Results 1 to 5 of 5
Thread: VCDS -- BRAKE FLUID BLEEDING PROCESS
    Jul 2019
    France
    Hello Everybody,
    Could you tell me how i should proceed on VCDS to bleed entierly the brake fluid on my Golf V ? (Clutch, ABS/ESP, Brake calipers)
    • What part of brake system must i bleed in the first time ?
    • What is the complete process to make the bleeding with success for all components ?
    For ABS part: I know that there is an option in VCDS to bleed ABS but i don't know where it is ?
    Could you give me your tips and tricks ?
    Look forward to hearing from you
    Best regards
    See below my autoscan of my "VW GOLF 5 - 105HP-77KW - 1.9L TDI - BLS"
    Sunday,21,July,2019,14:34:20:47337
    VIN: WVWZZZ1KZ8W177162   License Plate:
    Mileage: 229740km-142753mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ8W177162   Mileage: 229740km-142753miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 QJ    HW: 03G 906 021 AB
       Component: R4 1,9L EDC G000SG  1984
       Revision: --H07---    Serial number: VWX7Z0GN3NE8E7
       Coding: 0000071
       Shop #: WSC 02271 995 97128
       VCID: 77AB16E8E3C6CA2FFB3-8022
       Revision: 00H11001
       Coding: 0021121
       Shop #: WSC 01392 785 00200
       VCID: 73B322F8F7BEA60FC7B-8026
       Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
       Component: ClimatronicPQ35 130 1212
       Revision: 00130022    Serial number: 00000000000000
       VCID: 78A915D4EED8C557F29-802C
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Revision: 00H54000    Serial number: 00000005255840
       Coding: E58B8F2700041500471400001400000000097F075C000100000000000000
       Shop #: WSC 00000 785 00200
       VCID: 71BF28F08DA2941F357-8024
       Component: Wischer 131107 021  0501
       Coding: 00038805
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     191107 046  0204
       Coding: 00208933
       Component: 37 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1L6LZ4
       Coding: 0013111
       Shop #: WSC 01373 785 00200
       VCID: 3D27C4C0817A207FE1F-8068
       Subsystem 1 - Serial number: 6332MSME3151696CE
       Subsystem 2 - Serial number: 6342MSME303475611
       Subsystem 3 - Serial number: 6352QSME43342767D
       Subsystem 4 - Serial number: 6362QSME462D0D77U
       Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
       Component: J0527           636 0070
       Coding: 0002022
       VCID: 75B71CE0F9CAB83FE9F-8020
       Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0GN3NE8E7
       Coding: 0007103
       Shop #: WSC 24886 002 1048576
       VCID: 2C01F9846A00B9F7461-8078
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K07A300A5C
       Coding: E9807F0E0002020002
       VCID: 3039EDF44628DD177A9-8064
       Component: IMMO            VDD 1216
       Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
       Component: Tuer-SG         006 1219
       Coding: 0000180
       VCID: 392FD0D095521C5FCD7-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.069 H08 1901
       Shop #: WSC 00000 028 00001
       VCID: 3537DCE0B94AF83F29F-8060
       Coding: 809002005103087F2D0484056008CF03E0FC00
       VCID: 03537238A71E968FD7B-8056
       Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
       Coding: 0000436
       VCID: 3A2DCFDC90541747C4D-806E
       Part No SW: 1K0 035 186 AD    HW: 1K0 035 186 AD
       Component: Radio BVX       037 0048
       Revision: 00037000    Serial number: VWZ1Z2G6330308
       Coding: 0040400
       VCID: 68894594BE7855D7629-803C
       Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
       Component: Tuer-SG         006 1206
       Coding: 0000144
       Shop #: WSC 01392 785 1012552
       VCID: 3829D5D4AE580557329-806C
       Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
       Coding: 0000144
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 22 Einparkhilfe     0101
       VCID: 2D07F480511AB0FF51F-8078
    End----------(Elapsed Time: 01:16, VBatt start/end: 12.2V/12.2V)-----------
    New User
    Lithuania
    I think this module from Golf Mk5 does not have this functionality. I have came accross this problem a year or so ago.
    Yet one local brake systems specialist suggesested a way to do this. Not sure if it works but net time I get Golf 5 (or similar to it car) I will try.
    Dec 2016
    Amsterdam
    Quote Originally Posted by Henrick View Post
    You can also engage ABS during a test drive a few times, and then do a round of regular bleeding with a vacuum
    bleeder. The output test just engages the ABS unit to displace fluid from the valve block. When ABS intervenes during driving the same happens.
    Current:
  5. Likes Uwe, Fredrick Awuor liked this post
    Dec 2017
    Italy
    Hi. VCDS is not necessary to bleed entirely brake and clutch fluid on Golf Mk5.
    You need only a 2 bar pressure bleeder.
    VCDS is necessary only if you let air entering braking system, so if you have to bleed a car wich has actually his braking system full of fluid you don't need VCDS.
    Bleed first each caliper in this official VW sequence:
    -Front left
    -Front right
    -Rear left
    -Rear right
    Finally bleed clutch.
  7. Likes Uwe liked this post
