Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 123
Thread: 2006 Audi A6 C6 ABS Fault 01435
    Oct 2016
    I've been having an intermittent issue with my ABS controller, and I'm hoping someone here can help me make sense of it.
    Most (but not all) of the time that I start my car and begin driving, shortly after I begin my trip, my ABS module will throw out error code 01435 - implausible signal. However, every time I test my brakes, everything works fine. The brake light switch is functioning properly, the brake pressure sensor is reading accurate pressures, etc. I can clear the code, then continue my trip (for as long as I want) with no further issues - cruise control works, I've had the unfortunate pleasure of finding out that the ABS pump still functions, etc. I have also already replaced the brake light switch, just in case, since it was an inexpensive part. "When in doubt, swap it out."
    I've attached a full scan of my car, as well as links to screenshots of some of the measuring block values. The only thing I didn't catch, because I only saw it once and couldn't grab a screenshot before it went away, is for a couple seconds I had a NEGATIVE value for my brake pressure reading while holding down the pedal.
    Does anyone know what is going on? I'm hoping to avoid changing my ABS pump and control module, as that is a rather expensive repair.
    ABS ERROR:
    Monday,22,July,2019,06:22:15:10305
    VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
                    Address 03: ABS Brakes       Labels: 4F0-910-517.clb
    Control Module Part Number: 4F0 910 517 L    HW: 4F0 614 517 L
      Component and/or Version: ESP 8.0 quattro H04 0090
               Software Coding: 0020895
                Work Shop Code: WSC 02325 785 00200
                          VCID: 2D516BBEB4397F2702-8078
                        Reset counter: 0
                        Mileage: 304009 km
                        Date: 2019.07.22
                        Time: 06:18:34
                        Hex Value: 0x1600
                        Hex Value: 0x4006
                        Hex Value: 0x001C
                        Hex Value: 0xB1AB
                        Hex Value: 0x00FF
    SCREENSHOTS:
    https://www.dropbox.com/sh/aptace1eu...FT9-1xyia?dl=0
    FULL SCAN:
    Tuesday,23,July,2019,13:09:53:10305
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUKH74F86N------   License Plate:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 65 67 72 76 77
    VIN: WAUKH74F86N------   Mileage: 304290km-189077miles
    Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
       Part No SW: 4F1 910 559 E    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0060
       Revision: --H15---    Serial number:
       Coding: 010D0109190F0120
       Shop #: WSC 02325 785 00200
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 008 -
                        Reset counter: 40
                        Mileage: 304286 km
                        Date: 2019.07.23
                        Time: 12:58:59
                        RPM: 1024 /min
                        Mass Air / Rev.: 87.2 mg/str
                        Temperature: 97.5°C
                            Idle
                        Load: 11.4 %
    Readiness: 0000 0100
       Part No SW: 4F2 910 156 D    HW: 09L 927 156 A
       Component: AG6 09L 3,2 FSI USA 0010
       Revision: --H01---    Serial number:        4121901
       VCID: 2643949291CF4C7FC3-8072
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H04 0090
       Coding: 0020895
                        Reset counter: 4
                        Mileage: 304286 km
                        Date: 2019.07.23
                        Time: 12:59:00
                        Hex Value: 0x00C0
                        Hex Value: 0x43A2
                        Hex Value: 0x001C
                        Hex Value: 0xB1A2
                        Hex Value: 0x00FF
       Component: FBSAUDIC6 ELV   H31 0180
       Revision: 30070501    Serial number: 10604000310700
       Coding: 0000143
       Shop #: WSC 22162 444 84622
       VCID: 63C5CD86A27DF957E4-8036
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 EZS   H45 0070
       Component: FBSAUDIC6 KSG   H27 0080
       Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 303LU057513496
       Coding: 0001003
       Shop #: WSC 00000 000 08192
       VCID: 316977CEA8011BC726-8064
       Component: Bedienteil MMIC6H09 0060
       Subsystem 2 - Serial number: 00000002106611
       Subsystem 3 - Serial number: 0111.04.130000000100010057ÿ
       Subsystem 4 - Serial number: 010057ÿ
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000030079589
       Coding: 0524582
       VCID: 5BB5F5669A0DC197AC-800E
    00739 - Coolant Circulation Pump (V50)
                        Fault Status: 00100001
                        Reset counter: 40
                        Mileage: 303976 km
                        Date: 2019.07.22
                        Time: 05:53:43
                        Temperature: 91.0°C
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0190
       Coding: 0014123
       Shop #: WSC 02335 785 00200
       VCID: 2A5B60A285D7681FE7-807E
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Component: REGENLICHTSENSORH11 0050
       Coding: 00207440
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7263378
       VCID: 1C37B67ADF8386AF65-8048
    Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
       Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
       Component: SDAR XM         H04 0670
       Revision: 00000000    Serial number: AUZ4Z7E0036900
       VCID: 2B5565A68A2D71171C-807E
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 66 AIRBAG AUDI8RH29 0300
       Revision: 14H29000    Serial number: 00359D0B0SG%
       Coding: 0013878
       Subsystem 1 - Part No: 4F0 910 339 A
       Component: BF-Gewichtsens. H02 0050
       Subsystem 2 - Serial number: 6332CSME0D3D03755
       Subsystem 3 - Serial number: 6342CSME0D3C74089
       Subsystem 4 - Serial number: 6352QSME07174677G
       Subsystem 5 - Serial number: 6362QSME07561A119
       Subsystem 6 - Serial number: 63734SME0527123F-
       Subsystem 7 - Serial number: 63834SME070E29472
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026053240045
       Coding: 0002142
       Shop #: WSC 02323 785 00200
       VCID: 66C3D492514F8C7F03-8032
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
       Component: KOMBIINSTR. M73 H16 0630
       Revision: 00200000    Serial number: 4PY57VXC5
       Coding: 3153203
       Shop #: WSC 22162 067 57207
       VCID: 2149878EF8E1AB47B6-8074
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 1300805C060338
       Coding: ECFE73CD1B7904
       Shop #: WSC 02334 785 00200
       VCID: 275D999696C55577F8-8072
       Coding: 0082954
       VCID: 61C9C78EB861EB47F6-8034
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H45 1100
       Revision: 00000000    Serial number: 355KX057557242
       VCID: 387F4AEA4B7BCA8F61-806C
    02261 - Data Medium
                        Fault Status: 00101110
                        Reset counter: 35
                        Mileage: 303792 km
                        Date: 2019.07.18
                        Time: 19:11:26
                        Hex Value: 0x5D30
                        Hex Value: 0xC45E
                        Hex Value: 0x0E00
                        Hex Value: 0x75BC
       Component: TSG FA          H12 0270
       Revision: 00-00000
       Coding: 0052907
       VCID: 2C5766BA8F23762F15-8078
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01009192410000
       Coding: 4618941
       VCID: 2E536CB2B93F043F3B-807A
    01134 - Alarm Horn (H12)
                        Reset counter: 4
                        Mileage: 280724 km
                        Date: 2019.01.03
                        Time: 17:52:33
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H09 0240
       Revision: PROD_01     Serial number: 00000000702745
       Coding: 0000126
       Shop #: WSC 22162 444 999999
       VCID: 2541939EECC94767CA-8070
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000013563
       Coding: 0002114
       VCID: 5EB3FC72891FD4BFCB-800A
       Component: TSG BF          H12 0270
       Revision: 00-00000
       Coding: 0052907
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       VCID: 5DB1FB7E8419CFA7D2-8008
                        Fault Status: 00101101
                        Reset counter: 44
                        Mileage: 304280 km
                        Date: 2019.07.23
                        Time: 12:59:34
                        Voltage: 12.63 V
                        Count: 236
       Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
       Component: AFS 1           H01 0010
       Coding: 0000016
       VCID: 285F9AAA9BDB5A0FF1-807C
       Subsystem 1 - Part No: 4F0 941 329 A
       Component: AFS-Modul links H05 0010
       Subsystem 2 - Part No: 4F0 941 329 A
       Component: AFS-Modul rechtsH05 0010
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
       Revision: 00000000    Serial number: 394L+057632927
       Component: ENERGIEMANAGER  H12 0470
       Revision: 00000000    Serial number: 00000000006954
       Shop #: WSC 03830 444 45040
       VCID: 23458D86E2FDB957A4-8076
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  170129T0X7
       Coding: 344630393135313035432056413031373031323954305837
       Shop #: WSC 99999 444 16786
    02479 - Partial Consumer Shut-Off Active
                        Fault Frequency: 36
                        Mileage: 303538 km
                        Date: 2019.07.17
                        Time: 17:14:48
    02254 - Interface to Generator
                        Fault Frequency: 43
                        Reset counter: 44
                        Mileage: 303538 km
                        Date: 2019.07.17
                        Time: 17:14:55
       Coding: 0052778
       Shop #: WSC 02327 785 00200
       Revision: 00050100    Serial number: 00000900015030
       Coding: 0062221
       VCID: 224B8882FDE7B05FAF-8076
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000511290193
       Shop #: WSC 12336 024 394758
       VCID: 34677EDA57132EEF4D-8060
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0052778
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0030
       Revision: 00H09000    Serial number: 11720533417232
       Coding: 0201216
       Component: Handyvorb2      H11 1130
       Revision: 00000000    Serial number: 00000007525555
       Coding: 0010900
    End-------------------------(Elapsed Time: 02:56)--------------------------
  2. Likes Uwe, Dani liked this post
  3. #2
    Nice post.
    Obviously, you've been to the Wiki article for this fault.
    It sure would be nice if Audi provided more details as to what can cause this "Implausible Signal" code. To me it means the value from the brake pressure sensor isn't reasonable given other values the ABS module is seeing at the same time.
    I really wonder about that negative value.. Have you logged Group 9 while driving?
    Oct 2016
    My phone ate my first attempted reply...
    This is a Bosch controller, so unfortunately, I cannot log anything while driving. Also of interest, now that I've made a post about it, my car has been behaving itself all day today. Go figure.
    And yes, I live by your wiki when doing diagnostics work. It's a wonderful resource. I always start there, and only go elsewhere if it doesn't have enough/any information. Unfortunately, even "elsewhere" doesn't have anything terribly helpful for this one.
    The sensor is bad, there is a connection issue, ( most likely bad ground since happens cold )contaminated fluid port (doubtful) or faulty ABS module.
    The negative value is when sensor reading went or goes offline.
    Oct 2016
    Just to clarify and make sure we're on the same page... is that ANY negative value, or just a negative value such as -1? My sensor gave a negative value equivalent to what the actual pressure should be if positive. It was 30-something bar, except negative.
    Unplug it and watch values in blocks or additionally hook up a decade box and watch blocks as you tap out reading's to qualify the circuit.
    Oct 2016
    I'm afraid you've lost me. There's only a single plug to the ABS controller, so if I unplug it, I can't communicate with it anymore. And what is a decade box?
  9. #8
    Variable resister in this case to put between controller and sensor.
    JPPSG it's in there & Google it.
    Plug to ABS module doesn't mean anything being a single wire, what's the point of your statement?
  10. #9
    Oct 2016
    The sensor is built into the controller, so I can't put anything between them.
    Single plug means I can't power or communicate with the module if I unplug it, so I also can't try and isolate a single output from it without ruining my wire loom.
    It's sounding like I need to replace the module. Didn't want to, but it is what it is. Thank you both for your assistance.
  11. #10
    Oh sigh.........
    Nope...........
    Wire looms can be taken apart without ruining them, time to get proficient?
