Results 1 to 7 of 7
Thread: AUDI A1 TDI----LIMP MODE (1.6 TDI P0087)
    Nov 2016
    car went in limp mode today....any idea about this fault code?
    Friday,26,July,2019,16:19:31:07086
    VCDS Version: 19.6.0.6 (x64)
    VIN: WAUZZZ8X5CB039627   License Plate:
    Chassis Type: 8X-AU21 (8U0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
    VIN: WAUZZZ8X5CB039627   Mileage: 220590km-137068miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
       Component: R4 1.6l TDI   H63 9978
       Revision: --H63---    Serial number:
       Coding: 00114016030501080000
       Shop #: WSC 00046 790 00000
       ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
       ROD: EV_ECM16TDI02103L906023KG.rod
       VCID: 7F0710B2E6E6D2B7EC-802A
    10116 - Fuel Rail/System Pressure
              P0087 00 [101] - Too Low
                        Mileage: 220593 km
                        Date: 2019.07.26
                        Time: 16:02:53
                        Engine speed: 1469.00 /min
                        Vehicle speed: 41 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 14.456 V
                        Fuel high pressure: actual value-FUP_FIL: 72.839 MPa
                        Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                        Fuel level-FTL_CAN: 15 l
                        Fuel temperature-TFU: 51 °C
                        Fuel Metering Valve-VCV: 19.267 %
                        Fuel Pressure Regulator Valve-PCV: 38.194 %
                        Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 79931.641 kPa
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
       Component: ESP8.2i front H07 0001
       Revision: --------
       Coding: 330448E9437000BBCC2B12E4C2D800920C00
       Shop #: WSC 00046 000 00000
       VCID: 7F0710B2EAE6D2B7EC-802A
       Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
       Component: J255 Klima Manuell  0140
       Revision: 0000707S    Serial number: 03030005858844
       VCID: 346D0F9E5720C1EF41-8060
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
       Component: BCM PQ35  M   110 0655
       Revision: 00110 AE
       Coding: 0E000A2CA807F100201841E020000154538B7E0A01CF4122DC0887830045
       Shop #: WSC 00046 123 12345
       VCID: 4085534ED3986D4FD5-8014
       Subsystem 1 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    02739 - Bulb for Tail/Brake Light; Right
                        Fault Status: 00101010
                        Reset counter: 213
                        Mileage: 220432 km
                        Date: 2019.07.21
                        Time: 20:59:16
                        Voltage: 12.05 V
                            Term 50 On
    03192 - Lamp 2 for Blinker; Rear Left
                        Reset counter: 215
                        Mileage: 220435 km
                        Date: 2019.07.21
                        Time: 21:17:08
                        Voltage: 14.15 V
                            Term 50 On
    03193 - Lamp 2 for Blinker; Rear Right
                        Reset counter: 215
                        Mileage: 220435 km
                        Date: 2019.07.21
                        Time: 21:38:38
                        Voltage: 14.20 V
                            Term 50 On
    03351 - Bulb for DRL and Marker Light; Left
                        Fault Status: 01101010
                        Fault Frequency: 33
                        Reset counter: 178
                        Mileage: 220502 km
                        Date: 2019.07.23
                        Time: 17:33:46
                        Voltage: 12.60 V
                            Term 50 On
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
       Component: Airbag10.41   H04 0008
       Revision: --------    Serial number: 003JJ0039CR6
       Coding: 30314539303330303034554A305238583053
       ASAM Dataset: EV_Airba1041BPAAU210 001015
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 48954B6EF3A8550F1D-801C
       Serial number: 3554VRB40570M8GC60TN
       Serial number: 3575HRB405J0OPMG2OOP
       Serial number: 3585HRB40510N3MG8OFP
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB405B0MFP6I0U8
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
       Revision: FF010016    Serial number: 20110913100937
       Coding: 1184004000
       VCID: 39733EAAB8423C8792-806C
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Component: E221 - MFL  H08 0009
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
       Component: KOMBI_MEDIUM  H03 0179
       Coding: 41DE00
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
       VCID: 4085534EDB986D4FD5-8014
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
       Component: GAT 4CAN 1L M H10 0044
       Revision: 1P040023    Serial number: 2341P119180144
       Coding: FBCF005A000100010153
       Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
       Component: J367-BDM  H07 0171
       Serial number: 00000000007100549523
       Serial number: 11278001482021200181
       Component: IMMO          H03 0179
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
       Component: TSG FA        H09 0409
       Coding: 011E02200101000100
       VCID: 4E997D7619CC8B3F57-801A
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11251
       Shop #: WSC 00046
       VCID: 2F6700F2EA06E2373C-807A
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
       Component: TSG BF        H09 0409
       VCID: 4D9B7A7A14CAB0272E-8018
       Part No SW: 8X0 035 183 E    HW: 8X0 035 183 C
       Component: RMC Cnct      H51 0775
       Coding: 01010001008051070023000103010000010000
       VCID: 39733EAAB0423C8792-806C
       Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9462IW0B0139570
    End-------------------------(Elapsed Time: 02:09)--------------------------
    Seems pretty self-explanatory. Your ECU thought the pressure in the engine's fuel rail was too low.
    You can confirm when this happens by checking these measuring values:
    IDE00188-ENG102817 -- Fuel high pressure: actual value
    IDE00201-ENG102664 -- High fuel pressure: specified value
    These may also be interesting:
    IDE01378-ENG100595 -- High fuel pressure: control deviation
    In the end though, there's probably some mechanical reason for this that will have to be found the old-fashioned way.
    Nov 2016
    OK thanks, il check via measuring blocks
    Jun 2015
    Has it recently had a fuel filter or been missfuelled with petrol?
  6. Likes Jack@European_Parts liked this post
    Nov 2016
    Fuel filter looks new..... Not sure about miss fuelled..... As I've brought the car for my son a few weeks ago
    Jun 2015
    If the fuel filter has been chnaged and then the car started up without thoroughly purging the system using output tests then it is likely the pump is damaged internally, look closely for shiny particles inside the filter. If this the case, these particles can also get into the injectors and cannot cleaned out so you end up with new filter, new high pressure fuel pump, four new injectors injectors and cam belt kit with water pump plus having to clean out the entire fuel system to make sure no particles are left in there. Basically this just about writes the car off.
    Nov 2016
    Thanks.... It goes a good while before the issue, il av a look into it, check what you have said... Thanks
