Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: 18 GTI EPC light after manual swap
  1. #21
    Mar 2019
    New Zealand
    Try:
    01FA93A13424217547800607E0CAA980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
    Doesn't like it unfortunately, I get
    coding rejected
    error 13
    incorrect message length or invalid format
  2. #22
    Quote Originally Posted by racofuy View Post
    Doesn't like it unfortunately, I get coding rejected error 13, incorrect message length or invalid format
    Exactly, because the length of the first Coding I posted, should be correct.
    Cleared the login attempts and code S12345 now works.
    When pasting the new long code and entering "do it" I get error message
    Long code must be same length or have same number of hexdecimal characters.
    What error message is that, please post a screen shot.
  3. #23
    Mar 2019
    New Zealand
    Ok just tried your original code again and for what ever reason accepts it now but doesn't seem to "stick"
    Took shots as I went through the process[IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Then click ok,
    close controller - go back. switch off and wait.
    Turn on ign and re scan
    [IMG][/IMG]
  4. Likes Uwe liked this post
  5. #24
    It looks changed to me, make a new Autoscan and post it.
  6. Likes Uwe liked this post
  7. #25
    Mar 2019
    New Zealand
    Ok so I did autoscan, cleared and re scan.
    Results below,
    Tuesday,06,August,2019,07:46:14:41053
    VCDS Version: 19.6.1.0 (x64)
    Workshop Code: 666 12345 054321
    VIN: WVWZZZAUZJW149977   License Plate:
    Mileage: 110km-68mi   Repair Order:
    Chassis Type  AU-VW37 (3Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 4B 52 5F A5 A9
    VIN: WVWZZZAUZJW149977   Mileage: 110km-68miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
       Revision: --H13---
       Coding: 091900322444050B2000
       Shop #: WSC 12345 666 54321
       ROD: EV_ECM20TFS0205G0906259C.rod
       VCID: 2E53F94F71B7183F3B-807A
    17169 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:08
                        Coolant temperature: 13 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 12.246 V
                        ACC variants (coding): ACC
                        CCS Switch: ACC operating unit
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        ACC variants: ACC with Stop & Go
                        Engine: operating status: ES
    Readiness: 1110 0001
       Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
       Component: ESC           H25 0523
       Revision: 00000000    Serial number: 63257000001151
       Coding: 01FA93A13424217547800607E0CAA980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
       VCID: 030578FB8AB5455784-8056
    8277 - Databus
              U1122 00 [009] - Implausible Message
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [009] - -
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
       Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
       Revision: 00001K08
       Coding: 0012000420010000110500001210142A
       VCID: 6CD73347872BAA2F55-8038
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
                        Outside air temperature: 12.0 °C
                        Engine speed: 0 /min
                        Temperature after evaporator: 14.0 °C
                        System run time-Terminal 15 on: 255 s
       Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H36 0253
       Serial number: 01001733200812
       ROD: EV_BCMBOSCH_018.rod
       VCID: 081F6FD7B393660FD1-805C
       Component: WWS    171102  042 0551
       Serial number:         171111033250
       Component: RLHS  047 0105
       Serial number: S9Y17M11D29H15M39S32
       Coding: 00A8DD
       Serial number: 000000000ZY173000GUM
       Serial number: 00000000000000046658
    555797 - Databus
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:12
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617320
       Coding: 0371167841
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 50AF87B70B436ECF49-8004
    13697025 - Control Module
              U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:10
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 2B0067C315FFC728949C810580400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E73C90FA1D7E8BFAB-806A
    0803 - Databus
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
                        Voltage terminal 15: 12.2 V
                        Status_ACC_System: ACC_irreversible error
    0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
    2119 - Databus
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
    2068 - Databus
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Serial number: 003VWR3LSKF8
       Coding: 98CCC000000000005C000000008800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 09196AD3A8991F07CE-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E06021851041
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E07021850200
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 411 17
       Serial number: 357000000000A84D882P
       Subsystem 4 - Part No SW: -----------    HW: 480 002 411 17
       Serial number: 3580000000045C09882L
       Subsystem 5 - Part No SW: -----------    HW: 480 402 411 17
       Serial number: 3510001C72839D06B588
       Subsystem 6 - Part No SW: -----------    HW: 480 402 411 17
       Serial number: 3520001C92839D03357%
       Subsystem 7 - Part No SW: -----------    HW: 480 402 611 17
       Serial number: 3550001AB2796E02E64D
       Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 23111704401267
       Coding: 0C00
       VCID: 050166E384817B67AA-8050
       Part No SW: 5G1 920 756 C    HW: 5G1 920 756 C
       Component: KOMBI         302 0310
       Coding: 27AD19006F88000801886B0B5401000000000000
       VCID: 2D51FE437CB1632702-8078
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007086889
       Coding: 030100347F085800FB00027C1C0F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF.rod
       VCID: 387FDF1783F3D68F61-806C
       Serial number: 29170002540300097446
       Coding: 2DFFFF
       Serial number: 2952266004
    8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
              B114E 96 [009] - Component internal failure
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
                        Supply voltage: Terminal 30: 12.0 V
                        Terminal 15: On
    8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
              B114F 96 [009] - Component internal failure
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
                        Terminal 15: On
              U1101 00 [009] - Active
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
                        Terminal 15: On
       Component: HRE_Master    H12 0080
       Serial number: 0460702225
       Coding: 02031203
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D71CE03ACD1F3A7B2-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0460293131
       Coding: 020312
       Serial number: 071117EK510734
       Coding: 003E02208801048100001001
       VCID: 4385B8FBCA358557C4-8016
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 00020000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3B75C01BB2C5FD978C-806E
    Address 4B: Multifunc. Module
    Interface not compatible.
       Serial number: 121117EKA33711
       Coding: 003E00208E01048100801000
       VCID: 428BBDFFD52F8C5FCF-8016
       Part No SW: 3Q0 035 846     HW: 3Q0 035 846
       Component: MU-S-N-ER     H24 0245
       Serial number: VWZAZ2R0642410
       Coding: 02730008FF00000051510001001828001F0203D601200100C7
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 6ED3394FB137583F7B-803A
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHT3234340
              B201A 00 [009] - -
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:08
                        Voltage terminal 30: 12.3 V
                        Status_Software_Version_Management-module_name: D
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H07 0272
       Serial number: 27111712P21176
       Coding: 000307000000040100020050C150A80088000E200020
       VCID: 3C77C307B7CBFAAF85-8068
    0646 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
                        Control Module temperature: 18 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 313.3 s
                        Voltage terminal 15: 12.1 V
                        mid: 00 29
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    0659 - Steering
              C10AC F2 [009] - Lane-Holding Assistance Not Coded
                        Reset counter: 23
                        Mileage: 110 km
                        Date: 2019.08.06
                        Time: 07:43:09
                        System run time: 313.9 s
                        mid: 02 A6
                        Status of camera: System malfunction
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Serial number: 171013203235
       VCID: 6BD5305B8225AD175C-803E
    End-------------------------(Elapsed Time: 04:27)--------------------------
  8. #26
    The Coding in ABS is changed, there are no "other DTC" appeared in ABS, from that new coding.
    If the engine control module can be used for man. transmission, maybe eeprom must be changed (tuner).
    I would suggest Remove Battery, for maybe 20 min.
    Remove Component Protection.
  9. Likes Uwe liked this post
  10. #27
    Mar 2019
    New Zealand
    Thank you for all your help, I'll disconnect battery today.
    Next a visit to the dealer to get CP removed.
    I want to go stg 1 anyway so you suggest maybe flashing ecu with a manual file if possible?
  11. #28
    Fix ALL the faults BEFORE flashing the engine ECU
  12. Likes Uwe liked this post
