Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: MK4 tdi bew issues after turbo replace/egr delete/stage 2 tune
    Verified VCDS-Lite User
    Jul 2019
    Delaware, USA
    newbie here but running out of ideas and no close shops. theres enuff online info to confuse ya. ill keep it simple but theres a long story if any of this sounds familiar. blew stock turbo at 225k. replaces with garrett vnt17 and did egr and cooler delete and purchased malone tune at same time. over a week or so got the mechanicals swapped and went to load tune. ecm already had a RC tun that i wasnt' aware of. problem ;
    Address 02: Auto Trans Labels: 09A-927-750.LBL
    Controller: 09A 927 750 AM
    Component: AG5 Getriebe 09A 0251
    VCID: 769FAD5841DF
    54-00 - Incorrectly Equipped
    clear it with vcds and it comes right back.
    if codes are cleared with bluepoint scan tool it will stay away with vcds. only deleting codes with vcds car will start in 4th gear and not come out. no 1,2,3,5. BP scanner clearing will get car moving and shifting thru all gears but cat will barely get out of its own way.
    Hello OP and welcome to the VCDS forum
    JPPSG and complete auto-scan would be a great start!
    Looks like induced FOD!
    That code exists because the modification's you have done are reflecting incompatible software to your hardware.
    Either return vehicle to stock & to do a comporting qualified repair or see your choice of AECD manipulator of record for a bitch out session.
    If & when your trans blows up, you now know where to send the bill don't ya?
    My guess is that the different behavior between the clears is that the other tool is using the generic OBD-II clear.
    If I were to speculate as to a root cause if the above code, I would suppose the TCU is upset with something in the ECU tune.
    OP is Engine ECU coded for an auto 09A gearbox?
    An auto-scan scan may shed light on that!
    A full unedited Auto-Scan rather than a tiny edit would be helpful
    Jul 2019
    Delaware, USA
    SORRY . STAY BUSY ALL THE TIME
    Chassis Type: 9M - VW Jetta IV
    Scan: 01,02,03,08,09,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
    Address 01: Engine       Labels: Redir Fail!
       Controller: 038 906 016 H
       Component: R4 1,9L EDC G000SG  6327
       Coding: 0150031
       Shop #: WSC 66565
       VCID: 194586E49081
    19460 -  Relay for Low-Output Preheating of Coolant (J359): Open or Short to Ground
                P3004 - 000 -   -
    19462 -  Relay for High-Output Preheating of Coolant (J360): Open or Short to Ground
                P3006 - 000 -   -
    16683 -  Boost Pressure Regulation: Control Range Not Reached
                P0299 - 000 -   -
    Readiness: N/A
       VCID: 769FAD5841DF
    01192 -  Torque Converter Lock-Up Clutch
                37-10 -  Faulty - Intermittent
    Address 03: ABS Brakes       Labels: 1C0-907-37x-ABS.LBL
       Controller: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0004097
       Shop #: WSC 00066
       VCID: 3319544C122D
    Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
       Controller: 1C0 909 605 F
       Component: 04 AIRBAG VW61 0202 0003
       Coding: 12340
       Shop #: WSC 00066
       VCID: 2721B01CD6F5
    00532 -  Supply Voltage B+
                07-10 -  Signal too Low - Intermittent
    Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
       Controller: 1J5 920 906 R
       Component: KOMBI+WEGFAHRSP VDO V55
       Coding: 15234
       VCID: 3C0B7F703F73
       3VWSR69M94M117437     VWZ7Z0D9321339
    01177 -  Engine Control Unit
                64-10 -  Not Currently Testable - Intermittent
    01304 -  Radio
                49-00 -  No Communications
    Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
       Controller: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: F0931B40A3BB
    01304 -  Radio
    Address 46: Central Conv.       Labels: 1C0-959-799.LBL
       Controller: 1C0 959 799 C
       Component: 1H KomfortgerŠt HLO 0003
       Coding: 00258
       Shop #: WSC 00066
       VCID: 3701605C0655
    01179 -  Incorrect Key Programming
                35-00 -   -
    00928 -  Locking Module for Central Locking; Front Driver Side (F220)
                27-00 -  Implausible Signal
    End   --------------------------------------------------------------------------------------------------
  7. #7
    Coding: 0150031
    Shop #: WSC 66565
    VCID: 194586E49081
    P3004 - 000 - -
    P3006 - 000 - -
    P0299 - 000 - -
    Readiness: N/A <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< <<<<<<<<<<<
    Coding: 0150031 <<<<<<<<<<<<<<<<<<<<<< Pardon me but isn't this coded for a stick?
  8. #8
    Jul 2019
    Delaware, USA
    CONTACTED MALONE BECAUSE OTHER THAN TURBO REPLACEMENT, EGR DELETE AND TUNE ISSUE-- HAVING TO TAKE ECM OUT TO SEND TO THEM SO IT WOULD OVER WRITE ROCKET CHIP TUNE. DIDN'T MESS WITH ANYTHING ELSE. THEY SAY ITS NOTHING IN THE TUNE AND IM TO FAR AWAY FOR THEM TO DIAGNOSE AND STOPPED REPLYING TO EMAIL?? AND YES JUST A SMALL SNAP ON(BLUEPOINT) SCANNER
  9. #9
    Jul 2019
    Delaware, USA
    IM NOT SURE. FIRST RUN WITH VCDS AND VW. THATS WHY IM REACHING OUT FOR IDEAS AND/OR HELP.
  10. #10
    Hey hey hey stop yelling & at the data as verified to be interpreted you presented, okay?
    This is their fault because when a TDI ECU is re-flashed some ECU's default to stick coding or the dopes use a BDM or full image that changes the eeprom and they just negate their duties to you as the consumer & to verify your config, no?
    If it smells like Malone leave it Alone?
    WTF did I say about yelling?
    Have any legacy scans from before you sent this controller out?
