
                        Outside air temperature: 26.5 °C
                        Left Rear Upper Body Vent Motor-Act.val.: 9998
                        Left Rear Upper Body Vent Motor-Specified value: 11335
                        Left Rear Upper Body Vent Motor-Stop open: 11406
                        Left Rear Upper Body Vent Motor-Stop closed: 10000
       Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H18 0782
       Coding: 008000
       ROD: EV_AirSuspe_VW51.rod
    455689 - Sensor for Ride-Height
              C1048 07 [009] - Mechanical Failure
                        Reset counter: 218
                        Mileage: 56017 km
                        Date: 2019.07.25
                        Time: 11:57:11
    455690 - Sensor for Ride-Height
              C1048 07 [008] - Mechanical Failure
                        Reset counter: 3
                        Mileage: 56018 km
                        Date: 2019.07.25
                        Time: 11:57:19
    677389 - Ride-Height System; Plausibility Error
              C1046 00 [008] - -
                        Reset counter: 3
                        Mileage: 55921 km
                        Date: 2019.07.24
                        Time: 21:30:56
    455693 - Sensor for Ride-Height
                        Reset counter: 3
                        Mileage: 55959 km
                        Date: 2019.07.24
                        Time: 23:05:28
              C10C8 00 [008] - -
                        Fault Frequency: 7
                        Reset counter: 3
                        Time: 00:00:00
       Revision: AA000000    Serial number: 00000053833662
       Coding: 0078130000002001000001010101102030303232203232
       VCID: F7BE9CD446E166F728-80A2
       Component: SARA 6D       H02 0056
       Revision: --------    Serial number: EJ1BPA8202TW7V
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       Coding: 011F16005E01628002080002
       VCID: C7DE2C147681D67798-8092
       Component: RCEPS         H36 0010
       Revision: 00001000    Serial number: 0027303374
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: B2286DC0E50343DFDF-80E6
       Revision: 00002001    Serial number: 0303515700
       Coding: 011A062000B901848020080002010E0F0000000000000000000000000000
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO2051692%
       Coding: 901F00
    01512 - Control Module for Sliding Roof
                        Fault Status: 01100101
                        Reset counter: 180
                        Mileage: 55133 km
                        Date: 2019.07.02
                        Time: 19:00:11
       VCID: C6C02110718BCF7F63-8092
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000617643
       ROD: EV_ParkiBrake_VW51.rod
       VCID: AB1670A4C22912179C-80FE
       Serial number: 130314-0002-017
       Coding: 11215F101000A200
       ROD: EV_HeadlRegulBasic.rod
       VCID: AD127EBCFC3D1C2782-80F8
       Part No SW: 4G0 035 182 L    HW: 4G0 035 182 J
       Component: RMC Cnct Plus H54 0801
       Coding: 0101000001E1DB47482B060303010000000000
       VCID: AA1875A0C5D30B1F67-80FE
       Subsystem 1 - Part No SW: 4G0 919 603 A    HW: 4G0 919 603 A
       Component: DU6 Basic  H43 0084
       Serial number: 9464B60D2576889
       Subsystem 2 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
       Serial number: 90349MC70018Z
       Coding: 010F14004001628002080002
       VCID: C9DA2A2C609520078E-809C
       Coding: 00060000031F030000030800424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: B12A62CCE00578C7A6-80E4
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    End----------(Elapsed Time: 02:20, VBatt start/end: 12.3V/12.3V)-----------
    Address 34: DTCs cleared
    Address 03: DTCs cleared
    Address 28: DTCs cleared
    16.4905° S, 151.7375° W
    - Have you look on the part itself? Should be a number that begins with [4G0] [ or [4H0] and is 9 or 10 characters long.
    If you can not see the number, there is a website called Parts Link 24 . This is where you can enter in your VIN number and find the exact parts you are looking for, its does require a payment for access, looks like $10(US) a day or $30(US) for a month. Or just call the dealership and ask for the part number, some will give it to you.
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
