Results 1 to 7 of 7
Thread: AC hack on 2012 Tiguan
    Apr 2017
    Yuengling Country
    Would anyone happen to know if there is a setting to stop the AC from going into Recirc mode when set to the lowest temperature?
    This is my module, but nothing seems obvious to that effect in the coding:
    2012 Tiguan with engine code AX, but I think it's the same as 5N
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0404
       Revision: 00001016
       Coding: 0000004002
       Shop #: WSC 01324 020 00200
       VCID: 005A896FAA8B92F79ED-8054
    2017 Q3 Quattro, 2012 Tiguan 4Motion
    I'm not seeing anything there that's likely to do that. Not in Coding and not in Adaptation.
    Apr 2017
    Yuengling Country
    Thank you very much for checking.
    It’s kinda funny, the Tig won’t let me do any of the tweaks I would like to do.
    Except for the tear drop wiper one.
    D’oh!
    Still, the interface paid for itself the one time I did the rear brakes!
    The rest is icing on the cake.
  4. Likes Uwe liked this post
    Jun 2019
    Berkshire UK
    Just interested to know why you would like to make this change, what benefit would you get?
    I assume you live on a hot climate to have the ac at the lowest setting, otherwise it would be low on gas.
    Apr 2017
    Yuengling Country
    Quote Originally Posted by Pmmcbl View Post
    Good question - it blows hotter air when on recirc.
    I'm not sure if it's a problem with this car or the design, but ever since we got it there were some things we didn't like about the HVAC setup.
    Like blowing hotter air on the driver side than the passenger side (in winter time), taking longer to cool when in recirculate mode in the summer.
    By comparison, my Q3 doesn't automagically set the recirc mode when I move it to the coldest setting, but the Tig does.
    Feb 2018
    Czech Republic
    AFAIK the recirc mode is (also) related to the window blowing/"defogging"/defrosting - what if you set it to low temp with other vents than to the window? Is it the same?
    Apr 2017
    Yuengling Country
    Quote Originally Posted by FandaTDI View Post
    No difference. If I turn on the fan and it's set to the lowest temp, it turns on recirculating, regardless.
    Also, if I lower the temp while in AC mode, it turns on recirc once it gets close to the lowest temp (end of turn for the knob).
