Friday,26,July,2019,11:39:18:41168
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8K0DA117808 License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72
VIN: WAUZZZ8K0DA117808 Mileage: 61750km-38369miles
Address 01: Engine (------CDNC) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0008
Revision: ECH09---
Coding: 32190013242601022000
Shop #: WSC 27985 001 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115 001010
ROD: EV_ECM20TFS0118K5907115.rod
VCID: 6FBBD0D47717017F777-803A
5456 - Starter Will Not Turn
P3054 00 [032] - Jammed or Electrical Malfunction
Mileage: 61670 km
Date: 2019.07.09
Time: 09:33:16
Coolant temperature: 30 °C
Intake air temperature: 34 °C
Voltage terminal 30: 11.732 V
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
4219 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
Part No SW: 8K9 907 379 L HW: 8K9 907 379 L
Component: ESP8 quattro H09 0100
Coding: 011544
Shop #: WSC 06335 000 00000
VCID: 4BC3644423CF1D5F3BF-801E
Part No SW: 8K0 907 064 GC HW: 8K0 907 064 FC
Component: BCM2 2.0 H11 0621
Coding: 03B24000000000000000
VCID: 77ABE8B40FC749BFAF7-8022
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0512000051877021
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000170630016
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Revision: D1000000 Serial number: 01050820121142
Coding: 642402C000
VCID: 3A2D31807C5594D7909-806E
03037 - Rear Temperature Selection Potentiometer (G538)
Fault Status: 00101010
Reset counter: 7
Mileage: 61685 km
Voltage: 11.90 V
Voltage: 4.90 V
Part No SW: 8K0 907 063 DD HW: 8K0 907 063 DD
Component: BCM1 1.0 H16 0103
Revision: 04016001 Serial number: 00000459292402
Coding: 290000308034A7C00081000300001F1F001D070827080201000008000000030000000024000000
VCID: 74B1DFB81EB122A78A5-8020
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 300712 H06 0080
Serial number: SWF12070305276
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20482151
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002407124589
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: F248CC36000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD94VDS7
Coding: 30534435363030303030554A3052384B3053
VCID: 48C95B483239F64716D-801C
Serial number: 6334MSME6F633104B
Serial number: 6344MSME701114480
Serial number: 6352QSME6B1B4566R
Serial number: 6362QSME342015700
Serial number: 63732SME5918357E8
Serial number: 63832SME2C18336C4
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20130726000443
Coding: 000017
Shop #: WSC 54929 000 1048576
VCID: 51FF762CC1E3378F413-8004
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 982 C HW: 8K0 920 982 C
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBH7AFK7D
Coding: 3384290202012600010000
VCID: 34311FB85E3162A74A5-8060
Part No SW: 8R0 907 468 H HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0051
Revision: 1Y050025 Serial number: 2541Y127270196
Coding: 80CF07FF00
VCID: 44D14F780E91D227FA5-8010
Serial number: 8472447901
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 12194002420011200410
Reset counter: 248
Mileage: 61598 km
Date: 2019.06.24
Time: 13:49:34
Bin. Bits: 10000
Voltage: 12.00 V
Count: 10
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0506
Revision: Serial number: 0000035809798
Coding: 011002204001410001
VCID: 50F97328CAE93E874ED-8004
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0022742561
Coding: 100000000001
Shop #: WSC 00860 210 94821
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311FB85EB162A74A5-8060
Revision: 00002001 Serial number: 0181213698
Coding: 013B062220BA00408030023680000000
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813005169002
VCID: 2D070ADCBD1B336F05B-8078
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000035831073
VCID: 4FFB7054D7D7217F577-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000082855
ROD: EV_ParkiBrake_AU48.rod
VCID: 38292B8842D986C766D-806C
Part No SW: 4G0 035 061 D HW: 4G0 035 061
Component: Radio U DAB H60 0100
Revision: AB001007 Serial number: 470G/0C7533755
Coding: 010103010000000001
VCID: 1E65DD10C0BDD8F78C1-804A
02983 - Connection between Impedance Converter 1 and Window Antenna
Fault Status: 00101011
Reset counter: 247
Mileage: 61593 km
Date: 2019.04.10
Time: 10:47:56
Voltage: 14.80 V
Reset counter: 247
Part No SW: 8R2 035 652 A HW: 8R2 035 652
Component: B-BN-EU H62 0175
Revision: -------- Serial number: 147GW0C7515061
Coding: 01010101000681ED01800B4E000000030000
VCID: 323D19A0A4256C97589-8066
Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Serial number: 9465H00C2563098
Subsystem 2 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Serial number: 00000001232687
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000036022505
Coding: 010002204001210001
VCID: 43D34C640B9FD51FC3F-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000036022522
End----(Elapsed Time: 01:36, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
