Weird issue with O2 sensor and idle hunting on 2010 VW Polo 1.6 TDI CAYB
   #21
That's far away from the truth I am afraid. But I can't and I don't want to change your mind. I respect your help and your contribution to my issue so far. Thanks Jack.
Ah nope............ :rolleyes:
https://forums.ross-tech.com/showth...o-1-6-TDI-CAYB&p=172459&viewfull=1#post172459
Following this I would like to ask your opinion on the following:
- Is it safe to delete EGR without deleting DPF? Cause I have read around that once you delete EGR it is good to delete DPF as well (which I am not gonna do mainly due to MOT reasons)
- In case that I replace EGR with a new one, it will need coding through VCDS, is that right? In such case can you point me to a guide of doing this coding myself?
Thank you again for your consideration; I look forward to your thoughts and advice.
Personally, I see the EGR valve as an ass to mouth effective instrument!
That's why we clean them and intakes.
Don't forget the mouth........
   #22
I will replace the EGR with the help of a friend who is mechanic but we are both not so familiar with VCDS. In case that I replace it myself, is it safe to drive let's say 40-50 miles to visit a tuner that can code the new EGR?
If the EGR valve is replaced with correct part, it should just need a Basic Setting:
IDE00785 -- Adaptation of EGR valve
zach138
C?ID=357411
Thanks a lot Uwe.
I'm looking into the Wahler one which I think is the one that is used by VW as well.
I'm looking to Haynes workshop manual for my car and I think that I will also need new gaskets for the egr pipes as well.
Hopefully next week I will try the replacement and fingers crossed that will solve my issue. Although I cannot still understand how a faulty EGR can affect the slow response of the O2 sensor :confused:
   #25
zach138
C?ID=357411
   #26
Thanks for the link.
Is there any case where the system is self-adapted after a reset or in this example after replacing the EGR? Like getting into a learning procedure?
Basic settings are learning procedures you command them in VCDS when initiated.............indeed some basic settings are self initiated by an ECU depending on stack firmware when a key is switched on before engine running, establishing a zero line or last ADP saved to eeprom of ref during saved adaptions from wear.
This is why DTC's should be cleared and and all adaptions done when changing any AECD component as per RTFB and scanner guidance.
EGR is like sticking a garden hose in your ass and than your mouth!
Get the drift?
   #27
zach138
C?ID=357411
Uwe, may I ask if this Basic Setting is also needed when we remove and clean the EGR? Cause I am thinking to try first a good clean and then see if it needs replacing.
Additionally to access Basic Settings in my car, do I need to login first with a secure code or so?
Thanks for your time.
   #28
I'm not sure. My guess is that it should probably be done at that point.
zach138
C?ID=357411
Thanks for your reply Uwe.
Im gonna remove and clean EGR and Throttle Body as a first step and see from there if there is a need of replacement.
One thing that I noticed is when I changed the O2 sensor (several miles and drive cycles ago...) I didn't perform any basic settings to this. Is this needed to do for the O2 sensor?
   #31
zach138
C?ID=357411
My bad, thanks for the ref Jack!
   #33
zach138
C?ID=357411
Hahaha!
I am trying to understand you but it is difficult in some cases since I'm not native (and not that familiar with mechanical terms especially in English) ;-)
In any case I always welcome your contribution!
