18 GTI EPC light after manual swap
racofuy
New Zealand
C?ID=197081
Working through the various fault codes today, many codes resolved after calibrating G85 and setting steering end stops.
Some remaining codes are easily resolved, A/C low pressure (requires gassing up)
Component protection still needs removing from sat nav install, ACC sensor needs calibrating at dealership.
This leaves me with the main one, the EPC light....
ABS says engine control unit coded wrong but cant see why, I've removed / un ticked the auto trans everywhere that I can see but maybe I'm missing something?
Thursday,25,July,2019,13:51:28:41053
VCDS Version: 19.6.0.2 (x64)
Workshop Code: 666 12345 054321
VIN: WVWZZZAUZJW149977   License Plate:
Mileage: 41km-25mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 4B 52 5F A5 A9
VIN: WVWZZZAUZJW149977   Mileage: 41km-25miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   Coding: 091900322464010B2000
   Shop #: WSC 12345 666 54321
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E53F94F71B7183F33-807A
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
                    Coolant temperature: 52 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.050 V
                    ACC variants (coding): ACC with braking until at standstill/Stop & Go
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    ACC variants: ACC with Stop & Go
                    Engine: operating status: ES
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 63257000001151
   Coding: 01FA93A13424217547800607E0CAA980C92C84E26007957738425038C2A9430B00000012121212B835351919323200
   Shop #: WSC 00046 000 00000
   VCID: 030578FB8AB545578C-8056
8277 - Databus
          U1122 00 [009] - Implausible Message
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:38:01
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0012000420010000110500001210142A
   VCID: 6CD73347872BAA2F5D-8038
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
                    Outside air temperature: 16.0 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 22.3 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001733200812
   ROD: EV_BCMBOSCH_018.rod
   VCID: 081F6FD7B393660FD9-805C
   Component: WWS    171102  042 0551
   Serial number:         171111033250
   Component: RLHS  047 0105
   Serial number: S9Y17M11D29H15M39S32
   Coding: 00A8DD
   Serial number: 000000000ZY173000GUM
   Serial number: 00000000000000046658
262936 - Sensor for anti-theft alarm system
          B1330 29 [009] - Signal Implausible
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:57
555797 - Databus
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:38:00
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617320
   Coding: 0371167841
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50AF87B70B436ECF41-8004
13697025 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 2B0067C315FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E73C90FA1D7E8BFA3-806A
0803 - Databus
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 12.0 V
                    Status_ACC_System: ACC_irreversible error
0101 - Databus
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
2119 - Databus
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
2068 - Databus
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Serial number: 003VWR3LSKF8
   Coding: 98CCC000000000005C000000008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 09196AD3A8991F07C6-805C
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169677E06021851041
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169676E07021850200
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 411 17
   Serial number: 357000000000A84D882P
   Subsystem 4 - Part No SW: -----------    HW: 480 002 411 17
   Serial number: 3580000000045C09882L
   Subsystem 5 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3510001C72839D06B588
   Subsystem 6 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3520001C92839D03357%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 611 17
   Serial number: 3550001AB2796E02E64D
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 23111704401267
   Coding: 0C00
   VCID: 050166E384817B67A2-8050
   Part No SW: 5G1 920 756 C    HW: 5G1 920 756 C
   Component: KOMBI         302 0310
   Coding: 27AD19006F88000801886B0B5401000000000000
   VCID: 2D51FE437CB163270A-8078
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007086889
   Coding: 030100347F085800FB00027C1C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: 387FDF1783F3D68F69-806C
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 27150000245620045065
   Coding: 28FFFF
   Serial number: 2952266004
          U1101 00 [009] - Active
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
   Component: HRE_Master    H12 0080
   Serial number: 0460702225
   Coding: 02031203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D71CE03ACD1F3A7BA-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0460293131
   Coding: 020312
   Serial number: 071117EK510734
   Coding: 003E02208801048100001001
   VCID: 4385B8FBCA358557CC-8016
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 00020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B75C01BB2C5FD9784-806E
Address 4B: Multifunc. Module
Interface not compatible.
   Serial number: 121117EKA33711
   Coding: 003E00208E01048100801000
   VCID: 428BBDFFD52F8C5FC7-8016
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     H24 0245
   Serial number: VWZAZ2R0642410
   Coding: 02730208FF00000051510001001828001F0207D601200100C7
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 6ED3394FB137583F73-803A
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT3234340
7 Faults Found:
          B201A 00 [009] - -
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:57
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name: D
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:57
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:38:00
          B1064 13 [009] - Open Circuit
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:38:00
          B1061 13 [009] - Open Circuit
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:38:00
          B1066 13 [009] - Open Circuit
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:38:00
7181 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:38:01
                    BAP-BAP_Function_ID: 1B
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 27111712P21176
   Coding: 000307000000010100020054C150A90088000E200020
   VCID: 3C77C307B7CBFAAF8D-8068
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:57
                    Control Module temperature: 33 °C
                    Outside air temperature: 13.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 374.7 s
                    mid: 00 29
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
                    Reset counter: 18
                    Mileage: 41 km
                    Date: 2019.07.22
                    Time: 23:37:58
                    System run time: 375.3 s
                    mid: 02 A6
                    Status of camera: System malfunction
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 171013203235
   VCID: 6BD5305B8225AD1754-803E
End-------------------------(Elapsed Time: 04:28)--------------------------
andy_911
Austria
C?ID=149628
Hello, I think that you will have a problem with ACC. You can't have a follow to stop or stop and go function with manual transmission. Maybe you need a new SwaP Code for ACC. Celabrating the sensor will not be the solve the problem.
racofuy
New Zealand
C?ID=197081
Thanks for your reply, Swap code?
Maybe code it out altogether from the installed list?
racofuy
New Zealand
C?ID=197081
Although would be good to at least have cruise working
andy_911
Austria
C?ID=149628
Is it possible to have ACC with manual transmission?
darkchina811
ITALY
C?ID=333184
of course it is, but there is something unclear here: did you retrofit ACC or did it come as stock with the car?
since the car is a 2018, you have the "flat" radar behind the VW badge on the hood. this cannot be retrofitted, because it needs a FeC code (kinda same as SWaP) which cannot be obtained aftermarket.
racofuy
New Zealand
C?ID=197081
ACC came stock with the car. Being that it was dsg is still set up for stop go which I understand now won't work on manual of course.
racofuy
New Zealand
C?ID=197081
Any further input appreciated, just to clarify the car left the factory with ACC and dsg. Only change is manual swap.
Somnus
SLC, USA
C?ID=215931
As far as the Engine Control Module Incorrectly Coded Fault, I would check the Engine coding, more specifically the Cruise Control section, as it might need to be adjusted now that ACC w/ Stop&Go is no longer a valid configuration
Also, the bytes controlling ACC and transmission type in the ABS controller might need to be updated as well
NEtech
C?ID=56995
I have some guesses for ABS Coding, but am not 100%, do you want to test ABS coding ?
There is also engine coding.
NEtech
C?ID=56995
[01-Engine] Coding
091900322444010B2000
Maybe with speed limiter, the 2 man. I have scan on are 05 for Byte 6
091900322444050B2000
[03-ABS] Coding
019334214706E0A980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
Yes it must be shorter!
Copy this clb file, to c:\Ross-Tech\VCDS\Labels\User
[03-ABS]
[Security Access - 16]
Enter: S12345
[Do It!]
[Coding - 07]
Paste:
 019334214706E0A980C92C84E26007957734405038C2A9430B00000012121212B835351919323200 to "New coding"
[Do It!]
racofuy
New Zealand
C?ID=197081
[01-Engine] Coding
[03-ABS] Coding
[03-ABS]
Enter: S12345
[Do It!]
[Coding - 07]
Paste:
[Do It!]
Thank you, the engine ecu code accepted but fault code remains.
The ABS controller did not accept the login code so could not enter new long code.
NEtech
C?ID=56995
It should. What is the return message ?
You write exactly as it is shown: S12345
Check Adv. Meas Values, in search field`, write: "323" or "security", is it zero ?
Is 40168 accepted ?
You have battery charger connected ?
Normally if a know login is not accepted, Stop VCDS, Ign. OFF for 10-20 sec., Ign. ON, try again.
racofuy
New Zealand
C?ID=197081
I'll try again tomorrow, the message was something like the controller rejected....., must be 5 numeric digits.
I'll try the same again otherwise the 40168
Appreciate your help.
I'll update tomorrow.
NEtech
C?ID=56995
In general, I would recommend to upgrade your VCDS interface to the new version.
racofuy
New Zealand
C?ID=197081
Yes agree with you, its on my "to get" list.
Back to this, no login and checked 323 its sitting at 3
Leaving key off makes no difference, is there another way to clear this?
Battery charger is connected.
racofuy
New Zealand
C?ID=197081
Cleared the login attempts and code S12345 now works.
When pasting the new long code and entering "do it" I get error message
Long code must be same length or have same number of hexdecimal characters.
Currently trying to obtain an autoscan from a manual version of this car.
Finding owners is no problem however no one so far has vcds.
NEtech
C?ID=56995
Try:
01FA93A13424217547800607E0CAA980C92C84E26007957734405038C2A9430B00000012121212B835351919323200
