Results 1 to 10 of 10
Thread: 2011 VW Passat ABS Coding
    Feb 2019
    I will be working on a 2011 VW Passat in the next couple of days ( sorry I haven’t had a chance to scan it yet).
    The ABS was replaced with a replacement and now needs coding.
    I have the following information and was wondering if anyone would be able to provide the correct coding for it:
    VIN: Wvwzzz3czbe759923
    ABS Part Nr:3AA614109N
    Here is the PR Code:
    Thanks for your help
    Aug 2016
    Eindhoven, NB, NL
    A full autoscan would be useful. Any chance of posting one? See below
  3. Likes Jack@European_Parts, Uwe liked this post
    Feb 2019
    Im going to be with the car tomorrow so will post one then. I thought maybe with the above information it might be possible to obtain the information
    Feb 2019
    Quote Originally Posted by m3nt4l View Post
    Tuesday,23,July,2019,09:14:54:08713
    VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
    VIN: WVWZZZ3CZBE759923   License Plate:
    Mileage: 159210km-98928mi   Repair Order: ft11 nys
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 14 15 16 17 19 25 37 42 44 46 4F 52 53 56 61
              62 72
    VIN: WVWZZZ3CZBE759923   Mileage: 159210km-98928miles
       Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
       Component: R4 2.0l TDI   H24 9978
       Revision: 47H24---    Serial number: 00000000000000
       Coding: 00190012042501080000
       Shop #: WSC 00156 210 00000
       ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
       ROD: EV_ECM20TDI01103L906018BF.rod
       VCID: 6FAE2D9BB6BF053770-803A
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 159214 km
                        Date: 2019.07.23
                        Time: 08:22:37
                        Coolant temperature: 18 C
                        Intake air temperature: 19 C
                        Voltage terminal 30: 12.040 V
                        ACC target acceleration: 0.000 m/s
                        ACC control module received status-Bits 0-7: 4
                        Status of ACC/CCS acceleration interface-Bits 0-7: 0
                        Acceleration: 0.000 m/s
                        Engine status: COENG_READY
    4891 - EGR Valve (N18)
              P0403 00 [237] - Malfunction
                        Mileage: 159214 km
                        Date: 2019.07.23
                        Time: 08:23:18
                        Engine speed: 901.50 /min
                        Normed load value: 41.2 %
                        Coolant temperature: 19 C
                        Intake air temperature: 18 C
                        Voltage terminal 30: 14.820 V
                        Air mass: actual value (mg/stroke): 509.3 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                        EGR Solen.val.: actual value: 106.87 %
                        EGR valve: offset closed: 3.13 %
                        Actuator for high pressure EGR: status-Bits 0-7: 0
                        Actuator for high pressure EGR: status-Bits 0-7: 55
                        High press EGR actuator: actual unconditioned volt val: 689.0 mV
    Readiness: 1 1 0 0 1
       Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
       Component: J104   C2 450M VD71 0005
       Revision: --H07---    Serial number: 00000003826968
       Coding: 0008037
       Shop #: WSC 00028 790 00011
       VCID: 383CD6C74B71828F61-806C
                        Reset counter: 113
                        Speed: 252.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.50 V
                        Bin. Bits: 00011111
                        Count: 212
                        Hex Value: 0x0000
                        Reset counter: 113
                        Reset counter: 113
       Part No SW: 5K0 907 044 ED    HW: 5K0 907 044 ED
       Component: Climatronic   H17 1010
       Revision: 00001003
       Coding: 0000000003
       Shop #: WSC 00015 115 00000
       VCID: 71AA2BE3A08B13C766-8024
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
       Component: BCM PQ47 H+   413 0452
       Revision: BC413001
       Coding: 0000000000000000009800209400802443517788406007600080C7200041
       Shop #: WSC 05311 000 00000
       VCID: 393AD3C3B07B9B879E-806C
       Subsystem 1 - Part No SW: 3C8 955 119 E    HW: 3C8 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer 22041  10  0603
       Coding: 00B795
       Component: RLS 200511 05  54  0403
       Coding: 0330ED
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475     HW: 7N0 919 475
       Component: PARKHILFE 8K  H04 0009
       Revision: --------    Serial number: 77631113104092
       Coding: 108003
       ASAM Dataset: EV_EPHVA18VW47X0000 001003
       ROD: EV_EPHVA18VW47X0000.rod
       VCID: 7CB40AD7F7C96EAFC5-8028
    Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
       Part No SW: 3C0 907 376 A    HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0071
       Revision: 00000000    Serial number: 04051102850001
       Coding: 010180
       Shop #: WSC 05314 000 00000
       VCID: 271E05BB56CF1D77F8-8072
    01316 - ABS Control Module
                        Fault Status: 00101101
                        Reset counter: 153
                        Mileage: 159214 km
                        Date: 2013.12.13
                        Time: 08:22:33
                        Bin. Bits: 00000000 00001010
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__306 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0P9EUPLI
       Coding: 0012342
       VCID: 4CD49A172FE91E2F35-8018
       Subsystem 1 - Serial number: 6332MTS634211111
       Subsystem 2 - Serial number: 6342MTS632681111
       Subsystem 3 - Serial number: 6351HTS6BOHM0AKR
       Subsystem 4 - Serial number: 6361HTS651ON0AKJ
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010040    Serial number: 20110510100404
       Coding: 0182270000
       VCID: 72A824EFA58D28DF9F-8026
       Coding: E20000
       Part No SW: 3C8 920 970 P    HW: 3C8 920 970 P
       Coding: 440F01
       Shop #: WSC 05314 115 00000
       VCID: 393AD3C3B87B9B879E-806C
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 030511F1001405
       Coding: 469007
       VCID: 312AEBE3680B53C726-8064
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0399
       Revision: 00043000    Serial number: VWZCZ000000000
       VCID: 76A018FF01E534FFB3-8022
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2L3348065
       Coding: 000004110400000000011000
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: 608C5EA77B61AA4FF9-8034
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0502
       Revision: 12110009    Serial number: 0002874756
       Coding: 0202B5
       Shop #: WSC 05311 115 00000
       VCID: 6D923793BCB3F72742-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0401
       Serial number: 00000002170257
       Coding: 000090
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 207    3201
       Revision: 00H20000
       Shop #: WSC 02069 000 90108
       VCID: 3424E2F7571966EF4D-8060
                        Fault Status: 01101101
                        Fault Frequency: 7
                        Reset counter: 113
                        Mileage: 159214 km
                        Date: 2013.12.13
                        Time: 09:02:15
                        Voltage: 12.63 V
                            DD
                        Temperature: 30.0C
       Component:    KSG PQ47 ELV 043 0631
       Coding: 01910A0001860E763604941570085FCE107C01
       Subsystem 1 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HORN H11 9005
       Component: EZE_2         H35 0614
       Coding: 00000008
       VCID: 6FAE2D9BBEBF053770-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0502
       Revision: 14110009    Serial number: 0002870309
       Coding: 0202B4
       VCID: 6E90309FB1B50C3F7B-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0401
       Serial number: 00000002168671
       Coding: 000090
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000352327
       Coding: 0022067
       VCID: 3326E1EB521761D754-8066
                        Fault Frequency: 14
                        Reset counter: 113
                        Mileage: 159214 km
                        Date: 2013.12.13
                        Time: 08:22:35
                        Voltage: 12.00 V
                        Count: 104
                        Hex Value: 0x1263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71AA2BE3A88B13C766-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370471837
    End----------(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.6V)-----------
  6. Likes Dana liked this post
    HQ
    I find some examples that look to be very similar to this Passat and they have ABS coding of 0003504.
    Jef
    United States
    After checking the scan sent via e-mail I agree with Jef's baseline coding however I don't believe it is L0R Right-hand drive specific. If you end up with new DTCs using that value please try: 0004016
    That's basically Jef's coding but with RHD active.
    0FB0 | 0004016
    0DB0 | 0003504
    Nov 2016
    001,0,Current Wheel Speed
    001,1,Speed Sensor,Front Left (G47),Range: 0.0...255.0 km/h
    001,2,Speed Sensor,Front Right (G45),Range: 0.0...255.0 km/h
    001,3,Speed Sensor,Rear Left (G46),Range: 0.0...255.0 km/h
    001,4,Speed Sensor,Rear Right (G44),Range: 0.0...255.0 km/h
    B001,0,Brake System Bleeding
    B001,1,Status, ,
    B001,2, , ,
    B001,3, , ,
    B001,4, , ,
    003,0,Switches and Warning Lights
    003,1,Clutch (F36),& Interlock (N110),1x = Clutch Pedal Switch
    operated\nx1 = Interlock Switch active (P/N)
    003,2,Brake System,Warning L. (K118)
    003,3,ABS,Warning L. (K47)
    003,4,ASR/ESP,Warning L. (K155)
    004,0,Steering Angle / Lateral Acceleration / Rotation Rate
    004,1,Steering Angle,Sensor (G85),Range: -720.0...+720.0 \nTolerance
    (when straight): 2.5
    004,2,Lateral Acc.,Sensor (G200),Specification (Standing):  1.5 m/s
    004,3,Rotation Rate,Sensor (G202),Range: -69.0...+69.0
    /s\nSpecification:  1.5 /s
    004,4,Longitudinal,Acc. Sensor (G251),Specification:  1.5 m/s
    005,0,Brake Pressure && Steering Angle Sensor Status
    005,1,Brake Pressure,Sensor (G201),Specification:  3.0 bar
    005,2,Steering Angle,Sensor (G85) Status,Range: Initialised/N.
    Initialised/Implausible
    005,3,ASR/ESP-Button,(E256),Range: ON/OFF
    005,4,Brake Light,Switch (F)
    006,0,Voltage Supply
    006,1,Voltage,Terminal 15
    006,2,Voltage,Term.30 (Valves),Range: 0.0...20.5 V
    006,3,Voltage,Term.30 (Logic),Range: 0.0...20.5 V
    006,4,Voltage,Pump Motor,Range: 0.0...20.5 V
    007,1,EDS Shut-Off,(Overtemp.),1xxx = Front Left\nx1xx = Front
    Right\nxx1x = Rear Left\nxxx1 = Rear Right
    008,0,Adaptation Status
    008,1,Adaptation,Overboost
    008,3,Adaptation,Vacuum Level
    009,2,Brake Pressure,Sensor (G201)
    009,3,Vacuum Pressure,Regulator
    010,1,Trailer,Stabilization
    010,2,Input,Signals,1xx = Wipers ON\nx1x = Drivers Door OPEN\nxx1 =
    Reverse Gear ENGAGED
    011,0,Speed Encoder Errors (Front Left)
    011,1,Encoder Errors,(G47) Minimum
    011,2,Encoder Errors,(G47) Maximum
    011,3,Encoder Errors,(G47) Average
    012,0,Speed Encoder Errors (Front Right)
    012,1,Encoder Errors,(G45) Minimum
    012,2,Encoder Errors,(G45) Maximum
    012,3,Encoder Errors,(G45) Average
    013,0,Speed Encoder Errors (Rear Left)
    013,1,Encoder Errors,(G46) Minimum
    013,2,Encoder Errors,(G46) Maximum
    013,3,Encoder Errors,(G46) Average
    014,0,Speed Encoder Errors (Rear Right)
    014,1,Encoder Errors,(G44) Minimum
    014,2,Encoder Errors,(G44) Maximum
    014,3,Encoder Errors,(G44) Average
    018,0,Tire Pressure Monitoring (TPMS) III
    018,1,TPMS Button,Status,Range: Operated/Not Oper.
    B042,0,Tire Pressure Monitoring System (TPMS) Reset
    B042,1,Tire Pressure,Monitoring System
    B042,2, , ,
    B042,3,Reset Status
    B042,4, , ,
    B042,11,Resetting the Tire Pressure Monitoring System (TPMS) through this
    B042,12,Basic Setting will erase all learned Values and active Warnings.
    B042,13,It can also be used in cases where TPMS has been retroffitted but
    B042,14,the required TPMS Button is not installed yet.
    053,3,ESP-Off,Lamp/Message,Range: Lamp ON/ Lamp OFF
    053,4,ASR/ESP,Warning L. (K155),Range: ON/OFF
    B060,0,Adjustment of Steering Angle Sensor (G85)
    B060,1,Adjustment
    B060,2,Adjustment,Status,Specification: OK
    B060,3,Steering Angle,Sensor (G85),Range: -720.0...+720.0 \nTolerance
    B061,0,Adjustment of Rotation Rate & Lateral/Longit. Acc. Sensor
    (G200/G202/G251)
    B061,1,Adjustment
    B061,2,Adjustment,Status,Specification: OK
    B066,0,Adjustment of Brake Pressure Sensor (G201)
    B066,1,Adjustment
    B066,2,Adjustment,Status,Specification: OK
    B066,3,Brake Pressure,Sensor (G201),Specification:  7.0 bar
    070,1,ESP-Status,,Range: Activated/Not Activated
    070,2,ASR-Status,,Range: Activated/Not Activated
    070,3,EDS-Status,,Range: Activated/Not Activated
    070,4,Auto-Hold,Status,Range: Activated/Not Activated
    071,1,Parking Brake,Status,Range: Activated/Not Activated
    111,0,Front Left Wheel Speed Sensor
    111,1,Status Air Gap,Measurement (FL)
    111,2,Air Gap,Measurement (FL)
    111,3,Status Rotation,Direction (FL)
    111,4,Rotation,Direction (FL)
    112,0,Front Right Wheel Speed Sensor
    112,1,Status Air Gap,Measurement (FR)
    112,2,Air Gap,Measurement (FR)
    112,3,Status Rotation,Direction (FR)
    112,4,Rotation,Direction (FR)
    113,0,Rear Left Wheel Speed Sensor
    113,1,Status Air Gap,Measurement (RL)
    113,2,Air Gap,Measurement (RL)
    113,3,Status Rotation,Direction (RL)
    113,4,Rotation,Direction (RL)
    114,0,Rear Right Wheel Speed Sensor
    114,1,Status Air Gap,Measurement (RR)
    114,2,Air Gap,Measurement (RR)
    114,3,Status Rotation,Direction (RR)
    114,4,Rotation,Direction (RR)
    125,0,CAN-Databus Powertrain (Communication)
    125,1,Engine,Electronics,Range: Engine 1/Engine 0\nSpecification: Engine
    125,2,Transmission,Electronics (J104),Range: Transm. 1/Transm. 0
    125,3,Instrument Cluster,(J285),Range: Instruments 1/Instruments
    0\nSpecification: Instruments 1
    125,4,Steering Angle,Sensor (G85),Range: Steer. ang. 1/Steer. ang.
    0\nSpecification: Steer. ang. 1
    126,0,CAN-Databus Powertrain (Communication)
    126,1,Gateway,(J533),Range: Gateway 1/Gateway 0\nSpecification: Gateway 1
    126,2,Airbag,(J234),Range: Airbag 1/Airbag 0\nSpecification: Airbag 1
    126,3,All-Wheel,Drive (J492),Range: AWD 1/AWD 0\nSpecification: AWD 1
    126,4,Parking Brake,(J540),Range: EPB 1/EPB 0\nSpecification: EPB 1
    127,0,CAN-Databus Powertrain (Communication)
    127,2,Immobilizer,,Range: Immobilizer 1/Immobilizer 0\nSpecification:
    Immobilizer 1
    127,3,Steering Aid,(J500),Range: Steering 1/Steering 0\nSpecification:
    Steering 1
    127,4,Park/Steer,Assist (J791)
    LC,00,0,Adaptive Cruise Control Installed (ACC)
    LC,00,1,EcoFuel/CNG
    LC,00,2,Alltrack
    LC,00,3,Alltrack Offroad
    LC,01,0,Control Module Coded [STANDART] (WHT...A Wheel Speed Sensors)
    LC,01,1,RHD
    LC,01,2,Indirect-TMPS installed
    LC,01,3,Start/Stop installed
    LC,01,4,DSG-02E installed
    LC,01,6,Front Assist Installed
    LC,01,7,Follow to Stop (DSG/ACC)
    LC,02,0~7,B9,Engine Code: CFGB/CFGC Manual
    LC,02,0~7,BC,Engine Code: CFGB/CFGC DSG
    LC,02,0~7,BF,Engine Code: CFGB/CFGC DSG 4Motion
    LC,02,0~7,B6,Engine Code: CFFB Manual 4Motion
    LC,02,0~7,B3,Engine Code: CFFB DSG
    LC,02,0~7,B0,Engine Code: CFFB Manual
    LC,02,0~7,B7,Engine Code: CAYC Manual
    LC,02,0~7,A4,Engine Code: BWS DSG 4Motion
    LC,02,0~7,A7,Engine Code: CAYC Manual
    LC,02,0~7,68,Engine Code: CAXA Manual
    LC,02,0~7,6B,Engine Code: CAXA DSG
    LC,02,0~7,89,Engine Code: CCZB DSG
    LC,02,0~7,86,Engine Code: CCZB Manual
    LC,02,0~7,71,Engine Code: CDGA DSG
    LC,02,0~7,7A,Engine Code: CDAA DSG
    LC,02,0~7,6E,Engine Code: CDGA Manual
    S00,Brake Electronics (J104) Security Access
    S01,40168 = Basic Setting Enabling
    S02,50403 = Adaptation Enabling (Overboost)
    S03,70605 = Adaptation Enabling (Park Steer Assist)
    A021,0,Overboost (OB) / Overload Operation
    A021,5,Overboost (OB) / Overload Operation
    A021,6,The Overboost Level specifies how the Hydraulic System will behave
    in
    A021,7,an Overload Sitation. Check the Data Plate for the Engine Type/PR-
    Code.
    A021,8,
    A021,9, 4 = PR-DB0/D4L/D4X/D31/D42
    A021,10,7 = PR-D34/D38/D48/D67/D91/D93/D94/D2D/D2L/DE2/M92
    A021,11,X = Other engines
    A021,11,
    A33,0,
    A51,0,
    A055,0,Brake Disc Wiper (BDW)
    A055,3,Current,Setting
    A055,5,Brake Disc Wiper (BDW)
    A055,6,This Function is used to keep the Brake Discs dry and clear in
    Rainy Weather.
    A055,7,Once the Windshield Wipers are active (either manually or
    automatically) for
    A055,8,longer than 5 Seconds the Brake Disc Wiper will be active as well
    and engage
    A055,9,the Brake Pads with minimal Brake Pressure. This Procedure will be
    repeated
    A055,10,occasionally as long as the Windshield Wipers are active.
    A055,11,
    A055,12,0 = Brake Disc Wiping inactive
    A055,13,1 = Brake Disc Wiping active
    A056,0,Trailer Stabilization
    A056,3,Stabilization,Status
    A056,5,Trailer Stabilization
    A056,6,0 = Trailer Stabilization inactive
    A056,7,1 = Trailer Stabilization active
    A056,8,
    A056,9,NOTES: Check the PR-Codes for this Vehicle. Trailer Stabilization
    MUST NOT be enabled
    A056,10,for legal Reasons if any of the following Country Specifications
    are listed:
    A056,11,PR-B27/B29/B30/B34/B35/B38/B39/BU1/BU2
    A061,0,Vacuum Level / Hydraulic Brake Booster (HBO/HBV)
    A061,1,Brake Booster
    A061,2,Brake Booster,Status
    A061,5,Vacuum Level / Hydraulic Brake Booster (HBO/HBV)
    A061,6,The Vacuum Level specifies how the Hydraulic Brake Booster.
    A061,7,is engaged. Check the Data Plate for the Engine Type/PR-Code.
    A061,9,0 = PR-D2D/D2L/D4X/D4L/D34/D38/D42/D48/D67/D91/D93/D94/DB0/DE2/M92
    A061,10,1 = PR-D4X(With 1AS)
    A061,11,1 = PR-D4L/D42(With 1AS)
    A061,12,1 = PR-D2L/D2D/D67(With 1AS)
    A061,12,X = Other Engines
    A065,0,Hydraulic Braking Power Enhancement
    A065,5,Hydraulic Braking Power Enhancement
    A065,6,Release of Auto-Hold braking funcion.
    A065,7,
    A065,8,0 - Disabled 1 - Early
    A065,9,2 -Normal (default) 3 - Late
    A067,0,Electronic Differential Lock (XDS)
    A067,5,Electronic Differential Lock (XDS)
    A067,6,The Electronic Differential Lock XDS is an Enhancement to the
    existing EDS-Function.
    A067,7,
    A067,8,0 = Electronic Differential Lock inactive (PR-1Y0)
    A067,9,1 = Electronic Differential Lock active (PR-1Y3)
    A094,0,Park Steer Assist (PLA)
    A094,5,Park Steer Assist (PLA)
    A094,6,0 = Park Steer Assist (PLA) NOT installed [PR-7X0/7X1/7X2]
    A094,7,1 = Park Steer Assist (PLA) installed [PR-7X5/7X6]
    This label file should make coding simple for the b7 abs
  10. Likes Dana liked this post
  11. #8
    United States
    Quote Originally Posted by rhinopower View Post
    Thanks! golfi_vend sent us something similar in the past which we added to a FS task (to-do list for label files and coding charts). I'll add this to FS#1351 so we can use the info to build a complete chart.
    Best,
    Dana
  12. Likes DrPeter, Uwe, Jack@European_Parts liked this post
  13. #9
    Nov 2016
    Best,
    Dana
    I think it originated from him anyway. Makes life so simple
  14. #10
    Feb 2019
    Working!!
    Thank you Dana your coding worked perfectly . Sorry for the late reply ive been away.
    Thanks!!
  15. Likes Dana, Uwe, Fredrick Awuor, Jef liked this post
