Results 11 to 20 of 30
Thread: MK4 tdi bew issues after turbo replace/egr delete/stage 2 tune
    Coding: 0150031 NEIN! You are not one years old anymore, it's your birthday, you're four!
    Your solution answer sir
    Coding: 0x24A12 converted to decimal should suffice!
    or
    100100101000010010
  2. #12
    Verified VCDS-Lite User
    Jul 2019
    Delaware, USA
    sorry computer at work ill turn letters down . its been a long time running if its 1 digit in a code. I'll give that 4 a shot before my hour ride home later.
  4. #13
    Jul 2019
    Delaware, USA
    Well seemed to take care of that issue. Going to do another scan and see if I can fix boost control issue next. N75 is new but thinking I'm going to have to dig into vacuum lines more. All I have to deal with is the reservoir and n75
  5. Likes Jack@European_Parts liked this post
  6. #14
    Jul 2019
    Delaware, USA
    Thursday, 25 July 2019, 14:16:02:51331
    Chassis Type: 9M - VW Jetta IV
    Scan: 01,02,03,08,09,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
    Address 01: Engine       Labels: Redir Fail!
       Controller: 038 906 016 H
       Component: R4 1,9L EDC G000AG  6327
       Coding: 0150034
       Shop #: WSC 66565
       VCID: 194586E49081
    16683 -  Boost Pressure Regulation: Control Range Not Reached
                P0299 - 000 -   -
    Readiness: N/A
    Address 02: Auto Trans       Labels: 09A-927-750.LBL
       Controller: 09A 927 750 AM
       Component: AG5 Getriebe 09A   0251
       VCID: 769FAD5841DF
    Address 03: ABS Brakes       Labels: 1C0-907-37x-ABS.LBL
       Controller: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0004097
       Shop #: WSC 00066
       VCID: 3319544C122D
    Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
       Controller: 1C0 909 605 F
       Component: 04 AIRBAG VW61 0202 0003
       Coding: 12340
       Shop #: WSC 00066
       VCID: 2721B01CD6F5
    00532 -  Supply Voltage B+
                07-10 -  Signal too Low - Intermittent
    Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
       Controller: 1J5 920 906 R
       Component: KOMBI+WEGFAHRSP VDO V55
       Coding: 15234
       VCID: 3C0B7F703F73
       3VWSR69M94M117437     VWZ7Z0D9321339
    01177 -  Engine Control Unit
                64-10 -  Not Currently Testable - Intermittent
    01314 -  Engine Control Module
                49-10 -  No Communications - Intermittent
    01315 -  Transmission Control Module
    01304 -  Radio
                49-00 -  No Communications
    Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
       Controller: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: F0931B40A3BB
    01304 -  Radio
    Address 46: Central Conv.       Labels: 1C0-959-799.LBL
       Controller: 1C0 959 799 C
       Component: 1H KomfortgerŠt HLO 0003
       Coding: 00258
       Shop #: WSC 00066
       VCID: 3701605C0655
    01179 -  Incorrect Key Programming
                35-00 -   -
    00928 -  Locking Module for Central Locking; Front Driver Side (F220)
                27-00 -  Implausible Signal
    End   ------------------------------------------------------------
    So heres a new scan. coding is the same as first time i did this without all the faults. only original one is the radio. and looks like 19 coding should be 00007 not a 6. definitely closer to running as good as it did before
  7. #15
    Fix the WG setting and watch the deviation is negative or positive.........post the log?
  8. #16
    Jul 2019
    Delaware, USA
    did i mention im not the brightest light on the christmas tree and new to this . im sure i can post the log thats after i figure out how to fix WG setting
  9. #17
    0x01-08-011 ................
    https://forums.ross-tech.com/showthr...ut-0x01-08-000
    Ja ja Sure sure..............
  10. #18
    Jul 2019
    Delaware, USA
    Jul 2019
    Delaware, USA
    That might work. Started with cel off ran to 60 by then light on, turned around and ran to 60 w/cel on
  12. #20
    No data here or an auto scan.....
