Results 1 to 9 of 9
Thread: Fuel rail pressure to low (1.6 TDI P0087)
    Jul 2019
    Peebles, Scotland
    2012 seat Ibiza 1.6TDI fuel rail pressure to low. 0087. Coil light on! Limp mode! Any ideas?
    Hi and welcome.
    Jul 2019
    Peebles, Scotland
    Friday,26,July,2019,17:22:18:26536
    VCDS Version: Release 19.6.0 (x64) Running on Windows 10 x64
                    Address 01: Engine       Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 LE    HW: 03L 906 023 Q
      Component and/or Version: R4 1.6l TDI   H33 9978
               Software Coding: 00114016002500080000
                Work Shop Code: WSC 131071 1023 2097151
                  ASAM Dataset: EV_ECM16TDI02103L906023LE 003011 (SE25)
                           ROD: EV_ECM16TDI02103L906023LL.rod
                          VCID: 74B1DDCFEE3D5527DE9-8020
    10116 - Fuel Rail/System Pressure
              P0087 00 [232] - Too Low
                        Mileage: 90433 km
                        Date: 2019.07.24
                        Time: 16:59:10
    Engine speed: 1635.25 /min
                        Vehicle speed: 65 km/h
                        Coolant temperature: 95 C
                        Intake air temperature: 29 C
                        Voltage terminal 30: 14.118 V
                        Fuel high pressure: actual value-FUP_FIL: 103.955 MPa
                        Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                        Fuel level-FTL_CAN: 31 l
                        Fuel temperature-TFU: 45 C
                        Fuel Metering Valve-VCV: 23.686 %
                        Fuel Pressure Regulator Valve-PCV: 53.510 %
                        Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 129931.641 kPa
    Readiness: 1 1 0 0 0
    Jul 2019
    Peebles, Scotland
    Friday,26,July,2019,17:19:51:26536
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: VSSZZZ6JZCR122168   License Plate:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 4B 56 77
    VIN: VSSZZZ6JZCR122168   Mileage: 90620km-56308miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
       Component: R4 1.6l TDI   H33 9978
       Revision: --H33---    Serial number:
                        Mileage: 90433 km
                        Date: 2019.07.24
                        Time: 16:59:10
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 100200DB006F00B4082600E800D900000000
       Shop #: WSC 04941 000 00000
       VCID: 0059811FAA457987CA1-8054
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6J0 820 043 C    HW: 6J0 820 043 C
       Component: Climatronic   H07 0606
       Revision: S0000000
       VCID: 2411ED8F1EDD85A78E9-8070
                        Fault Status: 00101101
                        Reset counter: 109
                        Mileage: 90343 km
                        Date: 2013.12.12
                        Time: 07:58:33
       Part No SW: 7H0 937 089 F    HW: 7H0 937 089
       Component: BCM T5GP Li4  H50 0254
       Revision: BS050001    Serial number: 0465 016120173
       Coding: 24880BE88861250093300EF06ECB8EC80F80602F608C2009200000000000
       Shop #: WSC 64564 324 38760
       VCID: 392F2CFB895FE84FCDF-806C
       Component: RLS 010212 05  54  0403
       Coding: 02242D
       Subsystem 2 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 3110
       Coding: 030000
       Subsystem 3 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 3110
       Coding: 020000
       Subsystem 4 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
     Subsystem 5 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HO  H11 9005
       Subsystem 6 - Part No: 1K8 951 171 A
       Subsystem 7 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3121
       Subsystem 8 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3121
    Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
       Part No SW: 6J0 919 475 B    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H08 0008
       Revision: --------    Serial number: 36861132200647
       Coding: 000007
       Shop #: WSC 06402 785 00200
       ASAM Dataset: EV_SE250ParkiAssis2 S01006
       ROD: EV_SE250ParkiAssis2.rod
       VCID: 353720CBA5C70C2F297-8060
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagA0D H09 0020
       Revision: --------    Serial number: 003GX012VZ7%
       Coding: 003044
       Shop #: WSC 06401 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4ACD6337DC3973D7545-801E
       Serial number: 3495RRB404R126SEC20E
       Serial number: 3505RRB404P126SEH0T-
       Part No SW: 6J0 920 903 H    HW: 6J0 920 903 H
       Component: KOMBI         H02 0504
       Coding: 410A00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       VCID: 2F3B12A3479B36FF63B-807A
       Part No SW: 6N0 909 901     HW: 7H0 937 089
       Component: GW-K-CAN TP20 H50 0254
       Revision: BS050001
       Coding: 322300
       VCID: 70B9D1DF9AA569073A1-8024
       Component: IMMO          H02 0504
       VCID: 6A8DC3B7BCF993D7745-803E
       Part No SW: 6J0 035 342 E    HW: 6J0 035 342 E
       Revision: A1001003    Serial number: 7661738846
       Coding: 020000
       VCID: 2615F78768E177B790D-8072
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10121
       Shop #: WSC 06402
       VCID: 2F3B12A34E5B36FF63B-807A
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441 A
       Component: MF-Modul       0007 0001
       Shop #: WSC 77005 000 00000
       VCID: 313F14DB5D2F200F75F-8064
    Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
       Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
       Component: Radio         H15 0204
       Revision: R0000000    Serial number: SEZAZ2L1961825
       Coding: 0005020002
       VCID: 2A0D03B77CF953D7B45-807E
       Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
       Component: TELEFON       H13 2730
       Revision: 1B001001    Serial number: 00007661841208
       Coding: 0200000001010110
       ASAM Dataset: EV_UHVNA A01015
       ROD: UHVNA.rod
    End----------(Elapsed Time: 02:01, VBatt start/end: 12.6V/12.5V)-----------
    Since you have a very similar engine and exactly the same fault code, I am almost tempted to merge with this thread:
    https://forums.ross-tech.com/showthread.php?19505
    Mar 2014
    Las Vegas, Nevada
    First let me state that I am not familiar with the 1.4L TDI, but I assume that it is a common rail system similar to the similar year 2.0L system sold in the US. I have some experience with fuel pressure regulation issues. If your 1.4L TDI is not a similar common rail design, feel free to stop reading now. First a question: Is this problem solid or does the car run OK when you re-start it? I had a TDI that got fuel pressure DTC and limp mode every few hundred miles. Restart it and it was good for another few hundred miles. It was not fun to troubleshoot.
    If the problem is constant (car will not restart) it could be the HPFP. If your car uses the same dodgy Bosch CP4.2 pump we got here in the US, pull out the fuel metering valve on the top of the pump and look for metal shavings. If the screen is full of metal pieces, you have a serious (read expensive) problem. The HPFP has self destructed and spread debris throughout the entire fuel system.
    If the HPFP is OK, your 2 best options are that metering valve I mentioned above and the fuel pressure regulator valve on the fuel rail itself. I have no idea how this works in Scotland, but in the US the fuel pressure regulator valve alone costs more than a complete fuel rail assembly - which includes the valve. This makes no sense, but this is Volkswagen.
    Have Fun!
  7. #7
    Jul 2019
    Peebles, Scotland
    new to ross tech so not up to speed with how to use measuring block? Any help would be apprecited
  8. #8
    Jul 2019
    Peebles, Scotland
    continental hpfp, valve side mounted so can't remove without taking the whole pump out!
  9. #9
    Jul 2019
    Peebles, Scotland
    Happens ever day now. Usually after about 20 miles or were going up a hill. Stop car switch off and restart and light goes of and you get any other 10miles or so before the light reappears.
