Results 1 to 3 of 3
Thread: Polo AW Park Assist Coding Help
    Oct 2014
    Guys, I'm going to retrofit the park assist to my 2018 VW Polo AW RHD and wondering if anyone could help with the coding? I already have the 8 sensors on the car, so I'll add the remaining 4 sensors and just need to know what needs to be coded.
    Any help would be fantastic.
    Scott
    Monday, 15, July, 2019,15: 06: 00: 03210
    VCDS - Windows Based VAG / VAS Emulator Running on Windows 7 x86
    VCDS Version: 19.6.1.0 HEX-V2 CB: 0.4508.4
    www .Ross-Tech.com
    Dealer / Store Name: VCDS
    Workshop Code: 444 03743 000001
    VIN: WVWZZZAWZKU007157 License Plate: SL68XKS
    Mileage: 10669km-6629mi Repair Order:
    Chassis Type: AW-VW27 ( 3Q0)
    Scan: 01 02 03 08 09 10 13 15 17 19 3C 44 5F CA
    VIN: WVWZZAWZKU007157 Mileage: 10669km-6629miles
    01 Engine - Status: OK 0000
    02-Auto Trans - Status: OK 0000
    03-ABS Brakes - Status: OK 0000
    08-Auto HVAC - Status: OK 0000
    09-Cent. Elect. - Status: OK 0000
    10-Park / Steer Assist - Status: OK 0000
    13-Auto Dist. Reg - Status: OK 0000
    15-Airbags - Status: OK 0000
    17-Instruments - Status: OK 0000
    19-CAN Gateway - Status: OK 0000
    3C-Lane Change - Status: OK 0000
    44-Steering Assist - - Status: OK 0000
    5F Information Electr. - Status: OK 0000
    CA-Sunroof - Status: OK 0000
    Address 01: Engine (J623 -DKRF ) Labels:. 04E-907-309-V1.clb
      Part No SW: 04C 906 025 M HW: 04C 907 309 BB
      Component: R3 1.0l TFS H20 6196
      Revision: D7H20000 Code
      : 0125003223041D080000
      Shop #: WSC 31414 790 00200
      ASAM Dataset: EV_ECM10TFS01104C906025M 002003
      ROD: EV_ECM10TFS01104C906025B_002_VW27.rod
      VCID: 2A0D01F4AC7FE1F7B4D-807E
      Part No SW: 0CW 300 042 D HW: 0AM 927 769E
      Component: GSG DQ200G2_M H05 1606
      Revision: 00005008 Serial number: CU501806176987
      Shop #: WSC 17734 418 534600
      ROD: EV_TCMDQ200021_VW27.rod
      VCID: 372B28806FCD4C1F3B3-8062
    Address 03: ABS Brakes (J104) Labels: Redir Fail!
      Part No SW: 2Q0 614 517 AD HW: 2Q0 614 517 N
      Component: ESC_base_vFGS H23 0223
      Serial number: 08514728180704
      Coding: 0A034C64354150B432FDAC1B24E142A649124D26226A242444541254452442659248B26444562424222A482AA251D64A3D8A6B52BC
      ASAM data set: 004032 EV_Brake1BOSCHESPMQBA0
      ROD: EV_Brake1BOSCHESPMQBA0.rod
      VCID: 70B9D39C4A23DB273A9-8024
    Address 08: Auto HVAC (J255) Labels: * Redir Fail!
      Part No SW: 2G0 907 044 L HW: 2G0 907 044 L
      Component: Climatronic H03 0501
      Coding: 0121000008000100011008010244010D000000000000000000000000
      Shop #: WSC 03743 444 00001
      ASAM Dataset: EV_ACClimaBHBMQBA0 004017
      ROD: EV_ACClimaBHBMQBA0_VW27.rod
      VCID: 2D070AE89D91F6CF51F-8078
      Part No SW: 2Q0 937 090 A HW: 2Q0 937 090
      Component: BCM A0 Hours + H98 0926
      Serial Number: 00001817500231
      ASAM Dataset: EV_BCMA0 204001
      ROD: EV_BCMA0_204.rod
      VCID: 3039139C8AA39B277A9-8064
      Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
      Component: RLHS 052 0107
      Serial number: SAY18M07D11H03M24S29
      Coding: 0038DD
      Drivers Door Control Modules:
      Subsystem 2 - Part No SW: 2Q2 959 881 D HW: 2Q2 959 881 D
      Component: FHSG_DRV 001 0002
      Serial number: 00000000000021749146
      Coding: 1F0037
      Subsystem 3 - Part No SW: 2Q2 959 882 D HW: 2Q2 959 882 D
      Component: FHSG_PSG 001 0002
      Serial number: 00000000000021753752
      Code: 058037
      Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
      Serial number: 000000000ZY181501S2X
      Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
      Component: Siren, DWA 005 0314
      Serial number: 00000000000099190056
      Subsystem 6 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 GB
      Component: FOND_FHSG_DRV 006 0007
      Serial number: 00000000000022454493
      Coding: 1F0000
      Subsystem 7 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 GB
      Component: FOND_FHSG_PSG 006 0007
      Serial number: 00000000000022520572
      Coding: 070000
    Address 10: Park / Steer Assist (J446) Labels: | 5Q0-919-294.clb
      Part No SW: 5QA 919 294 C HW: 5QA 919 294
      Component: PDC 8 Channel H07 0050
      Serial number: 000308418018181 Code
      : 0471155011
      ROD: EV_EPHVA18AU3700000_009_VW27.rod
      VCID: 4CC1676C064BDFC7661-8018
    Address 13: Auto Dist. Reg (J428) Labels: | 2Q0-907-572.clb
      Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
      Component: ACCCONTIMQB H02 0233
      Code: 3200600248FF8748949C8145004087
      VCID: 3E253DA440F77D57F85- 806A
    Address: Airbags (J234) Labels: * None
      Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
      Component: VW22Airbag 010 0248
      Revision: --------
      Code: 88CCC0C0000000005C5400CF008800000065
      ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
      ROD: EV_AirbaVW22BPAVW27X.rod
      VCID: 025D8954748FD9B7DCD-8056
      Subsystem 1 - Part No SW: ----------- HW: 442 061 207 18
      Serial number: 3577Y20B127578D2E47A
      Subsystem 2 - Part No SW: ----------- HW: 442 061 207 18
      Serial number: 3587Y20B127578D3D235
      Subsystem 3 - Part No SW: ----------- HW: 442 0B0 707 18
      Component: SideSensor_Dr 1C7 0148
      Serial number: 351778299293EDC5510T
      Subsystem 4 - Part No SW: ----------- HW: 442 0B0 707 18
      Serial number: 35277829B293EDC3E465
      Subsystem 5 - Part No SW: ----------- HW: 442 132 705 18
      Component: FrontSensor_D 290 118A
      Serial number: 355AG11B5298CB11C69%
    Address 17: Instruments (J285) Labels: | 5G0-920-XXX-17.clb-SRI3
      Part No SW: 2G0 920 790A HW: 2G0 920 790A
      Component: COMBI 506 1701
      Coding: 20AD010821802600018872095001000000000000
      ASAM Dataset: EV_DashBoardVDDMQBA0 001026
      ROD: EV_DashBoardVDDMQBA0_VW27.rod
      VCID : 2517F2C8C561CE8F99F-8070
    Address 19: CAN Gateway (J533) Labels: | 3Q0-907-530-V1.clb
      Part No SW: 3Q0 907 530Q HW: 3Q0 907 530C
      Component: GW MQB High 518 5344
      Serial number: 14061811602488
      Coding: 030100046F085600FA0002481C0F0001000107000000000000000000
      ROD: EV_GatewNF.rod
      VCID: 3D273AA84DF1664FE1F-8068
      Component: 1-00-02-00-04
      Subsystem 2 - Part No SW: 2G0 959 442K HW: 2G0 959 442K
      Component: E221__MFL-DC1 H02 0052
      Serial number: 39170002831130077484
      Coding: 25FFFF
      Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
      Component: J367-BDMBOSCH H02 2011
      Serial number: 10088840
    Address 3C: Lane Change (J1086) Labels: * None
      Part No SW: 2Q0 907 686 A HW : 2Q0 907 686 A
      Component: HRE3_Kl15_Mst H03 0051
      Serial number: 00000435986817
      Coding: 90014500
      ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
      ROD: EV_HREntryHellaGen3Kl15_001_VW48.rod
      VCID: 38292BBC62D34367329-806C
    Address 44: Steering Assist (J792) Labels: * None
      Part No SW: 2Q2 909 144 J HW : 2Q2 909 144 F
      Component: TRW_G4L_MQBA0 620 6030
      Serial number: 0646183CB4J1942
      Coding: 00000000000000000101020101000101000001
      ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
      ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
      VCID: 3A2D31B45CDF5177C4D-806E
    Address 5F: Information Electr. (J794) Labels: | 5G0-035-MIB-STD2.clb
      Part No SW: 3Q0 035 874C HW: 3Q0 035 874C
      Component: MU-S-ND-ER 853 0890
      Serial number
      : Code: 02720001BE00000041110101008808001F0500F601200000CF
      ROD: EV_MUStd4CDELP_VW27.rod
      VCID: 323D199484AFA9370CD-8066
      Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
      Component: ABT_Std-2_Nav H52 8130
      Serial number: VWZ6ZHV1564256
      Subsystem 2 - Part No SW: 5NA 919 866 AG HW: -----------
      Component: ECE AS 2020 --- 1310
      Serial number: ------------ --------
    Address CA: Sunroof (J245) Labels: | 4M0-907-594.clb
      Part No SW: 4M0 907 594 H HW: 4M0 907 594
      Component: SAD_STG_1 014 0005
      Code: 508000727001
      VCID: 3B2334B053E5687FDFB-806E
    End ---------- (Elapsed Time: 01:17, VBatt start / end: 12.0V / 12.0V) ----
    May 2017
    You need the sensors, switch for PLA and naturally a new module.
    Coding needs to be done to ABS, instruments and code the PLA module correctly.
  3. Likes Uwe liked this post
    Oct 2014
    Can anyone help please with exactly what the coding changes need to be?
    Kind Regards
    Scott
