Hello
I have original Ross Tech cable and yesterday I couldn’t put the correct coding of the module
03: ABS Brakes, Part No SW: 5N0 614 109 AE, HW: 5N0 614 109 AE, Component: J104 C6 450M V4F3 0120 . The car is an Audi Q3 2.0 TDI from 2012, with the Chassis Type: 8U-AU21 (8U0)
Somehow I find the Coding 0017525 or 0050308 and then I try to perform the zero position calibration for the Steering Angle Sensor (G85), but without success.
I didi t like your instructions.
Here is the full autoscan:
So could someone tell me the correct coding for the Audi Q3 2.0 TDI, from 2012, with the VIN WAUZZZ8U2DR012626 ?
All this problems emerged when my cliente change the odometer for another one with color display and then he put the original dasboard and even with it I couldn’t perform the G85 and I get many problems at the ABS anda t the Steering Wheel
So I guess that if i find out the right coding for the ABS then I could perform the zero position calibration for the Steering Angle Sensor (G85) with success.
Thank you and regards from Portugal
Carlos Martins
Wednesday,24,July,2019,21:01:03:16010
VCDS Version: 19.6.1.0
VIN: WAUZZZ8U2DR012626 License Plate:
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 55 56 5F 62 6C 72
VIN: WAUZZZ8U2DR012626 Mileage: 38070km-23655miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CN HW: 03L 906 018 ES
Component: R4 2.0l TDI H28 9977
Revision: 41H28--- Serial number:
Coding: 00190032042401080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01103L906018CN 003007
ROD: EV_ECM20TDI01103L906018CN.rod
VCID: 78F98465C3EDC18FA1-802C
4815 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [167] - -
Mileage: 38075 km
Date: 2019.07.24
Time: 20:47:01
Coolant temperature: 89 °C
Intake air temperature: 43 °C
Voltage terminal 30: 12.400 V
Requested transmission torque: 1000.0 Nm
Limitation: accelerator pedal: 126.6 Nm
Cruise Control System (CCS): status-Bits 0-7: 234
selected gear-Bits 0-7: 0
Transmission torque intervention status-Bits 0-7: 0
Transmission torque intervention status-Bits 0-7: 4
Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
U0415 00 [039] - -
Mileage: 38075 km
Date: 2019.07.24
Time: 20:46:57
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 38075 km
Date: 2019.07.24
Time: 20:46:57
Longitudinal acceleration: raw value: 32.767 m/s²
Vehicle inclination acceleration angle: raw value: -0.001 m/s²
Status: incline angle-Bits 0-7: 0
Longitudinal acceleration: 0.000 m/s²
Longitudinal acceleration sensor: status-Bits 0-7: 1
Vehicle lateral acceleration: raw value: 327.67 g
Vehicle lateral acceleration: 0.00 g
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AE HW: 5N0 614 109 AE
Revision: --H07--- Serial number: 00000005868330
Coding: 0017525
Shop #: WSC 00049 770 00155
VCID: 6ED5A23D79A98F3F7B-803A
9 Faults Found:
Reset counter: 243
Speed: 252.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.25 V
Bin. Bits: 00000001
Count: 215
Hex Value: 0x0000
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00000001
Count: 26
Hex Value: 0x0000
03201 - Adaptation Overboost
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
01324 - Control Module for All Wheel Drive (J492)
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:50:17
Part No SW: 8U0 820 043 E HW: 8U0 820 043 E
Component: E87 Klimavoll 0100
Revision: 00H04000 Serial number: 8U0820043E
VCID: 33637349520BE2D754-8066
04000 - Function limitation due to crash signal
Reset counter: 252
Mileage: 71824 km
Date: 2018.07.24
Time: 14:13:36
01177 - Engine Control Unit
Fault Status: 00101101
Reset counter: 252
Mileage: 71824 km
Date: 2018.07.24
Time: 14:13:45
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 0
Temperature: 23.0°C
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
Reset counter: 0
Temperature: 23.0°C
01853 - Heated Seat; Left Front (Z45)
Fault Status: 00101100
Reset counter: 5
Mileage: 37307 km
Date: 2019.07.10
Time: 12:53:18
Temperature: 26.5°C
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 K HW: 8X0 907 063 K
Component: BCM PQ35 M 110 0667
Revision: AE110667
Coding: 0E000A2FE8251AC8605840C02100894C57FF84AA216F912AE408878400C5
Shop #: WSC 00049 770 00010
VCID: 44812095C7A5556FFD-8010
Subsystem 1 - Part No SW: 8U1 955 119 HW: 8U1 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 120509 H35 0085
Serial number: 120604191526
Coding: 0047F7
Component: G397_RLFS H06 0002
Serial number: 20322643
Coding: 02006E
Address 10: Park/Steer Assist (J791) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 P HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0030
Revision: -------- Serial number: 56261216902675
Coding: 280205
Shop #: WSC 00049 770 00118
ASAM Dataset: EV_EPHVA2CAU3160000 003003
ROD: EV_EPHVA2CAU3160000_003.rod
VCID: 53A313C93ACBC2D774-8006
13637393 - Databus
Fault Frequency: 9
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:28:01
13637396 - Databus
Fault Frequency: 11
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:28:01
13637397 - Databus
Fault Frequency: 16
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:28:01
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
Component: AirbagVW-AU10 H07 0520
Serial number: 003LRR024TB
Coding: 30333132313030303030554A304C38553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 46853A9DF999677FE3-8012
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME5237251CZZZX
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME581D441CZZZ-
Serial number: 3516KSME137A231CZZZS
Serial number: 3526KSME1D37441CZZZZ
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME4F47091CZZZB
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Fault Frequency: 48
Reset counter: 28
Mileage: 38074 km
Date: 2019.07.24
Time: 18:43:17
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Fault Frequency: 16
Reset counter: 28
Mileage: 38074 km
Date: 2019.07.24
Time: 18:43:18
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 H
Revision: FF010017 Serial number: 20120620101195
Coding: 1184204000
VCID: 3B735B69B25B2A978C-806E
Subsystem 1 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
1140738 - Steering angle sensor
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:28:59
UBat: 12.80 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 930 C HW: 8U0 920 930 C
Component: KOMBI_MEDIUM H02 0251
Coding: 12CF00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
VCID: 377B47598E730EF768-8062
Part No SW: 8U0 907 468 J HW: 8U0 907 468 J
Component: GAT 4CAN 2L M H13 0059
Revision: 1R110032 Serial number: 3241R125170327
Coding: FBCF1A5A050B05610253
Shop #: WSC 05279 123 104857
VCID: 499F31A1E08788070E-801C
Subsystem 1 - Part No SW: 8U0 959 591 HW: 8V3 959 591
Component: J245 PS11.018 H02 0007
Serial number: WOO1682856A
Coding: 901E00
Subsystem 2 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900567816
Subsystem 3 - Part No SW: 8U0 959 591 HW: 8V3 959 591
Component: J394 PS11.018 H02 0007
Serial number: WOO1682829A
Coding: 801E00
Subsystem 4 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 12117001051021200181
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:57:26
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
01304 - Radio
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:58:21
Bin. Bits: 11111
Voltage: 13.60 V
Count: 6
Bin. Bits: 10000
Component: IMMO H02 0251
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 E HW: 8X0 959 793 E
Component: TSG FA H09 0410
Coding: 011E02205C00000000
VCID: 4FAB1FB91EE3A63750-801A
Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
Component: J500__APA-BS KL.374 1101
Revision: 1AH03837 Serial number: 00121400281101
Coding: 0000258
Shop #: WSC 80093 222 69422
VCID: 3D775571644F24A7B2-8068
02546 - Steering Limit Stop
Fault Status: 11100101
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:54:49
Term 15 On
RPM: 829 /min
(no units): 7.0
Voltage: 13.70 V
00566 - Steering Assistance Operation
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:54:49
Hex Value: 0x7301
Hex Value: 0x7601
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:54:49
(no units): 7.0
Steering Angle: 0.00°
Not OK
(no units): 5
01316 - ABS Control Module
Fault Status: 11101101
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:54:50
Term 15 On
RPM: 832 /min
(no units): 7.0
Voltage: 13.80 V
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 E HW: 8X0 959 792 E
Component: TSG BF H09 0410
Coding: 011E02201C00000000
VCID: 4E9502BD19E9AF3F5B-801A
Revision: H19 Serial number: 00000000269097
Coding: 0025157
VCID: 36654A5D4179F7FF73-8062
02844 - Lamp for Automatic Parking Function
009 - Open or Short to Ground
Fault Status: 01111001
Reset counter: 243
Mileage: 38075 km
Date: 2019.07.24
Time: 20:32:09
Voltage: 12.40 V
Count: 81
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
Fault Status: 01110000
Reset counter: 243
Mileage: 81069 km
Date: 2015.08.04
Time: 00:00:10
Voltage: 11.50 V
Count: 41
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
Fault Status: 01110101
Reset counter: 243
Mileage: 81069 km
Date: 2015.08.04
Time: 00:00:10
Voltage: 11.50 V
Count: 99
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
Fault Status: 01101101
Fault Frequency: 21
Reset counter: 243
Mileage: 81069 km
Date: 2015.08.04
Time: 00:00:11
Voltage: 11.40 V
Count: 69
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
Part No SW: 8X0 907 357 B HW: 8X0 907 357 A
Component: ****LWR12**** H02 0021
Serial number: 120612-0004-076
Coding: 1157961010022300
ROD: EV_HeadlRegulBasic.rod
VCID: 418F2981D0B74047D6-8014
0077 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Fault Frequency: 19
Reset counter: 243
Mileage: 81069 km
Date: 2015.08.04
Time: 00:00:12
0079 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Fault Frequency: 70
Reset counter: 243
Mileage: 37961 km
Date: 2019.07.23
Time: 00:00:26
0082 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 16
Reset counter: 28
Mileage: 38074 km
Date: 2019.07.24
Time: 18:43:18
0084 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 16
Reset counter: 28
Mileage: 38074 km
Date: 2019.07.24
Time: 18:43:18
0092 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 6
Reset counter: 28
Mileage: 38074 km
Date: 2019.07.24
Time: 18:43:18
Address 56: Radio
Part No SW: 8U0 035 193 B HW: 8U0 035 193 A
Component: RMC Cnct Nav H53 0775
Coding: 01000600028153070023020103010000000000
VCID: 346170559705E5EF4D-8060
Subsystem 1 - Part No: 8X0 919 884 L
Component: P41-50-17.03 0001
Subsystem 2 - Part No SW: 8U0 919 603 HW: 8U0 919 603
Component: DUBasic AU316 H41 0018
Serial number: AUZ8ZDC0601GRH
Part No SW: 8X0 959 795 A HW: 8X0 959 795 A
Component: TSG HL H06 0409
Coding: 010E02200000000000
VCID: 4D9705B114EF942722-8018
Address 6C: Back-up Cam.
Component: TSG HR H06 0409
End-------------------------(Elapsed Time: 03:31)--------------------------
Carlos Martins
