Results 1 to 6 of 6
Thread: How turn on Alarm Light when the door is open!!
    May 2017
    Brazil
    Hi everyone,
    A two weeks i am trying do one spexifi coding.
    I wanna turn on alarm light on the door (MQB Plataform) when open the door.
    Exemplo: If the door stay open, the light will stay on. When the door closed, the light alarm door turn off.
    Look the video below.
    https://www.instagram.com/p/BvQMaDJl...d=s9zct903i9ng
    Tks a lot if somebody help me.
    Best regards.
    Dec 2016
    DE
    Only possible in MQB-A0 cars, that have a set of light functions in the BCM adaptions, like this:
    ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
    ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
    ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
    ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
    ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
    ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
    ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
    ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
    ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
    ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
    ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
    ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,nicht aktiv ,16
    ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,nicht aktiv ,16
    ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,nicht aktiv ,16
    ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,nicht aktiv ,16
    ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,nicht aktiv ,16
    ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,nicht aktiv ,16
    ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,nicht aktiv ,16
    When you have those, the rest is a cheap trick.
  3. Likes jyoung8607, DV52 liked this post
    May 2017
    Brazil
    Yes, the plataform is MQB (new polo, virtus, golf, a3 and etc). Do you have this cheap trick?
    Tks a lot.
    May 2017
    Brazil
    I think that the "trick" is on Central Eletric 9 adaptation, ok? But know what change is the secret!!
    Dec 2016
    DE
    It‘s not possible on a Golf, since it is MQB-A1 (or -GEN1). On Polo for instance it is possible.
    Just change Leuchte15 SAFE LED C55-Light_Function_B_15 to the desired light function (i. e. „Door open“).
    May 2017
    Brazil
    thanks a lot!
    Breno
