Results 11 to 20 of 28
Thread: 18 GTI EPC light after manual swap
    Feb 2018
    SLC
    As far as the Engine Control Module Incorrectly Coded Fault, I would check the Engine coding, more specifically the Cruise Control section, as it might need to be adjusted now that ACC w/ Stop&Go is no longer a valid configuration
    Also, the bytes controlling ACC and transmission type in the ABS controller might need to be updated as well
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
  2. #12
    Quote Originally Posted by racofuy View Post
    Any further input appreciated
    I have some guesses for ABS Coding, but am not 100%, do you want to test ABS coding ?
    There is also engine coding.
  3. #13
    [01-Engine] Coding
    091900322444010B2000
    Maybe with speed limiter, the 2 man. I have scan on are 05 for Byte 6
    091900322444050B2000
    [03-ABS] Coding
    019334214706E0A980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
    Yes it must be shorter!
    Copy this clb file, to c:\Ross-Tech\VCDS\Labels\User
    [03-ABS]
    [Security Access - 16]
    Enter: S12345
    [Do It!]
    [Coding - 07]
    Paste:
     019334214706E0A980C92C84E26007957734405038C2A9430B00000012121212B835351919323200 to "New coding"
    [Do It!]
  4. Likes Uwe liked this post
  5. #14
    Mar 2019
    New Zealand
    [01-Engine] Coding
    [03-ABS] Coding
    [03-ABS]
    Enter: S12345
    [Do It!]
    [Coding - 07]
    Paste:
    [Do It!]
    Thank you, the engine ecu code accepted but fault code remains.
    The ABS controller did not accept the login code so could not enter new long code.
  6. #15
    It should. What is the return message ?
    You write exactly as it is shown: S12345
    Check Adv. Meas Values, in search field`, write: "323" or "security", is it zero ?
    Is 40168 accepted ?
    You have battery charger connected ?
    Normally if a know login is not accepted, Stop VCDS, Ign. OFF for 10-20 sec., Ign. ON, try again.
  7. #16
    Mar 2019
    New Zealand
    I'll try again tomorrow, the message was something like the controller rejected....., must be 5 numeric digits.
    I'll try the same again otherwise the 40168
    Appreciate your help.
    I'll update tomorrow.
  8. #17
    In general, I would recommend to upgrade your VCDS interface to the new version.
  9. #18
    Mar 2019
    New Zealand
    Yes agree with you, its on my "to get" list.
    Back to this, no login and checked 323 its sitting at 3
    Leaving key off makes no difference, is there another way to clear this?
    Battery charger is connected.
  10. #19
    Mar 2019
    New Zealand
    Cleared the login attempts and code S12345 now works.
    When pasting the new long code and entering "do it" I get error message
    Long code must be same length or have same number of hexdecimal characters.
    Currently trying to obtain an autoscan from a manual version of this car.
    Finding owners is no problem however no one so far has vcds.
  11. #20
    Try:
    01FA93A13424217547800607E0CAA980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
  12. Likes Uwe liked this post
