Results 1 to 8 of 8
Thread: Seat Arona (MQB-A0) BCM Adaptions Unknwon
    Feb 2018
    Hey Guys,
    yesterday I tried to code Rear Light as DRL to deactivate this about 5F.
    But in Light Function "A", there´s a value who´s called "Unknown (40)". I´ve checked it with German VCDS 18.9.1 and US 19.6.
    My luck was, I´ve done a Backup with ODIS, so I can go back to Original value, as ODIS show value (Unknown (40)) as "nicht_definiert_28"
    After Change value "Daytime running lights" there a lot of issues like some light are not working (High Beam, cornering lights ...)
    Address 09,2Q0 937 090 A,channel ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,adapted from,Unknown (40),to,Daytime running lights ,Monday,22,July,2019,16:42:24:15908
    Address 09,2Q0 937 090 A,channel ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,adapted from,Unknown (40),to,Daytime running lights ,Monday,22,July,2019,16:43:18:15908
    I did whole Scan only with german VCDS, so thats the only one I can deliver actually
    Sonntag,31,März,2019,16:54:55:15908
    VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x64
    VCDS Version: DRV 18.9.1.0  HEX-NET CB: 0.4502.4
    Datenstand: 20190215 DS296.0
    www.Ross-Tech.de
    Händler-/Werkstattname: LH Coding
    Betriebsnummer: 123 59348 004370
    Fahrzeug-Ident.-Nr.: VSSZZZKJZKR082354   KFZ-Kennzeichen:
    Kilometerstand: 1757km   Reparaturauftrag: Seat Arona
    Fahrzeugtyp: KJ-SE27 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 44 47 55 5F
    Fahrzeug-Ident.-Nr.: VSSZZZKJZKR082354   Kilometerstand: 1757km
    01-Motorelektronik -- Status: i.O. 0000
    02-Getriebe -- Status: i.O. 0000
    03-Bremsenelektronik -- Status: i.O. 0000
    05-Zugangs-/Startber. -- Status: i.O. 0000
    08-Klima-/Heizungsel. -- Status: i.O. 0000
    09-Zentralelektrik -- Status: i.O. 0000
    10-Einparkhilfe 2 -- Status: i.O. 0000
    13-Distanzregelung -- Status: i.O. 0000
    15-Airbag -- Status: i.O. 0000
    16-Lenkradelektronik -- Status: i.O. 0000
    17-Schalttafeleinsatz -- Status: i.O. 0000
    19-Diagnoseinterface -- Status: i.O. 0000
    2B-Lenksäulenverrieg. -- Status: i.O. 0000
    3C-Spurwechsel -- Status: i.O. 0000
    44-Lenkhilfe -- Status: i.O. 0000
    47-Soundsystem -- Status: i.O. 0000
    55-Leuchtweitenreg. -- Status: i.O. 0000
    5F-Informationselek. I -- Status: i.O. 0000
    Adresse 01: Motorelektronik (J623-DKRF)       Labeldatei: Keine
       Teilenummer SW: 04C 906 025 K    HW: 04C 907 309 BB
       Bauteil: R3 1.0l TFS   H20 6203
       Revision: D7H20000
       Codierung: 01250032236415081000
       Betriebsnr.: WSC 00049 770 00136
       ASAM Datensatz: EV_ECM10TFS01104C906025K 002002
       ROD: EV_ECM10TFS011_AU27.rod
       VCID: A81CA8F1D3CDBF0A35-80FC
    Adresse 02: Getriebe (J743)       Labeldatei: DRV\0CW-927-769.clb
       Teilenummer SW: 0CW 300 043     HW: 0AM 927 769 E
       Bauteil: GSG DQ200G2_M H05 1604
       Revision: 00005008    Seriennummer: CU501811175359
       Codierung: 0014
       ASAM Datensatz: EV_TCMDQ200021 001001
       ROD: EV_TCMDQ200021_VW27.rod
       VCID: F4A48C815F858BEA49-80A0
    Adresse 03: Bremsenelektronik (J104)       Labeldatei: Keine
       Teilenummer SW: 2Q0 614 517 AF    HW: 2Q0 614 517 M
       Bauteil: ESC_high_vFGS H34 0342
       Seriennummer: 08515183181030
       Codierung: 8A0D4C573D4951AF32FFBC1B12DE11A649344DE6226A24484454625445488865922CB26744562412222A462AA269D64FFD966BF2BF
       ASAM Datensatz: EV_Brake1BOSCHESPMQBA0 004036
       ROD: EV_Brake1BOSCHESPMQBA0_SE27.rod
       VCID: F2A88A99259185DA5B-80A6
    Adresse 05: Zugangs-/Startber. (J518)       Labeldatei:| DRV\5Q0-959-435.clb
       Teilenummer SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Bauteil: VWKESSYMQB    037 1204
       Revision: 00037000    Seriennummer: 0501823036
       Codierung: 112E0E0703
       Betriebsnr.: WSC 00049 770 00020
       ASAM Datensatz: EV_KessyHellaMQBAB 004046
       ROD: EV_KessyHellaMQBAB_SE27.rod
       VCID: C3C61F5D4AAB7C5200-8096
    Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:* Keine
       Teilenummer SW: 6F0 907 044 C    HW: 6F0 907 044 C
       Bauteil: Climatronic   H03 0502
       Codierung: 8100000008000100110008000240010D0000000000000000000000000000
       ASAM Datensatz: EV_ACClimaBHBMQBA0 004017
       ROD: EV_ACClimaBHBMQBA0_004_SE27.rod
       VCID: A71EABCDDED3B0723C-80F2
    Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\5Q0-937-08X-V2.clb
       Teilenummer SW: 2Q0 937 090 A    HW: 2Q0 937 090
       Bauteil: BCM A0 Std+   H98 0926
       Seriennummer: 00001835300048
       Betriebsnr.: WSC 00000 000 00000
       ASAM Datensatz: EV_BCMA0 204001
       ROD: EV_BCMA0_204.rod
       VCID: B02C4091EB1DF7CAED-80E4
       Sensor für Regen- und Lichterkennung:
       Subsystem 1 - Teilenummer SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labeldatei: DRV\5Q0-955-547.CLB
       Bauteil: RLS  050 0105
       Seriennummer: S5Y18M12D06H01M34S12
       Codierung: 00194D
       Türsteuergerät Fahrerseite:
       Subsystem 2 - Teilenummer SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
       Bauteil: FHSG_DRV  001 0001
       Seriennummer: 00000000000026072139
       Codierung: 13000F
       Türsteuergerät Beifahrerseite:
       Subsystem 3 - Teilenummer SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
       Bauteil: FHSG_PSG  001 0002
       Seriennummer: 00000000000025903481
       Codierung: 09000F
       Türsteuergerät Fahrerseite hinten:
       Subsystem 4 - Teilenummer SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Bauteil: FOND_FHSG_DRV  006 0007
       Seriennummer: 00000000000025871678
       Codierung: 010000
       Türsteuergerät Beifahrerseite hinten:
       Subsystem 5 - Teilenummer SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Bauteil: FOND_FHSG_PSG  006 0007
       Seriennummer: 00000000000025900347
       Codierung: 190000
    Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\5Q0-919-298.clb
       Teilenummer SW: 5QA 919 298 D    HW: 5QA 919 298 A
       Bauteil: PLA 3.0 12KH07 0050
       Seriennummer: 000308417318356
       Codierung: 0271165851
       ASAM Datensatz: EV_EPHVA2CAU3700000 009041
       ROD: EV_EPHVA2CAU3700000_VW27.rod
       VCID: D1EA251580D79EC282-8084
    Adresse 13: Distanzregelung (J428)       Labeldatei:| 2Q0-907-572.clb
       Teilenummer SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
       Bauteil: ACCCONTIMQB   H03 0342
       Codierung: 3200670340FF8728749C814580408700000000000000000000
       ASAM Datensatz: EV_ACCMRRCONTIVW376 003015
       ROD: EV_ACCMRRCONTIVW376.rod
       VCID: C2C81A5955B1755A0B-8096
    Adresse 15: Airbag (J234)       Labeldatei:* Keine
       Teilenummer SW: 5QF 959 655 L    HW: 5QF 959 655 L
       Bauteil: Airbag VW22   006 0520
       Revision: --------    Seriennummer: 003XNPQD1JU1
       Codierung: 88CCC0C000000000585400CF000C00000065
       ASAM Datensatz: EV_AirbaVW22TS6VW48X 001028
       ROD: EV_AirbaVW22TS6VW48X_SE27.rod
       VCID: DF8EF32DC60338B204-808A
       Crashsensor für Seitenairbag Fahrerseite:
       Subsystem 1 - Teilenummer SW: -----------    HW: 454 002 011 18
       Bauteil: SideSensor_Df  008 0887
       Seriennummer: 3570000000044011453.
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag Beifahrerseite:
       Subsystem 2 - Teilenummer SW: -----------    HW: 454 002 711 18
       Bauteil: SideSensor_Pf  008 0887
       Seriennummer: 358000000008C535FD2-
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Fahrerseite:
       Subsystem 3 - Teilenummer SW: -----------    HW: 454 800 412 18
       Bauteil: SideSensor_Dr  301 0148
       Seriennummer: 351004B1721170000000
       Codierung: 2D2D2D
       Crashsensor für Seitenairbag hinten Beifahrerseite:
       Subsystem 4 - Teilenummer SW: -----------    HW: 454 800 412 18
       Bauteil: SideSensor_Pr  301 0148
       Seriennummer: 35200C5042117000000%
       Codierung: 2D2D2D
       Crashsensor für Frontairbag Fahrerseite:
       Subsystem 5 - Teilenummer SW: -----------    HW: 454 802 611 18
       Bauteil: FrontSensor_D  307 0189
       Seriennummer: 35500F54CA216000000P
       Codierung: 2D2D2D
    Adresse 16: Lenkradelektronik (J524)       Labeldatei:| DRV\5Q0-953-549.clb
       Teilenummer SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
       Bauteil: Lenks.Modul   075 0235
       Revision: FF035035    Seriennummer: 20181207400811
       Codierung: 6414
       ASAM Datensatz: EV_SMLSVALEOMQB 001015
       ROD: EV_SMLSVALEOMQB.rod
       VCID: FBB6A7BD72DBC49208-80AE
    Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:* Keine-SRI3
       Teilenummer SW: 6F0 920 740 A    HW: 6F0 920 740 A
       Bauteil: KOMBI         212 2511
       Codierung: 04A4091A2D880008018862091001000080000000
       ASAM Datensatz: EV_DashBoardVDDMQBA0 001032
       ROD: EV_DashBoardVDDMQBA0_SE27.rod
       VCID: A306BFDDAAEB5C5260-80F6
    Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
       Teilenummer SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Bauteil: GW MQB High   442 4367
       Revision: --------    Seriennummer: 0008995374
       Codierung: 030100046F085700E8000250140F00010001070000000000000000000000
       ASAM Datensatz: EV_GatewNF 013025
       ROD: EV_GatewNF_VW27.rod
       VCID: EE909EE931A9A13ABF-80BA
       Generator:
       Bauteil: 0-00-00-00-00
       Steuergerät für Multifunktionslenkrad:
       Subsystem 2 - Teilenummer SW: 5F0 959 537 E    HW: 5F0 959 537 E
       Bauteil: E221__MFL-PR6  H04 0130
       Seriennummer: 000000000G0106031218
       Codierung: 002000
       Steuergerät für Batterieüberwachung:
       Subsystem 3 - Teilenummer SW: 2Q0 915 181     HW: 2Q0 915 181
       Bauteil: J367-BDMBOSCH  H02 2011
       Seriennummer: 100C0261
    Adresse 2B: Lenksäulenverrieg. (J764)       Labeldatei:* DRV\5Q0-905-861.clb
       Teilenummer SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Bauteil: ELV-MQBB      H08 0021
       Seriennummer: 18000393889002
       Codierung: 0800000000000000
       ASAM Datensatz: EV_ELVMarqMQBA0 002002
       ROD: EV_ELVMarqMQBA0_VW27.rod
       VCID: B12A4595E017FEC2E2-80E4
    Adresse 3C: Spurwechsel (J1086)       Labeldatei:| DRV\5Q0-907-686.clb
       Teilenummer SW: 5Q0 907 686 C    HW: 5Q0 907 686 C
       Bauteil: HRE_Master    H12 0081
       Seriennummer: 0500743302
       Codierung: 02011103
       ASAM Datensatz: EV_HREntryHella 001028
       ROD: EV_HREntryHella_SE27.rod
       VCID: BD3269A52C4F0AA276-80E8
       Steuergerät 2 für Spurwechselassistent:
       Subsystem 1 - Teilenummer SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
       Bauteil: HRE_Slave  H12 0081
       Seriennummer: 0500669402
       Codierung: 020111
    Adresse 44: Lenkhilfe (J792)       Labeldatei:* Keine
       Teilenummer SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
       Bauteil: TRW_G4L_MQBA0 611 6041
       Seriennummer: 0907348CB2K0063
       Codierung: 010001010000000001010201010001010000010101
       ASAM Datensatz: EV_SteerAssisTRWG4LMQBA0 011016
       ROD: EV_SteerAssisTRWG4LMQBA0_011.rod
       VCID: BC3464A1375503AA41-80E8
    Adresse 47: Soundsystem (J525)       Labeldatei:* Keine
       Teilenummer SW: 5Q6 035 456     HW: 5Q6 035 456
       Bauteil: KonzernAmp 8K H01 2427
       Revision: --------    Seriennummer: A1117A00106604
       Codierung: 0202000000AAAA00000000000000
       ASAM Datensatz: EV_AMPCAN8C1PASE 001015
       ROD: EV_AMPCAN8C1PASE_VW27.rod
       VCID: F3A68F9D5A8B8CD250-80A6
    Adresse 55: Leuchtweitenreg. (J745)       Labeldatei:| DRV\7P6-907-357.clb
       Teilenummer SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Bauteil: AFS-ECU       H07 0080
       Revision: --------    Seriennummer: --------------
       Codierung: 078A000009200003
       ASAM Datensatz: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_SE27.rod
       VCID: C1CA155550B76E4212-8094
    Adresse 5F: Informationselek. I (J794)       Labeldatei:* Keine
       Teilenummer SW: 5F0 035 877 A    HW: 5F0 035 877 A
       Bauteil: MU-S-ND-ER    H50 0514
       Seriennummer: SEZAZ2W0205441
       Codierung: 041206010000000011110103008808232F0100D401200500CE
       ASAM Datensatz: EV_MUStd4CTSAT 001001
       ROD: EV_MUStd4CTSAT_VW27.rod
       VCID: AA1852F9CDC18D1A23-80FE
       Anzeige- und Bedienungseinheit 1 für Informationselektronik:
       Subsystem 1 - Teilenummer SW: 6F0 919 605 A    HW: 6F0 919 605 A
       Bauteil: ABT_Std-2_Nav  H53 8130
       Seriennummer: SEZ6ZHV3411331
       Datenträger:
       Subsystem 2 - Teilenummer SW: 6P0 919 866 AF    HW: -----------
       Bauteil: ECE1 2018/19  --- 1030
       Seriennummer: --------------------
    Ende--------(Dauer: 01:25, Batt.-Spannung Start/Ende: 12.2V/12.1V)---------
  2. Likes hadez16 liked this post
  3. #2
    Hi and welcome.
    Maybe I'm not understanding the problem here. If ODIS says the value original value is "nicht_definiert", why is it surprising that VCDS considers it "Unknown"? I suppose there is a minor discrepancy that VCDS shows the value as 40 (decimal) which equals what ODIS is showing as 28 (hex)?
    Jun 2017
    I talked to Nils this morning and the dangerous thing is that several lighting functions stop working and you cannot change it back with VCDS because these "Unknown" light functions cannot be selected in the dropdown! Only ODIS can.
    It seems that this is one of those rare pitfalls where you cannot go back.
    Here is another excerpt from a BCM map of a VW Polo 6 (AW)
    ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,Unbekannt (26),16
    ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Unbekannt (70),16
    ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Unbekannt (70),16
    ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Unbekannt (70),16
  5. Likes Uwe, Dana liked this post
  6. #4
    You can go back if you make a raw hex map and then restore it.
  7. Likes PetrolDave, Dana liked this post
  8. #5
    Jun 2017
    Quote Originally Posted by Eric View Post
    That is what I missed in my reply, thanks! I was thinking of it
    Be aware that not every newbie creates a hex dump before playing around because coding is cool...
    Is there any clue what these Unknown values could mean? Are these magic placeholders? What is the Illuminati's role in this case?
  9. Likes Dana liked this post
  10. #6
    Feb 2018
    Hi and welcome.
    You missunderstood the ODIS Part. Odis says "nicht_definiert_28" so there are many other options possible with "nicht_definiert_xx". But VCDS only give value "unknown (xx)". But If I change "unknown (xx)" to "DRL" or anything else, there´s no way back to "unknown (xx)". I did a ODIS ADMAP before coding so I know the right value. But If not customer had do drive to dealer for factory reset.
    Actually I never tried Raw-Hex Backup, because Iam not sure It works correct.
    The amazing Part is, that these value control the DRL in Front and also flashing Light and If changed also High Beam. Car is equipped with LED Headlights
    Last edited by nirvananils; 07-24-2019 at 01:56 AM. Reason: Adding important information
  11. Likes Uwe, Dana liked this post
  12. #7
    Dec 2016
    DE
    I guess, what nivananils indirectly suggests is that VCDS should also allow to change the value to one of those undefined values. Like have all „known“ functions in the dropdown, followed by the unknown values, that only the internal number is known.
    If I remember correctly this is what VCP System does albeit in a crude way, ordering the possible values after their „index numbers“ creating gaps between the known entries.
  13. Likes nirvananils, PetrolDave liked this post
  14. #8
    Feb 2018
    RAW-HEX Adaption Backup seems working fine on this car, but customer wan´t to try it again after correct all the issues. But data seems good i will done my own research in it
