Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 123
Thread: 2006 Audi A6 C6 ABS Fault 01435
  1. #21
    Oct 2016
    I guess the question now is whether that's really the cause of the DTC. Clear the fault code. Try to reproduce a negative value. Is that when the fault code sets?
    I'll be logging all my trips to see if I can get a fault code. My traction control gets disabled while logging, but I'm hoping that won't prevent the fault code from setting.
  2. #22
    I wonder if G201 is mislabeled in stack and should be either G518 / G519 or even F234 for this car?
  3. #23
    Oct 2016
    So I know that F234 is the brake pedal pressure sensor, what are the other two? Google isn't coming up with anything useful.
  4. #24
    They are front left and right brake PSI sensors and WD shows no G201 at all & not for any version ABS in that era.
  5. #25
    Oct 2016
    WD wouldn't show it. G201 is integrated into the ABS controller, not a separate sensor.
  6. #26
    Will have to look at SSP and if that is the case time for module and a ref to check NHTSA for campaign huh?
  7. #27
  8. Likes Uwe, NZDubNurd liked this post
  9. #28
    Oct 2016
    I have a log during which the error code was thrown.
    https://www.dropbox.com/s/07x864lxpy...07.29.CSV?dl=0
    Interestingly, while it did occur after a string of negative values, it isn't the only such occurrence in this log. There are other instances of multiple negative values with no code being thrown. I placed a marker when the error code occurred, see line 5133 or timestamp 2236.58 for the marker.
    Related, I managed to find a 2006 A6 in a local junkyard, so I got a used ABS module for ~$75 instead of having to purchase one new. I feel incredibly lucky, as this generation car doesn't usually make it to junkyards - the dismantlers/parts resellers usually get their grubby mits on them first. I'll probably swap it in and code it this weekend, if I can make the time.
  10. #29
    Quote Originally Posted by davisev5225 View Post
    I'm not seeing an obvious reason for why it threw the DTC at that point.
  11. Likes Jack@European_Parts liked this post
  12. #30
    More likely a loose weld joint that could be fixed with actual solder?
    This process of bridging circuits in all modules I have seen & so far has been less than reliable, especially a CVT or MAF & ABS, no?
    It's only being used to save labor times and cost lives it seems, no?
