Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 78
Thread: 2006 Audi A6 C6 ABS Fault 01435
  1. #61
    Nothing worse than a lie huh?
    Jack: Chill out. The OP here is a legitimate RT customer working on a 13 year old car. Does it really matter where his wiring diagrams came from?
  2. #62
    Uwe it wasn't a matter of calling him out, it is a matter of confirming the information is correct for the car and without having to click on a link externally or going on a Easter egg hunt to do it.
    There is no VIN number or PR data to help build all verification of data & harder to check on FOD.
    When searching through similar data quick in the past & from other auto-scans I didn't find the G201 in my notes, so as aforementioned I mentioned the other PSI sensors & made request for the screenshots.
    Now I make up screen shots all the time from stuff on web than altered to make different to try and protect copyright or from old books I have & post to help and you know this is indeed a fact!
    Each time I make a consistent request here it is met with apprehension.
    Now if someone is going to start running their mouth, A. That it can't be done or B. Saying something I know or believe is false just to try and make me look like I'm arguing, then, fuck emm!
    You get upset at me when I argue too much so I try to not do it & I love a good debate!
    How about we start over?
    OP removed from block.
    OP please provide your VIN number & so we can check the microfiche for the proper parts to be correct in your car and build a PR tag to detect FOD?
    Please provide the alleged screen shot here & as I asked you before & are making ref too, this way to cross check the data and because you got said data from questionable sources and not ERWIN?
    Why am I catching shit for actually trying to help someone within the boundaries of the RT Church?
  3. #63
    I'm scratching my head wondering what the sense is in hiding the VIN on such an old car. I kinda understand doing that with a brand-new car that's still under warranty, especially if someone is tweaking or tuning it. But on a car this old, with almost 190,000 miles on it?
  4. #64
    Oct 2016
    Fear of title scams. But given that this is a specialty forum and therefore not well-travelled compared to most of the internet...
    VIN: WAUKH74F86N124065
    And since Jack wants to reset, let's reset. Uwe, you made a great point about the wiring diagrams being intellectual property, so in the interest of trying to stay within Fair Use guidelines, here are screenshots of the two relevant pages. Jack, please note on page 2, at the bottom of item 12, that the G201 sensor is integrated.
  5. Likes Uwe liked this post
  6. #65
    Oct 2016
    And here is every PR code for my car straight from an Audi dealer's service center, including PR codes that aren't included on the vehicle sticker. Nothing has been retrofitted to my car, no mods have been made. All replacement parts have been either factory original (new or from junkyard cars) or from brands sold by WorldPAC or ECS Tuning. My ABS module is the factory original part, as are all braking components other than wear parts (obviously) and the brake pedal switch.
    Vehicle Data
        Vehicle Data
    Brand: A VIN: WAUKH74F86N124065 Country Code: USA
    Model Year: 2006 Description: A6 Avant q 3.2 V6188 A6 Importer: 444
    Model Code: 4F55NL Production Date: 2005-12-15 Dealer Number: 08C15
    Engine Code: BKH Delivery Date: 2006-07-31
    Transmission Code: HYR Type Approval Number:
    Color Trim
    Model
    Color Code
    Paint number (Paint No.)
    description
    Exterior (body/roof) A2/A2 LY9B  Brilliant Black/Brilliant Black
    Interior NM   amaretto brown/black-black/black/ silver
    Warranty Key
    Code
    Description
    Change Date
    Service life
    US2 Current customer Californian state 2016-08-17
     U09 Xenon Bulb EXT 4/50,000 US only 2011-06-06
    PR Numbers
    No.
    Origin
    Family
    Description
    0G7 L GES Tiptronic
     0HP L AED Vehicle class differentiation 4F0
     0JL L GKV Weight category front axle weight range 11
     0LB L SIZ Special plates/stickers/ safety certificates for USA
     0M5 L KBV Fuel tank
     0N5 L HIA Standard rear axle
     0SS L SAU Labels/plates in English and French
     0TD L ZFM Front and rear floor mats
     0VM L BTA Information kit in American English
     0W2 L AKZ Label for central electric English-speaking countries
     0YM L GKH Weight range 12 installation control only, no requirement forecast
     1A2 L KRS Fuel system for SI engine with direct injection (FSI)
     1BA L DAE Standard suspension/shock absorption
     1C2 L FRO Antifreeze up to -35 degree celsius tolerance up to -40 degree C
     1D0 L AHV Without trailer hitch
     1EP L TYP Special identification plate (USA)
     1KD L BAH Disc brakes, rear
     1LG L BAV Disc brakes, front
     1N3 L LEN Speed-related variable steering assist (Servotronic)
     1PA L ABR Standard wheel bolts
     1S1 L BOW Tool kit and jack
     1SA L TWU Without additional engine guard
     1T1 L VBK First aid kit
     1VH L TWL Installation parts for six-cylinder engine
     1WG L GFW Transmission shafts w/ 88 mm in diameter
     1X1 L ATA Four wheel drive
     1XL E LRA Multi-function steering wheel with Tiptronic (leather + wood)
     1YF L GFH Transmission shafts for rear axle diameter 75.5
     1Z6 L KRM Increase in initial standard fuel filling
     2C5 L LSS Axial and vertical adjustable steering column
     2G1 L EBB Insert for the filling up of unleaded fuel
     2K2 L SFS reinforced bumpers
     2WA L ZBR Without additional tires
     2Z1 L TYZ Type sign at rear and "Quattro" nameplates respectively
     3B7 L ZKV Child seat anchor according to Canadian requirements and child seat system ISOFIX
     3F4 L RER Spare wheel with original equipment tire
     3FE L DEI Electric slide/tilt sunroof with sun screen/sunblind
     3G0 L KSI Without child seat anchor front (ISOFIX)
     3GN L LBH Variable cargo area concept
     3L4 P SIE Electric seat adjustment for both front seats, driver's seat with memory system
     3NZ L HIS Rear seat bench unsplit, backrest split folding
     3S1 L DAR Bright roof rails
     3X2 P DLS Load-through provision
     3Y3 E SSR Roll-up sun screen for rear window and rear side windows
     4A4 P SIH Seat heater for front and rear seats separately controlled
     4D0 L KMS Without seat ventilation/massage seat
     4GP L WSS Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
     4H5 L KDS Electrically operated child lock
     4K7 P TKV Central locking system "Keyless Entry" "two-stage unlocking"
     4KC L SSH Side and rear windows in heat-insulatingglass
     4L7 P IRS Breakaway interior rear view mirror, automatically dimming, with compass
     4UB L AIB Air bag for NAR
     4W0 L KBO Without cassette and CD storage unit
     4X3 L SAB Side air bag front with curtain air bag
     4Y0 L VSS Without storage compartment/safe box
     4ZB L ZIE Bright moldings
     5A5 L GRV Trunk lining, with stowage trays
     5C1 L KSA Body measures for increased safety requirements
     5D2 L TRF Carrier frequency 315 MHz
     5J0 L HES Without rear spoiler
     5K4 L LAC Without paint preservative
     5MG L EIH Decorative inserts, burr-walnut
     5NF L FHE Interstop gas prop for tailgate
     5RW L ASR Right exterior mirror: convex (US) large viewing field
     5SG L ASL Left exterior mirror: flat
     5XH L SON Sun visors with illuminated vanity mirror on driver's and front seat passenger's side
     6FA L BBO Components without special surface appearance
     6M1 P GPS Tie down straps
     6NQ E HIM Standard molded headlining
     6Q3 E SAG Wooden gearshift knob/handle
     6SS L KBB Luggage compartment floor covering
     6U7 L ZTD Additional dust protection measures
     6V2 L HEB Rear trim panel
     6W3 L KZV License plate bracket front (small, NAR)
     6XL P ASE Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
     7A2 L CDW CD changer
     7AN L EDW Anti-theft alarm system, backup horn andtowing protection
     7B2 L STD 12-volt socket in luggage boot
     7GA L AGM Emission standard LEV 2
     7K7 L RDK Tire pressure control, frequency 433 MHzbasic level version
     7M1 L EIL Scuff plates in door apertures with metal inserts
     7P1 L LOR Power adjustable lumbar support in frontseats
     7Q2 P NAV Navigation system with color screen
     7QA L CDR Without CD/DVD for navigation
     7X1 P EPH Park distance control
     7Y0 L SPU Without lane change assistant
     8DY L RAO Radio "HIGH" America
     8EH P HSW Bi-functional headlight with gas discharge lamp, for driving on the right(US design)
     8GV L GEN Alternator 180 A
     8K9 P FLS Separate daytime running lights with low beam assistant and "Coming Home" function
     8Q5 P LWR Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
     8RY P LSE Speakers with BOSE sound
     8SL L SBR Taillight assemblies with diodes (LED) (for NAR)
     8T1 L GRA Cruise control system (CCS)
     8TF L NEL Rear fog lights, left and right
     8X0 L SWR Without headlight washer system
     8Z6 L MKU Hot country
     9AQ L HKA Air conditioning plus
     9M0 L ZUH Without auxiliary/parking heater
     9P5 L SGK Seat belt reminder, optical and acousticelectric contact
     9Q4 P MFA Multi-function display/on-board computerwith check control
     9ZG L VTV Mobile phone preparation with hands-freespeaking system
     4E2 L SDH Tailgate/trunk lid release from inside (electrically)
     6E3 L MAS Front center armrest
     A00 L SAH No self-collection
     A8U I AUS Executive US equipment
     B0A L BLB Component parts set without country-specific design requirement
     B34 L TPL Legal requirements USA
     C00 L COC Operating permit, initial registration
     CC9 P RAD Alloy wheels 8J x 18
     D2G L MOT 6-cyl. gasoline eng. 3.2 L/188 kW (24V) FSI, homogeneous base engine is T14
     E0A L AAU No special edition
     F0A L FZS No special purpose vehicle, standard equipment
     FA0 L SVO Control of standard production
     FC1 E IND Customized installation
     FM0 L MDS Basic equipment variant
     FQ0 L QGM Standard production wheels
     G0R I GSP 6-speed automatic transmission for four-wheel drive vehicle
     GZ0 L EST Manually operated doors
     H6E P REI All-weather tires 245/40 R 18 97H (NAR)
     J0B L BAT 520 A (92 Ah) battery
     K8D I KAR Station Wagon Variant/Avant
     L0L L LEA Left-hand drive vehicle
     N0K E SIB Leather seat covering
     NT2 L TSP Transit coating (type 3)
     PAW G  cold-weather package USA
     PPX G  premium package
     PRF G  cast aluminium alloy wheels, 8Jx18, 7-arm design, with 245/40 R 18 tyres
     Q1A L VOS Standard front seats
     QE1 P ALG Tray areas package 1
     QH2 P SPR Voice control
     QQ1 L LCP With additional lights (interior lighting)
     QU0 P TVE Satellite radio reception USA
     T14 I GMO 6-cylinder gasoline engine 3.2 L Unit 06E.A (ALU)
     U1B L INS Instrument insert with mph speedometer, clock, tachometer and trip odometer
     V0A L REL Tires w/o specification of tire brand
     VC1 P GRT Remote-controlled garage door opener
     WTC G  technology package
     X9A G  National sales program USA
  7. #66
    Just look at the info now had for collective to commence...........
    Forgiven .........
    Hey look what I found ..........on the net too!
    Thank you for posting the screen shot my new friend now that we understand each other and you recognize my asshole ways!
    This is the component finder not the WD but yes the part is in the ABS manifold.
    Just because something is part of something and the dealer doesn't offer in RTFB & yes being very vague at times or not as a spare part & to force sell the unit, doesn't mean it can be tested, observed or sourced elsewhere!
    The forum to me is about learning & sharing but not one sided inputs and most of all I want people to work safe!
    That safety starts with qualifying that at the very least, the information you are reading is actually consistent to the platform!
    https://i.postimg.cc/pPP393bG/G201.png?dl=1
    Vehicle Identification No. WAUKH74F86N124065
    Model audi a6 av. qu. 3.2
    A6
    Date of production 15.12.2005
    Model year 2006
    Sales type 4F55NL
    Engine Code BKH
    Transmission Code HYR
    Axle drive 6A
    Equipment NM
    Roof color A2
    Carpet color code
    Exterior color / Paint Code A2 / Y9B
    FOD CHECK IN PROCESS!
    ABS module is correct....check!
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 0HP Vehicle class differentiation -4F0-
    Emission standard 7GA Emission standard LEV 2
    Trailer hitch 1D0 without trailer towing
    airbag 4UB Airbag for NAR
    Label for central electric 0W2 Label for central electric system English-speaking countries
    Tray areas package QE1 Storage compartment package 1
    Exterior mirror setting 6XL Exterior mirrors with memory feature, auto-dimming, power-folding/adjustable/ heated
    Left exterior mirror 5SG Left exterior mirror, flat
    Right exterior mirror 5RW Right exterior mirror, convex (US) large viewing field
    Drive type 1X1 Four-wheel drive
    Equipment levels A8U Executive US equipment
    Brake type in rear 1KD Disc brakes in rear
    batteries J0B 520 A (92 Ah) battery
    Brake type, front 1LG Silver caliper
    Components with special surface 6FA Components without special surface appearance
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    vehicle tools and jack 1S1 vehicle tools and jack
    Owner's manuals 0VM Information kit in American English
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A2 CD changer
    General operating permit, alterations C00 Operating permit, initial registration
    Shock absorption/suspension, chassis 1BA Federung/Daempfung, standard
    Roof rails/roof load rack 3S1 Bright roof rails
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Load-through hatch/ski bag 3X2 Load-through hatch
    Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
    Theft protection system 7AN Anti-theft alarm system, backup horn and towing protection
    Inserts 5MG Decorative inserts, burr-walnut
    Scuff plates 7M1 Scuff plates in door apertures with metal inserts
    Park distance control 7X1 Park distance control
    Power-operated door (power latching) GZ0 door, manually operated
    Hood and trunk stay 5NF Interstop gas prop for tailgate
    Headlight activation 8K9 Daytime headlights with automatic headlight control and coming home function
    Antifreeze 1C2 Antifreeze up to -35 degree celsius tolerance up to -40 degree C
    Alternators 8GV Alternator 180 A
    Transmission types/gearshift mechanisms 0G7 tiptronic
    Transmission shafts, rear axle 1YF Transmission shafts for rear axle, diameter 75.5
    Transmission shafts 1WG Transmission shafts 88 mm in diameter
    Weight category rear axle 0YM Weight range 12 installation control only, no requirement forecast
    Weight category front axle 0JL Weight category front axle weight range 11
    Base engine T14 6-cyl. petrol engine 3.2 l assembly 06E.A (ALU)
    Tie down straps/net/pocket 6M1 Tie down straps
    cruise control system 8T1 Cruise control system (CCS)
    Garage door opener VC1 Garage door opener
    Luggage compartment trim 5A5 Luggage compartment trim, with storage compartments
    Transmission specifications G0R 6-speed automatic transmission for four-wheel drive
    Rear trim panel 6V2 Rear trim panel
    Rear spoiler 5J0 Without rear spoiler
    Rear axle 0N5 Standard rear axle
    Molded headliner 6NQ Standard molded headlining
    Rear seats 3NZ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AQ Air conditioning plus
    Headlamps 8EH Bi-functional headlamps with gas discharge lamp, for driving on the right (US design)
    Customized installation FC1 Customized installation
    Instrument clusters U1B Instrument cluster with mph speedometer, clock, tachometer and trip odometer
    Breakaway interior rearview mirror 4L7 Breakaway interior rearview mirror, auto-dimming, with compass
    Body style K8D Wagon/Avant
    Luggage compartment floor covering 6SS Luggage compartment floor covering
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Fuel tank capacity 0M5 Fuel tank
    child safety 4H5 Electrically operated child lock
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    Fuel quantity for initial filling 1Z6 Increase in initial standard fuel filling
    Fuel systems 1A2 Fuel system for SI engine with direct injection (FSI)
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K4 with no paint conversation
    Rear cargo area 3GN Variable cargo area concept
    Light package (lighting) QQ1 With additional lights (interior lighting)
    Steering system arrangement L0L Left-hand drive
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Lumbar support 7P1 Power adjustable lumbar support in front seats
    steering wheels 1XL Multi-function steering wheel with tiptronic (leather + wood)
    Speaker installation 8RY loudspeaker with BOSE-sound
    Steering column systems 2C5 Steering column, adjusted axially and vertically
    Headlight range control 8Q5 Dynamic headlight range control, with cornering light (AFS 1)
    Center armrest 6E3 Center armrest in front
    Versions FM0 Basic equipment variant
    Multi-function display/trip computer 9Q4 Multi-function display/trip computer with check control
    Engine cooling 8Z6 Hot country
    Engine specifications D2G 6-cylinder SI engine 3.2 l/188 kW (24V) FSI, homogeneous base engine is T14
    Navigation device 7Q2 navigation system with colour screen
    rear fog lamp 8TF Rear fog lights, left and right
    Audi Sport/ Quattro GmbH FQ0 Series wheels
    Wheels CC9 Alloy wheels 8J x 18
    Radios 8DY Radio "HIGH" America
    Tire pressure monitoring system 7K7 Tire pressure monitoring system 433 MHz Basic
    tire H6E All-weather tires 245/40 R 18 97H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 3F4 spare wheel as road wheel
    PAW cold-weather package USA
    PPX premium package
    PRF cast aluminium alloy wheels, 8Jx18, 7-arm design, with 245/40 R 18 tyres
    WTC technology package
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q3 Gearshift knob/handle in wood
    Self-collection / special control A00 No self-collection
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SL Taillight assemblies with diodes (LED) (for NAR)
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Bumper systems 2K2 bumper reinforced
    Seat belt check 9P5 Visual and acoustic seat belt reminder, electric contact
    seat covers N0K Seat trim covers in leather
    Seat adjustment 3L4 Electric seat adjustment for both front seats, driver's seat with memory system
    seat heater 4A4 Seat heater for front and rear seats separately controlled
    Safety certificate 0LB With special labels safety certificates for USA
    sun visors 5XH Sun visors, with vanity mirror illuminated on driver's and front passenger side
    Audio-response system/voice control QH2 voice control
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Sunroof roller blind for rear/side windows 3Y3 Roll-up sunhade for rear window and rear door windows
    power outlet 7B2 12 volt socket in luggage compartment
    Handling production and pre-production FA0 Control of standard production
    Headlamp washer system 8X0 Without headlamp washer system
    Door and lid locking system 4K7 Central locking system "Keyless Entry" "two-stage unlocking"
    Type approval countries/countries with special requirements B34 Legal requirements USA
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Transit coating NT2 Transit coating (type 3)
    TV reception/digital radio reception QU0 Satellite radio reception USA
    Assembly parts for engine (drive bearing) 1VH Assembly part for 6-cyl. engine
    Identification plates 1EP Special identification label (USA)
    Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
    First aid kit / warning triangle 1T1 First aid kit
    Front seats Q1A Standard seats in front
    Storage compartment -- veneered key storage box 4Y0 Without storage compartment/safe box
    Telephone / telematics 9ZG preperation for mobile phone with hands free teleph.
    Windshield Glass 4GP Windshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Additional dust seals 6U7 Additional dust protection measures
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  8. #67
    Oct 2016
    Now that it looks like you're done with edits...
    Any idea if any of those outputs are the G201 pressure sensor? If so, how do I test it, especially given that it is a rare intermittent failure (and not always from a cold start)? Please understand, while I work in a technical field (wireless telecom) and have a background in computer tech support, my knowledge of electrical engineering is rather lacking, so I need "idiot" instructions.
    I do have my junkyard module that I can perform initial experiments on.
  9. #68
    I don't give instructions typically, I simply ask questions that you can surmise with your own tests and answers by using your own determinations, right?
    How about benching it and hooking up on K line/CAN etc. and seeing what is needed for inputs to power up on bench & to establish a reading and DTC list to vacate it with decade box for mere statics using VCDS?
    You have a used unit and pigtail right?
    Since you want instructions and the part is a combined component as per RTFB, I would say do a repair as per the RTFB & that comports with a qualified repair, however, before doing so, double check it isn't a recall or open campaign & for a free repair & if not; at least report that you have experienced a problem to the US Government & so if there is a campaign later, you can get reimbursed, right?
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
  10. #69
    Oct 2016
    I have a used spare unit, I do not have a pigtail. I also do not know anything about how the CANBUS or K-Line communications protocols work, nor do I believe I have all the necessary diagnostics tools to simulate it. I also don't have a decade box, though that seems like the easiest component to acquire. All in all, it seems like this level of diagnosis is beyond my abilities/capabilities.
    There also does not appear to be an active recall, investigation, or even complaint registered about this particular issue. Brake complaints seem to revolve around the parking brake switch or parking brake control module (located in the trunk), not the ABS module. I'll register a complaint once I can verify a repair solution.
    I guess I'm back to swapping the module... again.
  11. #70
    You sure about that and someone has to start someplace even if the first. no?
