Below is my car's scan result. It is a RHD, and issue is front-right level sensor (threading is broken) i.e. threading end that connects to wheel side.
Can someone help with the front-right level sensor part number please? Since the sensor is working fine I would like to see if I could get one in open market here.
Thursday,25,July,2019,23:09:46:11426
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZED4G3DY002451
Mileage: 56024km-34811mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 34 36 3B 42 44 46 52
53 55 5F 62 72 8F 90
VIN: WAUZED4G3DY002451 Mileage: 56024km-34811miles
Address 01: Engine (J623-CMGB) Labels: None
Part No SW: 03L 906 018 LC HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9979
Revision: 45H25---
Coding: 0A034012242400080000
Shop #: WSC 64639 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LC 003013
ROD: EV_ECM20TDI01103L906018LC.rod
VCID: F6A091D049EB1FFF33-80A2
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 4G2 927 155 D HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000000169
Shop #: WSC 90001 790 00000
ASAM Dataset: EV_TCMVL381 A02432
ROD: EV_TCMVL381.rod
VCID: AE1079B0F13B673FBB-80FA
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 06A147016085E280DB00
Shop #: WSC 90001 000 00000
VCID: B62051D0096B5FFFF3-80E2
0706 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[SCL_FA_Niveau_Druck_VL_Error]
Reset counter: 3
Mileage: 55921 km
Date: 2019.07.24
Time: 21:31:24
VzRef: 27
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 16
Uz: B1
0708 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[SCL_FA_Niveau_Druck_VR_Error]
Reset counter: 3
Mileage: 55921 km
Date: 2019.07.24
Time: 21:31:20
VzRef: 23
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 02
F-Type: 18
Uz: B1
Part No SW: 4H0 907 064 CT HW: 4H0 907 064 CT
Component: BCM2 2.0 H33 0433
Coding: 01983046000000000000
VCID: FDB28EFC64DD4CA772-80A8
Part No SW: 4G0 820 043 AD HW: 4G0 820 043 AD
Component: KLIMA 4 ZONEN H13 0086
Serial number: 06031300041557
Coding: 3421607889
ASAM Dataset: EV_AirCondiComfoUDS 002040
VCID: E18AD28CF065884776-80B4
Part No SW: 4H0 907 063 CE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0130
Revision: 19012002 Serial number: 00000001521633
Coding: 2600201040349FE08981008080001D0CCF9DC30823090201000008606101
VCID: ED92BEBC34BDDC27C2-80B8
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 130303 H36 0080
Serial number: 130309102841
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21024995
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 24 02 2013 00000034
Serial number: B8080996000000000001
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000008
VCID: AD127EBCF43D1C2782-80F8
Revision: 11001001 Serial number: 61061306001500
Coding: 08C105
VCID: F1AAA2CC208538C7E6-80A4
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00CBJ71
Coding: 30323436313230303232554A305234473053
Serial number: 3575HRB400K50EV4GPE-
Serial number: 3585HRB40531S1NK68AD
Serial number: 3515JRB400E50CTSPGMB
Serial number: 3525JRB400E50CTSC8HT
Serial number: 3554VRB40084UON8CP3C
Serial number: 3564VRB40084UON8H9GF
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20130208000697
Coding: 000034
VCID: B02C67C8E30F71CFA9-80E4
Subsystem 1 - Part No SW: 4G0 951 528 E HW: 4G0 951 528 E
Component: E221 - MFL H09 0010
Part No SW: 4G8 920 932 D HW: 4G8 920 932 D
Component: TDieRdw H79 0515
Revision: 28460208 Serial number: 658040313596006
Coding: 33A609001B410008010000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: B02C67C8EB0F71CFA9-80E4
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000844933
Coding: 00C1034400
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 3864680103
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0086
Serial number: 22021300041481
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
0027 - Motor for Rear Left Upper Body Vent
B10D3 07 [008] - Mechanical Failure
Reset counter: 246
Mileage: 55068 km
Date: 2019.06.29
Time: 16:37:01
Voltage terminal 30: 13.29 V
Outside air temperature: 26.5 °C
Left Rear Upper Body Vent Motor-Act.val.: 9998
Left Rear Upper Body Vent Motor-Specified value: 11335
Left Rear Upper Body Vent Motor-Stop open: 11406
Left Rear Upper Body Vent Motor-Stop closed: 10000
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008000
ROD: EV_AirSuspe_VW51.rod
455689 - Sensor for Ride-Height
C1048 07 [009] - Mechanical Failure
Reset counter: 218
Mileage: 56017 km
Date: 2019.07.25
Time: 11:57:11
455690 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Reset counter: 3
Mileage: 56018 km
Date: 2019.07.25
Time: 11:57:19
677389 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Reset counter: 3
Mileage: 55921 km
Date: 2019.07.24
Time: 21:30:56
455693 - Sensor for Ride-Height
Reset counter: 3
Mileage: 55959 km
Date: 2019.07.24
Time: 23:05:28
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Fault Frequency: 7
Reset counter: 3
Time: 00:00:00
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000053833662
Coding: 0078130000002001000001010101102030303232203232
VCID: F7BE9CD446E166F728-80A2
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA8202TW7V
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F16005E01628002080002
VCID: C7DE2C147681D67798-8092
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0027303374
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B2286DC0E50343DFDF-80E6
Revision: 00002001 Serial number: 0303515700
Coding: 011A062000B901848020080002010E0F0000000000000000000000000000
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO2051692%
Coding: 901F00
01512 - Control Module for Sliding Roof
Fault Status: 01100101
Reset counter: 180
Mileage: 55133 km
Date: 2019.07.02
Time: 19:00:11
Component: TSG BF H03 0507
VCID: C6C02110718BCF7F63-8092
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000617643
ROD: EV_ParkiBrake_VW51.rod
VCID: AB1670A4C22912179C-80FE
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130314-0002-017
Coding: 11215F101000A200
ROD: EV_HeadlRegulBasic.rod
VCID: AD127EBCFC3D1C2782-80F8
Part No SW: 4G0 035 182 L HW: 4G0 035 182 J
Component: RMC Cnct Plus H54 0801
Coding: 0101000001E1DB47482B060303010000000000
VCID: AA1875A0C5D30B1F67-80FE
Subsystem 1 - Part No SW: 4G0 919 603 A HW: 4G0 919 603 A
Component: DU6 Basic H43 0084
Serial number: 9464B60D2576889
Subsystem 2 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Serial number: 90349MC70018Z
Component: TSG HL H03 0507
Coding: 010F14004001628002080002
VCID: C9DA2A2C609520078E-809C
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: B12A62CCE00578C7A6-80E4
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:20, VBatt start/end: 12.3V/12.3V)-----------
Address 34: DTCs cleared
Address 03: DTCs cleared
Address 28: DTCs cleared
