Audi Q3 2.0 TDI, problems with ABS and ESP after odometer changed
Carlos Martins
Portugal
C?ID=207605
Hello
I have original Ross Tech cable and yesterday I couldn’t put the correct coding of the module
03: ABS Brakes, Part No SW: 5N0 614 109 AE, HW: 5N0 614 109 AE, Component: J104 C6 450M V4F3 0120 . The car is an Audi Q3 2.0 TDI from 2012, with the Chassis Type: 8U-AU21 (8U0)
Somehow I find the Coding 0017525 or 0050308 and then I try to perform the zero position calibration for the Steering Angle Sensor (G85), but without success.
I didi t like your instructions.
Here is the full autoscan:
Wednesday,24,July,2019,21:01:03:16010
VCDS Version: 19.6.1.0
VIN: WAUZZZ8U2DR012626   License Plate:
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 55 56 5F 62 6C    72
VIN: WAUZZZ8U2DR012626   Mileage: 38070km-23655miles
   Part No SW: 03L 906 018 CN    HW: 03L 906 018 ES
   Component: R4 2.0l TDI   H28 9977
   Revision: 41H28---    Serial number:
   Coding: 00190032042401080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906018CN 003007
   ROD: EV_ECM20TDI01103L906018CN.rod
   VCID: 78F98465C3EDC18FA1-802C
4815 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [167] - -
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:47:01
                    Coolant temperature: 89 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 12.400 V
                    Requested transmission torque: 1000.0 Nm
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 234
                    selected gear-Bits 0-7: 0
                    Transmission torque intervention status-Bits 0-7: 0
                    Transmission torque intervention status-Bits 0-7: 4
                    Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
          U0415 00 [039] - -
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:46:57
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:46:57
                    Longitudinal acceleration: raw value: 32.767 m/s²
                    Vehicle inclination acceleration angle: raw value: -0.001 m/s²
                    Status: incline angle-Bits 0-7: 0
                    Longitudinal acceleration: 0.000 m/s²
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: 327.67 g
                    Vehicle lateral acceleration: 0.00 g
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AE    HW: 5N0 614 109 AE
   Revision: --H07---    Serial number: 00000005868330
   Coding: 0017525
   Shop #: WSC 00049 770 00155
   VCID: 6ED5A23D79A98F3F7B-803A
9 Faults Found:
                    Reset counter: 243
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00000001
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00000001
                    Count: 26
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
00810 - Sensor 1/2 for Brake Pressure
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
01542 - Yaw Rate Sensor (G202)
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:50:17
   Part No SW: 8U0 820 043 E    HW: 8U0 820 043 E
   Component: E87  Klimavoll      0100
   Revision: 00H04000    Serial number: 8U0820043E
   VCID: 33637349520BE2D754-8066
04000 - Function limitation due to crash signal
                    Reset counter: 252
                    Mileage: 71824 km
                    Date: 2018.07.24
                    Time: 14:13:36
01177 - Engine Control Unit
                    Fault Status: 00101101
                    Reset counter: 252
                    Mileage: 71824 km
                    Date: 2018.07.24
                    Time: 14:13:45
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 0
                    Temperature: 23.0°C
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                    Reset counter: 0
                    Temperature: 23.0°C
01853 - Heated Seat; Left Front (Z45)
                    Fault Status: 00101100
                    Reset counter: 5
                    Mileage: 37307 km
                    Date: 2019.07.10
                    Time: 12:53:18
                    Temperature: 26.5°C
Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
   Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
   Component: BCM PQ35  M   110 0667
   Revision: AE110667
   Coding: 0E000A2FE8251AC8605840C02100894C57FF84AA216F912AE408878400C5
   Shop #: WSC 00049 770 00010
   VCID: 44812095C7A5556FFD-8010
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 120509  H35 0085
   Serial number:         120604191526
   Coding: 0047F7
   Serial number: 20322643
   Coding: 02006E
Address 10: Park/Steer Assist (J791)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 P    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0030
   Revision: --------    Serial number: 56261216902675
   Coding: 280205
   Shop #: WSC 00049 770 00118
   ASAM Dataset: EV_EPHVA2CAU3160000 003003
   ROD: EV_EPHVA2CAU3160000_003.rod
   VCID: 53A313C93ACBC2D774-8006
13637393 - Databus
                    Fault Frequency: 9
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:28:01
13637396 - Databus
                    Fault Frequency: 11
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:28:01
13637397 - Databus
                    Fault Frequency: 16
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:28:01
Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
   Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
   Component: AirbagVW-AU10 H07 0520
   Serial number: 003LRR024TB
   Coding: 30333132313030303030554A304C38553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 46853A9DF999677FE3-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME5237251CZZZX
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME581D441CZZZ-
   Serial number: 3516KSME137A231CZZZS
   Serial number: 3526KSME1D37441CZZZZ
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME4F47091CZZZB
          U0155 00 [008] - -
                    Fault Frequency: 48
                    Reset counter: 28
                    Mileage: 38074 km
                    Date: 2019.07.24
                    Time: 18:43:17
12674816 - Immobilizer Control Module
          U0167 00 [008] - No Communications
                    Fault Frequency: 16
                    Reset counter: 28
                    Mileage: 38074 km
                    Date: 2019.07.24
                    Time: 18:43:18
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 H
   Revision: FF010017    Serial number: 20120620101195
   Coding: 1184204000
   VCID: 3B735B69B25B2A978C-806E
   Subsystem 1 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
1140738 - Steering angle sensor
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:28:59
                    UBat: 12.80 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
   Part No SW: 8U0 920 930 C    HW: 8U0 920 930 C
   Component: KOMBI_MEDIUM  H02 0251
   Coding: 12CF00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
   VCID: 377B47598E730EF768-8062
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 J    HW: 8U0 907 468 J
   Component: GAT 4CAN 2L M H13 0059
   Revision: 1R110032    Serial number: 3241R125170327
   Coding: FBCF1A5A050B05610253
   Shop #: WSC 05279 123 104857
   VCID: 499F31A1E08788070E-801C
   Subsystem 1 - Part No SW: 8U0 959 591     HW: 8V3 959 591
   Component: J245 PS11.018  H02 0007
   Serial number:     WOO1682856A
   Coding: 901E00
   Subsystem 2 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900567816
   Subsystem 3 - Part No SW: 8U0 959 591     HW: 8V3 959 591
   Component: J394 PS11.018  H02 0007
   Serial number:     WOO1682829A
   Coding: 801E00
   Subsystem 4 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Serial number: 12117001051021200181
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:57:26
                    Bin. Bits:    11111
                    Voltage: 13.60 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
01304 - Radio
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:58:21
                    Bin. Bits:    11111
                    Voltage: 13.60 V
                    Count: 6
                    Bin. Bits:    10000
   Component: IMMO          H02 0251
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011E02205C00000000
   VCID: 4FAB1FB91EE3A63750-801A
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.374 1101
   Revision: 1AH03837    Serial number: 00121400281101
   Coding: 0000258
   Shop #: WSC 80093 222 69422
   VCID: 3D775571644F24A7B2-8068
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:54:49
                    RPM: 829 /min
                    (no units): 7.0
                    Voltage: 13.70 V
00566 - Steering Assistance Operation
                    Fault Status: 11101000
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:54:49
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:54:49
                    (no units): 7.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 5
                    Fault Status: 11101101
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:54:50
                    RPM: 832 /min
                    (no units): 7.0
                    Voltage: 13.80 V
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   Coding: 011E02201C00000000
   VCID: 4E9502BD19E9AF3F5B-801A
   Revision:   H19       Serial number: 00000000269097
   Coding: 0025157
   VCID: 36654A5D4179F7FF73-8062
02844 - Lamp for Automatic Parking Function
            009 - Open or Short to Ground
                    Fault Status: 01111001
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 20:32:09
                    Voltage: 12.40 V
                    Count: 81
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01110000
                    Reset counter: 243
                    Mileage: 81069 km
                    Date: 2015.08.04
                    Time: 00:00:10
                    Voltage: 11.50 V
                    Count: 41
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01110101
                    Reset counter: 243
                    Mileage: 81069 km
                    Date: 2015.08.04
                    Time: 00:00:10
                    Voltage: 11.50 V
                    Count: 99
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01101101
                    Fault Frequency: 21
                    Reset counter: 243
                    Mileage: 81069 km
                    Date: 2015.08.04
                    Time: 00:00:11
                    Voltage: 11.40 V
                    Count: 69
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 8X0 907 357 B    HW: 8X0 907 357 A
   Component: ****LWR12**** H02 0021
   Serial number: 120612-0004-076
   Coding: 1157961010022300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 418F2981D0B74047D6-8014
0077 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Fault Frequency: 19
                    Reset counter: 243
                    Mileage: 81069 km
                    Date: 2015.08.04
                    Time: 00:00:12
0079 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Fault Frequency: 70
                    Reset counter: 243
                    Mileage: 37961 km
                    Date: 2019.07.23
                    Time: 00:00:26
0082 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 28
                    Mileage: 38074 km
                    Date: 2019.07.24
                    Time: 18:43:18
0084 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 28
                    Mileage: 38074 km
                    Date: 2019.07.24
                    Time: 18:43:18
0092 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 28
                    Mileage: 38074 km
                    Date: 2019.07.24
                    Time: 18:43:18
Address 56: Radio
   Part No SW: 8U0 035 193 B    HW: 8U0 035 193 A
   Component: RMC Cnct Nav  H53 0775
   Coding: 01000600028153070023020103010000000000
   VCID: 346170559705E5EF4D-8060
   Subsystem 1 - Part No: 8X0 919 884 L
   Component: P41-50-17.03  0001
   Subsystem 2 - Part No SW: 8U0 919 603     HW: 8U0 919 603
   Component: DUBasic AU316  H41 0018
   Serial number: AUZ8ZDC0601GRH
   Part No SW: 8X0 959 795 A    HW: 8X0 959 795 A
   Component: TSG HL        H06 0409
   Coding: 010E02200000000000
   VCID: 4D9705B114EF942722-8018
Address 6C: Back-up Cam.
   Component: TSG HR        H06 0409
End-------------------------(Elapsed Time: 03:31)--------------------------
So could someone tell me the correct coding for the Audi Q3 2.0 TDI, from 2012, with the VIN WAUZZZ8U2DR012626 ?
All this problems emerged when my cliente change the odometer for another one with color display and then he put the original dasboard and even with it I couldn’t perform the G85 and I get many problems at the ABS anda t the Steering Wheel
So I guess that if i find out the right coding for the ABS then I could perform the zero position calibration for the Steering Angle Sensor (G85) with success.
Thank you and regards from Portugal
Carlos Martins
Which cluster is in the car now? New color one or original one?
Dana
Western PA, USA
Hi Carlos,
We received a few scans via email from you today so I'll paste the complete one here:
VCDS -- Windows Based VAG/VAS Emulator Running onWindows 7 x86
         72
6C-Back-up Cam. -- Status: Cannot be reached 1100
         U1017 00 [167] - -
         [New feature! Extended UDS fault detail is onlysupported by current gen. interfaces]
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:47:01
                   Calculated reducing transmission interventiontorque: 1000.0 Nm
14413 - Implausible Data Received from ABS ControlModule
         U0415 00 [039] - -
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:46:57
         U1113 00 [039] - -
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:46:57
  Coding: 0017525
9 Faults Found:
                   Reset counter: 243
                   Speed: 252.0 km/h
                   Hex Value: 0x0000
                   Voltage: 12.25 V
                   Bin. Bits: 00000001
                   Count: 215
                   Hex Value: 0x0000
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Hex Value: 0x0000
                   Voltage: 12.25 V
                   Bin. Bits: 00000001
                   Count: 26
                   Hex Value: 0x0000
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:50:17
                   Reset counter: 252
                   Mileage: 71824 km
                   Date: 2018.07.24
                   Time: 14:13:36
                   Reset counter: 252
                   Mileage: 71824 km
                   Date: 2018.07.24
                   Time: 14:13:45
01855 - Temperature Sensor for Heated Seat; Left Front(G344)
                   Reset counter: 0
                   Temperature: 23.0°C
01856 - Temperature Sensor for Heated Seat; Front Right(G345)
                   Reset counter: 0
                   Temperature: 23.0°C
                   Reset counter: 5
                   Mileage: 37307 km
                   Date: 2019.07.10
                   Time: 12:53:18
                   Temperature: 26.5°C
  Revision: AE110667
  Coding: 0047F7
  Coding: 02006E
  Coding: 280205
13637393 - Databus
                   Fault Frequency: 9
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:28:01
13637396 - Databus
                   Fault Frequency: 11
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:28:01
13637397 - Databus
                   Fault Frequency: 16
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:28:01
         U0155 00 [008] - -
                   Fault Frequency: 48
                   Reset counter: 28
                   Mileage: 38074 km
                   Date: 2019.07.24
                   Time: 18:43:17
                   Fault Frequency: 16
                   Reset counter: 28
                   Mileage: 38074 km
                   Date: 2019.07.24
                   Time: 18:43:18
  Coding: 1184204000
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:28:59
                   UBat: 12.80 V
  Coding: 12CF00
  Coding: 901E00
  Coding: 801E00
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:57:26
                   Bin. Bits:    11111
                   Voltage: 13.60 V
                   Count: 6
                   Bin. Bits:    10000
                   Time: 25.40 s
01304 - Radio
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:58:21
                   Bin. Bits:    11111
                   Voltage: 13.60 V
                   Count: 6
                   Bin. Bits:    10000
  Coding: 000002
  Coding: 0000258
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:54:49
                   RPM: 829 /min
                   (no units): 7.0
                   Voltage: 13.70 V
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:54:49
                   Hex Value: 0x7301
                   Hex Value: 0x7601
                   Hex Value: 0x0000
                   Hex Value: 0x0000
                   Hex Value: 0x0000
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:54:49
                   (no units): 7.0
                       Not OK
                   (no units): 5
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:54:50
                   RPM: 832 /min
                   (no units): 7.0
                   Voltage: 13.80 V
  Coding: 0025157
                   Reset counter: 243
                   Mileage: 38075 km
                   Date: 2019.07.24
                   Time: 20:32:09
                   Voltage: 12.40 V
                   Count: 81
                   Hex Value: 0x1250
                   Hex Value: 0x0001
                   Hex Value: 0x0101
                   Reset counter: 243
                   Mileage: 81069 km
                   Date: 2015.08.04
                   Time: 00:00:10
                   Voltage: 11.50 V
                   Count: 41
                   Hex Value: 0x1240
                   Hex Value: 0x0001
                   Hex Value: 0x0101
                   Reset counter: 243
                   Mileage: 81069 km
                   Date: 2015.08.04
                   Time: 00:00:10
                   Voltage: 11.50 V
                   Count: 99
                   Hex Value: 0x1240
                   Hex Value: 0x0001
                   Hex Value: 0x0101
                   Fault Frequency: 21
                   Reset counter: 243
                   Mileage: 81069 km
                   Date: 2015.08.04
                   Time: 00:00:11
                   Voltage: 11.40 V
                   Count: 69
                   Hex Value: 0x1250
                   Hex Value: 0x0001
                   Hex Value: 0x0101
         U1113 00 [137] - -
                   Fault Frequency: 19
                   Reset counter: 243
                   Mileage: 81069 km
                   Date: 2015.08.04
                   Time: 00:00:12
         U1113 00 [137] - -
                   Fault Frequency: 70
                   Reset counter: 243
                   Mileage: 37961 km
                   Date: 2019.07.23
                   Time: 00:00:26
         U1111 00 [008] - -
                   Fault Frequency: 16
                   Reset counter: 28
                   Mileage: 38074 km
                   Date: 2019.07.24
                   Time: 18:43:18
         U1111 00 [008] - -
                   Fault Frequency: 16
                   Reset counter: 28
                   Mileage: 38074 km
                   Date: 2019.07.24
                   Time: 18:43:18
         U1111 00 [008] - -
                   Reset counter: 28
                   Mileage: 38074 km
                   Date: 2019.07.24
                   Time: 18:43:18
Address 56: Radio
This one is far more complete than the one in post #1. I'll report back if I have any coding suggestions.
Dana
Western PA, USA
Continued. The coding was configured for a Q3, but one with that was AWD with 7-Speed Automatic [PR-G1D]
I believe the proper 03-ABS coding is: 0050308
Vehicle Identification No. WAUZZZ8U2DR012626
Model Audi Q3 2.0 TDI
AQ3
Date of production 28.06.2012
Model year 2013
Sales type 8UB0FC
Engine Code CFFB
Transmission Code NFZ
G0K 6-speed manual transmission
1X0 Front-wheel drive
7X5 Park assist
UG1 Hill hold control
7L6 Start/stop system with brake energy recovery
L0L Left-hand drive
C484 | 0050308
Carlos Martins
Portugal
C?ID=207605
l already tried that coding but I don't know where to start in order to erase all that errors.
Performing G85 many times and always without success
Do you have any clue please?
Must I follow any order?
I don't know what to do, The original instrument cluster is already in place but the errors in 03 Brakes are persistent...
Dana
Western PA, USA
The scan with 03 coded to 0050308 may help us but the exact order of Basic Settings is located on this page:
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics
If G85 won't calibrate I would skip it and move onto the other Basic Settings. Although it is the preferred method, you don't necessarily need to follow the exact order on that page.
P.S. This Q3 is built on the 5N Tiguan platform and the G85 position may be confirmed via BEEPing of the instrument cluster after you hold the steering to the extreme right and left lock stop for 10+ seconds in each direction. If the ABS based G85 calibration is not working properly when the module is otherwise fault-free I would test drive the vehicle followed by that end-stop procedure to see if that doesn't resolve the issues.
Carlos Martins
Portugal
C?ID=207605
Thank you Dana you have been a great help. Later tonight I will try your helpfull tips.
However I have one doubt: After get the security access by code 50403, adaptation enabling, on Adaptation, Channel 021 wich one shoud I select, 4 or 7?
Ando n Channel 061 shoud I choose 0 or 1?
Because the engine code and the transmission code doesn’t match with any option avaiable.
Again, let me tell you and other great members of this fórum how gratefull I am.
Thank you
Dana
Western PA, USA
Thanks for the kind words.
Looks like I failed to include this in your list of PR-Codes above:
D91 4-cyl. turbo diesel engine 2.0 l/103 kW (4V) TDI common rail; Base engine: TG3/TJ3/TU3/TU4/TL4/TP4/TM3/TW3/TR4/TS1/TN5
Channel 021: Overboost Level = 7
Channel 061: Hydraulic Brake Reinforcement = 0
Carlos Martins
Portugal
C?ID=207605
You are fantastic!
Carlos Martins
Portugal
C?ID=207605
Another try, another failure. :(
Here is the later autoscan:
Friday,26,July,2019,19:01:57:16010
          72
VIN: WAUZZZ8U2DR012626   Mileage: 38300km-23798miles
04-Steering Angle -- Status: Cannot be reached 1100
17-Instruments -- Status: Sporadic communication error 1000
4729 - Steering Effort Control Module
          U0130 00 [047] - No Communications
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:25:25
                    Engine speed: 829.50 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 97 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 12.240 V
                    Cruise Control System (CCS): status-Bits 0-7: 40
   Component: J104   C6 450M V4F7 0120
   Coding: 0050308
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:53:54
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:53:54
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:54:39
                    Speed: 2.0 km/h
                    Hex Value: 0x0000
                    Voltage: 12.50 V
                    Bin. Bits: 00011110
                    Count: 219
                    Hex Value: 0x0000
                    Reset counter: 0
                    Temperature: 23.0°C
                    Reset counter: 0
                    Temperature: 23.0°C
   Revision: AE110667
   Coding: 0E000A2FE8251AC8605860C02100894C57FF84AA216F912AE408878400C5
   Coding: 0047F7
   Coding: 02006E
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:53:16
                    Voltage: 12.05 V
                        Term 50 On
   Coding: 280204
13637396 - Databus
                    Fault Frequency: 20
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:28:39
13637397 - Databus
                    Fault Frequency: 19
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:28:39
   Coding: 1084204000
   ROD: EV_SMLSNGVOLWS.rod
   Coding: 12CF00
   Coding: 901E00
   Coding: 801E00
6 Faults Found:
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 00:07:03
                    Bin. Bits:    10111
                    Voltage: 12.10 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
01304 - Radio
                    Reset counter: 243
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 00:07:58
                    Bin. Bits:    10111
                    Voltage: 12.10 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 247
                    Mileage: 38075 km
                    Date: 2019.07.24
                    Time: 23:02:43
                    Bin. Bits:    11111
                    Voltage: 13.40 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 21.60 s
                    Reset counter: 28
                    Mileage: 38076 km
                    Date: 2019.07.24
                    Time: 23:20:20
                    Bin. Bits:    10111
                    Voltage: 12.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 28
                    Mileage: 38076 km
                    Date: 2019.07.24
                    Time: 23:20:20
                    Bin. Bits:    10111
                    Voltage: 12.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 28
                    Mileage: 38092 km
                    Date: 2019.07.25
                    Time: 10:24:34
                    Bin. Bits:    10000
                    Voltage: 11.30 V
                    Count: 17
   Coding: 000002
   Coding: 0000258
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:23:09
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:55:36
                    (no units): 4.0
                    Voltage: 12.10 V
                    Fault Frequency: 22
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:23:09
                    RPM: 828 /min
                    (no units): 7.0
                    Voltage: 12.20 V
                    Fault Status: 11100100
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:25:25
                    RPM: 829 /min
                    (no units): 7.0
                    Voltage: 12.20 V
   Coding: 0025157
                    Reset counter: 247
                    Mileage: 38305 km
                    Date: 2019.07.26
                    Time: 18:42:24
                    Voltage: 12.10 V
                    Count: 81
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 247
                    Mileage: 81069 km
                    Date: 2015.08.04
                    Time: 00:00:10
                    Voltage: 11.50 V
                    Count: 41
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 110
                    Reset counter: 247
                    Mileage: 81069 km
                    Date: 2015.08.04
                    Time: 00:00:11
                    Voltage: 11.40 V
                    Count: 104
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
          U1113 00 [137] - -
                    Fault Frequency: 35
                    Reset counter: 247
                    Mileage: 38303 km
                    Date: 2019.07.26
                    Time: 18:00:26
Address 56: Radio
End-------------------------(Elapsed Time: 03:30)--------------------------
I don't know what's I'm doing wrong.
When I make one turn to the right, I must make 2 turns to the left or just one? Because if I just make one turn the car will go straight and won't turn to the left
I mean: I must turn 360º to the right and then 360º to the left ang go in straight line?
It is possible that I'm doing something wrong?
Dana
Western PA, USA
I don't think you are doing anything wrong procedure-wise Carlos. This is not normal:
The steering angle is inside the slip ring which is Address 16: Steering wheel (J527). It is coded incorrectly (G85 not installed) in this scan:
Coding: 1084204000
It was coded correctly earlier:
Coding: 1184204000
I would code 16 back to 1184204000. Doing so should resolve the lack-of G85.
Next, the rear wheel speed sensor faults make me question the ABS coding. Either that, or someone installed a pair of incorrect WSS sensors resulting in those Incorrect Signal DTCs. Are you absolutely positive there weren't any other repairs to this car? I would want to take a look at the rear wheel speed sensors and rear axle parts in general just to make sure we aren't missing repair history.
P.S. You might want to also find out why the cluster was swapped. If it was just in an attempt to upgrade/retrofit that's perfectly fine but if the old unit was damaged in some way that may he helpful because the newest scan has a bunch of Sporadic communication errors.
Carlos Martins
Portugal
C?ID=207605
Dana, as far as I know the car was running fine untill my client/friend swap the cluster for one with color display with the part number 8U0 920 940H.
Today mu friend told me that the engine was replaced at Audi dealer some months ago. But i know for sure that he hadn't this kind of problems before.
One week ago he changed the Auto HVAC for another one with Heated seats, altrought he didn't wired the heated seats.
Today i get this autoscan:
Saturday,27,July,2019,13:30:04:16010
          72
VIN: WAUZZZ8U2DR012626   Mileage: 38340km-23823miles
04-Steering Angle -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Malfunction 1010
53-Parking Brake -- Status: Malfunction 1010
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:56
                    Vehicle speed: 255 km/h
                    Coolant temperature: 78 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 12.060 V
4713 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
                    Voltage terminal 30: 12.080 V
4716 - No Communications with Parking Brake Control Module
          U0128 00 [032] - -
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
          U0130 00 [044] - No Communications
                    Mileage: 38307 km
                    Date: 2019.07.26
                    Time: 19:47:33
                    Engine speed: 830.50 /min
                    Normed load value: 12.5 %
                    Coolant temperature: 102 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 13.400 V
   Coding: 0050308
                    Reset counter: 247
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:17:57
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 27
                    Hex Value: 0x0000
                    Reset counter: 32
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:17:57
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 156
                    Hex Value: 0x0000
                    Reset counter: 247
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:18:39
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011110
                    Count: 26
                    Hex Value: 0x0000
                    Reset counter: 247
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:18:42
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011110
                    Count: 157
                    Hex Value: 0x0000
                    Reset counter: 247
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:18:42
                    Reset counter: 0
                    Temperature: 23.0°C
                    Reset counter: 0
                    Temperature: 23.0°C
   Revision: AE110667
   Coding: 0047F7
   Coding: 02006E
10 Faults Found:
                    Reset counter: 32
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:31:02
                    Voltage: 13.75 V
                        Term 50 On
                    Fault Status: 00101010
                    Reset counter: 32
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:39:54
                    Voltage: 13.60 V
                        Term 50 On
                    Reset counter: 32
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:43:00
                    Voltage: 13.20 V
                        Term 50 On
                    Reset counter: 247
                    Mileage: 38307 km
                    Date: 2019.07.26
                    Time: 19:51:15
                        Term 15 Off
                    Voltage: 13.00 V
                        Term 50 Off
                    Reset counter: 247
                    Mileage: 38307 km
                    Date: 2019.07.26
                    Time: 19:51:15
                        Term 15 Off
                    Voltage: 13.00 V
                        Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:19:25
                        Term 15 Off
                    Voltage: 12.25 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:19:33
                        Term 15 Off
                    Voltage: 12.25 V
                        Term 50 Off
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:56
                    Voltage: 11.90 V
                        Term 50 On
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:56
                    Voltage: 11.90 V
                        Term 50 On
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:56
                    Voltage: 11.90 V
                        Term 50 On
   Coding: 280204
8 Faults Found:
12658720 - Databus
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
12656928 - Databus
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
12656929 - Databus
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
12656930 - Databus
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
12656931 - Databus
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
12656933 - Databus
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
13637396 - Databus
                    Fault Frequency: 18
                    Reset counter: 247
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:03:32
13637397 - Databus
                    Fault Frequency: 24
                    Reset counter: 247
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:03:32
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
   Coding: 1184204000
                    Reset counter: 247
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:17:03
                    UBat: 12.50 V
   Coding: 12CF00
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
12658688 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
   Coding: 901E00
   Coding: 801E00
6 Faults Found:
                    Reset counter: 247
                    Mileage: 38323 km
                    Date: 2019.07.26
                    Time: 00:00:04
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 4.90 s
                    Reset counter: 32
                    Mileage: 38323 km
                    Date: 2019.07.26
                    Time: 00:00:49
                    Bin. Bits:    00111
                    Voltage: 12.10 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
01304 - Radio
                    Reset counter: 247
                    Mileage: 38323 km
                    Date: 2019.07.26
                    Time: 00:01:49
                    Bin. Bits:    01111
                    Voltage: 13.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:56
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Coding: 000002
                    Fault Status: 00111100
                    Reset counter: 247
                    Mileage: 38310 km
                    Date: 2019.07.26
                    Time: 20:12:10
   Coding: 0000258
6 Faults Found:
                    Reset counter: 247
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:27:27
                    (no units): 4.0
                    Voltage: 12.20 V
                    Fault Frequency: 23
                    Reset counter: 32
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:20:06
                    RPM: 830 /min
                    (no units): 7.0
                    Voltage: 13.80 V
                    Fault Frequency: 32
                    Reset counter: 247
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:20:07
                    RPM: 826 /min
                    (no units): 7.0
                    Voltage: 13.80 V
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
                    Speed: 50.0 km/h
                    (no units): 5.0
                    Voltage: 12.00 V
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
                    Speed: 50.0 km/h
                    (no units): 5.0
                    Voltage: 12.00 V
                    Reset counter: 247
                    Mileage: 38346 km
                    Date: 2019.07.27
                    Time: 13:27:30
                    (no units): 4.0
                        Not OK
                    (no units): 13
   Coding: 0025167
                    Reset counter: 247
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:34:21
                    Voltage: 13.80 V
                    Count: 81
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 247
                    Mileage: 81069 km
                    Date: 2015.08.04
                    Time: 00:00:10
                    Voltage: 11.50 V
                    Count: 41
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 29
                    Reset counter: 247
                    Mileage: 38306 km
                    Date: 2019.07.26
                    Time: 19:03:32
                    Voltage: 12.10 V
                    Count: 105
                    Speed: 10.0 km/h
                    Hex Value: 0x1270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
02779 - Databus for Electric Parking Brake
                    Reset counter: 31
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
                    Voltage: 12.00 V
                    Count: 62
                    Hex Value: 0x1260
                    Hex Value: 0x0082
                    Hex Value: 0x0101
0074 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
0076 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
0078 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:20:55
          U1113 00 [137] - -
                    Fault Frequency: 16
                    Reset counter: 247
                    Mileage: 38307 km
                    Date: 2019.07.26
                    Time: 19:54:35
Address 56: Radio
03278 - Functionality Limited due to Missing Messages
                    Reset counter: 32
                    Mileage: 38329 km
                    Date: 2019.07.27
                    Time: 11:21:02
                    Bin. Bits: 00001101 00000000
End-------------------------(Elapsed Time: 10:48)--------------------------
I'm out of solutions and already spent many hours around the car. For sure I can't get rid of the G85 problem and the problems with both rear ABS sensors remain.
It it possible that the swap of the cluster frozzen some module? Is it possible that I have entered the wrong ABS coding? If so, what would be the right one?
Don't know what else I can do.
Many thanks for all the time you are consuming with me.
PetrolDave
Westbury, UK
C?ID=1423
Does the car have "Park Pilot" (or whatever the Audi name is for self parking)? If so check whether the rear ABS sensors are the correct ones as on many cars there are 2 versions of the rear ABS sensors.
Carlos Martins
Portugal
C?ID=207605
Yes the car has Park Assist (10). Could you advise how can i check if the ABS sensors are the correct ones?
Because, before the swap all was working good.
PetrolDave
Westbury, UK
C?ID=1423
Using ETKA with your VIN number entered, check the ABS sensor part number shown matches those fitted to the car.
Carlos Martins
Portugal
C?ID=207605
Unfortunatly I don't have ETKA anymore :(
Dana
Western PA, USA
Hi Carlos. Dave and I are driving at the same thing in regards to those rear WSS part numbers. According to PL24 by VIN the vehicle should have had:
Left rear: WHT 003 859 A which supers to WHT 003 859 B
Right Rear: WHT 003 858 A which supers to WHT 003 858 B
Those are for PR-Code 7X5
Next, as far as the 03-ABS coding is concerned the only other possible coding I can suggest is 0050564. If you haven't sent the car off I would try that before pulling rear wheels and investigating the WSS part numbers.
I cannot locate a baseline Q3 scan coded to 0050564 so do let us know the results even if it doesn't fix the car.
siLc
Tallinn, Estonia
C?ID=330192
"Park Assist (10)" is the parking assist module's generic name and shouldn't be taken as an indication whether the car has self-parking or not as the basic 4 and 8 channel parking assist modules are under the same generic name. You should be looking at the module description, which states:
   Coding: 280204
If acronym "PLA" is present, the module is of the self-parking variety.
Carlos Martins
Portugal
C?ID=207605
Hi
Your ABS coding did work. Many thanks. I believe I'm going in the right direction with your precious help.
However I get one error at ABS when 70km/h is reached and I don't understand why
Thursday,01,August,2019,18:58:11:16010
          72
VIN: WAUZZZ8U2DR012626   Mileage: 38840km-24134miles
   Component: J104   C6 450M V401 0120
   Coding: 0050564
00301 - ABS Return Flow Pump (V39)
                    Fault Frequency: 16
                    Reset counter: 1
                    Mileage: 38756 km
                    Date: 2019.07.31
                    Time: 19:17:32
                    Speed: 87.0 km/h
                    Hex Value: 0x0001
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 71
                    Hex Value: 0x0000
                    Reset counter: 0
                    Temperature: 23.0°C
                    Reset counter: 0
                    Temperature: 23.0°C
   Revision: AE110667
   Coding: 0047F7
   Coding: 02006E
                    Reset counter: 254
                    Mileage: 38753 km
                    Date: 2019.07.31
                    Time: 19:12:16
                    Voltage: 12.20 V
                        Term 50 On
                    Reset counter: 254
                    Mileage: 38753 km
                    Date: 2019.07.31
                    Time: 19:12:16
                    Voltage: 12.20 V
                        Term 50 On
                    Fault Frequency: 13
                    Reset counter: 41
                    Mileage: 38771 km
                    Date: 2019.07.31
                    Time: 19:36:22
                    Voltage: 13.55 V
                        Term 50 On
                    Fault Frequency: 15
                    Reset counter: 41
                    Mileage: 38771 km
                    Date: 2019.07.31
                    Time: 19:36:47
                    Voltage: 13.60 V
                        Term 50 On
   Coding: 080204
   Coding: 1184204000
   Coding: 12CF00
   Coding: 901E00
   Coding: 801E00
                    Reset counter: 254
                    Mileage: 38753 km
                    Date: 2019.07.31
                    Time: 19:09:52
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
01304 - Radio
                    Reset counter: 254
                    Mileage: 38753 km
                    Date: 2019.07.31
                    Time: 19:10:47
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    10000
   Coding: 000002
   Coding: 0000258
   Coding: 0025166
   Coding: 1157961010003300
Address 56: Radio
The ABS error is new and never seen that before on Audi Q3:
This error go away when ignition is off but when the car is running faster than 70 km/h the error appear again
Can anyone help me, please?
Regards from Portugal
