Can anybody tell me where this is located?
Is it a common item to fail or is it more likely to be wiring in or to the door?
Wednesday,24,July,2019,11:52:18:34893
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: TMBBJ7NE9F0239039 License Plate: JASON
Address 15: Airbags Labels: 5Q0-959-655.clb
Control Module Part Number: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component and/or Version: Airbag VW20 012 0200
Software Coding: 98CCC000000000005C5400CC008800000065
Work Shop Code: WSC 73430 790 00161
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116 (SK37)
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5B01C5E775F82FB33-802A
9443588 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 04 [137] - Internal System Fault
Mileage: 169381 km
Date: 2019.07.08
Time: 06:59:13
Address 15: DTCs cleared
Mileage: 170895 km
Date: 2019.07.24
Time: 11:52:29
Mileage: 170895 km
Date: 2019.07.24
Time: 11:52:29
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBJ7NE9F0239039 Mileage: 170895km-106189miles
Address 01: Engine (J623-CKFC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 8125
Revision: 83H22---
Coding: 11190032032501090000
Shop #: WSC 73430 031 00161
ASAM Dataset: EV_ECM20TDI01104L906021DS 002013
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79AFEFDDF951D61F8D7-802C
5253 - Diesel Particle Filter; Differential Pressure Sensor
P2452 00 [032] - Elect. Malfunction
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 61045000001253
Coding: 1A078A91242309750077060341CC245851249000608224F20063F072C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 47CB5925FF2570EF4B3-8012
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 37
Mileage: 170312 km
Date: 2019.07.16
Time: 13:36:58
Part No SW: 5E0 907 044 K HW: 5E0 907 044 K
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 01110104000100011005000000101000
VCID: 2D070B8D7D99BABF51F-8078
590081 - Control Circuit for A/C Compressor
B10A9 11 [008] - Short to Ground
Reset counter: 29
Mileage: 170025 km
Date: 2019.07.13
Time: 18:38:43
Outside air temperature: 17.0 °C
Engine speed: 800 /min
Compressor shut-off requirement: Compressor activation: malfunction in activation path
Compressor current: specified value: 0.000 A
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0137
Serial number: 01011510301049
Coding: 0F000842424702FB07A04082B10407280000000000000000000000000000
Shop #: WSC 73430 790 00161
ROD: EV_BCMBOSCH_013.rod
VCID: 7DA7FBCDED79EA3FA1F-8028
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 150320 041 0570
Serial number: 150324202347
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M04D22H15M36S20
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1504824ND
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000062028391
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Reset counter: 17
Mileage: 168378 km
Date: 2019.06.27
Time: 18:50:45
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431507801528
Coding: 0131061041
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 42DD4831D40755C79CD-8016
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0200
Revision: -------- Serial number: 003P4P6XDXQ$
Subsystem 1 - Part No SW: ----------- HW: 454 003 103 15
Serial number: 3576U000000FB8DCD31+
Subsystem 2 - Part No SW: ----------- HW: 454 003 103 15
Serial number: 3586U000000414ECD31I
Subsystem 3 - Part No SW: ----------- HW: 454 800 604 15
Component: SideSensor_Dr 111 0148
Serial number: 3516R725A4506000000
Subsystem 4 - Part No SW: ----------- HW: 454 800 604 15
Component: SideSensor_Pr 111 0148
Serial number: 3526RC1386D060000006
Subsystem 5 - Part No SW: ----------- HW: 454 802 503 15
Component: FrontSensor_D 114 0149
Serial number: 3556V8B802B06000000A
Mileage: 170895 km
Date: 2019.07.24
Time: 11:52:29
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 22041504400836
Coding: 1400
VCID: 77ABE9E5CF45C06FFB3-8022
Part No SW: 5E0 920 951 HW: 5E0 920 951
Component: KOMBI 310 4270
Coding: 23A402002190A60001086A001000000000000000
VCID: 6491AEA96ED33BF74E1-8030
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1204
Revision: -------- Serial number: 0003411166
Coding: 030100040F087300EF000248080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 71BFD7FDA1219E5F357-8024
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H05 0130
Serial number: 000000000C0046030415
Subsystem 3 - Part No SW: 5Q0 915 181 F HW: 5Q0 915 181 F
Component: J367-BDM H08 0223
Serial number: 62098D00564291828623
Part No SW: 5Q4 959 393 C HW: 5Q4 959 393 B
Component: TSG FS 009 0015
Serial number: 0000146109670
Coding: 001000208001040000001100
VCID: 43D34D35CB1D5CCF97B-8016
Serial number: 00000000000005873400
Coding: 1D0200
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8303
Part No SW: 5Q4 959 392 C HW: 5Q4 959 392 B
Component: TSG BFS 009 0015
Serial number: 0000145601105
Serial number: 00000000000005931538
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 874 A HW: 5E0 035 874 A
Component: MU-S-ND-ER 041 0435
Serial number: S7F02204151799
Coding: 03730101FF0000001111120100A800002F0000860100010046
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 2615F4A1586F89E7905-8072
Subsystem 1 - Part No SW: 5E0 919 605 D HW: 5E0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: SKZ8Z9RT301JWA
Subsystem 2 - Part No SW: 5E0 051 236 G HW: -----------
Component: ECE 2015 --- 0045
End----------(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.3V)-----------
Gateway Installation List: 5Q0 907 530 AB
