car went in limp mode today....any idea about this fault code?
Friday,26,July,2019,16:19:31:07086
VCDS Version: 19.6.0.6 (x64)
VIN: WAUZZZ8X5CB039627 License Plate:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X5CB039627 Mileage: 220590km-137068miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP
Component: R4 1.6l TDI H63 9978
Revision: --H63--- Serial number:
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
ROD: EV_ECM16TDI02103L906023KG.rod
VCID: 7F0710B2E6E6D2B7EC-802A
10116 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Mileage: 220593 km
Date: 2019.07.26
Time: 16:02:53
Engine speed: 1469.00 /min
Vehicle speed: 41 km/h
Coolant temperature: 93 °C
Intake air temperature: 39 °C
Voltage terminal 30: 14.456 V
Fuel high pressure: actual value-FUP_FIL: 72.839 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 15 l
Fuel temperature-TFU: 51 °C
Fuel Metering Valve-VCV: 19.267 %
Fuel Pressure Regulator Valve-PCV: 38.194 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 79931.641 kPa
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 330448E9437000BBCC2B12E4C2D800920C00
Shop #: WSC 00046 000 00000
VCID: 7F0710B2EAE6D2B7EC-802A
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030005858844
VCID: 346D0F9E5720C1EF41-8060
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
Component: BCM PQ35 M 110 0655
Revision: 00110 AE
Coding: 0E000A2CA807F100201841E020000154538B7E0A01CF4122DC0887830045
Shop #: WSC 00046 123 12345
VCID: 4085534ED3986D4FD5-8014
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
02739 - Bulb for Tail/Brake Light; Right
Fault Status: 00101010
Reset counter: 213
Mileage: 220432 km
Date: 2019.07.21
Time: 20:59:16
Term 15 On
Voltage: 12.05 V
Term 50 On
03192 - Lamp 2 for Blinker; Rear Left
Reset counter: 215
Mileage: 220435 km
Date: 2019.07.21
Time: 21:17:08
Term 15 On
Voltage: 14.15 V
Term 50 On
03193 - Lamp 2 for Blinker; Rear Right
Reset counter: 215
Mileage: 220435 km
Date: 2019.07.21
Time: 21:38:38
Term 15 On
Voltage: 14.20 V
Term 50 On
03351 - Bulb for DRL and Marker Light; Left
Fault Status: 01101010
Fault Frequency: 33
Reset counter: 178
Mileage: 220502 km
Date: 2019.07.23
Time: 17:33:46
Term 15 On
Voltage: 12.60 V
Term 50 On
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
Component: Airbag10.41 H04 0008
Revision: -------- Serial number: 003JJ0039CR6
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001015
ROD: EV_Airba1041BPAAU210.rod
VCID: 48954B6EF3A8550F1D-801C
Serial number: 3554VRB40570M8GC60TN
Serial number: 3575HRB405J0OPMG2OOP
Serial number: 3585HRB40510N3MG8OFP
Rear Impact Crash Sensor:
Serial number: 3515ZRB405B0MFP6I0U8
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 B HW: 5K0 953 569 H
Revision: FF010016 Serial number: 20110913100937
Coding: 1184004000
VCID: 39733EAAB8423C8792-806C
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8X0 920 980 D HW: 8X0 920 980 D
Component: KOMBI_MEDIUM H03 0179
Coding: 41DE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
VCID: 4085534EDB986D4FD5-8014
Part No SW: 8U0 907 468 A HW: 8U0 907 468 A
Component: GAT 4CAN 1L M H10 0044
Revision: 1P040023 Serial number: 2341P119180144
Coding: FBCF005A000100010153
Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H
Component: J367-BDM H07 0171
Serial number: 00000000007100549523
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 11278001482021200181
Component: IMMO H03 0179
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 D HW: 8X0 959 793 D
Component: TSG FA H09 0409
Coding: 011E02200101000100
VCID: 4E997D7619CC8B3F57-801A
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6700F2EA06E2373C-807A
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 D HW: 8X0 959 792 D
Component: TSG BF H09 0409
VCID: 4D9B7A7A14CAB0272E-8018
Part No SW: 8X0 035 183 E HW: 8X0 035 183 C
Component: RMC Cnct H51 0775
Coding: 01010001008051070023000103010000010000
VCID: 39733EAAB0423C8792-806C
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
Serial number: 9462IW0B0139570
End-------------------------(Elapsed Time: 02:09)--------------------------
