I'm a bit late to the party... have the same problem. Fault
01435.
Mine is a 2005 A6 Quattro 3.2L
And yep, I have been to the article for this fault. I should point out that I'm just a regular Audi driver, not a tech of any sort. So please go easy on me.
Here's what happened:
A couple of days ago, the ESP and lights came on. Once I started driving, the Parking Brake fault in the center came on as well. It goes off as soon as the wheels stop turning and comes back on when I start driving.
And yes, that beep can drive someone to madness. LOL
I checked the parking brake and it appears to be functioning as normal. The car drives and brakes normally.
I did have a low battery a week prior and needed jumping. So I ran a scan and it returned 4 Quiescent Current faults. It was time for a new battery, which I replaced yesterday. I ran another scan today to see if I could reset the faults, thinking maybe the voltage problem caused a glitch.
I can't seem to get it cleared.
Here is the full scan from today, and I hope I'm doing this right:
Sunday,12,January,2020,11:25:38:43060
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: WAUDG74F25N122676 License Plate:
Mileage: 191680km-119104mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 65 67 72 77
VIN: WAUDG74F25N122676 Mileage: 191680km-119104miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 B HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0020
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 05139 444 83890
VCID: 2B03FA8C1F0FB31F4C5-807E
000632 - Fuel Injector #6 (N84)
P0278 - 006 - Contribution/Balance Fault - Intermittent
Fault Status: 00100001
Reset counter: 7
Mileage: 191121 km
Date: 2019.12.17
Time: 17:02:10
RPM: 1312 /min
Mass Air / Rev.: 256.2 mg/str
Temperature: 81.0°C
Part Throttle
Load: 43.9 %
Speed: 38.0 km/h
P1602 - 008 - Voltage too Low - Intermittent
Fault Status: 00001000
Reset counter: 14
Mileage: 191277 km
Mass Air / Rev.: 0.0 mg/str
Temperature: 22.5°C
Engine Off
Load: 0.0 %
P1653 - 008 -
Fault Status: 01101000
Fault Frequency: 12
Reset counter: 40
Mileage: 191277 km
Date: 2019.12.30
Time: 08:26:23
RPM: 1568 /min
Mass Air / Rev.: 158.1 mg/str
Temperature: 24.0°C
Idle
Load: 19.6 %
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 4028906
Shop #: WSC 02325 785 00200
VCID: 290F008415F3A10FBE9-807C
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0020895
VCID: 2D07F494211BBD2F521-8078
008 - Implausible Signal
Fault Frequency: 6
Reset counter: 221
Mileage: 191635 km
Date: 2020.01.10
Time: 07:36:19
Hex Value: 0x0000
Hex Value: 0x4382
Hex Value: 0x001C
Hex Value: 0xB1AD
Hex Value: 0x00FF
Reset counter: 221
Mileage: 191681 km
Date: 2005.02.01
Time: 12:02:36
Hex Value: 0x0000
Hex Value: 0x4382
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x00FF
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300155096
Coding: 0000015
Shop #: WSC 06402 785 00200
VCID: 639352AC375F3B5FB45-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H26 0080
00191 - Passenger's Door Handle Touch Sensor (G416)
Fault Status: 01111011
Reset counter: 220
Mileage: 191658 km
Date: 2020.01.10
Time: 13:37:14
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 220
Mileage: 191658 km
Date: 2020.01.10
Time: 13:37:14
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 360DK057523670
Coding: 0000003
Shop #: WSC 05139 444 104911
VCID: 313FE8E43D23D9CF769-8064
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000143950
Subsystem 3 - Serial number: 0120.04.050000000100010067ÿ
Subsystem 4 - Serial number: 010067ÿ
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000026 Serial number: 00000000140982
Coding: 0524326
VCID: 5BE36A4C0F2F039FFC5-800E
01853 - Heated Seat; Left Front (Z45)
Fault Status: 01101011
Reset counter: 218
Mileage: 191635 km
Date: 2020.01.10
Time: 07:36:24
Temperature: 21.0°C
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0002121
Shop #: WSC 02335 785 00200
VCID: 66954BB8C46D4E7753B-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Fault Frequency: 27
Reset counter: 221
Mileage: 191632 km
Date: 2020.01.10
Time: 07:36:00
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7162212
VCID: 1C6129504AA144A735F-8048
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D3022210
Reset counter: 218
Mileage: 191635 km
Date: 2020.01.10
Time: 07:36:20
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D08CD6Q
Coding: 0013622
VCID: 26150BB804ED8E7793B-8072
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME090C33570
Subsystem 3 - Serial number: 6342CSME097E1B228
Subsystem 4 - Serial number: 6351HSME07172617+
Subsystem 5 - Serial number: 6361HSME070A2202Y
Subsystem 6 - Serial number: 6371VSME07284D23M
Subsystem 7 - Serial number: 6381VSME07286733K
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025051100025
Coding: 0002041
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H02 0030
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0630
Revision: 01000000 Serial number: 4R850TV45
Coding: 2129263
Shop #: WSC 50451 001 1048576
VCID: 1E6523585CBD56B7DBB-804A
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080542881C4
Coding: 6CFE73CD1B5904
VCID: 270B06BC03E7977FA8D-8072
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619F58A42D43294FA69-8034
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0051947
Shop #: WSC 02327 785 00200
Reset counter: 6
Mileage: 191681 km
Date: 2020.01.11
Time: 15:44:15
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01003941210000
Coding: 4618301
VCID: 2E05F3982C1DC6376BB-807A
01134 - Alarm Horn (H12)
Fault Status: 01101100
Reset counter: 221
Mileage: 165174 km
Date: 2017.08.24
Time: 17:20:11
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000030664
Coding: 0000026
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0050
Revision: Serial number: 00000000089631
Coding: 0001114
VCID: 5EE563581C3D16B79BB-800A
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0051947
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DE76454113B0DAF821-8008
01316 - ABS Control Module
Fault Status: 00101101
Fault Frequency: 43
Reset counter: 5
Mileage: 191632 km
Date: 2020.01.10
Time: 07:39:10
Voltage: 13.04 V
Count: 236
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000016
Shop #: WSC 05139 444 109253
VCID: 698F4084D573610F7E9-803C
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Revision: 00000000 Serial number: 394ES057543740
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000027842
Shop #: WSC 05139 444 58901
VCID: 231312AC77DF7B5FF45-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 0330207712
Coding: 344630393135313035432056413030333330323037373132
Shop #: WSC 57227 000 1048576
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000700004988
Coding: 0062221
Shop #: WSC 05139 444 59514
VCID: 60995DA026492047A97-8034
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000504220168
Shop #: WSC 12336 024 394758
VCID: 3431E1F0C231ECE71DF-8060
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0051754
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007521822
Coding: 0010900
VCID: 280905800EF99807A17-807C
End----------(Elapsed Time: 01:53, VBatt start/end: 13.9V/13.9V)-----------
Here is the code from just the module:
Sunday,12,January,2020,11:29:23:43060
Version: 19.6.2.0 HEX-V2 : 0.4508.4
Address 03: Brakes Labels: 4F0-910-517.clb
Control Module Part Number: 4F0 910 517 L HW: 4F0 614 517 L
Component and/or Version: ESP 8.0 quattro H03 0090
Software Coding: 0020895
Work Shop Code: 02325 785
00200
Reset counter: 222
Mileage: 191681 km
Date: 2020.01.12
Time: 11:27:18
Hex Value: 0x0000
Hex Value: 0x4382
Hex Value: 0x001C
Hex Value: 0xB1AC
Hex Value: 0x00FF
Address 03: cleared
Address 03,4F0 910 517 L,recoded (Short coding),from,0020895,to,0020895,(02325/785/
00200),
Address 53,4F0 910 801 ,recoded (Short coding),from,0005022,to,0005022,(02334/785/
00200),
I guess my question is, how screwed am I?
If it's the sensor, it can't be replaced individually, right? It would require the whole to be exchange?
My second question is: this is my only car. How safe is it for me to drive it if you discount me going crazy with the BEEEEEPING each time I start rolling again?
Any help would be so greatly appreciated.
