Hello everybody!
I am French and it's my first post on this forum as I just bought an HEX-V2 to investigate what is happening to my 2015 Audi A6 C7 4G.
The symptoms are:
- the retractable MMI Display is blocked closed and no ways to get it open
- no MMI console panel key is responding.
So I started an auto-scan which reveal only one error given by 5F controller:
I am not sure of the exact configuration because I have not the official workshop documents but one interesting thing is this controller should display some sub-systems like E80 which is the control panel.
After this, as this controller manages a MOST bus (optical, easy to see, it's a very specific connector), I tried the Optical Bus Diagnostics in Application menu.
Output is below at the end of the log file.
So I don't know what I can investigate exactly... And a (funny) thing is that this last diagnostic tests the Gateway (J533) which mine has NO Optical connector.
Any ideas... I am sure that the answer is interesting!
The symptoms are:
6691 - Local Data Bus
I looked for information about the controller which gave this default and discover that is supposed to manage sub-systems on different buses.I am not sure of the exact configuration because I have not the official workshop documents but one interesting thing is this controller should display some sub-systems like E80 which is the control panel.
Friday,26,July,2019,10:43:20:02858
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G5FN085631 License Plate:
Mileage: 84270km-52362mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
69 72 8F 90 AC
VIN: WAUZZZ4G5FN085631 Mileage: 84270km-52362miles
Address 01: Engine (J623-CRTE) Labels: Redir Fail!
Part No SW: 4G2 907 311 C HW: 4G2 907 401
Component: 3.0TDI EDC17 H34 0007
Revision: 92H34---
Coding: 0A254012053601030000
Shop #: WSC 26733 003 1048576
ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
ROD: EV_ECM30TDI0114G2907311C.rod
VCID: 2517F060E561B48F99F-8070
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 A HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0008
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2B030658838582FF4FB-807E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 17A69E41E8657982BB00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FDB420867FD0E5FF33-806A
Part No SW: 4H0 907 064 FP HW: 4H0 907 064 EP
Component: BCM2 2.0 H36 0560
Coding: 05A86F0E000000000000
VCID: 7CA1F50436EBD547961-8028
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 07041500040314
Coding: 36011178210000
VCID: 6393AE78ABD50ABFB7B-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001041747502
Coding: 2600001400349FE08181408380001D0CCF9CE20826090201000008206101150200400024030000
VCID: 71BFD43061A9A82F357-8024
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 150314 H37 0080
Serial number: 150325122221
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23867849
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 12 03 2015 00000203
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 99380E97000000000001
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P10041XK1
Coding: 30333130313730323731554A304C34473053
VCID: 3B23361873E5127FDFB-806E
Serial number: 3575HRB404T37GLK4PE7
Serial number: 3585HRB405937GLK216+
Serial number: 3515JRB405136F9QOH1A
Serial number: 3525JRB405536F9QK1RL
Serial number: 3554VRB4051367OMJ93H
Serial number: 3564VRB4051367OM39LK
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OCU0021L
Coding: 000014
VCID: 3B2336187365127FDFB-806E
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0010
Serial number: 14 02 2015 A0047606
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 933 Q HW: 4G8 920 933 Q
Component: TDieRdw H08 0043
Revision: 04001037 Serial number: 658310315596060
Coding: 13A60A000B410008030000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3E253F0C60F70757F85-806A
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001778374
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 75B7E0201541840FE9F-8020
Serial number: 1900856003
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 150113000000000003CB
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 01041500040825
Coding: 20
VCID: 3D2738006DF11C4FE1F-8068
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000141839433
VCID: 77ABEA280FCDF61FFB3-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720GT3JR
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 33331E385BB5DA3F07B-8066
Component: TSG FA H03 0507
Coding: 011F17015E00628002080002
VCID: 47CB5AE83FAD469F4B3-8012
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0023643378
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS_009.rod
VCID: 392F2C1079D9206FCD7-806C
Revision: 00002001 Serial number: 0363751724
Coding: 01000E3800B900818320080428030E470000000000000000000000000000
Subsystem 1 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93479329
Component: TSG BF H03 0507
VCID: 46D557EC38A75F97B05-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001416767
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070840BD918CCF51F-8078
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 043 B HW: 4G1 035 043
Component: MU-H-N-EU 041 MU-H-N-EU 041 00730073
Serial number: A591D0F7525204
Coding: 01750101FF0A000013110001000A00002F0006E5F1700100DF
ROD: N/A
VCID: 1D67D880CD317C4FC1F-8048
U10BA 00 [008] - No Communication
[Sub-Bus Bus keine Kommunikation]
Component: TSG HL H03 0507
Coding: 010F15004000628002080002
VCID: 49CF5CD029B9B0EF5D7-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001001 Serial number: 0363786524
Coding: 0100000202000000
Component: TSG HR H03 0507
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F1430A1A9E82F757-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D1B3CA4AFD3370CD-8066
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150721803
ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:17, VBatt start/end: 12.2V/12.2V)-----------
Control Module Part Number: 4G8 907 468
Component and/or Version: J533--Gateway H13 0075
Optical Bus Diagnostic : Standard
Controller Electrical Optical
CAN Gateway ERROR ERROR
Information Electr. ERROR ERROR
Instruments ERROR ERROR
